Monday,04,November,2019,18:42:07:21865
VIN: WAUZZZF21LN014066
Mileage: 3093km
Chassis Type: F2-AU58 (4N2)
Scan: 01 02 03 09 13 15 16 17 19 36 42 44 46 52 5F 69 6D 80 81 A5
          AC BB BC D6 D7
VIN: WAUZZZF21LN014066   Mileage: 3093km-1921miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DEZD)       Labels: None
   Part No SW: 05L 906 027 BB    HW: 05L 907 309
   Component: R4 2.0l TDI   H22 7221
   Revision: E1H22---
   Coding: 0A2540122374050C34082000000400000000000000000000
   ASAM Dataset: EV_ECM20TDI01105L906027BB 005001
   ROD: EV_ECM20TDI01105L906027BB.rod
   VCID: 6D923783BCC497277C-8038
   Part No SW: 4K0 927 153 D    HW: 0HK 927 156 B
   Component: 0CK 20TDI RdW H01 0002
   Revision: --H01---    Serial number: 0000002025
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 2E10F08F71422C3F05-807A
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190189001523
   Part No SW: 4N0 907 379 AL    HW: 4N0 907 379 P
   Component: ESP9 Premium  H06 0856
   Coding: 0CAA499714A30B9A519E4897008352E2F5B9C1309228D08A12004A47AF9D83
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 0248743F955A785FB1-8056
   Part No SW: 4N0 907 063 FE    HW: 4N0 907 063 AE
   Component: BCM1 MLBevo   H10 0690
   Coding: 07000143E17900CD074C87089CFE8C68130B3310040600970100080019331A810841080240100000000001000001001A0000000000010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 016011
   ROD: EV_BCM1BOSCHAU651_016_AU49.rod
   VCID: 76A018EFC99254FF8D-8022
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001906120405928
   Coding: 7DC727
   Serial number: 23336647X81A955555A0
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 16S20.07.1900300747
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE108051923610733
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AE    HW: 4K0 947 135 AE
   Component: Dachmodul  H42 0415
   Serial number: C00324162
   Coding: 0D0104
   Part No SW: 4K0 907 561 G    HW: 4K0 907 561
   Component: LRR4R         H04 0332
   Coding: 5261FF4C58082C00010360E00000003A4A1246484401009E01
   ASAM Dataset: EV_ACCBOSCHAU65X 002023
   ROD: EV_ACCBOSCHAU65X_AU58.rod
   VCID: 3228E4FF657A08DF61-8066
2342 - Databus
          [FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
                    Reset counter: 131
                    Mileage: 2864 km
                    Date: 2019.11.03
                    Time: 11:21:11
                    Control Module temperature: 24 °C
                    Voltage terminal 15: 12.8 V
                    Velocity_vehicle_reference: 32.08 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.25 m/s²
                    Steering_angle-Data: 1.100 °
                    Yaw_rate-Data: -0.021 rad/s
                    adjustment_calculation: On
                    Misalignment angle: horiz: -0.054 °
                    Misalignment angle: horiz: fast algorithm: -0.080 °
                    Congestion pilot: status: OFF
                    Outside air temperature: 11.50 °C
                    Sensor blindness: radar: Blindness: limited scope via part absorption
2344 - Databus
          [FAULT_CAMERA_DIRT_OBJ]
                    Reset counter: 113
                    Mileage: 2187 km
                    Date: 2019.10.27
                    Time: 19:37:21
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 13.6 V
                    Velocity_vehicle_reference: 11.48 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.76 m/s²
                    Steering_angle-Data: -59.500 °
                    Yaw_rate-Data: -3.705 rad/s
                    Misalignment angle: horiz: -0.078 °
                    Misalignment angle: horiz: fast algorithm: -0.069 °
                    Outside air temperature: 8.00 °C
                    Sensor blindness: radar: no blindness detected
2343 - Databus
          [FAULT_CAMERA_DIRT_PEDEST]
                    Reset counter: 113
                    Mileage: 2187 km
                    Date: 2019.10.27
                    Time: 19:37:21
1538 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_BLIND]
                    Reset counter: 131
                    Mileage: 2864 km
                    Date: 2019.11.03
                    Time: 11:21:11
                    Velocity_vehicle_reference: 31.90 m/s
                    Longitudinal_acceleration_vehicle_reference: 0.28 m/s²
                    Steering_angle-Data: 1.600 °
                    Yaw_rate-Data: 0.014 rad/s
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H19 2720
   Serial number: 003YZM06UGZ9
   Coding: AACCF0C00CC00000985400FFF00D41AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4AD89C1FEDEA601F39-801E
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2019190017900000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2019185175400000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 002 207 19
   Serial number: 35700000000BC7CCEC3C
   Subsystem 4 - Part No SW: -----------    HW: 480 002 407 19
   Serial number: 35800000000F09A07E3V
   Subsystem 5 - Part No SW: -----------    HW: 480 032 507 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C24B908E409EDO
   Subsystem 6 - Part No SW: -----------    HW: 480 032 507 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C24B9842610AC6
   Subsystem 7 - Part No SW: -----------    HW: 480 031 807 19
   Component: FrontSensor_D  002 0149
   Serial number: 355001C2462449B01A2
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 031 807 19
   Component: FrontSensor_P  002 0149
   Serial number: 356001C24621C010FDDA
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 707 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C244B0C810ADDA
   Subsystem 10 - Part No SW: -----------    HW: 480 001 207 19
   Serial number: I0M000000003B5357DBC
   Subsystem 11 - Part No SW: -----------    HW: 480 001 207 19
   Serial number: I0N00000000A16357DBB
9634932 - Control Module for Front Left Belt Tensioner
          B1304 74 [008] - Actuator slipping
                    Mileage: 909 km
                    Date: 2019.10.13
                    Time: 10:03:33
   Part No SW: 4N0 907 129 AJ    HW: 4N0 907 129 AJ
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 79BA13D3F88C3B87E0-802C
   Part No SW: 4K0 920 790 B    HW: 4K0 920 790 B
   Component: FBenRDWACC--- H12 0208
   Coding: 858438C26C8000080DC0E1609080680008002000
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2C14FA87475E5E2F2B-8078
16777089 - Databus
          [ACC_12 communication error can_error_timeout]
                    Fault Frequency: 53
                    Reset counter: 130
                    Mileage: 12 km
                    Date: 2019.10.03
                    Time: 15:33:19
   Part No SW: 4N2 907 468 BB    HW: 4N2 907 468 AB
   Component: Gateway       H16 0052
   Revision: BD000001    Serial number: 018BD503819709
   Coding: 02010005002006405A860002005B0132DC18004710000000097D078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   VCID: 7AB80CDFFD8A309FE9-802E
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863130019071900D0
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000382101763
   Coding: 00581A400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS002 0189
   Serial number: YE007SFQ34276
   Coding: 001FDB0052000480A000B000
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 3E30C0CFA122DCBF95-806A
   Part No SW: 4N0 909 144 E    HW: 4N0 909 144 C
   Component: EPS_MLBEVO2BS H22 0505
   Coding: B4002101010000
   ASAM Dataset: EV_EPSVWBSAU426 010017
   ROD: EV_EPSVWBSAU426_010.rod
   Part No SW: 4N0 907 064 DP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H15 0182
   Coding: 01340000002000E06309A0040C00C80203024000804F04502F0400000504823F001F0100010011
   ASAM Dataset: EV_BCM2CONTIAU651 010009
   ROD: EV_BCM2CONTIAU651_010_VW53.rod
   VCID: 004C7E379B566A4FA7-8054
   Ignition key:
   Subsystem 2 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Component: GEB.F.Heckoef  H17 0906
   Serial number: 11844666
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS002 0189
   Serial number: YE007SG41298D
   Coding: 001FDB005E000480A000B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 3D32C7C3AC24C7A78C-8068
   Part No SW: 4K0 035 064 C    HW: 4K0 035 064 A
   Component: MU-H-LN-EU    053 2647
   Coding: 01850201FF0A000043110001000800102F0001E403F008008E
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 240412A72F8E966FE3-8070
   Subsystem 1 - Part No: V03 959 804 BH
   Component: MIB2P_EU_Q119  0360
   Subsystem 2 - Part No SW: 4K0 919 605 C    HW: 4K0 919 605 A
   Component: DU AU58x High  H42 0147
   Serial number: INX00123051900060169
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1010
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 B    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0110
   Serial number: 00004419000077196048
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K0 919 603 B    HW: 4K0 919 603
   Component: DU AU58x Bot  H41 0147
   Serial number: INX00113041900080201
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051900438534014
   Part No SW: 4M0 907 383 F    HW: 4M0 907 383 B
   Component: Anhaenger     H27 0253
   Revision: 9A001003    Serial number: 0522639295
   Coding: 0110000202000000
   ROD: EV_TrailFunctGener2Hella_VW27.rod
   VCID: 3522DFE394141FE744-8060
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: A2-C737-6252-4
   Coding: 12F0
   ROD: EV_DeckLidCONTIAU736_AU38.rod
   VCID: 3424E2E79F6E06EF73-8060
Address 80: Batt. reg. aux. accum. (A1)       Labels: None
   Part No SW: 4K0 915 101     HW: 4K0 915 101
   Component: MQ-BMS        H20 0127
   Serial number: 19000057597002
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 608C5EB77B16CA4FC7-8034
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 19.197 40567
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 281C069753A6720FCF-807C
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AM    HW: 4N0 907 107 H
   Component: zFAS Var C    H09 0293
   Coding: 0401820000000000000BD60000B0060C189F5600000000000000000000969401009BA80000000000000000800000000000000000000000000000400000000000000072040080009000800080000000000080400000A0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001_AU58.rod
   VCID: 0A585C1FAD6A201FF9-805E
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [008] - View Temporarily Restricted
          [temp view limitations]
                    Fault Frequency: 9
                    Reset counter: 131
                    Mileage: 869 km
                    Date: 2019.10.13
                    Time: 00:55:22
                    EyeQ temperatures-CPU: -40 °C
                    EyeQ temperatures-VPM: 23 °C
                    Vehicle speed: 118.23 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: No
4107 - Databus
          [reversibler_Fehler_im_ACC_System]
                    Reset counter: 131
                    Mileage: 2864 km
                    Date: 2019.11.03
                    Time: 11:21:11
65540 - Following-Distance Warning (High)
          C12DA F0 [008] - Status Feedback for HMI Implausible
                    Reset counter: 131
                    Mileage: 2864 km
                    Date: 2019.11.03
                    Time: 11:21:16
                    Profile master status distance warning high-Nominal status: On
                    Profile master status distance warning high-Actual status:: ERROR
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 80A 907 355 F    HW: 80A 907 355 D
   Component: SCR-Stg-G4H08 0004
   ASAM Dataset: EV_RDCMHelbaAU426 003011
   ROD: EV_RDCMHelbaAU426_003.rod
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS004 0189
   Serial number: YE007SG51389C
   Coding: 000FD90000000480A000B000
   VCID: 40CCBE37DBD6AA4FE7-8014
   Component: TSG HBFS004 0189
   Serial number: YE007SG600057
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 572 DC    HW: 4K0 941 572 D
   Component: LMS_MLBevo    H06 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
   VCID: 72A824FFA5FA48DFA1-8026
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.1V)-----------
