2020 Audi A6 35 TDI 120kW (J623-DEZD)
Monday,04,November,2019,18:42:07:21865
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZF21LN014066
Mileage: 3093km
Chassis Type: F2-AU58 (4N2)
Scan: 01 02 03 09 13 15 16 17 19 36 42 44 46 52 5F 69 6D 80 81 A5
AC BB BC D6 D7
VIN: WAUZZZF21LN014066 Mileage: 3093km-1921miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DEZD) Labels: None
Part No SW: 05L 906 027 BB HW: 05L 907 309
Component: R4 2.0l TDI H22 7221
Revision: E1H22---
Coding: 0A2540122374050C34082000000400000000000000000000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM20TDI01105L906027BB 005001
ROD: EV_ECM20TDI01105L906027BB.rod
VCID: 6D923783BCC497277C-8038
Address 02: Auto Trans (J217) Labels:| 0CJ-927-156.clb
Part No SW: 4K0 927 153 D HW: 0HK 927 156 B
Component: 0CK 20TDI RdW H01 0002
Revision: --H01--- Serial number: 0000002025
ASAM Dataset: EV_TCMDL382021 002031
ROD: EV_TCMDL382021_AU58.rod
VCID: 2E10F08F71422C3F05-807A
Manual Transmission Fluid Pump:
Subsystem 1 - Part No SW: 0CK 927 152 AA HW: 0CK 321 281 L
Component: V553 MTFP 003 0576
Serial number: 75145041190189001523
Part No SW: 4N0 907 379 AL HW: 4N0 907 379 P
Component: ESP9 Premium H06 0856
Coding: 0CAA499714A30B9A519E4897008352E2F5B9C1309228D08A12004A47AF9D83
ROD: EV_ESP9BOSCHCMP_004_AU65.rod
VCID: 0248743F955A785FB1-8056
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 4N0 907 063 FE HW: 4N0 907 063 AE
Component: BCM1 MLBevo H10 0690
Coding: 07000143E17900CD074C87089CFE8C68130B3310040600970100080019331A810841080240100000000001000001001A0000000000010100000000000000000000
ASAM Dataset: EV_BCM1BOSCHAU651 016011
ROD: EV_BCM1BOSCHAU651_016_AU49.rod
VCID: 76A018EFC99254FF8D-8022
Subsystem 1 - Part No SW: 4K1 955 119 HW: 4K1 955 119
Component: J400FRWISCH 063 0740
Serial number: 00000001906120405928
Coding: 7DC727
Subsystem 2 - Part No SW: 81A 955 555 A HW: 81A 955 555
Component: G397_RLFSS H06 0002
Serial number: 23336647X81A955555A0
Coding: 02006E
Subsystem 3 - Part No SW: 4K1 941 501 HW: 4K1 941 501
Component: E1 - LTM H05 0053
Serial number: 16S20.07.1900300747
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE108051923610733
Interior Light Module:
Subsystem 5 - Part No SW: 4K0 947 135 AE HW: 4K0 947 135 AE
Component: Dachmodul H42 0415
Serial number: C00324162
Coding: 0D0104
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4K0 907 561 G HW: 4K0 907 561
Component: LRR4R H04 0332
Coding: 5261FF4C58082C00010360E00000003A4A1246484401009E01
ASAM Dataset: EV_ACCBOSCHAU65X 002023
ROD: EV_ACCBOSCHAU65X_AU58.rod
VCID: 3228E4FF657A08DF61-8066
2342 - Databus
[FAULT_ACA_QF_STATUS_DISPLAY_ERROR]
Reset counter: 131
Mileage: 2864 km
Date: 2019.11.03
Time: 11:21:11
Control Module temperature: 24 °C
Voltage terminal 15: 12.8 V
Velocity_vehicle_reference: 32.08 m/s
Longitudinal_acceleration_vehicle_reference: 0.25 m/s²
Steering_angle-Data: 1.100 °
Yaw_rate-Data: -0.021 rad/s
adjustment_calculation: On
Misalignment angle: horiz: -0.054 °
Misalignment angle: horiz: fast algorithm: -0.080 °
Congestion pilot: status: OFF
Outside air temperature: 11.50 °C
Sensor blindness: radar: Blindness: limited scope via part absorption
2344 - Databus
[FAULT_CAMERA_DIRT_OBJ]
Reset counter: 113
Mileage: 2187 km
Date: 2019.10.27
Time: 19:37:21
Control Module temperature: 32 °C
Voltage terminal 15: 13.6 V
Velocity_vehicle_reference: 11.48 m/s
Longitudinal_acceleration_vehicle_reference: 0.76 m/s²
Steering_angle-Data: -59.500 °
Yaw_rate-Data: -3.705 rad/s
Misalignment angle: horiz: -0.078 °
Misalignment angle: horiz: fast algorithm: -0.069 °
Outside air temperature: 8.00 °C
Sensor blindness: radar: no blindness detected
2343 - Databus
[FAULT_CAMERA_DIRT_PEDEST]
Reset counter: 113
Mileage: 2187 km
Date: 2019.10.27
Time: 19:37:21
1538 - Sensor for Automatic Distance Control
[FAULT_SENSOR_BLIND]
Reset counter: 131
Mileage: 2864 km
Date: 2019.11.03
Time: 11:21:11
Velocity_vehicle_reference: 31.90 m/s
Longitudinal_acceleration_vehicle_reference: 0.28 m/s²
Steering_angle-Data: 1.600 °
Yaw_rate-Data: 0.014 rad/s
Address 15: Airbags (J234) Labels:* None
Part No SW: 4N0 959 655 Q HW: 4N0 959 655 Q
Component: AirbagVW31 H19 2720
Serial number: 003YZM06UGZ9
Coding: AACCF0C00CC00000985400FFF00D41AC00C5
ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
ROD: EV_AirbaVW31SMEAU65x_VW53.rod
VCID: 4AD89C1FEDEA601F39-801E
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4N0 980 945 A HW: 4N0 980 945 A
Component: BeltPretRevFL H10 0115
Serial number: 00AI2019190017900000
Coding: 04F001
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4N0 980 946 A HW: 4N0 980 946 A
Component: BeltPretRevFR H10 0115
Serial number: 00AI2019185175400000
Coding: 04F001
Subsystem 3 - Part No SW: ----------- HW: 480 002 207 19
Serial number: 35700000000BC7CCEC3C
Subsystem 4 - Part No SW: ----------- HW: 480 002 407 19
Serial number: 35800000000F09A07E3V
Subsystem 5 - Part No SW: ----------- HW: 480 032 507 19
Component: SideSensor_Dr 002 0149
Serial number: 351001C24B908E409EDO
Subsystem 6 - Part No SW: ----------- HW: 480 032 507 19
Component: SideSensor_Pr 002 0149
Serial number: 352001C24B9842610AC6
Subsystem 7 - Part No SW: ----------- HW: 480 031 807 19
Component: FrontSensor_D 002 0149
Serial number: 355001C2462449B01A2
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 480 031 807 19
Component: FrontSensor_P 002 0149
Serial number: 356001C24621C010FDDA
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 480 031 707 19
Component: PedP_Sensor_C 002 0149
Serial number: 230001C244B0C810ADDA
Subsystem 10 - Part No SW: ----------- HW: 480 001 207 19
Component: PedPSensor_D2 001 0887
Serial number: I0M000000003B5357DBC
Subsystem 11 - Part No SW: ----------- HW: 480 001 207 19
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000A16357DBB
9634932 - Control Module for Front Left Belt Tensioner
B1304 74 [008] - Actuator slipping
Mileage: 909 km
Date: 2019.10.13
Time: 10:03:33
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4N0 907 129 AJ HW: 4N0 907 129 AJ
ROD: EV_SMLSKLOAU736_VW53.rod
VCID: 79BA13D3F88C3B87E0-802C
Address 17: Instruments (J285) Labels:* None-SRI2
Part No SW: 4K0 920 790 B HW: 4K0 920 790 B
Component: FBenRDWACC--- H12 0208
Coding: 858438C26C8000080DC0E1609080680008002000
ROD: EV_DashBoardAU65X_VW53.rod
VCID: 2C14FA87475E5E2F2B-8078
16777089 - Databus
[ACC_12 communication error can_error_timeout]
Fault Frequency: 53
Reset counter: 130
Mileage: 12 km
Date: 2019.10.03
Time: 15:33:19
Part No SW: 4N2 907 468 BB HW: 4N2 907 468 AB
Component: Gateway H16 0052
Revision: BD000001 Serial number: 018BD503819709
Coding: 02010005002006405A860002005B0132DC18004710000000097D078E10000000
ASAM Dataset: EV_CGateCONTIAU491 004190
ROD: EV_CGateCONTIAU491_004_VW53.rod
VCID: 7AB80CDFFD8A309FE9-802E
Subsystem 1 - Part No SW: 4K0 951 523 H HW: 4K0 951 523 H
Component: E221__MFL H06 0003
Serial number: 00000000000000000000
Subsystem 2 - Part No SW: 4K0 915 181 HW: 4K0 915 181
Serial number: 741863130019071900D0
Address 36: Seat Mem. Drvr (J136) Labels:* None
Part No SW: 4M4 959 760 HW: 4M4 959 760
Component: MEM-FS 009 0044
Serial number: 00000382101763
Coding: 00581A400000B4010003010101010000000000000000000000000000004000
ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M1 959 593 D HW: 4M1 959 593 D
Component: TSG FS002 0189
Serial number: YE007SFQ34276
Coding: 001FDB0052000480A000B000
VCID: 3E30C0CFA122DCBF95-806A
Part No SW: 4N0 909 144 E HW: 4N0 909 144 C
Component: EPS_MLBEVO2BS H22 0505
Coding: B4002101010000
ASAM Dataset: EV_EPSVWBSAU426 010017
ROD: EV_EPSVWBSAU426_010.rod
Address 46: Central Conv. (J393) Labels:* None
Part No SW: 4N0 907 064 DP HW: 4N0 907 064 P
Component: BCM2 MLBevo H15 0182
Coding: 01340000002000E06309A0040C00C80203024000804F04502F0400000504823F001F0100010011
ASAM Dataset: EV_BCM2CONTIAU651 010009
ROD: EV_BCM2CONTIAU651_010_VW53.rod
VCID: 004C7E379B566A4FA7-8054
Ignition key:
Subsystem 2 - Part No SW: 3G0 962 243 C HW: 3G0 962 243 C
Component: GEB.F.Heckoef H17 0906
Serial number: 11844666
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 4M1 959 592 D HW: 4M1 959 592 D
Component: TSG BFS002 0189
Serial number: YE007SG41298D
Coding: 001FDB005E000480A000B000
VCID: 3D32C7C3AC24C7A78C-8068
Part No SW: 4K0 035 064 C HW: 4K0 035 064 A
Component: MU-H-LN-EU 053 2647
Coding: 01850201FF0A000043110001000800102F0001E403F008008E
ROD: EV_MUHigGen2pALPI_AU27.rod
VCID: 240412A72F8E966FE3-8070
Subsystem 1 - Part No: V03 959 804 BH
Component: MIB2P_EU_Q119 0360
Subsystem 2 - Part No SW: 4K0 919 605 C HW: 4K0 919 605 A
Component: DU AU58x High H42 0147
Serial number: INX00123051900060169
Component: Gracenote2 1010
Volume Control 1:
Subsystem 4 - Part No SW: 4K1 919 616 B HW: 4K1 919 616 A
Component: LSR-D5/C8 H33 0110
Serial number: 00004419000077196048
Display Unit 5 For Multimedia System:
Subsystem 5 - Part No SW: 4K0 919 603 B HW: 4K0 919 603
Component: DU AU58x Bot H41 0147
Serial number: INX00113041900080201
Media socket:
Subsystem 6 - Part No SW: 4N0 035 736 A HW: 4N0 035 736
Component: MediaConnectH 014 0133
Serial number: 051900438534014
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 F HW: 4M0 907 383 B
Component: Anhaenger H27 0253
Revision: 9A001003 Serial number: 0522639295
Coding: 0110000202000000
ROD: EV_TrailFunctGener2Hella_VW27.rod
VCID: 3522DFE394141FE744-8060
Part No SW: 4M0 959 107 D HW: 4M0 959 107 A
Component: HDSG-Modul H13 0171
Revision: -------- Serial number: A2-C737-6252-4
Coding: 12F0
ROD: EV_DeckLidCONTIAU736_AU38.rod
VCID: 3424E2E79F6E06EF73-8060
Address 80: Batt. reg. aux. accum. (A1) Labels: None
Part No SW: 4K0 915 101 HW: 4K0 915 101
Component: MQ-BMS H20 0127
Serial number: 19000057597002
ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
ROD: EV_BMS12VLiIonSDIAU49X.rod
VCID: 608C5EB77B16CA4FC7-8034
Address 81: Gear Shift (J587) Labels: None
Part No SW: 4K1 713 041 H HW: 4K1 713 041 H
Component: GSM-LL H14 0051
Serial number: 19.197 40567
ASAM Dataset: EV_GSMKAMAU581 001005
ROD: EV_GSMKAMAU581.rod
VCID: 281C069753A6720FCF-807C
Address A5: Frt Sens. Drv. Assist (J1121) Labels:* None
Part No SW: 4KE 907 107 AM HW: 4N0 907 107 H
Component: zFAS Var C H09 0293
Coding: 0401820000000000000BD60000B0060C189F5600000000000000000000969401009BA80000000000000000800000000000000000000000000000400000000000000072040080009000800080000000000080400000A0
ASAM Dataset: EV_ZFASAU516 001003
ROD: EV_ZFASAU516_001_AU58.rod
VCID: 0A585C1FAD6A201FF9-805E
221284 - Front Camera for Driver Assist Systems
C12B3 FD [008] - View Temporarily Restricted
[temp view limitations]
Fault Frequency: 9
Reset counter: 131
Mileage: 869 km
Date: 2019.10.13
Time: 00:55:22
EyeQ temperatures-CPU: -40 °C
EyeQ temperatures-VPM: 23 °C
Vehicle speed: 118.23 km/h
Front camera: blinding detection-Status: not active
Front camera: blinding detection-Blinding detected by light assistance assessment module: No
Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
Front camera: blinding detection-Blinding detected by object recognition assessment module: No
Front camera: blinding detection-Blinding detected by distance regulation assessment module: Yes
Front camera: blinding detection-Blinding detected by road profile estimation assessment module: No
Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
Front camera: blinding detection-Glare detected: No
Front camera: blinding detection-free view detected once: No
4107 - Databus
[reversibler_Fehler_im_ACC_System]
Reset counter: 131
Mileage: 2864 km
Date: 2019.11.03
Time: 11:21:11
65540 - Following-Distance Warning (High)
C12DA F0 [008] - Status Feedback for HMI Implausible
Reset counter: 131
Mileage: 2864 km
Date: 2019.11.03
Time: 11:21:16
Profile master status distance warning high-Nominal status: On
Profile master status distance warning high-Actual status:: ERROR
Address AC: Reductant Control (J880) Labels: None
Part No SW: 80A 907 355 F HW: 80A 907 355 D
Component: SCR-Stg-G4H08 0004
ASAM Dataset: EV_RDCMHelbaAU426 003011
ROD: EV_RDCMHelbaAU426_003.rod
Part No SW: 4M1 959 595 D HW: 4M1 959 595 D
Component: TSG HFS004 0189
Serial number: YE007SG51389C
Coding: 000FD90000000480A000B000
VCID: 40CCBE37DBD6AA4FE7-8014
Component: TSG HBFS004 0189
Serial number: YE007SG600057
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 4K0 941 572 DC HW: 4K0 941 572 D
Component: LMS_MLBevo H06 0031
ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
ROD: EV_LMSLeftHELLAAU58X_AU38.rod
VCID: 72A824FFA5FA48DFA1-8026
Address D7: Light Ctrl Right 2 (A27) Labels: None
ASAM Dataset: EV_LMSRightHELLAAU58X 001013
ROD: EV_LMSRightHELLAAU58X_AU38.rod
End----------(Elapsed Time: 01:46, VBatt start/end: 12.3V/12.1V)-----------
Post Thanks / Like - 3 Likes
