Results 1 to 5 of 5
Thread: VW T CROSS 2019 - LANE ASSIST, TRAFFIS SIGN RECOGNITION PROBLEM
    Sep 2019
    Croatia
    Hello, here is the Auto-Scan of my new car.
    Wednesday,06,November,2019,09:19:10:60999
    VIN: WVGZZZC1ZLY023566   License Plate: RI353H
    Mileage: 1561km-969mi   Repair Order:
    Chassis Type: C1-VW27 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 44 55 5F 75 A5 D6 D7
    VIN: WVGZZZC1ZLY023566   Mileage: 1561km-969miles
    Address 01: Engine (J623-DGTD)       Labels: None
       Part No SW: 04L 906 056 TT    HW: 04L 907 445 F
       Component: R4 1.6l TDI   H01 6938
       Revision: 22101001
       Coding: 0125403243641D091000
       Shop #: WSC 00788 648 00255
       ASAM Dataset: EV_ECM16TDI03004L906056TT 004001
       ROD: EV_ECM16TDI03004L906056ML_VW27.rod
       VCID: 127C417744E165E76F3-8046
    Readiness: N/A
       Part No SW: 0CW 300 043 F    HW: 0AM 927 769 E
       Component: GSG DQ200G2_M H05 1602
       Revision: 00005008    Serial number: CU501908145268
       ROD: EV_TCMDQ200021_VW27.rod
       VCID: 3A2CC9D73CD17DA7C73-806E
       Part No SW: 2Q0 614 517 AF    HW: 2Q0 614 517 M
       Component: ESC_high_vFGS H34 0342
       Serial number: 08501677190806
       Coding: 9205533E3D4349B0CA01BC1C12E011A649265146446A2448485452554548886592648A6222562412122A4AAAA269C64FFD9663F2BF
       ASAM Dataset: EV_Brake1BOSCHESPMQBA0 004036
       ROD: EV_Brake1BOSCHESPMQBA0.rod
       VCID: 72BC21F72421C5E7CF3-8026
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0524948027
       Coding: 132C0C0723
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       ROD: EV_KessyHellaMQBAB_VW27.rod
       VCID: 45D6AA2B452F025FBA1-8010
    Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
       Part No SW: 2G0 907 044 Q    HW: 2G0 907 044 Q
       Component: Climatronic   H05 0701
       Coding: 612010000802010001100800524401150100000000000000000000000000
       ASAM Dataset: EV_ACClimaBHBMQBA0 004023
       ROD: EV_ACClimaBHBMQBA0_VW27.rod
       VCID: 323CE1F7E4A185E70F3-8066
       Part No SW: 2Q0 937 090 B    HW: 2Q0 937 090
       Component: BCM A0 Std+   H10 0934
       Serial number: 01101923200214
       ASAM Dataset: EV_BCMA0 205001
       ROD: EV_BCMA0_205_VW27.rod
       VCID: 313EEEFBE1A7BEFF769-8064
       Drivers Door Control Module:
       Subsystem 1 - Part No SW: 2Q2 959 405     HW: 2Q2 959 163
       Component: FHSG_DRV  002 0005
       Serial number: 00000000000030763704
       Coding: 0300F0
       Subsystem 2 - Part No SW: 2Q2 959 406     HW: 2Q2 959 164
       Component: FHSG_PSG  002 0005
       Serial number: 00000000000030708932
       Coding: 1900F0
       Subsystem 3 - Part No SW: 5Q0 907 658     HW: 5Q0 907 658
       Component: HS  003 0002
       Serial number: S4Y19M07D12H17M08S15
       Subsystem 4 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
       Component: FOND_FHSG_DRV  007 0010
       Serial number: 00000000000033084771
       Coding: 030000
       Subsystem 5 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
       Component: FOND_FHSG_PSG  007 0010
       Serial number: 00000000000033387805
       Coding: 1B0000
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Component: PDC 8 Kanal   H08 0061
       Serial number: 000150058319241
       Coding: 0471155851
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       ROD: EV_EPHVA18AU3700000_009_VW27.rod
       VCID: 50F88B7F8A6DD7F7197-8004
       Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H03 0372
       Coding: 3204670208FF8748949C810580508700000000000000000004
       ASAM Dataset: EV_ACCMRRCONTIVW376 003016
       ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
       VCID: 43D2B4334B1B3C6F945-8016
       Part No SW: 2Q0 959 655 AM    HW: 2Q0 959 655 AM
       Component: VW22Airbag    012 0351
       Revision: --------
       Coding: 88CCC0C0000000005C5400CF000C40A80065
       ASAM Dataset: EV_AirbaVW22BPAVW27X 001020
       ROD: EV_AirbaVW22BPAVW27X.rod
       VCID: 0848631F32BDDF37817-805C
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 654 980 945     HW: 654 980 945
       Component: BeltPretRevFL  004 0051
       Serial number: 278A-001603091900230
       Coding: 303531
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 654 980 946     HW: 654 980 946
       Component: BeltPretRevFR  004 0051
       Serial number: 278A-001702091900017
       Coding: 303531
       Subsystem 3 - Part No SW: -----------    HW: 442 062 108 19
       Serial number: 3577Y50C731F1E91C42D
       Subsystem 4 - Part No SW: -----------    HW: 442 062 108 19
       Serial number: 3587Y50C731F1E9200EB
       Subsystem 5 - Part No SW: -----------    HW: 442 0B2 808 19
       Serial number: 35177829D33B285452DP
       Subsystem 6 - Part No SW: -----------    HW: 442 0B2 808 19
       Serial number: 35277829D328BA04D1BX
       Subsystem 7 - Part No SW: -----------    HW: 442 132 308 19
       Component: FrontSensor_D  290 118A
       Serial number: 355AG11A130CACA1A2C
       Part No SW: 2G0 920 790 B    HW: 2G0 920 790 B
       Component: KOMBI         502 4187
       Coding: 04A410186D8800080188220B5000000800000404
       ASAM Dataset: EV_DashBoardVDDMQBA0 001041
       ROD: EV_DashBoardVDDMQBA0_VW27.rod
       VCID: 26140DA7D869E94793B-8072
       Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
       Component: GW MQB High   442 4388
       Revision: --------    Serial number: 0000030054
       Coding: 030100044F0873002310025C180F00010001070000000000000000000000
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       VCID: 70B82BFF2A2DF7F7397-8024
       Component: 4-01-02-01-04
       Subsystem 2 - Part No SW: 3G0 959 442 F    HW: 3G0 959 442 F
       Component: E221__MFL-PR6  H06 0110
       Serial number: PR6-0440036204191684
       Coding: 2C1D00
       Subsystem 3 - Part No SW: 2Q0 915 181     HW: 2Q0 915 181
       Component: J367-BDMBOSCH  H02 2011
       Serial number: 1016A20D
       Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
       Component: ELV-MQBB      H08 0021
       Serial number: 19000233117007
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW27.rod
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 A    HW: 2Q0 907 686 A
       Component: HRE3_Kl15_Mst H05 0052
       Serial number: 00000524520597
       Coding: 50014500
       ASAM Dataset: EV_HREntryHellaGen3Kl15 001009
       ROD: EV_HREntryHellaGen3Kl15_001_VW48.rod
       VCID: 3828D3DF02DD6FB7317-806C
    Address 44: Steering Assist (J792)       Labels:* None
       Part No SW: 2Q1 909 144 M    HW: 2Q1 909 144 F
       Component: TRW_G4L_MQBA0 611 6041
       Serial number: 01J7A0RJCB4K242
       Coding: 010000010100000001010201010001000000010101
       ASAM Dataset: EV_SteerAssisTRWG4LMQBA0 011016
       ROD: EV_SteerAssisTRWG4LMQBA0.rod
       VCID: 3C20CFCF36E54397D5F-8068
       Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
       Coding: 0688000001200003
       ASAM Dataset: EV_HeadlRegulAFSMQBMAX 001001
       ROD: EV_HeadlRegulAFSMQBMAX_VW27.rod
       VCID: 41DEBE3B51072E7F869-8014
       Part No SW: 2GM 035 840     HW: 2GM 035 840
       Component: MU-S--ER      724 0873
       Coding: 02120600BE0000004111000100080A001F0500F40120000002
       Shop #: WSC 40072 001 1048576
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 7AAC09D77C51BDA7873-802E
       Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
       Component: ABT_Std-2  H61 8214
       Serial number: VWZ6ZJW2420025
       Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
       Component: OCULowMQBLGE  H19 0825
       Revision: --------
       Coding: 022106016A16140D0100040000354003804600
       ASAM Dataset: EV_OCULowMQBLGE 004049
       ROD: EV_OCULowMQBLGE_004_VW27.rod
       VCID: 3D26C2CB2DFF4A9FE21-8068
       Part No SW: 3Q0 980 654 R    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H11 0460
       Serial number: 13081915K15231
       Coding: 0002070600000401002200148156440084000E20000000
       ASAM Dataset: EV_MFKBoschMQBB 002041
       ROD: EV_MFKBoschMQBB_002_VW27.rod
       VCID: 46D4AD2778290947B3B-8012
       Part No SW: 992 941 571 AC    HW: 992 941 571 A
       Component: LED1L         H08 9201
       ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
       ROD: EV_LLPGen3LKEBODPO68X.rod
       VCID: 639254B3EBDB5C6FB45-8036
       Component: LED1R         H08 9201
       ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
    End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
    I had problem with activating Traffic sign recognition, everything went well but there are no signs appearing on the active info display.
    Also, I had normal lane assist factory activated, but then I activated in adaptations option to select via menu ( that activates lane assist guidance)
    but everything seems like before because it does not centre the vehicle in the middle of the road, but at least steering wheel is not vibrating.
    Also, there is a sign of a car with a little sand-clock that seems to deactivate after some speed every time, but before coding, there wasn't any sign.
    Managed to change the look of AID with tube variations in 17-Instruments Adaptation, does anyone know any other way to put bubbles in AID, it is not working like on VW Golf where you change Display Depiction option.
    Cheers.
    Feb 2018
    TSR seems to need Dataset on it to get working. All Camera till "L" has Dataset equiped by factory, but new need TSR Dataset on it. So you have "R" inside so thereŽs no Dataset for TSR in it
    Sep 2019
    Croatia
    Is there any way to put dataset into the car?
    Feb 2018
    Yes but no way with VCDS, youŽll need ODIS or VCP. But ODIS is just possible if you have xml Dataset but they are not easy to get
    Sep 2019
    Croatia
    Can you link me somewhere, how to do it with vcp?
    And do you know anything about lane assist guidance?
