Hello.
This is my first post. I'm from Denmark and work as an independant technician and problemsolver for auto workshops. I have worked with VCDS for 13 years. But now I have a problem I can't solve myself.
The car is a 2013 Golf 7 which after dealer coded new key lost function of the cruise control. Not long ago, a thread with exactly the same problem was created in this forum, but there are no solution yet as I see it.
I have genuine ODIS, and have tried to recode all the modules to their original coding with SWM. That mysteriously did not solve the problem. I have in collaboration with Niels, tried to experiment a bit with the coding in 01 and 19 but with no luck. The only thing that is not working by now is the cruise control. The customer insists that the problem was not there before the new key was coded. The dealer denies that it have anything to do with the new key they have added, but have offered to start a diagnostics session if he agrees to pay all the cost and the labour, which he of course knows will be expensive. So his regular workshop called me when they could not solve the problem themselves.
The codes I have tried:
01: 01190012232415082000
19: 030000042B086400EF000248080E00010001000000000000000000000000
No luck.
If I code 01 to have NO cruise control, the faultcode can be deleted.
The cruise control are NOT retrofitted.
There exsits no autoscan from before the key was coded.
Any suggestions?
All inputs will be appreciated!
Thanks, Jimmy
No luck.
Any suggestions?
Thanks, Jimmy
Wednesday,06,November,2019,09:21:34:29794
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
Dealer/Shop Name: Diagnose Specialisten ApS
VIN: WVWZZZAUZEW060422 License Plate: AJ27576
Mileage: 84885km-52745mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZEW060422 Mileage: 84885km-52745miles
Address 01: Engine (J623-CJZA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 H HW: 04E 907 309 A
Component: R4 1.2l TFS H08 9020
Revision: WAH08---
Coding: 01190012242415082000
ASAM Dataset: EV_ECM12TFS01104E906016H 001009
ROD: EV_ECM12TFS01104E906016H.rod
VCID: 270BFB58AF6A521FA8D-8072
17149 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [038] - -
[Checking coding/versions ofcontrol modules in drivetrain]
Mileage: 84885 km
Date: 2019.11.06
Time: 01:07:43
Coolant temperature: 55 °C
Intake air temperature: 19 °C
Voltage terminal 30: 12.015 V
Mass flow through throttle valve: 0.0 kg/h
Readiness: 1110 0001
Part No SW: 5Q0 907 379 CK HW: 5Q0 907 379 G
Component: ESC H31 0472
Revision: 00000000 Serial number: 61763000000634
Coding: 01FA6AA12426296C037B060241C52580562494C06082A4F300200068C002
Shop #: WSC 50664 003 1048576
VCID: 074B9BD84FAA721F88D-8052
Part No SW: 5G0 907 044 AA HW: 5G0 907 044 AA
Component: Climatronic H02 0705
Revision: 00001K06
Coding: 00020004200100011005000000101000
VCID: 6695B65C68E08B1753B-8032
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AA HW: 5Q0 937 084 AA
Component: BCM MQBAB H H14 0112
Serial number: 00011318701694
Coding: 00040846C24100D34BE44000001C07081000000000000000000000000000
ROD: EV_BCMBOSCH_011.rod
VCID: 77ABEB183F4A029FF8D-8022
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 130630 042 0551
Serial number: 130702062205
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 20425444
Part No SW: 5Q0 959 655 M HW: 5Q0 959 655 M
Component: AirbagVW20 011 0361
Serial number: 003M1R03YGK/
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 4ACD62EC1C384F77573-801E
Belt Pretensioner left:
Component: BeltPretRevFL H35 0340
Serial number: 34169667B08071370922
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0340
Serial number: 34169668B08071350686
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 806 13
Serial number: 35767000000C337DFC07
Subsystem 4 - Part No SW: ----------- HW: 480 002 806 13
Serial number: 358670000002E65DFC0A
Subsystem 5 - Part No SW: ----------- HW: 480 402 106 13
Serial number: 3516502C910CBDD6016K
Subsystem 6 - Part No SW: ----------- HW: 480 402 906 13
Serial number: 3526502C110CBDD370FP
Subsystem 7 - Part No SW: ----------- HW: 480 402 706 13
Serial number: 3556502A1106FA20F1FG
Part No SW: 5Q0 953 507 AM HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 02071304220024
Coding: 1604
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 015F85C0618E4C2FC69-8054
Part No SW: 5G0 920 851 HW: 5G0 920 851
Component: KOMBI 104 3380
Coding: 07A402002300000800080800040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 6597B15095E6800F5A1-8030
Part No SW: 5Q0 907 530 K HW: 5Q0 907 530 D
Component: GW MQB Low 123 1144
Revision: -------- Serial number: 0000749523
Coding: 030000342B086400EF00024C080E00010001000000000000000000000000
ASAM Dataset: EV_GatewLear 009013
ROD: EV_GatewLear_009.rod
VCID: 392F2D2049DED4EFCE9-806C
Subsystem 2 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 2489810803
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
Component: TSG FS 012 0006
Serial number: 22061301100273
Coding: 003003208000048000001000
VCID: 3D2739305DF6E8CFE21-8068
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001956288
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 01
ROD: EV_SteerAssisMQB_008.rod
Part No SW: 5Q0 959 392 A HW: 5Q0 959 392
Component: TSG BFS 012 0006
Serial number: 23061302091512
Coding: 003001208000048000801000
VCID: 3C21343446ECE1C7D5F-8068
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001865671
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT1.clb
Part No SW: 5G0 035 867 HW: 5G0 035 867
Component: MU-E--ER 636 5675
Serial number: 04061300010047
Coding: 02730000FF0000004011000100000000000000040000010000
ASAM Dataset: EV_MUEnt4CLGE 001025
ROD: EV_MUEnt4CLGE_VW37.rod
VCID: 698FBD6079FEA46F7E9-803C
End----------(Elapsed Time: 00:57, VBatt start/end: 12.3V/13.2V)-----------
