Results 1 to 3 of 3
Thread: 2.5L Transmission ID's Interchageable
    Jun 2019
    California, USA
    Quick Question: Are 2.5L Jetta Transmissions interchangeable with one another, like for instance mine is currently a KGL. Can I swap with HRM transmissions or various code models?
    - SoCalJR
    16.4905 S, 151.7375 W
    The transmissions may appear to be the same, both are 09G six speed automatic transmission.
    They may bolt up and work fine, however I would be careful. Here is what I found and you can make your own decision to use a different transmission, personally, I would keep the codes the same because the KGL is the 'newer' one and maybe rated for more power? That is just an educated guess.
    KGL (6A)
    Part number: 09G300034B (09G300034BX)
    For Engine codes: CBTA, CBUA and CCCA --> (125kW/170HP)
    - Jetta 07/2007 to 12/2014
    HRM (6A)
    Part number: 09G300037M (09G300037MX)
    For Engine codes: BGP, BGQ and BTK --> (110kW/150HP)
    - Jetta 04/2005 to 07/2007
    Hope this helps,
    drpeter
  3. Likes Uwe, jdreid liked this post
    Jun 2019
    California, USA
    Thanks so much, DrPeter! I appreciate the help, definitely going to stick with the same transmission ID Code now.
    - SoCalJR
  5. Likes DrPeter liked this post
