Results 1 to 10 of 10
Thread: 2018 USA Tiguan R-Line LED lamps retrofit
    Verified VCDS User obdserwis-pl's Avatar
    May 2019
    Poland
    Hello
    We have 2018 Tiguan from retrofitting to full LEDs (R Line packet). Wiring is done by another workshop.
    Situation now is only low beams works. No other lights.
    So do you have any suggestions?
    I watched another threads connected with this problems, and not found any solution (eg. https://forums.ross-tech.com/showthread.php?20695)
    My idea now is to copy some adaptations from 4B module, maybe from this car: https://forums.ross-tech.com/showthread.php?18164
    Wednesday,30,October,2019,19:36:29:02777
    Dealer/Shop Name: OBDserwis.pl
    VIN: 3VV3B7AX8JM174376   License Plate:
    Mileage: 12326km-7659mi   Repair Order:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 19 29 2B 39 3C 42 44 4B 52
              5F 69 6C 75 CA D6 D7 D8 D9
    VIN: 3VV3B7AX8JM174376   Mileage: 12326km-7659miles
    29-Left Light -- Status: Malfunction 0010
    39-Right Light -- Status: Malfunction 0010
    3C-Lane Change -- Status: Cannot be reached 0100
    4B-Multifunc. Module -- Status: Malfunction 0010
    CA-Sunroof -- Status: OK 0000
    D6-Light Ctrl Left 2 -- Status: Not registered 0011
    D7-Light Ctrl Right 2 -- Status: Not registered 0011
    D8-LED HeadL. Pwr Left -- Status: Cannot be reached 0100
    D9-LED HeadL. Pwr Right -- Status: Cannot be reached 0100
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122424010F34000000000000000000000000000000
       Shop #: WSC 00066 790 00449
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C343886B7617EAFBB-8068
    17158 - Databus
    17921 - Databus
              U1122 00 [032] - Implausible Message
       Part No SW: 09G 927 158 B    HW: 09G 927 158
       Component: AISIN AQ8     206 3380
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00444
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 322816BE6525B8DF61-8066
       Part No SW: 5Q0 614 517 CQ    HW: 5Q0 614 517 AC
       Component: ESC           H25 0423
       Revision: 00000000    Serial number: 50958000000897
       Coding: 0BFA6BA454271B70C57A0207A2C949D0D62AD8A34045927010415058C282420B002764121A1C230A35351919323200
       Shop #: WSC 01383 790 50316
       VCID: 0248867E9505C85FB1-8056
    8362 - Databus
              [FCAN: RCTA_01 is not received]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 03:08:40
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 44
                        Mileage: 12152 km
                        Date: 2019.10.04
                        Time: 10:22:18
       Component: VWKESSYMQB    037 0907
       Revision: 00037000    Serial number: 0477643063
       Coding: 132C0C0723
       VCID: 3E30328EA17D6CBF95-806A
       Part No SW: 5NN 907 044 F    HW: 5NN 907 044 F
       Component: AC Automat    H35 4401
       Revision: 20K03000    Serial number: 00000D00156980
       Coding: 00020024200118001005000012111406
       ASAM Dataset: EV_ACClimaPrehVW37X 002025
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 4FEE7F4A16D7F5376E-801A
       Part No SW: 5Q0 937 087 AS    HW: 5Q0 937 087 AP
       Component: BCM PQ37BOSCH 034 0246
       Revision: --------    Serial number: C86401061804FY
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0C54A846A7418E2FCB-8058
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 180427  034 0373
       Serial number: 18042222009110
       Subsystem 2 - Part No SW: 8U0 955 559     HW: 8U0 955 559   Labels: 8U0-955-559.CLB
       Serial number: 72160003
    14 Faults Found:
    131586 - Function Restricted due to Insufficient Voltage
              U1400 00 [008] - -
              [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
    566550 - Databus
              [LCM links - unplausibler Datensatz]
                        Fault Frequency: 18
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:53
    566806 - Databus
              [LCM rechts - unplausibler Datensatz]
                        Fault Frequency: 18
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:53
    568086 - Databus
              [LCM links - Blinker defekt]
                        Fault Frequency: 18
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:53
    568342 - Databus
              [LCM rechts - Blinker defekt]
                        Fault Frequency: 18
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:53
    7178 - Bulb for High Beam Headlamp Left
              B1219 15 [009] - Open or Short to Plus
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:29:26
    7434 - Bulb for High Beam Headlamp Right
              B121A 15 [009] - Open or Short to Plus
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:29:27
    5386 - Bulb for Front Right Turn Signal
              B11EA 15 [009] - Open or Short to Plus
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 21:00:25
    8970 - Bulb for Right Fog Lamp
              B1220 15 [009] - Open or Short to Plus
                        Fault Frequency: 17
                        Reset counter: 245
                        Mileage: 10503 km
                        Date: 2019.08.21
                        Time: 15:53:33
    13578 - Bulb for Left Tail Light 2
              B12C0 15 [008] - Open or Short to Plus
    18954 - Left LED Module for DRL and Parking Lights
              B12EC F5 [009] - Control Circuit Open or Short to Plus
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:55
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 200
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:34:01
    526359 - Control Module Incorrectly Coded
              U1014 00 [009] - -
              [Steuergerät falsch codiert->Keine Anzeige]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:53
    526615 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.07.15
                        Time: 10:23:53
       Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
       Component: PLA 3.0 12K   H09 0021
       Serial number: 002004167478000
       Coding: 0231467A51
       Shop #: WSC 01487 111 28888
       ASAM Dataset: EV_EPHBO2CVW3260000 010016
       VCID: 3B363B9AB26F7997B2-FFFE
    12 Faults Found:
    1113107 - Front Parking Aid Sensor(s)
              B10FC 13 [009] - Open Circuit
                        Fault Frequency: 108
                        Reset counter: 11
                        Mileage: 11911 km
                        Date: 2019.09.16
                        Time: 10:47:42
    1080083 - Rear Parking Aid Sensor(s)
              B107B 13 [009] - Open Circuit
                        Fault Frequency: 102
                        Reset counter: 11
                        Mileage: 11926 km
                        Date: 2019.09.20
                        Time: 07:53:27
    1112068 - Front Left Center Parking Aid Sensor
              B10F8 04 [009] - Internal System Fault
                        Reset counter: 10
                        Mileage: 12288 km
                        Date: 2019.10.06
                        Time: 08:31:18
    1112324 - Front Right Center Parking Aid Sensor
              B10F9 04 [009] - Internal System Fault
                        Reset counter: 11
                        Mileage: 12326 km
                        Date: 2019.10.08
                        Time: 19:31:50
    1079089 - Center Rear Left Parking Aid Sensor
              B1077 31 [009] - No Signal
                        Reset counter: 225
                        Mileage: 10963 km
                        Date: 2019.08.25
                        Time: 16:41:00
    1079060 - Center Rear Left Parking Aid Sensor
              B1077 14 [009] - Open or Short to Ground
                        Reset counter: 179
                        Mileage: 8735 km
                        Date: 2019.07.21
                        Time: 12:46:01
    1078788 - Rear Left Parking Aid Sensor
              B1076 04 [009] - Internal System Fault
                        Reset counter: 11
                        Mileage: 12273 km
                        Date: 2019.10.05
                        Time: 17:08:15
    1078858 - Rear Left Parking Aid Sensor
              B1076 4A [009] - Incorrect component(s) installed
                        Reset counter: 11
                        Mileage: 12326 km
                        Date: 2019.10.08
                        Time: 19:31:32
    1079572 - Rear Right Parking Aid Sensors
              B1079 14 [009] - Open or Short to Ground
                        Reset counter: 179
                        Mileage: 8735 km
                        Date: 2019.07.21
                        Time: 12:46:01
    1079556 - Rear Right Parking Aid Sensors
              B1079 04 [009] - Internal System Fault
                        Reset counter: 10
                        Mileage: 12290 km
                        Date: 2019.10.06
                        Time: 09:27:18
    1079626 - Rear Right Parking Aid Sensors
              B1079 4A [009] - Incorrect component(s) installed
    1080852 - Side Rear Right Parking Aid Sensors
              B107E 14 [009] - Open or Short to Ground
    Address 13: Auto Dist. Reg
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM093EBT
       Coding: 8CCCFC00000000005000001AC20800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 05429D62842BFF6794-8050
       Occupant Detection:
       Serial number: IBH0000000000099DALM
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 002 004 18
       Serial number: 3570000000086D2C5D2X
       Subsystem 3 - Part No SW: -----------    HW: 480 002 004 18
       Serial number: 35800000000FEB604D2
       Subsystem 4 - Part No SW: -----------    HW: 480 402 904 18
       Serial number: 3510001C929B6A831746
       Subsystem 5 - Part No SW: -----------    HW: 480 402 804 18
       Serial number: 3520001BB29D67852458
       Subsystem 6 - Part No SW: -----------    HW: 480 402 704 18
       Serial number: 3550001A529D6772C79H
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 402 704 18
       Component: FrontSensor_P  000 6149
       Serial number: 35600019F29D6761C50E
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 25021820240271
       Coding: 0410
       VCID: 075E976ABE27ED77E6-8052
       Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
       Component: KOMBI         380 0310
       Coding: 03A4091A2788000807882A0954000000A0000000
       Shop #: WSC 11618 000 00000
              U1014 00 [009] - -
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:41:03
    16777008 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_SWA_0x1A keine Kommunikation]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:41:06
    16776982 - Databus
              [SWA_01 keine Kommunikation]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:41:03
       Component: GW MQB High   518 5323
       Serial number: 11051800840611
       Coding: 030100347F085900FA0002481C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 383C24968359528F5F-806C
       Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
       Serial number: 0811808223300796BH2B
       Coding: 280000
       Serial number: 1508325800
    131662 - Lane change assistant control module
              U1045 00 [009] - No communication
              [Timeout Knoten 0x4E / 3C - Steuergerät für Spurwechselassistent]
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.07.13
                        Time: 00:27:15
                        Supply voltage: Terminal 30: 11.1 V
                        Terminal 15: On
    131736 - No Communications with Undefined Control Module
              U1126 00 [009] - -
              [Timeout Knoten 0x98]
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.07.13
                        Time: 00:27:15
                        Terminal 15: On
    131737 - No Communications with Undefined Control Module
              U1126 00 [009] - -
              [Timeout Knoten 0x99]
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.07.13
                        Time: 00:27:15
                        Terminal 15: On
       Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
       Component: LCM_MLBevoH08 0014
       VCID: 45C25D62C4AB3F67D4-8010
    0019 - Headlamp Type
              C119F 00 [008] - Implausible
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:51:44
    0033 - Supply voltage
              U1011 00 [009] - Voltage too Low
              [Supply voltage - lower limit exceeded]
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:37:42
    0036 - Terminal 15
              U1405 00 [009] - Implausible signal
              [Clamp 15 implausible signal]
                        Fault Frequency: 18
                        Reset counter: 247
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:36:14
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 18000102415002
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_VW37.rod
       VCID: 332613BA9A3FB1D76A-8066
                        Fault Frequency: 21
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:51:44
                        Fault Frequency: 135
                        Reset counter: 11
                        Mileage: 11750 km
                        Date: 2019.09.05
                        Time: 14:57:14
    0036 - Terminal 15
                        Fault Frequency: 18
                        Reset counter: 247
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:36:14
    Address 3C: Lane Change
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 7038814702482
       Coding: 003013200000028000000000
       Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000000428321
       Coding: 011000
       Revision: 00000000    Serial number: 0002382846
       Coding: 01000010004000
       Shop #: WSC 00066 790 00066
       ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
       VCID: 40CC4C76DB891A4FE7-8014
    Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V1.clb
       Serial number: 22031810802606
       Coding: 000000070100094E07000900000000000000000000000000000000000000
       Shop #: WSC 00049 770 00107
       VCID: 72A8D6BEA5A5F8DFA1-8026
    10 Faults Found:
    13705478 - Databus
              [RLS_01 data bus missing message]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    13705473 - Databus
              U1121 00 [137] - Missing Message
              [Fahrwerk_01 data bus missing message]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    0035 - Databus for Front Lighting
              U12EB 00 [009] - Additional Installations Detected
              [CAN_AFS_multiple_plug_LCM_identified]
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    0037 - Databus for Front Lighting
              [CAN_AFS_multiple_plug_LED_Leimo_identified]
                        Reset counter: 11
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    13705988 - Databus
              U1123 00 [137] - Received Error Message
              [FA_Hoehenwert_VL_00 received error value]
                        Fault Frequency: 71
                        Reset counter: 10
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    13705989 - Databus
              [FA_Hoehenwert_HL_00 received error value]
                        Fault Frequency: 71
                        Reset counter: 10
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    66678 - Databus
              [LCM_Datensatz_Fehler_L received error value]
                        Fault Frequency: 19
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:34:14
    66679 - Databus
              [LCM_Datensatz_Fehler_R received error value]
                        Fault Frequency: 19
                        Reset counter: 32
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:34:14
    66881 - Databus
              [LED_L_falsch_codiert received error value]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
    66882 - Databus
              [LED_R_falsch_codiert received error value]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 02:31:56
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 8038815200283
       VCID: 44C44066CF91066FC3-8010
       Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000000420495
       Coding: 091000
       Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
       Component: MU-S-S-US     722 0867
       Coding: 02730600BE00000051110001001808001F0100C40120050002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2E1002CE711D9C3F05-807A
       Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
       Component: ABT_Std-2  H52 8130
       Serial number: VWZ6ZJV1151165
              B11CF 53 [009] - Deactivated
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 03:05:05
                        Voltage terminal 30: 11.9 V
                        SDARS_tuner_status_2-Antenna current: 104 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
    7194 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Side assist (0x1A) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 03:04:28
                        Voltage terminal 30: 11.8 V
                        BAP-BAP_Function_ID: 02
       Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
       Component: Anhaenger     H27 0264
       Revision: 8A001003    Serial number: 0504818959
       Coding: 0100000202000000
       VCID: 42C8467ED585085FF1-8016
    136203 - Supply Voltage
              P1757 00 [009] - Open Circuit
                        Fault Frequency: 211
                        Reset counter: 11
       Coding: 0123060120002017300040
       VCID: 393A2192B8534B87A0-806C
       Component: OCULowMQBUS   009 0570
       Coding: 02230602C2823A017F1E06000000
       ROD: EV_OCULowMQB.rod
       VCID: 43C6437ACA9F0157FA-8016
       Coding: 00804073260C
       VCID: 3D323582AC7B77A78C-8068
       VCID: 1660CA2EE98D44FF6D-8042
              C119F 00 [009] - Implausible
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:36:12
    0785 - Bulb for Low-Beam Headlamp
              C1198 F0 [009] - Current Coding Electrical Malfunction
                        Reset counter: 11
                        Mileage: 11889 km
                        Date: 2019.09.15
                        Time: 11:00:53
    0849 - Bulb for High-Beam Headlamp
              C1199 F0 [009] - Current Coding Electrical Malfunction
                        Reset counter: 11
                        Mileage: 11889 km
                        Date: 2019.09.15
                        Time: 11:00:53
       ROD: EV_LEDModLeftMELCOAU736_VW48.rod
                        Reset counter: 172
                        Mileage: 8046 km
                        Date: 2019.06.28
                        Time: 01:36:12
                        Reset counter: 11
                        Mileage: 11889 km
                        Date: 2019.09.15
                        Time: 11:00:53
                        Reset counter: 11
                        Mileage: 11889 km
                        Date: 2019.09.15
                        Time: 11:00:53
    Address D8: LED HeadL. Pwr Left
    Address D9: LED HeadL. Pwr Right
    End----------(Elapsed Time: 02:49, VBatt start/end: 14.9V/14.9V)-----------
    Oct 2017
    Northwest UK
    Has the car got ACC (front distance sensor) and lane assist? What did it have prior to wiring the LED Headlights? Do you know what wiring has been done?
    There are more errors here than only Headlights. Try clearing all faults are run another scan. I'd advise you to compare your settings with one from factory, assuming the wiring is correct? Do you have a backup scan prior to changes being made?
    May 2019
    Poland
    Yes, ACC is present lane assist also, but now not works. Car came to me after another workshop. Don't know if wiring is correct.
    Turn signals and high beams are priority for now.
    This is first backup of coding I have. That is situation when car came to my workshop
    Apr 2019
    Quote Originally Posted by obdserwis-pl View Post
    The thread you watching is mine and I have not done the retrofit yet. But have pretty clear idea what I would do.
    For the wiring, you need to repin or make an adapter from 10 pin to 14pin. I believe low beam is the only wire that stays at the same position pin 5 on both 10-pin and 14-pin connector. In theory low beam will always work even if you don't do anything simply because its the same. Rest is slightly different connection which all go to BCM J519.
    Once you are 100% + sure your connection is correct then you can proceed to coding. If you don't have good wiring you will go crazy figuring out coding.
    For the coding (again I have not done it yet). Is to add all modules into CAN cateway. Code 4B module based on the autoscan you posted. Then you need to go to J519 and match adaptations
    Oct 2017
    Northwest UK
    What lights has it got at the minute? Led? D6 and D7 need enabling in the gateway it would seem. What lights did it have before the install?
    Apr 2019
    Quote Originally Posted by myounus View Post
    He mentioned this is a USA Tiguan which means the car must have standard halogen headlights with LED DRL. Which are also wired differently than halogen headlights in Europen Tiguans. In addition European LED headlights are wired differently than USA LED Headlights.
    General note, one must be very careful and consider this when rewiring headlights. I hope that the shop that did the wiring realized that.
  7. Likes Uwe liked this post
    Oct 2017
    Northwest UK
    Quote Originally Posted by OEMplusCC View Post
    Time to get the WD out and check!
  9. Likes Uwe liked this post
  10. #8
    May 2019
    Poland
    Don't really know, if my wiring is 100% OK. Customer said, that wiring is done correct from 10pin to 14pin socket.
    Now I want to know, that my coding is OK.
    What do you mean
    Which autoscan and adaptations you are talking about? 2019 Tiguan SEL Premium?
  11. #9
    Apr 2019
    Yes this one for autoscan(long coding) and adaptation channels:
    https://forums.ross-tech.com/showthr...ium)-2-0L-DGUA
    But be careful because that car has windshield camera which I assume you don't have. You will have to pick what you need or don't need.
    Again I have not done this myself, so its possible I might be wrong on something. What I'm telling you is what I would have done
  12. Likes Uwe liked this post
  13. #10
    May 2016
    There are some important things about these headlights. These are fully CANBUS controlled. That means: turn, DRL, high beams and parking lights are totally functioned by canbus. This needs to be connected by the 55 (xenonrange) or 4B (multifunctional module). Depending on this you need to get your wiring ok.
    The wiring for 55 module is other that the 4B module. 29 39 D6 D7 no need to be coded in the gateway as the are subsystems recognized by the 55/4B module. This only need BF additional canbus (correct me if i'm wrong), I have not find this option in VCDS only ODIS.
    If someone need some help with installation PM me. Done this enoug times.
  14. Likes Uwe liked this post
