Results 1 to 7 of 7
Thread: Passat B8 2016 retrofit
Hybrid View
    Oct 2019
    Hi.
    I hope it is okay I start a new thread as I now have more problems after retrofitting the last parts.
    I can't figure out and load the autoscan right.
    I've retrofitted..:
    Blind spot
    PLA 3.0
    Area view
    TPMS
    A5 camera
    LED High front
    AID
    I think I've got the Blind spot coded but don't know until next week when I get the CP removed
    But I can't figure out why I have "Local databus" error in A5 camera
    Camera gets calibrated Friday.
    When I drive forward and get close to something the p-sensor turns on but they do not appear on the screen.
    I need to turn off the p-sensor on the button and turn it on again for it to appear on the screen.
    Every time I start the car it makes the sign assist error in the cluster. I hope it will be resolved Friday when calibrated.
    It shows the sign in the cluster but only the same as in the navi and it does not read the right boards I pass by
    Wednesday,06,November,2019,16:43:38:52337
    Workshop Code: 970 22339 012345
    VIN: WVWZZZ3CZGExxxxxx   License Plate:
    Mileage: 89856km-55833mi   Repair Order:
    Chassis Type: 3C-VW48 (5Q0)
    Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 52 55 5F
              65 69 6C 6D A5 BB BC CF
    VIN: WVWZZZ3CZGExxxxxx   Mileage: 89856km-55833miles
    CF-Lane Chge Asst 2 -- Status: Malfunction 0010
    Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
       Component: R4 2.0l TDI   H23 2011
       Revision: B4H23---
       Coding: 011D003A047405083000
       Shop #: WSC 22339 970 00001
       ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
       ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
       VCID: 7BB621D8F2291197F2-802E
       Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
       Component: DQ250-6F MQB  H53 4906
       Revision: 06253104    Serial number: TFK01602241041
       Shop #: WSC 05311 115 00061
       ROD: EV_TCMDQ250021.rod
       VCID: 1F0E35480671ADB7BE-804A
       Revision: 00000000    Serial number: 61046000000938
       Coding: 0FEC6A8F34220B74077D060841C549F0562CD0E0608292F11862F078C209
       VCID: 7AB824DCFD13289FE9-802E
       Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Component: VWKESSYMQB    026 0710
       Revision: 00026000    Serial number: 0401603713
       Coding: 000F0F0F03
       Shop #: WSC 05311 115 00236
       VCID: 393AFBD0B895E387A0-806C
       Part No SW: 5G0 907 044 BH    HW: 5G0 907 044 BH
       Component: Climatronic   H04 1202
       Revision: 00001K10
       Coding: 12020104204101011015500000101802
       Shop #: WSC 00015 115 08193
       ASAM Dataset: EV_ACClimaBHBVW37X 005137
       VCID: 6E90188CB15B743F45-803A
       Air quality sensor:
       Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Component: BCM PQ37BOSCH 028 0163
       Revision: --------    Serial number: 8658160416012I
       Coding: 00071D46C2C102FF53C44004001457081C80000000000000000000000000
       ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
       ROD: EV_BCMBOSCH_015.rod
       VCID: 034659388AD96957BA-8056
       Component: WWS    160326  042 0607
       Serial number:         160408192827
       Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
       Serial number: 90070925
       Coding: 00006E
       Serial number: 20 01 2016  10000219
       Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
       Serial number: 000308417618081
       Coding: 0A71265A51
       ROD: EV_EPHVA2CAU3700000.rod
       VCID: 50ECA6740B2F42CF77-8004
       Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Component: ACC BOSCH MQB H04 0194
       Coding: 3200670B51FFC428949C804D
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3424CAE49FF71EEF73-8060
       Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Component: Airbag VW20   013 0195
       Revision: --------    Serial number: 003STP7HZFH4
       Coding: 88CCC000008000005C5400CC000800000065
       Shop #: WSC 05314 000 00001
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F4ED5C8E6310DB7DE-802A
       Subsystem 1 - Part No SW: -----------    HW: 454 000 204 16
       Serial number: 3576U000000426303A1.
       Subsystem 2 - Part No SW: -----------    HW: 454 000 204 16
       Serial number: 3586U000000A5B5D4A1P
       Subsystem 3 - Part No SW: -----------    HW: 454 802 503 16
       Serial number: 3516RE6FDFF090000000
       Subsystem 4 - Part No SW: -----------    HW: 454 802 503 16
       Serial number: 3526RB1E4FF09000000Q
       Subsystem 5 - Part No SW: -----------    HW: 454 802 803 16
       Serial number: 3556VB451470A0000006
       Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
       Revision: FF033033    Serial number: 20160303501287
       Coding: 0C10
       ROD: EV_SMLSVALEOMQB.rod
       Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
       Component: KOMBI         412 1460
       Coding: 07A509986F8C000C01887F0F3001000000000000
       VCID: 271E2DA85E216577C6-8072
       Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
       Component: STH-MQB       007 0072
       Coding: 9309
       Shop #: WSC 00015 115 00001
       VCID: 383CFED4839FFA8F5F-806C
       Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Component: R149 T91-LIN  003 0301
       Serial number: 00000000000001374380
       Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2246
       Revision: --------    Serial number: 10041610801934
       Coding: 0B0300345F017300FB0002581C0F00010001070000000000000000000000
       ROD: EV_GatewConti_013.rod
       VCID: 79BA3BD0F8152387E0-802C
       Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H11 0040
       Serial number: 29160000731660016146
       Coding: 2DFFFF
       Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
       Serial number: 0448649703
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Component: WECHSELRICHTE  H55 0033
       Serial number: 0226931
       Analog clock:
       Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Serial number: 16000073540012
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA03F0A0656BC758-8024
       Part No SW: 3Q0 907 566 B    HW: 3Q0 907 566
       Component: MRR1Rear      H16 0230
       Revision: --------
       Coding: 14C002
       VCID: 373EFDE88E81F5F756-8062
    267010 - Databus
              [FAULT_SLAVE]
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
                        Control Module temperature: 31 °C
                        Voltage terminal 30: Measured value not available
                        Vehicle speed: 0.00 km/h
                        Terminal 15 status: Measured value not available
                        Voltage terminal 15: 11.60 V
              U1101 00 [009] - Active
              [Component protection is active]
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
                        Voltage terminal 15: 11.70 V
       Serial number: 040416ED414997
       Coding: 001F0B20DC00020000001000
       VCID: 43C69938CA59A957FA-8016
       Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Component: MQB_PP_APA    204 2041
       Revision: 00000000    Serial number: 0000735503
       Coding: 01010011005000
       ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       VCID: 3D32EFC0ACBDDFA78C-8068
       Serial number: 060416ED60262A
       Coding: 001F0120DC00020000001000
       VCID: 42C89C3CD543A05FF1-8016
       Component: AFS-ECU       H01 0120
       Coding: 039A00001F210200
       VCID: 3FCE95C8A6B1CDB79E-806A
       Subsystem 1 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo li.  H07 0001
       Coding: E02400
       Subsystem 2 - Part No SW: 7PP 941 572 A    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
       Component: LED LeiMo re.  H07 0001
       Coding: E02400
       Coding: E02400
       Component: LeiMo rechts  H02 X003
       Coding: E02400
       Part No SW: 3G0 035 043 J    HW: 3G0 035 043
       Component: MU-H-N-EU     H50 0343
       Serial number: A683D0GB030629
       Coding: 02840201FF00000051110001000808031F0106E441200000DF
       VCID: 230639B82A1989579A-8076
       Component: ABT_High  H63 0032
       Serial number: VWZ8Z9SKL00H4C
       Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote2  --- 1012
              U1111 00 [008] - -
                        Reset counter: 28
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:20
                        Voltage terminal 30: 12.0 V
                        BAP-BAP_Function_ID: 01
       Serial number: 30000000199487
       ROD: EV_RDKBERU30_006_VW48.rod
    8398082 - Tire Pressure Sensor(s)
              C111A 31 [009] - No Signal
                        Reset counter: 201
                        Mileage: 88074 km
                        Date: 2019.10.19
                        Time: 03:02:17
                        Vehicle speed: 58 km/h
                        Outside air temperature: 9.5 °C
                        Reception level antenna 1: 620 mV
                        Offset level antenna 1: 270 mV
       Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Component: Anhaenger     H21 0203
       Revision: 8A001003    Serial number: 0400569602
       Coding: 0100000202000000
       VCID: 3B36E1D8B2A9D197B2-806E
       Part No SW: 5Q0 907 556     HW: 5Q0 907 556
       Component: Areaview 2    H11 0329
       Serial number: C854706JG000690
       Coding: 01840201E70F200000204814
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
       ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
       VCID: 76A030ECC90B4CFF8D-8022
    9616786 - Surroundings Camera Front
              B127C F0 [009] - Calibration Failed
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
    9616787 - Surroundings Camera Rear
              B127D F0 [009] - Calibration Failed
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
    10489856 - No Basic Setting
              B2010 00 [009] - -
              [RearView system not calibrated]
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
    9616994 - Front Surroundings Camera
              B127C 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
    9617993 - Rear Surroundings Camera
              B127D 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
       Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0253
       Revision: --------    Serial number: 30613377500000
       Coding: 0280
       Component: MQB_B_MFK     H09 0272
       Serial number: 04091815P12091
       Coding: 0004080200000401002423478040A10094000E200020
       VCID: 3C34E2C4B7A7D6AFBB-8068
    0660 - No Basic Setting
              B2010 00 [009] - -
              [Initial_calibration_missing]
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
                        Control Module temperature: 28 °C
                        Outside air temperature: 2.5 °C
                        System run time: 224.9 s
                        Voltage terminal 15: 11.6 V
                        mid: 00 1E
                        Status of camera: System malfunction
                        Engine_Running_Info: 0
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
    1122597 - Local Data Bus
              U1169 00 [009] - Missing Message
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
                        System run time: 225.3 s
                        mid: 01 43
                        Software_Info_4: 2
                        Software_Info_3: 7
                        Software_Info_2: 2
                        Software_Info_1: 0
       Serial number: 090316EC817976
       Coding: 000E01200100020000001000
       VCID: 45C28720C46D9767D4-8010
       Serial number: 090316EC817797
       Part No SW: 3Q0 907 590 B    HW: 3Q0 907 590
       Revision: --------
       Coding: 14C002
                        Reset counter: 243
                        Mileage: 89856 km
                        Date: 2019.11.06
                        Time: 16:39:18
    End----(Elapsed Time: 02:31, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Feb 2018
    First you have to remove Component Protection in all ECU. Then you have to search in ECU 5F in Adaptions for "0x07" to activate TPMS in Menu. Also you have to do all Basic Setting in the new ECU. After that please give us a new Scan and we have to look which things you have to do
  3. Likes Uwe liked this post
    Jul 2014
    Tallinn, Estonia
    Quote Originally Posted by VAGParts View Post
    Did you run the seperate CAN circuit from A5 camera to ACC radar and activated the appropriate option in ACC radar coding? Be advised, when you change the coding, the local databus fault would be gone but ACC will cease to function. ACC will work again once camera is calibrated.
  5. Likes Uwe liked this post
    Oct 2019
    Yes there are CAN wires for radar fitted. Orange / white - orange / brown and I have coded the camera in 13-Auto Dist. Reg
    Jul 2014
    Tallinn, Estonia
    If the CAN interface is coded in both A5 and 13 and the A5 fault still remains and ACC is still working, then either there is something wrong with the coding or the CAN connection (CAN-H/CAN-L wires mixed up?). I don't have any coding samples available at the moment to verify if your 13 coding is correct.
    Oct 2019
    I've come a little further with my project.
    I'm having problems with my TPMS High. Sometimes it works and other times it doesn't, inside discover pro it writes "starter" and then nothing happens anymore.
    In AID, it switches between displaying tire pressure and "Tire pressure disabled"
    After I got the error in 03-ABS it does not work at all.
    The car had TPMS Low from the factory
    Wednesday,27,November,2019,22:21:01:52337
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    Mileage: 92672km-57583mi   Repair Order: 271119
    VIN: WVWZZZ3CZGExxxxxx   Mileage: 92672km-57583miles
       Revision: B4H23---
    16401 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 79
                        Date: 2019.11.26
                        Time: 14:11:04
       Coding: 000F0F0F03
       Revision: 00001K10
       Air quality sensor:
       Coding: 00006E
    10506 - Bulb for Left Tail Light
              B12BE 15 [008] - Open or Short to Plus
                        Reset counter: 83
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 16:33:52
    204290 - Remote key 1
              B1479 18 [008] - Current Too Low
                        Reset counter: 84
                        Mileage: 92652 km
                        Date: 2019.11.27
                        Time: 16:35:58
    1049604 - Lamp 1 for Contour Lighting of Door; Front Left
              U1176 00 [009] - No Communications
              [Leuchte 1 für Türkonturbeleuchtung vorn linkskeine Kommunikation]
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 14:11:07
    1050628 - Lamp 1 for Contour Lighting of Door; Front Right
              U1178 00 [009] - No Communications
              [Leuchte 1 für Türkonturbeleuchtung vorn rechtskeine Kommunikation]
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 14:11:07
    1051652 - Lamp 1 for Contour Lighting of Door; Rear Left
              U117A 00 [009] - No Communications
              [Leuchte 1 für Türkonturbeleuchtung hinten linkskeine Kommunikation]
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 14:11:07
    1052676 - Lamp 1 for Contour Lighting of Door; Rear Right
              U117C 00 [009] - No Communications
              [Leuchte 1 für Türkonturbeleuchtung hinten rechtskeine Kommunikation]
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 14:11:07
       Coding: 0A71267A51
       Coding: 3200674B51FFC428949C804D
       Coding: 0C10
       Coding: 9309
       Coding: 2DFFFF
       Analog clock:
       Revision: --------
       Coding: 14C002
       Coding: E02400
       Coding: E02400
       Coding: E02400
       Coding: E02400
    8389634 - TPMS Display
              C1239 F0 [008] - Position Determination Not Possible
                        Reset counter: 84
                        Mileage: 92621 km
                        Date: 2019.11.27
                        Time: 10:01:44
                        Outside air temperature: 8.0 °C
                        Reception level antenna 1: 670 mV
       Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
       Component: Areaview 2    H13 0608
       Serial number: C854707JG034284
       Coding: 01840201E30F20000000480C
       Shop #: WSC 00070 000 00000
       ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
       ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
              B2010 00 [009] - -
                        Fault Frequency: 10
                        Reset counter: 44
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 21:21:05
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 21:21:05
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 21:21:05
    9618000 - Left Surroundings Camera
              B127E 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 21:21:05
    9618001 - Right Surroundings Camera
              B127F 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 39
                        Mileage: 92586 km
                        Date: 2019.11.26
                        Time: 21:21:05
       Coding: 0280
       Coding: 000408020000040100242347C040A90094000E200020
       Shop #: WSC 22339 970 12345
       Revision: --------
       Coding: 14C002
    End----------(Elapsed Time: 02:27, VBatt start/end: 12.2V/12.1V)-----------
    Dec 2016
    Amsterdam
    TPMS module needs a dataset if its a new module.
    Current:
