- Joined
- Dec 2, 2016
- Messages
- 85
- Reaction score
- 25
- Location
- Cardiff(ish), South Wales, UK.
- VCDS Serial number
- C?ID=288281
Hiya Folks,
I am trying to do an adaptation reset on a DPF that has been replaced but the pop-up balloon with the security access code isn't showing, maybe because the vehicle is too new?
Autoscan:
Any one have the code so I can put this to bed?
Craig
Autoscan:
Wednesday,06,November,2019,17:52:06:50827
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
Dealer/Shop Name: Lightrofit
VIN: WMA11VUY2K9011856 License Plate:
Chassis Type: UY-VN54 (3Q0)
Scan: 01 03 08 09 13 15 17 19 3D 42 44 52 5F BB BC
VIN: WMA11VUY2K9011856 Mileage: 6502km-4040miles
3D-Special Function -- Status: OK 0000
BB-Door Rear Drv -- Status: Cannot be reached 0100
BC-Door Rear Pass -- Status: Cannot be reached 0100
Address 01: Engine (J623-DASB) Labels: None
Part No SW: 04L 906 056 BD HW: 04L 907 445 C
Component: R4 2.0l TDI H01 6412
Revision: 23201001
Coding: 001940106024050800000000000000000000000000000000
Shop #: WSC 00069 790 00020
ASAM Dataset: EV_ECM20TDI03004L906056BD 005004
ROD: EV_ECM20TDI03004L906056BD.rod
VCID: 70AC21BBAB6598CF57-8024
23902 - Diesel Particle Filter
P2463 00 [175] - Excessive Soot Accumulation
Mileage: 6502 km
Date: 2019.10.22
Time: 00:53:12
Engine speed: 829.25 /min
Normed load value: 22.7 %
Coolant temperature: 53 °C
Intake air temperature: 13 °C
Voltage terminal 30: 13.976 V
Counter for regeneration time of diesel particle filter: 1159 s
Particle filter: kilometers since last regeneration: 1003.7
Particle filter: soot mass measured: 4.84 g
Particle filter: soot mass calculated: 46.27 g
Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 0.0 mbar
Particle filter: field regeneration lock status: 8200
27277 - System Voltage
P0562 00 [039] - Too Low
Mileage: 6502 km
Date: 2019.10.22
Time: 00:53:12
Engine speed: 825.00 /min
Air mass at air mass meter 1: 50.4 kg/h
Standardised airflow ratio: 0.997 counts
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.98 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
Charge air pressure specified value: 0.923 bar
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1074 mbar
Mean injection quantity: 6 mg/stroke
Index of current engine mode: 4
Index of next requested engine mode: 4
Index of engine target mode: 4
Readiness: N/A
Part No SW: 2N0 907 379 D HW: 2N0 907 379 C
Component: ESC_base H02 0860
Serial number: 08509014190412
Coding: 29AA8477483EB683944F216512496D063DF120B8
ASAM Dataset: EV_Brake1ESP90iBOSCHVN54X 701030
ROD: EV_Brake1ESP90iBOSCHVN54X_701.rod
VCID: 373EDAA78E8B0FF756-8062
0602 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Dst_EpsTorqReqRejected]
Reset counter: 86
Mileage: 6502 km
Date: 2019.10.22
Time: 00:17:37
Address 08: Auto HVAC (J65) Labels:* None
Part No SW: 7C0 907 184 N HW: 7C0 907 184 N
Component: Heizung H01 0401
Coding: A07110000800030001000800500101000000000000000000000000000000
Shop #: WSC 00069 790 00012
ASAM Dataset: EV_AirCondiBHTCVN54X 003020
ROD: EV_AirCondiBHTCVN54X_VN46.rod
VCID: 3522D0AF9487FDE744-8060
Part No SW: 5Q0 937 084 DA HW: 5Q0 937 084 CD
Component: BCM MQBAB B H38 0273
Serial number: 01001911900517
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_AU27.rod
VCID: 7AB80393FD19D29FE9-802E
Steering Column Switch:
Subsystem 1 - Part No SW: 5Q1 953 521 BH HW: 5Q1 953 569 A
Component: Lenks.Modul H13 0170
Serial number: 0100090420190C200830
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 Q HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0342
Coding: 2A00400100EF8448949C814D00308700000000000000000000
ASAM Dataset: EV_ACCMRRCONTIVW376 003015
ROD: EV_ACCMRRCONTIVW376_AU27.rod
VCID: 42C8BB73D5495A5FF1-8016
Part No SW: 3Q0 959 655 CL HW: 3Q0 959 655 CL
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z1P8HUB45
Coding: 800080000000000040000000008800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0A585353ADF9C21FF9-805E
Subsystem 1 - Part No SW: ----------- HW: 454 800 703 19
Component: FrontSensor_D 305 0109
Serial number: 35500866411180000005
Front Sensor Passenger:
Subsystem 2 - Part No SW: ----------- HW: 454 801 403 19
Component: FrontSensor_P 305 0109
Serial number: 356006D4212180000008
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 7C0 920 941 B HW: 7C0 920 941 B
Component: KOMBI 211 2700
Coding: 27A4110020002600018A2A010400000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009068
ROD: EV_DashBoardVDDMQBAB_VN54.rod
VCID: 250200EF24278D67F4-8070
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Serial number: 11041911601454
Coding: 030000044F05730000000000000E00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E903FC3B1518E3F45-803A
Subsystem 1 - Part No SW: 2N0 915 181 HW: 2N0 915 181
Component: J367-BDMConti H03 1051
Serial number: 75884902001904050092
197149 - Generator
U1052 00 [009] - No Communication
[Generator (LIN#1) Timeout]
Reset counter: 86
Mileage: 6502 km
Date: 2019.10.22
Time: 00:16:06
Supply voltage: Terminal 30: 13.9 V
Terminal 15: On
Address 3D: Special Function (J608) Labels:* None
Part No SW: 2N0 907 427 M HW: 2N0 907 427 H
Component: KFG H24 0208
Serial number: GB24191257598
Coding: 000000000000000002000008000000
ASAM Dataset: EV_SpeciFunctFlextVN54X 006024
ROD: EV_SpeciFunctFlextVN54X_006_VN54.rod
VCID: 3A38C393BD99129FA9-806E
Part No SW: 5Q4 959 393 F HW: 5Q4 959 393 F
Component: TSG FS 006 0246
Serial number: 0000373492571
Coding: 00300B200101020100001000
ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
VCID: 46C0A763F961667FDD-8012
196660 - Motor for Window Regulator
B1487 54 [009] - Missing Calibration / Basic Setting
Reset counter: 86
Mileage: 6502 km
Date: 2019.10.22
Time: 00:16:10
Address 44: Steering Assist (J500) Labels:| 2N0-909-143.clb
Part No SW: 2N0 909 143 G HW: 2N0 909 143 C
Component: EPS_MQB_ZFLS 701 7031
Coding: 0107
ASAM Dataset: EV_SteerAssisMNB 002009
ROD: EV_SteerAssisMNB_VN54.rod
VCID: 312AE4BF60EFD1C718-8064
Part No SW: 5Q4 959 392 F HW: 5Q4 959 392 F
Component: TSG BFS 006 0246
Serial number: 0000372521355
ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
VCID: 45C2A06FC4676D67D4-8010
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 2E0 035 130 HW: 2E0 035 130
Component: MU-G--EU 611 0242
Serial number: VWZGZ1W5632653
Coding: 084500002800000000110001010002002F0000040000010000
ASAM Dataset: EV_MUGlb4CHBAS 001001
ROD: EV_MUGlb4CHBAS.rod
VCID: 53E68E373A33C3D74A-8006
Address BB: Door Rear Drv
Address BC: Door Rear Pass
End----------(Elapsed Time: 00:45, VBatt start/end: 14.0V/14.0V)-----------
Craig
