Results 1 to 10 of 11
Thread: Audi A4 b7 model stw
    New User
    Nov 2019
    Hey, I have couple issues after car got water inside, yes its watterproof, bottom, water stay inside and CCM was damaged. I bought new and install it but there is one strange problem, when i open left front door, in door panel in multimeter , open left door indicator”led” .
    When I open right front door , shows same gauge that left door is open, rear doors work right eith right indicator.
    Question.
    Can I use ross- tech to change samething that right door open in ”door openpanel”.
    Please post a full unedited VCDS Auto-Scan so we can see how this B7 A4 is equipped.
  3. Likes Uwe liked this post
    New User
    Nov 2019
    Wednesday,06,November,2019,21:43:57:43728
    VIN: WAUZZZ8E86A127192   License Plate:
              67 69 75 76 77
    VIN: WAUZZZ8E86A127192   Mileage: 171410km-106509miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 8E0 910 401 E    HW: 8E0 907 401 AJ
       Component: 3.0L V6TDI  G000SG  0030
       Revision: --H01---    Serial number:
       Coding: 0011911
       Shop #: WSC 67849 150 85095
       VCID: 211FE2B64DC3470FE69-8074
    8 Faults Found:
    005491 - Left Engine Mount Solenoid Valve (N144)
                   P1573 - 001 - Open Circuit
                        Fault Status: 01110001
                        Mileage: 171284 km
                        RPM: 756 /min
                        Torque: 27.3 Nm
                        Voltage: 12.16 V
                        Bin. Bits:        0
                        Bin. Bits:        0
                        Bin. Bits:        0
    005658 - Glowplug for Cylinder 1 (Q10)
                   P161A - 001 - Open Circuit
                        Mileage: 171299 km
                        RPM: 924 /min
                        Torque: 117.0 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 14.67 V
                        Duty Cycle: 24.5 %
                        Temperature: 1.8°C
    005659 - Glowplug for Cylinder 2 (Q11)
                   P161B - 001 - Open Circuit
                        Mileage: 171299 km
                        RPM: 924 /min
                        Torque: 117.0 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 14.67 V
                        Duty Cycle: 24.5 %
                        Temperature: 1.8°C
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 001 - Open Circuit
                        Mileage: 171299 km
                        RPM: 924 /min
                        Torque: 117.0 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 14.67 V
                        Duty Cycle: 24.5 %
                        Temperature: 1.8°C
    005661 - Glowplug for Cylinder 4 (Q13)
                   P161D - 001 - Open Circuit
                        Mileage: 171299 km
                        RPM: 924 /min
                        Torque: 117.0 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 14.67 V
                        Duty Cycle: 24.5 %
                        Temperature: 1.8°C
    005662 - Glowplug for Cylinder 5 (Q15)
                   P161E - 001 - Open Circuit
                        Mileage: 171299 km
                        RPM: 924 /min
                        Torque: 117.0 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 14.67 V
                        Duty Cycle: 24.5 %
                        Temperature: 1.8°C
    005663 - Glowplug for Cylinder 6 (Q15)
                   P161F - 001 - Open Circuit
                        Mileage: 171299 km
                        RPM: 924 /min
                        Torque: 117.0 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 14.67 V
                        Duty Cycle: 24.5 %
                        Temperature: 1.8°C
    004120 - Intake Manifold Runner (Bank 2)
                   P1018 - 001 - Lower limit not reached - Intermittent
                        Fault Status: 00100001
                        Mileage: 171376 km
                        Torque: 0.0 Nm
                        Voltage: 12.46 V
                        Duty Cycle: 20.5 %
                        Duty Cycle: 88.8 %
                        Duty Cycle: 20.5 %
    Address 03: ABS Brakes        Labels: 8E0-910-517.clb
       Part No SW: 8E0 910 517 E    HW: 8E0 614 517 AL
       Component: ESP8 quattro    H05 0120
       Coding: 0004425
       Shop #: WSC 06325 000 00000
       VCID: 290FFA9635F38F4FBE9-807C
       Part No: 8E0 820 043 BM
       Component:   A4 Klimaautomat   2832
       Coding: 00000
       VCID: 6D87CE86C48B536F121-50D0
    Address 09: Cent. Elect.        Labels: 8E0-907-279-8EC.lbl
       Part No: 8E0 907 279 L
       Component: int. Lastmodul  ECE 0504
       Coding: 11021
       Shop #: WSC 65536
       VCID: 3B2330DECA7F0DDFDC5-4AA4
    Address 15: Airbags        Labels: 8E0-959-655-94.lbl
       Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
       Component:    Airbag 9.41  H11 3530
       Revision: 91H1135    Serial number: 0036M0084N8V
       Coding: 0033622
       VCID: 3B2330DECF6F0DDFDC5-806E
       Subsystem 1 - Serial number: 6332DRB40255D2A9T
       Subsystem 2 - Serial number: 6342DRB40255CE28W
       Subsystem 3 - Serial number: 6352ARB400A16453B
       Subsystem 4 - Serial number: 6362ARB400AF6690T
       Subsystem 5 - Serial number: 63729RB400BDF06D+
       Subsystem 6 - Serial number: 63829RB400BDF016U
    01284 - Side Airbag; Drivers Side; Disabled
                        Fault Priority: 8
       Part No: 8E0 953 549 Q
       Component: Lenksáulenmodul     0601
       Coding: 04042
       Shop #: WSC 06325
       VCID: 41DF4236A893670F869-4AA4
    01301 - Control Module for Voice Recognition (J507)
    Address 17: Instruments        Labels: 8E0-920-9xx-8EC.lbl
       Part No SW: 8E0 920 931 P    HW: 8E0 920 931 P
       Component: KOMBI+WFS 4     H12 0110
       Revision: 0110        Serial number: 00000000000000
       Coding: 0005001
       Shop #: WSC 75264 512 00000
       VCID: 353726E6E95BDBAF2A1-50F4
    Address 18: Aux. Heat        Labels: 8E0-265-105.lbl
       Part No: 8E0 265 105 G
       Component: Standheizung Diesel 0316
       Coding: 00111
       Shop #: WSC 06325
       VCID: 270BFCAE26C7B93FA8D-513C
    Address 25: Immobilizer        Labels: 8E0-920-9xx-8EC.lbl
       Coding: 0005001
    Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
       Part No SW: 8E0 035 192 D    HW: 8E0 035 192 D
       Component: RNS-E HIGH EU   H70 0550
       Revision:      01S    Serial number: AUZBZ7E1121538
       Coding: 0301715
       VCID: 2517F6A659CBAB2F9A1-5160
    Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
       Part No: 8E0 951 177
       Component: Innenraumueberw.   0804
       Coding: 00001
       VCID: 6B83C09EFA9F5D5F0C5-508A
       Part No: 8E0 959 433 CA
       Component: Komfortgerát T3B    3332
       Coding: 06911
       Shop #: WSC 06335
       VCID: 72BDDDFADDB58C97CF3-4AA4
       Subsystem 1 - Part No: 8E1959801H
       Component: Tőrsteuer.FS BRM 0506
       Subsystem 2 - Part No: 8E1959802B
       Component: Tőrsteuer.BF BRM 0205
       Component: Tőrsteuer.HL BRM 0606
       Component: Tőrsteuer.HR BRM 0606
       Part No SW: 4F0 910 357 E    HW: 4F0 907 357 E
       Component: AFS 1           H01 0010
       Coding: 0000019
       VCID: 2809FF922EF9B647A17-807C
       Subsystem 1 - Part No: 8E0 941 329
       Component: AFS-Modul links H03 0020
       Subsystem 2 - Part No: 8E0 941 329
       Component: AFS-Modul rechtsH03 0020
    Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
       Coding: 0301715
    Address 76: Park Assist        Labels: 8E0-919-283-8EC.lbl
       Part No SW: 8E0 919 283 D    HW: 8E0 919 283 D
       Component: Parkhilfe 4-Kan H06 0010
       Revision: 00H06000    Serial number: 00067802020528
       Coding: 0010014
       VCID: 313F12F61D03F78F769-5184
                        Reset counter: 142
       Part No SW: 8P0 862 335 C    HW: 8P0 862 335 C
       Component: FSE_255x BT     H18 0160
       Revision: 00000001    Serial number: 00000000329378
       Coding: 0011811
       VCID: 363521EAF45DD0B723B-50D0
                        Reset counter: 23
                        Time Indication: 15
    End----------(Elapsed Time: 04:58, VBatt start/end: 12.4V/12.4V)-----------
    It looks like your CCM is coded for RHD. Try changing its coding from 06911 to 06783.
  6. Likes PetrolDave liked this post
    New User
    Nov 2019
    Now have to say that I am so green rookie that I dont know where to change it , i have own rosstech so long period, 3 days ,
    Oct 2017
    Northwest UK
    Coding: 06911
    Open this module.
    Change 06911 to 06783. Save it.
  9. Likes Uwe liked this post
  10. #7
    [Select]
    [46-Cent. Conv]
    [Coding]
    It will look something like this:
    The change will be done in the field labelled "Software Coding"
  11. #8
    New User
    Nov 2019
    Thanks it works now its right door open.
    Hmm..... but not ready yet, is there somewhere in internet place where I can see with vincode, what all functions has been in my car when it was new ?
    One thing is which I like to change next is automatic door lockong system, when I speed 20km/h all doors locks and that has not been there and I dont like that. We dont need that in forest Finland
  12. #9
    Quote Originally Posted by KajFinland View Post
    Subtract 32 from the existing coding in the Central Convenience module. So if your coding is now 06783, change it to 06751.
  13. #10
    This link to the Ross-Tech wiki page for the B7 may be helpful http://wiki.ross-tech.com/wiki/index...riolet_(8E/8H)
  14. Likes Uwe liked this post
