Results 1 to 3 of 3
Thread: 2014 Bentley Continental GT ACC Calibration
    Nov 2019
    Knoxville, TN
    Good Morning everyone,
    I am currently working on a 2014 Bentley, and the customer hit a bump in the road, knocking the ACC (adaptive cruise control) radar out of its holder. I have corrected the mechanical issue, and now have to calibrate it. I have found the process to calibrate it through VCDS, but I need the security access code to enter the system. Does any one know of the code I can use to proceed? I do understand that these radars are very sensitive, and could possibly be damaged due to the hit, but I want to first attempt calibration, before deeming the radar inoperable. I have included a full autoscan, in which there is a code for misalignment of the radar. Thanks in advance!
    Chassis Type: ZA-BY62 (6N0)
    Scan: 01 02 03 05 06 07 08 09 13 15 16 17 19 23 26 2E 34 36 37 38
              46 47 53 56 65 68 6C 71 76 77
    VIN: SCBGT3ZA9EC088140   Mileage: 49330km-30652miles
    68-Wiper Electr. -- Status: OK 0000
    71-Battery Charger -- Status: OK 0000
    Address 01: Engine (------CMMC)       Labels: None
       Part No SW: 4W0 906 560 A    HW: 079 907 309
       Component: 4.0l V8TFSI / H57 0001
       Revision: NFH57---    Serial number: VWX3Z0M7006167
       Coding: 252A00126566000E0001
       Shop #: WSC 00083 790 00189
       ASAM Dataset: EV_ECM40TFS0114W0906560A 001003
       ROD: EV_ECM40TFS0114W0906560A.rod
       VCID: 362036C68952F9FF73-8062
    4330 - Function Restriction due to Faults in Other Modules
              U1113 00 [047] - -
                        Mileage: 49331 km
                        Date: 2019.11.01
                        Time: 14:27:05
                        Engine speed: 650.50 /min
                        Normed load value: 7.1 %
                        Coolant temperature: 99 C
                        Intake air temperature: 57 C
                        Voltage terminal 30: 13.970 V
                        Engine status: COENG_RUNNING
                        Engine oil temperature: 92.9 C
                        Engine operating condition-Channel 87: Idling
                        Relative load value: 19.41 %
                        Current system status: SYC_DRIVE
                        Time since ignition off: 9421 s
                        Engine torque: 71.3 Nm
    Readiness: 1110 0101
    Address 02: Auto Trans (J217)       Labels:| 0CM-325-025.clb
       Part No SW: 3W0 927 158 A    HW: 0CU 927 760 A
       Component: OBL 40TFSIUSA H16 0001
       Revision: --H16---    Serial number:
       Coding: 000002
       ASAM Dataset: EV_TCMAL450211 002010
       ROD: EV_TCMAL450211_BY62.rod
       VCID: 3B3627F2B27024978C-806E
    Address 03: ABS Brakes        Labels: None
       VCID: 55E2914AB814D2E79A-8000
    No Faults Found
       Part No SW: 3D0 909 137 G    HW: 3D0 909 137 G
       Component: 7B Kessy            6850
       Revision: 00H24072    Serial number: VWX3Z0M7006167
       Coding: 0405741
       VCID: 2B1617B28E10B4171C-807E
       Part No SW: 4W0 959 760     HW: 4W0 959 760
       Component: MEM-BFS       H04 0600
       Revision: AA000000    Serial number: 00000060018275
       Coding: D01A1B2485A70000090001010101000000212727000000
       Shop #: WSC 00083 790 00242
       VCID: 7F4E13E2EAE8F8B7E0-802A
    Address 07: Control Head        Labels: 3D0-907-048.clb
       Part No SW: 3D0 907 048     HW: 3D0 907 048
       Component: J127 KBT vorn       0100
       Revision: ABH15001    Serial number: VWZ6Z7N0146006
       VCID: 6386BF92A6403C57E4-8036
    Address 08: Auto HVAC        Labels: 3W7-907-040.clb
       Part No: 3W7 907 040 D
       Component: Climatronic BY625   3030
       Coding: 0001101
       VCID: 393A3DFA744C16879E-806C
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 Q    HW: 3D0 937 049 Q
       Component: J519                7700
       Revision: -4007---    Serial number: --------------
       Coding: 40820000AB2A11800508030000000000
       VCID: 383C38FE4F460F8F61-806C
    Address 13: Auto Dist. Reg        Labels: None
       Part No SW: 4W0 907 567     HW: 4W0 907 567
       Component: AC201  NAR BY685   00931
       Revision: 00041000    Serial number: 00000000588539
       Coding: 0020685
       Shop #: WSC 00083 790 00206
       VCID: 7DB2E9EA20E4EAA7F2-8028
    00234 - Sensor for Automatic Distance Regulation Misadjusted
                003 - Mechanical Failure
                        Fault Status: 01100011
                        Reset counter: 156
                        Mileage: 49331 km
                        Date: 2019.11.07
                        Time: 10:03:16
                        Count: 117
    Address 15: Airbags        Labels: None
       Part No SW: 3W3 959 655     HW: 3W3 959 655
       Component: 31 Airbag 9.43  H04 0050
       Revision: 93H04005    Serial number: 003FV000DTNS
       Coding: 0013105
       VCID: 04449C0E430E9B6FBD-8050
       Subsystem 1 - Part No: 3W7 959 339 C
       Component: BF-Gewichtsens. H03 0101
       Subsystem 2 - Serial number: 021EY
       Subsystem 3 - Serial number: 0001.01.0000H030000000000063
       Subsystem 4 - Serial number: 0000006332DRB40F258816S63
       Subsystem 5 - Serial number: 58816S6342DRB40F245323I63
       Subsystem 6 - Serial number: 45323I63528RB406E809D4Y63
       Subsystem 7 - Serial number: 809D4Y63628RB406E802B1N63
       Subsystem 8 - Serial number: 802B1N63747RB406D698EEA63
       Subsystem 9 - Serial number: 698EEA63847RB406EE7304W
       Subsystem 10 - Serial number: E7304W
       Part No: 7L6 953 549 L
       Component: J527                3601
       Coding: 0000242
       VCID: 48DC483E3FA67F0F11-801C
    Address 17: Instruments        Labels: 3Wx-920-xxx-17.lbl
       Part No SW: 3W0 920 851 L    HW: 3W0 920 851 L
       Component: J285 KOMBI-INST.    3925
       Revision: KPH10V02
       Coding: 0042214
       Shop #: WSC 11685 002 1048576
       VCID: 3FCE53E26E6838B7A0-806A
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3W0 920 851 L
       Component: J533  GW-K-CAN TP20 3925
       Coding: DFF3FFAEEB0D5700
       VCID: 70ACC0DE63B697CF69-8024
    Address 23: Brake Booster        Labels: None
       Part No: 3W0 907 563 B
       Component: BREMSBOOSTER    007 0430
       Revision: 00007000    Serial number: 00000000026572
       VCID: 3A3822F6714A1D9F97-806E
    Address 26: Auto Roof        Labels: 3W7-959-255.clb
       Part No: 3W7 959 255 B
       Component: J256  VSG BY615     1717
       Revision: 00017000    Serial number: 00000007500009
       Shop #: WSC 00083 790 00205
       VCID: 46C0460635B2697FE3-8012
       Revision: A1001003    Serial number: 7664802678
       Coding: 030100
       Shop #: WSC 00083 790 00191
       VCID: 2B1617B24A10B4171C-807E
    Address 34: Level Control        Labels: 3Wx-907-553-34.clb
       Part No: 3W7 907 553 E
       Component: LUFTFDR.-CDC- 3C3V0 7606
       Coding: 0005521
       VCID: 43C65F1206805C57C4-8016
       Component: MEM-FS        H04 0600
       Revision: AA000000    Serial number: 00000060034108
       Coding: D01A1B2485A70000090001010101010000212727000000
       Shop #: WSC 00083 790 00236
    01882 - Lumbar Support Fore / Aft Adjustment Button (E336); Forward
                        Fault Status: 00100011
                        Reset counter: 162
                        Mileage: 46319 km
                        Date: 2019.04.27
                        Time: 10:25:10
    01881 - Lumbar Support Height Adjustment Button (E335); Down
                        Reset counter: 162
                        Mileage: 46319 km
                        Date: 2019.04.27
                        Time: 10:25:10
    Address 37: Navigation (J0506)       Labels: None
       Part No SW: 3W0 035 017 L    HW: 3W0 035 017 L
       Component: RNS-MID       H15 0520
       Revision: AB001001    Serial number: VWZ6Z7N0146006
       Coding: 04010002000000044000
       VCID: 362036C68152F9FF73-8062
       Subsystem 1 - Part No: 3W0 919 859 BE
       Component: NAR V3.1  7921
    00862 - Antenna for GPS Navigation (R50/R52)
                        Fault Status: 00100111
                        Reset counter: 196
                        Mileage: 47758 km
                        Date: 2019.09.12
                        Time: 09:36:39
    Address 38: Roof Electronics        Labels: None
       Part No: 3W0 907 135 G
       Component: Dachmodul           0803
       Coding: 0006077
       Shop #: WSC 00083 790 00214
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 P
       Component: GS HSG              8136
       Coding: 0000040
       Shop #: WSC 00083 790 00211
       VCID: 3D3229EA65642AA7B2-4B1E
       Subsystem 1 - Part No: 3W7 959 701 B
       Component: Tuersteuergeraet FS 1108
       Subsystem 2 - Part No: 3W7 959 702 B
       Component: Tuersteuergeraet BF 1108
       Subsystem 3 - Part No: 3W7 959 703 E
       Component: Tuersteuergeraet HL 0804
       Subsystem 4 - Part No: 3W7 959 704 E
       Component: Tuersteuergeraet HR 0804
       Subsystem 5 - Part No: 3W3 909 610
       Component: 25 HDSG             1811
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    00941 - Exterior Mirror Retract Motor; Driver Side (V121)
    Address 47: Sound System        Labels: None
       Part No SW: 3W7 035 465 A    HW: 3W7 035 465 A
       Component: DSP 8 Channel       0050
       Revision: 00H07001    Serial number: 75811000513805
       VCID: 393A3DFA704C16879E-806C
    Address 53: Parking Brake
    Address 56: Radio (J0506)       Labels: None
                        Reset counter: 196
                        Mileage: 47758 km
                        Date: 2019.09.12
                        Time: 09:36:39
    Address 65: Tire Pressure        Labels: None
       Part No SW: 3W7 907 273 C    HW: 3W7 907 273 C
       Component: J0502 RDK           0006
       Revision: 0004 006    Serial number: 00000900003205
       Coding: 0000604185BB63B8EE43BB0076FF0065FF004B6E4B6E4B6E4B6E4B6E
       Shop #: WSC 00083 790 00209
       VCID: 40CC501E1796474FD9-8014
    Address 68: Wiper Electr.        Labels: 3Wx-955-023.clb
       Part No: 3W1 955 023 L
       Component: Wischermodul       0401
       Shop #: WSC 00000 725 65552
       VCID: 3FCE53E26A6838B7A0-806A
       Part No SW: 3W3 907 441 C    HW: 3W3 907 441 C
       Revision: 00H12000    Serial number: 525 PA8J350357
       Coding: 2020002
    Address 71: Battery Charger (J367)       Labels:* None
       Part No SW: 3W3 915 181 A    HW: 3W3 915 181 A
       Component: EMM Batt Man  H04 0570
       Serial number: 0000000001
       Coding: 1E0100
       Shop #: WSC 61486 000 1048576
       ASAM Dataset: EV_BatteChargVaria1 002019
       ROD: EV_BatteChargVaria1_002.rod
       VCID: 373E3BC28E5800F768-8062
       Part No SW: 3W0 919 283 G    HW: 3W0 919 283 E
       Component: J446  ST Parkhilfe  0111
       Revision: 11H02001    Serial number: 58131313600283
       Coding: 0300056
       VCID: 41CA551A1C9C4E47D6-8014
       Part No SW: 3D0 035 730 B    HW: 3D0 035 730 B
       Component: Telefon       012 0825
       Revision: --------    Serial number: 35909603569306
       Coding: 020105000100010000000000
       ASAM Dataset: EV_UHVPremi A02705
       ROD: EV_UHVPremi_A02.rod
       VCID: 1B76C77212B044976C-804E
    End----------(Elapsed Time: 02:21, VBatt start/end: 14.6V/14.6V)-----------
    Oct 2017
    Northwest UK
    You need to have the calibration board and equipment to properly calibrate. My advice is to take the car to a VW dealer or a third party garage who does ADAS calibration.
  3. Likes Uwe liked this post
    16.4905 S, 151.7375 W
    Based on some research, there does not appear to be any Security Access code needed for the Adaptation Channel that is used to relearn the ADR(Automatic Distance Regulation) Sensor.
    You mentioned you "found the process to calibrate it through VCDS", could you elaborate on this a bit more? Is this a procedure or a "test plan"? Tell us more....
    And yes, I agree with myounus "You need to have the calibration board and equipment to properly calibrate" - due to the fact that if the adjustment is off, you have 2 1/2 tons of vehicle that could be incorrectly calibrated, traveling at highway speeds!
    Thanks,
    drpeter
  5. Likes Uwe liked this post
