Results 1 to 10 of 13
Thread: Folding Mirrors With Keyfob Audi Q3
    Nov 2014
    Hi everyone, I have a gentleman who would like his mirrors to fold in when he locks his car with the keyfob. Car is an Audi Q3 2015. How would I go about doing this? I have never done anything like this with VCDS before so any help would be greatly appreciated. Thanks
    Not all cars have the hardware required to implement this. Please post an Auto-Scan so people can see how this one is equipped.
    Nov 2014
    I will have to wait until I can get the car back before I can post a scan. The mirrors fold in from the inside of the car so I believe the module should support them folding in with the keyfob.
    Feb 2018
    As Iam right there are Gen3 Door ECU inside, so there´s no possibility with VCDS
    Nov 2014
    Hi everyone, here is the autoscan of the audi q3. Thanks
    Friday,08,November,2019,10:42:20:63801
    VCDS Version: 19.6.2.0 (x64)
    VIN: WAUZZZ8U4FR018253   License Plate:
    Mileage: 70860km-44030mi   Repair Order:
    Chassis Type: 8U-AU21 (8U0)
    Scan: 01 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 55 5F 62 72
    VIN: WAUZZZ8U4FR018253   Mileage: 70860km-44030miles
    55-Headlight Range -- Status: Sporadic communication error 1000
    Address 01: Engine (J623-CUVC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 016 BF    HW: 04L 907 309 K
       Component: R4 2.0l TDI   H20 2911
       Revision: 8AH20---
       Coding: 01190032043701080000
       Shop #: WSC 27915 002 1048576
       ASAM Dataset: EV_ECM20TDI01104L906016BF 004002
       ROD: EV_ECM20TDI01104L906016BF_004.rod
       VCID: 6ED812D6B16E3C3F45-803A
    9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
              P2209 00 [096] - Implausible Signal
                        Mileage: 70605 km
                        Date: 2019.11.05
                        Time: 09:27:43
                        Engine speed: 1927.00 /min
                        Normed load value: 68.6 %
                        Vehicle speed: 29 km/h
                        Coolant temperature: 93 °C
                        Intake air temperature: 57 °C
                        Voltage terminal 30: 13.240 V
                        Unlearning counter according OBD: 28
                        NOx sens.dwnstrm.SCR cat conv: NOx conc.: 0 ppm
                        NOx sensor before SCR cat conv: NOx concentration: 17 ppm
                        NOx sens. dwnstrm. of SCR cat.: target heat. temp reached-Bits 0-7: 0
                        NOx sensor after SCR catalytic converter: supply voltage: 0 mV
                        NOx sensor before SCR catalytic converter: supply voltage: 12640 mV
                        Extern.temp.sens.1 bank 1: raw value: 7.5 °C
                        Mean injection quantity: 14.21 mg/stroke
    Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
       Part No SW: 5N0 614 109 CA    HW: 5N0 614 109 CA
       Component: ESC-EBC460iV1 H08 0004
       Serial number: A00QH6F
       Coding: 21F124A1C921E3742079840524C693C704355700508B4884
       Shop #: WSC 00049 770 00152
       ASAM Dataset: EV_Brake1ESCEPBTRW 003039
       ROD: EV_Brake1ESCEPBTRW_003.rod
       VCID: 6CDC18DE8772CE2F6B-8038
    0763 - Tire Pressure Warning
              C102D 00 [008] - -
                        Reset counter: 230
                        Mileage: 54067 km
                        Date: 2019.03.22
                        Time: 17:09:55
                        Additional_Codes: 1E FF 00 0D 6E 7F 00 48 02
                        DTC: 00 02 FB
                        Additional2: 00 03 01 08 05 22 A7 00 A7 00
       Part No SW: 8U0 820 043 F    HW: 8U0 820 043 F
       Component: E87  Klimavoll      0210
       Revision: 00H05000    Serial number: 8U0820043F
       VCID: 346CC0BE57C256EF73-8060
    01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
                        Fault Status: 00101010
                        Reset counter: 212
                        Mileage: 70582 km
                        Date: 2019.11.04
                        Time: 11:10:26
                        Voltage: 14.50 V
                        (no units): 255.0
                        Temperature: 9.0°C
    01809 - Actuating Motor for Temperature Flap; Left (V158)
                        Fault Status: 00100011
                        Reset counter: 212
                        Mileage: 53240 km
                        Date: 2019.03.10
                        Time: 15:28:19
                        Voltage: 14.40 V
                        Temperature: 17.5°C
                        (no units): 207.0
                        (no units): 152.0
                        Temperature: 4.5°C
    Address 09: Cent. Elect. (J519)       Labels:. 8X0-907-063.clb
       Part No SW: 8X0 907 063 AB    HW: 8X0 907 063 AB
       Component: BCM PQ35  M   113 0817
       Revision: AB113817
       Coding: 0E000A2CA805F1C0201849C80144094C43FF25AA006F912BE400878400C1
       Shop #: WSC 00049 770 00010
       VCID: 7CFC289EFF125EAFFB-8028
       Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS316 141203  H37 0090
       Serial number:         141215020408
       Coding: 0047F7
       Serial number: 23648554
       Coding: 02006E
       Subsystem 3 - Part No: 8X0 951 177 A
       Component: Sensor, DWA 0  005 0002
    Address 10: Park/Steer Assist (J791)       Labels:* None
       Part No SW: 8U0 919 475 B    HW: 4H0 919 475 E
       Component: PARKHILFE PLA H06 0060
       Revision: --------    Serial number: 56231436300185
       Coding: 181208
       Shop #: WSC 00049 770 00116
       ASAM Dataset: EV_EPHVA2CAU3160000 003004
       ROD: EV_EPHVA2CAU3160000_003.rod
       VCID: 42809666D576E85FF1-8016
    Address 15: Airbags (J234)       Labels:| 8X0-959-655.clb
       Part No SW: 8U0 959 655 C    HW: 8U0 959 655 C
       Component: AirbagVW-AU10 H09 0900
       Serial number: 003PAR0A8UL5
       Coding: 30523232333030303030554A305238553053
       ASAM Dataset: EV_AirbaAU10SMEAU316 001010
       ROD: EV_AirbaAU10SMEAU316_001.rod
       VCID: 47968772FE54CD7726-8012
       Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3496KSME536A7B34ZZZ2
       Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3506KSME160D0B34ZZZQ
       Serial number: 3516KSME16347834ZZZP
       Serial number: 3526KSME5E100B34ZZZS
       Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
       Serial number: 3555USME69566D32ZZZ9
    Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
       Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
       Component: LENKS.MODUL   016 0162
       Revision: FF010018    Serial number: 20150121101381
       Coding: 1084204000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 3D7AE59AAC8897A78C-8068
       Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
       Serial number: 16 01 2015  F0047887
    Address 17: Instruments (J285)       Labels:| 8X0-920-xxx-17.clb-SRI1
       Part No SW: 8U0 920 990 H    HW: 8U0 920 990 H
       Component: KOMBI_COLOUR  H02 0350
       Coding: 42CF01
       ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
    13639168 - Function Restricted due to Missing Message(s)
              U1111 00 [008] - -
                        Reset counter: 212
                        Mileage: 70582 km
                        Date: 2019.11.04
                        Time: 11:20:26
    Address 19: CAN Gateway (J533)       Labels: 8X0-907-468.clb
       Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
       Component: GAT 4CAN 1L M H13 0090
       Revision: 1P140041    Serial number: 4141P15124008A
       Coding: FBCF1A5A000108610353
       Shop #: WSC 28422 002 1048576
       VCID: 1122692AC89043C738-8044
       Component: J367-BDM  H07 0180
       Serial number: 32022931481491380295
       Serial number: 15015002935021200181
    01771 - Control Module for Headlight Range (J431)
                        Reset counter: 212
                        Mileage: 70582 km
                        Date: 2019.11.04
                        Time: 11:20:26
                        Bin. Bits:    11111
                        Voltage: 13.30 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 25.40 s
       Part No SW: 8U0 857 511 B    HW: 8U0 857 511 B
       Component: FLA           H03 0012
       Revision: AA002001
       Coding: 02020A64747464545425363E00
       VCID: 3A70EE86B5A6A09FA9-806E
       Part No SW: 0AY 907 554 J    HW: 0AY 907 554 J
       Component: Haldex4Motion H52 7522
       Serial number: HA1-00023.12.14
       Coding: 0001
       VCID: 52A0A626051678DF41-8006
       Component: IMMO          H02 0350
       Coding: 000002
       ASAM Dataset: EV_Immo_UDS_VDD_AU10 A04113
       ROD: EV_Immo_UDS_VDD_AU10.rod
    Address 42: Door Elect, Driver (J386)       Labels:. 8X0-959-793.clb
       Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
       Component: TSG FA        H11 0415
       Coding: 011806201C01000000
       VCID: 52A0A6260D1678DF41-8006
       Part No: 5N0 909 144 R
       Component: EPS_ZFLS Kl. 296    3501
       Revision: 00H22000
       VCID: 40849C6E137AFA4FE7-8014
    Address 52: Door Elect, Pass. (J387)       Labels:. 8X0-959-792.clb
       Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
       Component: TSG BF        H11 0415
       Coding: 011806201E01000000
       VCID: 51A2A92A081003C778-8004
       Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
       Serial number: 150124-0002-068
       Coding: 11C7A4101000A500
       ROD: EV_HeadlRegulBasic.rod
       VCID: 448C907ECF62E66FC3-8010
       Part No SW: 8U1 035 192 D    HW: 8U1 035 192 A
       Component: RMC Nav Plus  H61 0186
       Coding: 01010600024153470823020103010000000000
       VCID: 3668FAB681BE44FF4D-8062
       Subsystem 1 - Part No: 8X0 919 884 H
       Component: P28-50-14.06  0001
       Subsystem 2 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
       Component: DUBasic AU316  H42 0018
       Serial number: AUZ8ZDEM502QCB8
                        Reset counter: 225
                        Mileage: 70808 km
                        Date: 2019.11.07
                        Time: 13:32:01
                        Bin. Bits: 00000000 10000000
                        Bin. Bits: 00000000 00000000
       Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
       Component: TSG HL        H08 0415
       Coding: 010006200001000000
       VCID: 4FA6AF521E2415376E-801A
       Component: TSG HR        H08 0415
    End-------------------------(Elapsed Time: 03:16)--------------------------
    Nov 2014
    Looking at the modules, is it possible to get the mirrors to fold in the locking the car with the keyfob? or is this not supported? Thanks
  7. #7
    Nov 2014
    Customer is coming back sometime today to find out if it can be done, so if anyone knows that would be great. Thanks
  8. #8
    Feb 2018
    As I said, in my opinion you have to use VCP to edit EEPROM in Door ECU. VCDS can´t do this job
  9. #9
    Nov 2014
    Quote Originally Posted by nirvananils View Post
    My apologies I didnt quite understand what you said. Where do I get VCP and what is the cost? Thanks
  10. #10
    Mar 2017
    Vcp software can be downloaded fron the net , but i think the cable is pricey for the benefit off using the keyfob
