Friday,08,November,2019,10:42:20:63801
VCDS Version: 19.6.2.0 (x64)
VIN: WAUZZZ8U4FR018253 License Plate:
Mileage: 70860km-44030mi Repair Order:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 03 08 09 10 15 16 17 19 20 22 25 42 44 46 52 55 5F 62 72
VIN: WAUZZZ8U4FR018253 Mileage: 70860km-44030miles
55-Headlight Range -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CUVC) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 BF HW: 04L 907 309 K
Component: R4 2.0l TDI H20 2911
Revision: 8AH20---
Coding: 01190032043701080000
Shop #: WSC 27915 002 1048576
ASAM Dataset: EV_ECM20TDI01104L906016BF 004002
ROD: EV_ECM20TDI01104L906016BF_004.rod
VCID: 6ED812D6B16E3C3F45-803A
9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
P2209 00 [096] - Implausible Signal
Mileage: 70605 km
Date: 2019.11.05
Time: 09:27:43
Engine speed: 1927.00 /min
Normed load value: 68.6 %
Vehicle speed: 29 km/h
Coolant temperature: 93 °C
Intake air temperature: 57 °C
Voltage terminal 30: 13.240 V
Unlearning counter according OBD: 28
NOx sens.dwnstrm.SCR cat conv: NOx conc.: 0 ppm
NOx sensor before SCR cat conv: NOx concentration: 17 ppm
NOx sens. dwnstrm. of SCR cat.: target heat. temp reached-Bits 0-7: 0
NOx sensor after SCR catalytic converter: supply voltage: 0 mV
NOx sensor before SCR catalytic converter: supply voltage: 12640 mV
Extern.temp.sens.1 bank 1: raw value: 7.5 °C
Mean injection quantity: 14.21 mg/stroke
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CA HW: 5N0 614 109 CA
Component: ESC-EBC460iV1 H08 0004
Serial number: A00QH6F
Coding: 21F124A1C921E3742079840524C693C704355700508B4884
Shop #: WSC 00049 770 00152
ASAM Dataset: EV_Brake1ESCEPBTRW 003039
ROD: EV_Brake1ESCEPBTRW_003.rod
VCID: 6CDC18DE8772CE2F6B-8038
0763 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 230
Mileage: 54067 km
Date: 2019.03.22
Time: 17:09:55
Additional_Codes: 1E FF 00 0D 6E 7F 00 48 02
DTC: 00 02 FB
Additional2: 00 03 01 08 05 22 A7 00 A7 00
Part No SW: 8U0 820 043 F HW: 8U0 820 043 F
Component: E87 Klimavoll 0210
Revision: 00H05000 Serial number: 8U0820043F
VCID: 346CC0BE57C256EF73-8060
01841 - Potentiometer/Actuator for Temperature Flap; Left (G220)
Fault Status: 00101010
Reset counter: 212
Mileage: 70582 km
Date: 2019.11.04
Time: 11:10:26
Voltage: 14.50 V
(no units): 255.0
Temperature: 9.0°C
01809 - Actuating Motor for Temperature Flap; Left (V158)
Fault Status: 00100011
Reset counter: 212
Mileage: 53240 km
Date: 2019.03.10
Time: 15:28:19
Voltage: 14.40 V
Temperature: 17.5°C
(no units): 207.0
(no units): 152.0
Temperature: 4.5°C
Address 09: Cent. Elect. (J519) Labels:. 8X0-907-063.clb
Part No SW: 8X0 907 063 AB HW: 8X0 907 063 AB
Component: BCM PQ35 M 113 0817
Revision: AB113817
Coding: 0E000A2CA805F1C0201849C80144094C43FF25AA006F912BE400878400C1
Shop #: WSC 00049 770 00010
VCID: 7CFC289EFF125EAFFB-8028
Subsystem 1 - Part No SW: 8U2 955 119 HW: 8U2 955 119 Labels: 1KX-955-119.CLB
Component: WWS316 141203 H37 0090
Serial number: 141215020408
Coding: 0047F7
Component: G397_RLFS H06 0002
Serial number: 23648554
Coding: 02006E
Subsystem 3 - Part No: 8X0 951 177 A
Component: Sensor, DWA 0 005 0002
Address 10: Park/Steer Assist (J791) Labels:* None
Part No SW: 8U0 919 475 B HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0060
Revision: -------- Serial number: 56231436300185
Coding: 181208
Shop #: WSC 00049 770 00116
ASAM Dataset: EV_EPHVA2CAU3160000 003004
ROD: EV_EPHVA2CAU3160000_003.rod
VCID: 42809666D576E85FF1-8016
Address 15: Airbags (J234) Labels:| 8X0-959-655.clb
Part No SW: 8U0 959 655 C HW: 8U0 959 655 C
Component: AirbagVW-AU10 H09 0900
Serial number: 003PAR0A8UL5
Coding: 30523232333030303030554A305238553053
ASAM Dataset: EV_AirbaAU10SMEAU316 001010
ROD: EV_AirbaAU10SMEAU316_001.rod
VCID: 47968772FE54CD7726-8012
Subsystem 1 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3496KSME536A7B34ZZZ2
Subsystem 2 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3506KSME160D0B34ZZZQ
Serial number: 3516KSME16347834ZZZP
Serial number: 3526KSME5E100B34ZZZS
Subsystem 5 - Part No SW: 8U0 959 651 HW: 8U0 959 651
Serial number: 3555USME69566D32ZZZ9
Address 16: Steering wheel (J527) Labels:| 8X0-953-569.clb
Part No SW: 8X0 953 521 D HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0162
Revision: FF010018 Serial number: 20150121101381
Coding: 1084204000
ROD: EV_SMLSNGVOLWS.rod
VCID: 3D7AE59AAC8897A78C-8068
Subsystem 1 - Part No SW: 8U0 951 528 G HW: 8U0 951 528 G
Serial number: 16 01 2015 F0047887
Address 17: Instruments (J285) Labels:| 8X0-920-xxx-17.clb-SRI1
Part No SW: 8U0 920 990 H HW: 8U0 920 990 H
Component: KOMBI_COLOUR H02 0350
Coding: 42CF01
13639168 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 212
Mileage: 70582 km
Date: 2019.11.04
Time: 11:20:26
Part No SW: 8U0 907 468 AQ HW: 8U0 907 468 G
Component: GAT 4CAN 1L M H13 0090
Revision: 1P140041 Serial number: 4141P15124008A
Coding: FBCF1A5A000108610353
Shop #: WSC 28422 002 1048576
VCID: 1122692AC89043C738-8044
Component: J367-BDM H07 0180
Serial number: 32022931481491380295
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Serial number: 15015002935021200181
Reset counter: 212
Mileage: 70582 km
Date: 2019.11.04
Time: 11:20:26
Bin. Bits: 11111
Voltage: 13.30 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Part No SW: 8U0 857 511 B HW: 8U0 857 511 B
Component: FLA H03 0012
Revision: AA002001
Coding: 02020A64747464545425363E00
VCID: 3A70EE86B5A6A09FA9-806E
Part No SW: 0AY 907 554 J HW: 0AY 907 554 J
Component: Haldex4Motion H52 7522
Serial number: HA1-00023.12.14
Coding: 0001
VCID: 52A0A626051678DF41-8006
Component: IMMO H02 0350
Coding: 000002
ROD: EV_Immo_UDS_VDD_AU10.rod
Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb
Part No SW: 8X0 959 793 H HW: 8X0 959 793 H
Component: TSG FA H11 0415
Coding: 011806201C01000000
VCID: 52A0A6260D1678DF41-8006
Part No: 5N0 909 144 R
Component: EPS_ZFLS Kl. 296 3501
Revision: 00H22000
VCID: 40849C6E137AFA4FE7-8014
Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb
Part No SW: 8X0 959 792 H HW: 8X0 959 792 H
Component: TSG BF H11 0415
Coding: 011806201E01000000
VCID: 51A2A92A081003C778-8004
Part No SW: 8X0 907 357 E HW: 8X0 907 357 B
Serial number: 150124-0002-068
Coding: 11C7A4101000A500
ROD: EV_HeadlRegulBasic.rod
VCID: 448C907ECF62E66FC3-8010
Part No SW: 8U1 035 192 D HW: 8U1 035 192 A
Component: RMC Nav Plus H61 0186
Coding: 01010600024153470823020103010000000000
VCID: 3668FAB681BE44FF4D-8062
Subsystem 1 - Part No: 8X0 919 884 H
Component: P28-50-14.06 0001
Subsystem 2 - Part No SW: 8U0 919 603 A HW: 8U0 919 603 A
Component: DUBasic AU316 H42 0018
Serial number: AUZ8ZDEM502QCB8
Reset counter: 225
Mileage: 70808 km
Date: 2019.11.07
Time: 13:32:01
Bin. Bits: 00000000 10000000
Bin. Bits: 00000000 00000000
Part No SW: 8X0 959 795 C HW: 8X0 959 795 C
Component: TSG HL H08 0415
Coding: 010006200001000000
VCID: 4FA6AF521E2415376E-801A
Component: TSG HR H08 0415
End-------------------------(Elapsed Time: 03:16)--------------------------
