Golf Mk7 Front Assist unavailable
jj2910
C?ID=163032
Hi, after reading this forum for years its my first time post so go easy :-)
100 miles after VW fitting a new DSG box just out of warranty i get a front assist unavailable dash light come on. After a bit of googling i am not sure if its a radar unit fault or it needs calibration. Could one of you good fellows cast your eye over the scan and offer some advice?. i am not sure on the component protection error as the car has only ever had work done by VW. If i need to replace the radar unit i would prefer to source and fit myself and return to VW just for calibration. i am not keen on giving vw any more money than i need too.
 Tuesday,05,November,2019,15:07:48:20073
VIN: WVWZZZAUZHW030223   License Plate:
Mileage: 37313km-23185mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9
VIN: WVWZZZAUZHW030223   Mileage: 37313km-23185miles
Address 01: Engine (J623-CJXC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 F    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 091D00122466050B2004
   ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
   ROD: EV_ECM20TFS0205G0906259F.rod
   VCID: 313F16AFE1ADBC1F769-8064
17176 - Databus
          U1123 00 [047] - Received Error Message
                    Fault Frequency: 13
                    Mileage: 37277 km
                    Date: 2019.11.03
                    Time: 16:31:13
                    Coolant temperature: 60 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 11.855 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H54 4934
   Revision: 06454104    Serial number: TFK01806201553
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 53F37C27BB71AE0F245-8006
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61716000000907
   Coding: 01FA93A15423196C4779070241C66980C92A98E2E082967718425078C20803
   VCID: 7BA3F4877361864F9C5-802E
   Part No SW: 5G0 907 044 BL    HW: 5G0 907 044 BL
   Component: Climatronic   H04 1601
   Revision: 00001K08
   Coding: 00120004200110011005000000101022
   VCID: 72BDD9A3242BC707CF3-8026
   Air quality sensor:
   Part No SW: 5Q0 937 084 CL    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061617004541
   Coding: 03001A46C24122F30BA44080B11C07281000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 04518F7B0E9FF9B7EDF-8050
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    160527  042 0551
   Serial number:         160610123559
   Component: RLHS  037 0059
   Serial number: S2Y16M06D24H02M53S26
   Coding: 90A8DD
   Serial number: 000000000ZY1615128H6
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066144463
   Revision: --------    Serial number: 39331617005920
   Coding: 0071151011
   Shop #: WSC 59767 001 1048576
   VCID: 43D34C674B113E8F945-8016
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500478151FFC428949C8045000006
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: EV_ACCBOSCHVW416_001_VW37.rod
   VCID: 3B23348733E1464FDC5-806E
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Reset counter: 145
                    Mileage: 37277 km
                    Date: 2019.11.03
                    Time: 17:03:11
                    Control Module temperature: 16 °C
                    Voltage terminal 15: 14.5 V
          U1101 00 [009] - Active
          [FAULT_THP_EC_COUNTER]
                    Reset counter: 99
                    Mileage: 37277 km
                    Date: 2019.11.03
                    Time: 16:31:12
                    Control Module temperature: 19 °C
                    Voltage terminal 15: 11.8 V
2065 - Databus
          [FAULT_TSK_HANDSHAKE]
                    Reset counter: 144
                    Mileage: 37285 km
                    Date: 2019.11.04
                    Time: 08:27:02
                    Voltage terminal 15: 11.7 V
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    015 0388
   Serial number: 003MLR1VTSE4
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F5B009767799A6FB0D-802A
   Belt Pretensioner left:
   Serial number: 34169677D21061640703
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676D20061640112
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 35767000000CD5796B16
   Subsystem 4 - Part No SW: -----------    HW: 480 001 706 16
   Serial number: 35867000000474C49B1
   Subsystem 5 - Part No SW: -----------    HW: 480 401 406 16
   Serial number: 3516502B520FC4C261BH
   Subsystem 6 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 35265029F21160C4C166
   Subsystem 7 - Part No SW: -----------    HW: 480 401 806 16
   Serial number: 35565029D21160C4232
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160622401255
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB409727F95A6FF0D-806A
   Part No SW: 5G1 920 958 B    HW: 5G1 920 958 B
   Component: KOMBI         303 8311
   Coding: 27AD08082F80260001886B011400000000000000
   VCID: 303913ABEAA7B517797-8064
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005007183
   Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F79B766F817795F-8028
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0040
   Serial number: 29160001164350066233
   Coding: 2DFFFF
   Serial number: 2853020404
   Serial number: HA1-00018.05.16
   Coding: 0001
   VCID: 4ACD61436C3BEFC7573-801E
   Serial number: 080616EF820669
   Coding: 003F0220D001048000001000
   Subsystem 1 - Part No SW: 5Q0 959 812     HW: 5Q0 959 812   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000010440853
   Coding: 0D0000
   Coding: 8107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D31833CDB7F47C73-806E
   Serial number: 050616EF500429
   Coding: 003F0020DE01048000801000
   VCID: 42DD4963540B37879F3-8016
   Subsystem 1 - Part No SW: 5Q0 959 811     HW: 5Q0 959 811   Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000010521491
   Coding: 150000
   Coding: 02AE01000B000200
   VCID: 40D9436B5A072597897-8014
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0757
   Coding: 02730001FF00000051110101008808001F0207D601200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJU025B9
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 99
                    Mileage: 37277 km
                    Date: 2019.11.03
                    Time: 16:31:15
                    Voltage terminal 30: 11.8 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0001
   Serial number: 160506201324
   VCID: 2F3B10D7F799AAEF60D-807A
End----(Elapsed Time: 01:41, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Many Thanks,
J.
DrPeter
16.4905° S, 151.7375° W
The fault codes that are present in your Auto-Scan would indicate there is a concern with the J428-Adaptive cruise control unit, it's wiring/connections or it's components. You may want to have a visual inspection of the J428-Adaptive cruise control unit to be sure there are no obvious concerns.
Silly question, have you tried to clear all the fault codes? If so you maybe able to disconnect the battery for 30 minutes and then reconnect it, turn the ignition on and then try to clear all the fault codes.
Note : All three of these components are connected together with an Extended CAN-Bus and a Sensor fusion CAN-Bus connection, see the Official Factory Repair manuals and wiring diagrams for more information and where to check for possible wiring concerns as this is a little different than the normal CAN-Bus.
- J428 Adaptive cruise control unit
- J533 Data bus diagnosis interface
- R242 Front camera for driver assist systems
If the J428 is original to this vehicle, the "Component Protection" fault code can set if the J428 has lost communications with other vehicle controllers that provide the unique vehicle information that the J428 needs to make sure it has not been installed into a different vehicle.
You can install a new J428, it will need to go to the dealer for the proper calibration procedures.
Hope this helps,
drpeter
jj2910
C?ID=163032
Thanks for your reply. Prior to posting the auto scan i tried to clear the fault codes but they come back straight away. i also disconnected the battery but it was nowhere close to 30 minutes. initial inspection of the radar unit does not show anything obvious. I don't think this car (september 2016 Mk7 UK Golf) has the R242 camera as its definitely not part of the rear view mirror housing. i also noticed today that the mode button to select Eco, normal or race no longer works which i assume is the last fault showing on the autoscan. Is this a coincidence or is there anyway it could possibly be related? i will try disconnecting the battery for a longer period and then start looking for a 5Q0 907 561 G cruise control unit. i read somewhere that disconnecting the J428 unit from the extended can bus or removing power to it would need the unit to be re-calibrated even if its not physically moved. would that be correct?
thanks,
J.
DrPeter
I do not recall any mention of any calibrations of the J428 if the battery was disconnected. I do see the repair manual states the following:
Under the following conditions the Distance Regulation Control Module - J428- must be calibrated:
♦ Distance Regulation Control Module - J428- was removed and installed or replaced.
♦ The lock carrier service position was performed
♦ The lock carrier was removed and installed.
♦ The lock carrier was replaced
♦ The rear axle toe were replaced
So I think it is safe to disconnect the battery for a while. Also if there is no R242 Camera, the CAN-Bus appears to be the same.
drpeter
downtime
C?ID=280813
I would try dealer first to try and get this one removed :
                    Reset counter: 99
                    Mileage: 37277 km
                    Date: 2019.11.03
                    Time: 16:31:12
That will cause the radar to disconnect and cause a front assist unavailable error. New DSG mecha will require CP removal and most likely your dealer just forgot to do it ACC module. It is very hard for me to believe that the radar would be broken all of a sudden.
jj2910
C?ID=163032
It’s hard for me to believe as well. I emailed the service guy at the dealer soon after the light came on. They said they couldn’t see how it was related but were happy to investigate it for £85. With the drive mode button not working, the ACC and the component protection fault happening 100 miles after the gearbox being replaced does seem to be a bit odd... then again having the car serviced in warranty and then 300 miles later (4weeks out of warranty) it needs a new gearbox (at 20k miles) says it all. If it wasn’t for bad luck I wouldn’t have any ;-).
golfi_vend
Tartu, Estonia
C?ID=195131
If gearbox CP got removed without renewing other CP stuff then this is exactly how it happens.
There are few tpis about this for techs that do one and only one thing. Also FeC-s also tend to dissapear when renewing CP.
DV52
C?ID=194404
                    Reset counter: 99
                    Mileage: 37277 km
                    Date: 2019.11.03
                    Time: 16:31:12
hmm.........Yes, it's just indicative - but the difference between the mileage values on the autoscan date of production and the mileage value on the CP error suggests that this car doesn't travel far (i.e. 37 kms in 2 x days).
Plus the CP error in the hex13 module doesn't have a matching twin DTC in the CP master module (i.e. hex19) - which is real odd (I've seen this happen in hacked MIB units).
Not sure what it all means, but proper CP interrogation is only meant to happen after ignition switch-on (as I understand) and given that the hex13 module hasn't been changed it should have easily passed the routine challenge/response identity-check process on 3rd November 2019.
And, even if the module had an unfortunately timed hiccup when OP turned the ignition key on 3rd November 2019, the module should have re-established its legitimacy to be on the CAN network in a subsequent ignition cycle.
So, given the odd nature of these circumstances and notwithstanding the requirement for FAZIT connection in dealing with CP errors, (IMO) it's worth attempting to delete this DTC with VCDS (or try DrPeter's suggestion). It's an easy try and there is no downside and there is very little "downtime" -pun intended ;).
downtime
C?ID=280813
Good thinking again Don but unfortunately OP already tried clearing DTCs and wrote that they come back immediately.
DSG mecha and TCM seem to have more mastery touch to the cars systems as for example you can clear CAN installation info from DSG module.
So if ACC CP is matched somehow to both engine ECM and transmission TCM then naturally they’re not matching now and CP is triggered.
jj2910
C?ID=163032
Thanks all for the information and advise. Went back to the dealer who cleared the faults and “reset basic settings”. Not easy getting information from someone in service who doesn’t know an ass from an elbow. There was no charge and all is working again....for now.
Cheers,
J.
