Results 1 to 6 of 6
Thread: 98 Jetta AHU TDI: Engine Light & Limp Mode with electrical faults, N108, G70, EGR
    New User
    Nov 2019
    California, USA
    New user, looking to get verified. Have VCDS and codes to share for troubleshooting help.
    1998 VW Jetta, AHU TDI, 154K, engine light comes on about 10 seconds after start and car runs in limp mode.
    VIN: 3VWTL8AJ4AM644784
    Symptoms were a slow and intermittent onset, but are now always there.
    I did a physical inspection and replaced a couple old hoses off of the MAF sensor.
    I replaces a bad hose in the brain box years ago.
    Any help with probable causes of the codes below would be greatly appreciated.
    The car won't pass California SMOG in current condition.
    Thanks for looking!
    -Carnie
    Monday,04,November,2019,17:54:21:16662
    VCDS Version: 19.6.2.0 (x64)
    Chassis Type: 1H - VW Golf/Vento III (1992 > 1999)
    Scan: 01 02 03 08 12 15 25 41 56
    Address 01: Engine        Labels: 028-906-021-AHU.lbl
       Part No: 028 906 021 JB
       Component: 1,9l R4 EDC  G40SG  1457
       Coding: 00002
       Shop #: WSC 00066
       VCID: 58BF7A62B8527D8FBF-4AE8
    01269 - Commencement of Injection Valve (N108)
                31-10 - Open or Short to Ground - Intermittent
    00553 - Mass Air Flow Sensor (G70)
    00560 - Exhaust Gas Recirculation System
                17-10 - Control Difference - Intermittent
    Readiness: N/A
    Address 15: Airbags        Labels: 1J0-909-60x-VW3.lbl
       Part No: 1J0 909 603 T
       Component: AIRBAG VW3 -        V03
       Coding: 00084
       Shop #: WSC 00066
       VCID: 3A7BC0EA261E8F9FA9-4B00
                32-10 - Resistance Too High - Intermittent
    00532 - Supply Voltage B+
    End-------------------------(Elapsed Time: 02:17)--------------------------
    If it were mine, I'd start by check wiring diagrams to see if N108, G70 and the EGR system have anything in common, like a source of power or a ground.
    New User
    Nov 2019
    California, USA
    Uwe, good call. Looking through the manual, all 3 items are on the T68-68 pin connector. I'll look into cleaning that.
    N108 Cold Start Valve is on Ground 56
    G70 MAF Sensor is on Ground 56.
    N18 EGR Vacuum Regulator Solenoid Valve is on Ground 52.
    I'll get to work on those tomorrow. Thanks for the steerage.
    -Carnie
    New User
    Nov 2019
    California, USA
    I don't suppose anyone has a ground map that shows the physical locations of Ground 52 and Ground 56?
    I cleaned the ones under the battery tray.
    New User
    Nov 2019
    California, USA
    Success.
    I'm not sure exactly which one fixed it but after doing the following and clearing the codes, the check engine light is gone:
    1. Removed battery, battery tray, cleaned both ground lugs under the battery tray.
    2. Cleaned the ground lug on the passenger side of the engine under the 24 pin connector and coolant hoses. (Has 3 small wires)
    3. Removed the T-68, 68 pin connector from the ECU (all engine sensors are connected to this) cleaned pins with electrical contact cleaner, applied a contact enhancer, and lubricated seals with dielectric grease.
    4. Started engine. Check engine light was still present.
    5. Cleared codes.
    6. Started engine, drove a few miles. Still no check engine light.
    Ok, now off to get it smogged, quick before it comes back.
    -Carnie
    Quote Originally Posted by CarnieTDI View Post
    Check Readiness first!
