Results 1 to 5 of 5
Thread: 2008 Audi A6 C6 Allroad - Glow Plug light flashing, limp mode, won't start. Help?
    New User
    Nov 2019
    Lithuania
    Question 2008 Audi A6 C6 Allroad - Glow Plug light flashing, limp mode, won't start. Help?
    Asking for advice from experienced people.
    History: because of bad fuel quality and dirt in the tank i needed to change injectors and clean all fuel system (changed all 6 injectors, fuel filter, took out fuel tank, washed it, dried it, changed low pressure pump in the tank.) Coded injectors, did DPF emergency regeneration... all was fine at that point, engine performed perfectly, drove around 500 km.
    During one day trip there was a bumpy road and i hit one pit on asphalt in the highway - after around 30 seconds glow plug light started flashing and there was a huge loss in power. I stopped the car and switched off the engine, started again, it worked on idle for 5 seconds and suddenly engine has stopped.. after that it couldn't start trying multiple times, been pushing starter until battery started to die. (i had enough fuel in the tank and fuel was good quality since the repair).
    Here is the complete auto-scan:
    2008 Audi A6 Allroad 3.0TDI 171kW
    VIN: WAUZZZ4F78N......   Mileage: 317210km-197105miles
    Address 01: Engine        Labels: 059-907-401-ASB.clb
       Part No SW: 4F9 910 401 L    HW: 4F0 907 401 C
       Component: 3.0L V6TDI  G000AG  0010
       Revision: --H04---    Serial number:
       Coding: 0011372
       Shop #: WSC 66565 257 00032
       VCID: 2E58B939B989D63F05-807B
    005715 - Please check DTC Memory of ABS Controller
                   P1653 - 002 -  - Intermittent
                        Mileage: 316755 km
                        Date: 2019.11.01
                        Time: 17:03:19
                        Duty Cycle: 1.0 %
                        Voltage: 12.08 V
                        Bin. Bits: 00101000
                        Torque: 109.2 Nm
                        Bin. Bits: 00000100
    005658 - Glowplug for Cylinder 1 (Q10)
                   P161A - 001 - Open Circuit
                        Fault Status: 01100001
                        Mileage: 316767 km
                        Date: 2019.11.02
                        Time: 10:52:23
                        RPM: 924 /min
                        Torque: 136.5 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 13.83 V
                        Duty Cycle: 24.1 %
                        Temperature: 2.7∞C
    005660 - Glowplug for Cylinder 3 (Q12)
                   P161C - 001 - Open Circuit
                        Mileage: 316767 km
                        Date: 2019.11.02
                        Time: 10:52:23
                        RPM: 924 /min
                        Torque: 136.5 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 13.83 V
                        Duty Cycle: 24.1 %
                        Temperature: 2.7∞C
    005662 - Glowplug for Cylinder 5 (Q15)
                   P161E - 001 - Open Circuit
                        Mileage: 316767 km
                        Date: 2019.11.02
                        Time: 10:52:23
                        RPM: 924 /min
                        Torque: 136.5 Nm
                        Duty Cycle: 1.0 %
                        Voltage: 13.83 V
                        Duty Cycle: 24.1 %
                        Temperature: 2.7∞C
    004195 - Fuel Pressure Regulation
                   P1063 - 001 - Control Range Not Reached - MIL ON
                        Fault Status: 11110001
                        Mileage: 317207 km
                        Date: 2019.11.03
                        Time: 18:17:21
                        RPM: 1848 /min
                        Torque: 273.0 Nm
                        (no units): 5.0
                        Voltage: 13.91 V
                        Pressure: 475.7 bar
                        Duty Cycle: 42.6 %
       Part No SW: 4F5 910 156 C    HW: 09L 927 156 C
       Component: AG6 09L 3,0 TDI RdW 0020
       Revision: --H03---    Serial number:        4359852
       Shop #: WSC 02325 758 00200
       VCID: 28544F219B6D880FCF-807D
    005913 - Functionality limited due to Engine Control Module
                   P1719 - 000 -  - Intermittent
                        Mileage: 316755 km
                        Date: 2019.11.01
                        Time: 16:59:58
    Address 03: ABS Brakes        Labels: 4F0-910-517.clb
       Part No SW: 4F0 910 517 AB    HW: 4F0 614 517 R
       Component: ESP 8.0 quattro H05 0040
       Coding: 0000392
       VCID: 64CC1B11A7C52C6F23-8031
                        Reset counter: 81
                        Mileage: 316755 km
                        Date: 2019.11.01
                        Time: 16:16:15
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x0024
                        Hex Value: 0x0195
                        Hex Value: 0x00FF
       Component: FBSAUDIC6 ELV   H31 0230
       Revision: 09010701    Serial number: 10601500852478
       Coding: 0000131
       Shop #: WSC 40567 222 87330
       VCID: 63CE180DA2CB2B57DA-8037
       Subsystem 1 - Part No: 4F0 910 131 E
       Subsystem 2 - Part No: 4F0 910 220 K
       Component: FBSAUDIC6 IDG   H01 0053
       Part No SW: 4F0 910 732 A    HW: 4E0 035 729
       Component: Interfacebox    H43 4220
       Revision: 00000000    Serial number: 350HT077815553
       Coding: 0003002
       Shop #: WSC 02335 758 00200
       VCID: 21425205F857794788-8075
       Subsystem 2 - Serial number: 00000000840547
       Subsystem 3 - Serial number: 0120.08.070000000100010773ˇ
       Subsystem 4 - Serial number: 010773ˇ
                        Reset counter: 84
                        Mileage: 317208 km
                        Date: 2019.11.03
                        Time: 18:45:06
                        Bin. Bits:       10
       Part No SW: 4F0 910 043 A    HW: 4F1 820 043 AG
       Component: KLIMABETAETIGUNGH30 0020
       Revision: 00000053    Serial number: 00000030276610
       Coding: 0000278
       VCID: 1C3C63F1DF3554AF5B-8049
       Part No SW: 4F0 910 279 K    HW: 4F0 907 279
       Component: ILM Fahrer      H18 0250
       Coding: 0012122
       VCID: 3162A245A8B7C9C718-8065
       Subsystem 1 - Part No: 4F1 910 113 C  Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H05 0210
       Coding: 00064784
       Shop #: WSC 02335
       Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH13 0100
       Coding: 00146221
       Shop #: WSC 02335
       Part No SW: 4E0 910 110 C    HW: 4E0 035 110 A
       Component: MP3-Changer     H46 0350
       Revision: 00046006    Serial number: AUZ5ZBG3462549
       VCID: 18347FE12B0D388F7F-804D
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 42 AIRBAG AUDI8RH30 0280
       Revision: 09H30000    Serial number: 0037LD0THNE+
       Coding: 0013362
       VCID: 29524A258067B107D0-807D
       Subsystem 1 - Serial number: 6332CSME1A6A743EG
       Subsystem 2 - Serial number: 6342CSME16121571T
       Subsystem 3 - Serial number: 6352QSME3B0B3847O
       Subsystem 4 - Serial number: 6362QSME37784443I
       Subsystem 5 - Serial number: 63734SME38501A15Y
       Subsystem 6 - Serial number: 63834SME351B0C630
       Revision: 00H02000    Serial number: 90026072060157
       Coding: 0002042
       Shop #: WSC 02323 758 00200
       VCID: 27564C1D96738777C6-8073
       Part No SW: 4F0 910 930 C    HW: 4F0 920 933 J
       Component: KOMBIINSTR. M73 H21 0240
       Revision: 00700000    Serial number: 72U31FV87
       Coding: 7209158
       Shop #: WSC 28268 001 1048576
       VCID: 234E580DE24B6B579A-8077
    00532 - Supply Voltage B+
                        Reset counter: 84
                        Mileage: 317208 km
                        Date: 2019.11.03
                        Time: 18:45:00
       Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
       Component: J533__Gateway   H06 0060
       Revision: 00H06000    Serial number: 1100B0773180FC
       Coding: F751BE7F30020600
       Shop #: WSC 02334 758 00200
       VCID: 2D5ABE35B48FAD273C-8079
    Address 34: Level Control        Labels: 4F0-910-553.clb
       Part No SW: 4F0 910 553 A    HW: 4F0 907 553 A
       Component: J197 LUFTFEDER  H17 0060
       Serial number: 00619003690500
       Coding: 0000220
       VCID: 22405D09FD51625F91-8077
                        Fault Status: 00101101
                        Fault Frequency: 7
                        Reset counter: 81
                        Mileage: 316755 km
                        Date: 2019.11.01
                        Time: 16:14:57
       Part No SW: 4F0 910 793 P    HW: 4F0 959 793 P
       Component: TSG FA          H12 0230
       Revision: 00000000    Serial number: "ó
       Coding: 0003626
       Shop #: WSC 02327 758 00200
       VCID: 37769C5D46D317F756-8063
       Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
       Component: Komfortgeraet   H25 0200
       Revision: 02000025    Serial number: 01058729180000
       Coding: 3351281
       VCID: 3260AD49ADB1F2DF61-8067
    01505 - Bulb for Blinkers; Rear Right (M8)
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Reset counter: 44
                        Mileage: 313510 km
                        Date: 2019.07.30
                        Time: 16:03:31
    Address 47: Sound System (J525)       Labels: Redir Fail!
       Part No SW: 4F0 910 223 K    HW: 4F0 035 223 L
       Component: Amp.-ASK-RD   H07 0250
       Revision: S0900000
       Coding: 080001
       Shop #: WSC 02399 823 56573
       VCID: 2648411951799E7FFD-8073
       Component: ILM Beifahrer   H12 0100
       Revision:             Serial number: 00000000470735
       Coding: 0001103
       VCID: 5EB829F989A906BFF5-800B
       Part No SW: 4F0 910 793 P    HW: 4F0 959 792 P
       Component: TSG BF          H12 0230
       Revision: 00000000    Serial number: 6
       Coding: 0003626
       Part No SW: 4F0 910 801 C    HW: 4F0 907 801 A
       Component: EPB  CDEC0080   H04 0080
       Revision: --H04---
       Coding: 0000321
       Shop #: WSC 02324 758 00200
       VCID: 20445701F35D704F87-8075
       Part No: 8P0 907 357 H
       Coding: 0000004
       VCID: 3F86F47D6EE32FB79E-806B
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 L
       Revision: 00000000    Serial number: 384K/067624809
       Shop #: WSC 40995 222 98481
       Part No SW: 4F0 910 181 F    HW: 4F0 915 181 B
       Component: J0644 BEM       H12 0760
       Revision: 00000000    Serial number: 00000000013281
       VCID: 244C5B11E7456C6FE3-8071
       Component: von VA0  2708021438
       Coding: 344630393135313035442056413032373038303231343338
       Shop #: WSC 00000 384 00290
    02272 - Quiescent Current Stage 1
                        Mileage: 317212 km
                        Date: 2019.11.03
                        Time: 19:11:59
                        Mileage: 317212 km
                        Date: 2019.11.03
                        Time: 20:17:10
       Component: TSG HL          H21 0210
       Coding: 0003114
    Address 69: Trailer (J345)       Labels:. 4F0-907-383.clb
       Part No SW: 4F0 907 383 C    HW: 4F0 907 383 C
       Component: Anhaenger     H14 0080
       Revision: 2B002001    Serial number: 00000106002078
       Coding: 0103030000000000
       VCID: 2B5EB02D4A9BA31722-807F
    Address 6D: Trunk Elect.        Labels: Redir Fail!
       Part No SW: 4F9 910 591     HW: 4F9 827 851 F
       Component: ValeoHeckdeckel H24 0290
       Revision: --H24001    Serial number: E5030000B
       Shop #: WSC 98765 666 38354
       VCID: 6CDC73314F15642F6B-8039
       Subsystem 1 - Part No: 4F9 910 592
       Subsystem 3 - Serial number: RD03.08.07--H24001001B0086ˇ
       Subsystem 4 - Serial number: 1B0086ˇ
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0210
       Coding: 0003114
       Part No SW: 4F0 910 283 H    HW: 4F0 919 283 H
       Component: Parkhilfe 8-Kan H12 0080
       Revision: 00H12000    Serial number: 06330722501766
       Coding: 0211416
    End-------------------------(Elapsed Time: 03:25)--------------------------
    Sep 2016
    Riga, Latvia
    First of all post an full UNEDITED autoscan
    Second - watch/log fuel pressure in the rail while cranking.
  3. Likes Uwe liked this post
    Quote Originally Posted by MartinsX View Post
    His scan is close enough to complete for me to be OK with it.
    Sep 2016
    Riga, Latvia
    If scan is accepted by You, I have couple more suggestions for OP
  6. Likes Uwe liked this post
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Hi, solved problem yet?
    Have you checked wiring to "Fuel pressure regulating valve N276" and also "Fuel pressure sender G247", both situated on common rail, also the wiring to fuel HP pump.
    Use the VCDS, and monitor pressure, or more preferably attach a pressure gauge to the manifold (special fitting/adapter and suitable hose, please use equipment of sufficient pressure rating and correct threads, also be aware of the high pressure accumulated in the common rail, even after engine has stopped. This must not be underestimated, as serious injury and damage may likely occur, if not dealt with correctly.
    I suggest reading the Audi SelfStudyProgram 350, page 24 "Common Rail Fuel Injection System", this will give a better understanding of system, as well as sensors and their position. Although one should always use maintenance manual for repair/servicing.
    2nd thing, it seems like you might have a battery or regulator problem, might just be use of VCDS and scanning car without having a charger connected, but if you have issues with battery it would be worth checking battery condition as well as charging.
    Would be interesting to know how hard/severely the bump was.
    Regards
    Gremling
    Last edited by Gremling; 12-17-2019 at 04:10 AM. Reason: Grammar, spelling and update
  8. Likes Uwe liked this post
