Asking for advice from experienced people.
History: because of bad fuel quality and dirt in the tank i needed to change injectors and clean all fuel system (changed all 6 injectors, fuel filter, took out fuel tank, washed it, dried it, changed low pressure pump in the tank.) Coded injectors, did DPF emergency regeneration... all was fine at that point, engine performed perfectly, drove around 500 km.
During one day trip there was a bumpy road and i hit one pit on asphalt in the highway - after around 30 seconds glow plug light started flashing and there was a huge loss in power. I stopped the car and switched off the engine, started again, it worked on idle for 5 seconds and suddenly engine has stopped.. after that it couldn't start trying multiple times, been pushing starter until battery started to die. (i had enough fuel in the tank and fuel was good quality since the repair).
Here is the complete auto-scan:
2008 Audi A6 Allroad 3.0TDI 171kW
VIN: WAUZZZ4F78N...... Mileage: 317210km-197105miles
Address 01: Engine Labels: 059-907-401-ASB.clb
Part No SW: 4F9 910 401 L HW: 4F0 907 401 C
Component: 3.0L V6TDI G000AG 0010
Revision: --H04--- Serial number:
Coding: 0011372
Shop #: WSC 66565 257 00032
VCID: 2E58B939B989D63F05-807B
P1653 - 002 - - Intermittent
Mileage: 316755 km
Date: 2019.11.01
Time: 17:03:19
Duty Cycle: 1.0 %
Voltage: 12.08 V
Bin. Bits: 00101000
Torque: 109.2 Nm
Bin. Bits: 00000100
005658 - Glowplug for Cylinder 1 (Q10)
P161A - 001 - Open Circuit
Fault Status: 01100001
Mileage: 316767 km
Date: 2019.11.02
Time: 10:52:23
RPM: 924 /min
Torque: 136.5 Nm
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 24.1 %
Temperature: 2.7∞C
005660 - Glowplug for Cylinder 3 (Q12)
P161C - 001 - Open Circuit
Mileage: 316767 km
Date: 2019.11.02
Time: 10:52:23
RPM: 924 /min
Torque: 136.5 Nm
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 24.1 %
Temperature: 2.7∞C
005662 - Glowplug for Cylinder 5 (Q15)
P161E - 001 - Open Circuit
Mileage: 316767 km
Date: 2019.11.02
Time: 10:52:23
RPM: 924 /min
Torque: 136.5 Nm
Duty Cycle: 1.0 %
Voltage: 13.83 V
Duty Cycle: 24.1 %
Temperature: 2.7∞C
004195 - Fuel Pressure Regulation
P1063 - 001 - Control Range Not Reached - MIL ON
Fault Status: 11110001
Mileage: 317207 km
Date: 2019.11.03
Time: 18:17:21
RPM: 1848 /min
Torque: 273.0 Nm
(no units): 5.0
Voltage: 13.91 V
Pressure: 475.7 bar
Duty Cycle: 42.6 %
Part No SW: 4F5 910 156 C HW: 09L 927 156 C
Component: AG6 09L 3,0 TDI RdW 0020
Revision: --H03--- Serial number: 4359852
Coding: 0000001
Shop #: WSC 02325 758 00200
VCID: 28544F219B6D880FCF-807D
005913 - Functionality limited due to Engine Control Module
P1719 - 000 - - Intermittent
Mileage: 316755 km
Date: 2019.11.01
Time: 16:59:58
Address 03: ABS Brakes Labels: 4F0-910-517.clb
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Coding: 0000392
VCID: 64CC1B11A7C52C6F23-8031
Reset counter: 81
Mileage: 316755 km
Date: 2019.11.01
Time: 16:16:15
Hex Value: 0x0000
Hex Value: 0x02A2
Hex Value: 0x0024
Hex Value: 0x0195
Hex Value: 0x00FF
Component: FBSAUDIC6 ELV H31 0230
Revision: 09010701 Serial number: 10601500852478
Coding: 0000131
Shop #: WSC 40567 222 87330
VCID: 63CE180DA2CB2B57DA-8037
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 K
Component: FBSAUDIC6 IDG H01 0053
Address 07: Control Head Labels: 4F0-910-7xx-07-H.clb
Part No SW: 4F0 910 732 A HW: 4E0 035 729
Component: Interfacebox H43 4220
Revision: 00000000 Serial number: 350HT077815553
Coding: 0003002
Shop #: WSC 02335 758 00200
VCID: 21425205F857794788-8075
Component: Bedienteil MMIC6H01 0060
Subsystem 2 - Serial number: 00000000840547
Subsystem 3 - Serial number: 0120.08.070000000100010773ˇ
Subsystem 4 - Serial number: 010773ˇ
Reset counter: 84
Mileage: 317208 km
Date: 2019.11.03
Time: 18:45:06
Bin. Bits: 10
Part No SW: 4F0 910 043 A HW: 4F1 820 043 AG
Component: KLIMABETAETIGUNGH30 0020
Revision: 00000053 Serial number: 00000030276610
Coding: 0000278
VCID: 1C3C63F1DF3554AF5B-8049
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H18 0250
Coding: 0012122
VCID: 3162A245A8B7C9C718-8065
Subsystem 1 - Part No: 4F1 910 113 C Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0210
Coding: 00064784
Shop #: WSC 02335
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00146221
Shop #: WSC 02335
Part No SW: 4E0 910 110 C HW: 4E0 035 110 A
Component: MP3-Changer H46 0350
Revision: 00046006 Serial number: AUZ5ZBG3462549
VCID: 18347FE12B0D388F7F-804D
Address 15: Airbags Labels: 4F0-910-655-8R.clb
Part No SW: 4F0 910 655 E HW: 4F0 959 655 B
Component: 42 AIRBAG AUDI8RH30 0280
Revision: 09H30000 Serial number: 0037LD0THNE+
Coding: 0013362
VCID: 29524A258067B107D0-807D
Subsystem 1 - Serial number: 6332CSME1A6A743EG
Subsystem 2 - Serial number: 6342CSME16121571T
Subsystem 3 - Serial number: 6352QSME3B0B3847O
Subsystem 4 - Serial number: 6362QSME37784443I
Subsystem 5 - Serial number: 63734SME38501A15Y
Subsystem 6 - Serial number: 63834SME351B0C630
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0410
Revision: 00H02000 Serial number: 90026072060157
Coding: 0002042
Shop #: WSC 02323 758 00200
VCID: 27564C1D96738777C6-8073
Component: E0221 H02 0030
Part No SW: 4F0 910 930 C HW: 4F0 920 933 J
Component: KOMBIINSTR. M73 H21 0240
Revision: 00700000 Serial number: 72U31FV87
Coding: 7209158
Shop #: WSC 28268 001 1048576
VCID: 234E580DE24B6B579A-8077
00532 - Supply Voltage B+
Reset counter: 84
Mileage: 317208 km
Date: 2019.11.03
Time: 18:45:00
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 A HW: 4L0 907 468 B
Component: J533__Gateway H06 0060
Revision: 00H06000 Serial number: 1100B0773180FC
Coding: F751BE7F30020600
Shop #: WSC 02334 758 00200
VCID: 2D5ABE35B48FAD273C-8079
Address 34: Level Control Labels: 4F0-910-553.clb
Part No SW: 4F0 910 553 A HW: 4F0 907 553 A
Component: J197 LUFTFEDER H17 0060
Serial number: 00619003690500
Coding: 0000220
VCID: 22405D09FD51625F91-8077
01316 - ABS Control Module
Fault Status: 00101101
Fault Frequency: 7
Reset counter: 81
Mileage: 316755 km
Date: 2019.11.01
Time: 16:14:57
Part No SW: 4F0 910 793 P HW: 4F0 959 793 P
Component: TSG FA H12 0230
Revision: 00000000 Serial number: "ó
Coding: 0003626
Shop #: WSC 02327 758 00200
VCID: 37769C5D46D317F756-8063
Part No SW: 4F0 910 289 K HW: 4F0 907 289 K
Component: Komfortgeraet H25 0200
Revision: 02000025 Serial number: 01058729180000
Coding: 3351281
VCID: 3260AD49ADB1F2DF61-8067
01505 - Bulb for Blinkers; Rear Right (M8)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 44
Mileage: 313510 km
Date: 2019.07.30
Time: 16:03:31
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 4F0 910 223 K HW: 4F0 035 223 L
Component: Amp.-ASK-RD H07 0250
Revision: S0900000
Coding: 080001
Shop #: WSC 02399 823 56573
VCID: 2648411951799E7FFD-8073
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H12 0100
Revision: Serial number: 00000000470735
Coding: 0001103
VCID: 5EB829F989A906BFF5-800B
Part No SW: 4F0 910 793 P HW: 4F0 959 792 P
Component: TSG BF H12 0230
Revision: 00000000 Serial number: 6
Coding: 0003626
Part No SW: 4F0 910 801 C HW: 4F0 907 801 A
Component: EPB CDEC0080 H04 0080
Revision: --H04---
Coding: 0000321
Shop #: WSC 02324 758 00200
VCID: 20445701F35D704F87-8075
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Coding: 0000004
VCID: 3F86F47D6EE32FB79E-806B
Part No SW: 4E0 910 541 Q HW: 4F0 035 541 L
Component: TUNER EU/US/RDW H42 0620
Revision: 00000000 Serial number: 384K/067624809
Coding: 0000001
Shop #: WSC 40995 222 98481
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000013281
VCID: 244C5B11E7456C6FE3-8071
Component: von VA0 2708021438
Coding: 344630393135313035442056413032373038303231343338
Shop #: WSC 00000 384 00290
02272 - Quiescent Current Stage 1
Mileage: 317212 km
Date: 2019.11.03
Time: 19:11:59
02273 - Quiescent Current Stage 2
Mileage: 317212 km
Date: 2019.11.03
Time: 20:17:10
Part No SW: 4F0 910 795 E HW: 4F0 959 795 E
Component: TSG HL H21 0210
Coding: 0003114
Address 69: Trailer (J345) Labels:. 4F0-907-383.clb
Part No SW: 4F0 907 383 C HW: 4F0 907 383 C
Component: Anhaenger H14 0080
Revision: 2B002001 Serial number: 00000106002078
Coding: 0103030000000000
VCID: 2B5EB02D4A9BA31722-807F
Address 6D: Trunk Elect. Labels: Redir Fail!
Part No SW: 4F9 910 591 HW: 4F9 827 851 F
Component: ValeoHeckdeckel H24 0290
Revision: --H24001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6CDC73314F15642F6B-8039
Subsystem 1 - Part No: 4F9 910 592
Subsystem 3 - Serial number: RD03.08.07--H24001001B0086ˇ
Subsystem 4 - Serial number: 1B0086ˇ
Part No SW: 4F0 910 795 E HW: 4F0 959 794 E
Component: TSG HR H21 0210
Coding: 0003114
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 H HW: 4F0 919 283 H
Component: Parkhilfe 8-Kan H12 0080
Revision: 00H12000 Serial number: 06330722501766
Coding: 0211416
End-------------------------(Elapsed Time: 03:25)--------------------------
