HI all!
First post and over all new to VCDS. First off i love the software... but i'm worried i screwed something up. I've had no trouble with things like programming new key fobs, adapting new CECM and multi function steering wheel and a few other tweaks. At some point though the yellow steering and the traction control lights came on and both are functioning in an extremely limited mode if they are functioning at all. i tried the learning process with turning the wheel to certain positions for specified times and also driving for several hundred miles hoping it would self learn but have had no such luck. Currently i'm at a bit of a loss and don't know where to "turn" next and would appreciate and suggestions.
Thanks in advance!
AutoScan-
Thanks in advance!
AutoScan-
Sunday,03,November,2019,18:42:50:38212
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWCR71K16W170286 License Plate:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWCR71K16W170286 Mileage: 491360km-305316miles
37-Navigation -- Status: Not registered 0011
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 AR HW: Hardware No
Component: 2.5l R5/4V G 6747
Revision: -------- Serial number: VWZ7Z0F3579635
Shop #: WSC 01279 785 00200
VCID: 79AFEAD365D0068F8E9-802C
000017 - Bank 1: Camshaft A (Intake)
P0011 - 008 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
Mileage: 489428 km
Time: 22:17:54
RPM: 2153 /min
Load: 60.8 %
Speed: 88.0 km/h
Temperature: 78.0°C
Temperature: 14.0°C
Absolute Pres.: 980.0 mbar
Voltage: 13.970 V
000369 - Fuel Trim; Bank 1
P0171 - 001 - System Too Lean - Intermittent
Fault Status: 00100001
Mileage: 489532 km
Time: 20:46:53
RPM: 1947 /min
Load: 70.6 %
Speed: 79.0 km/h
Temperature: 83.0°C
Temperature: 33.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
005170 - Secondary Air Injection Solenoid Valve (N112)
P1432 - 004 - Open Circuit - Intermittent
Mileage: 490081 km
Time: 00:07:19
RPM: 1017 /min
Load: 36.8 %
Temperature: 61.0°C
Temperature: 36.0°C
Voltage: 8.001 V
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0021122
VCID: 71BFD2F33DA04ECF369-8024
Part No: 1K0 820 047 EC
Component: Climatic PQ35 090 0505
VCID: 698FBA931570B60F7E9-803C
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 Q HW: 3C0 937 049 Q
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000002330203
Coding: 008D8F314004150000140000001400000028730B5C0000
Shop #: WSC 01287 785 00200
VCID: 372B2CEB1344D0FF38D-8062
Subsystem 1 - Part No: 1K1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW350 013 0402
Coding: 00063445
Shop #: WSC 01287
Reset counter: 81
Mileage: 491361 km
Voltage: 12.75 V
Part No SW: 1K0 909 605 P HW: 1K0 909 605 P
Component: 5L AIRBAG VW8R 032 7900
Revision: 03032000 Serial number: 0038FD05CLB2
Coding: 0013644
Shop #: WSC 01269 785 00200
VCID: 392F2AD32550C68FCE9-806C
Subsystem 1 - Part No: 1K0 959 339 D
Component: BF-Gewichtsens. 006 0006
Subsystem 2 - Serial number: 6332MSME107B3A1AE
Subsystem 3 - Serial number: 6342MSME110B630F9
Subsystem 4 - Serial number: 6352QSME0B3222478
Subsystem 5 - Serial number: 6362QSME0A2C117BM
Subsystem 6 - Serial number: 63727SME09650203S
Subsystem 7 - Serial number: 63827SME086C05495
Part No SW: 1K0 953 549 AJ HW: 1K0 953 549 AJ
Component: J0527 034 0070
Coding: 0002022
VCID: 7AADF5DF60D60D97873-802E
Component: E0221 007 0050
Part No: 1K0 920 953 C
Component: KOMBIINSTRUMENT VDD 4312
Coding: 0007203
Shop #: WSC 07434 444 92463
VCID: 2B03009BDF0C641F4C5-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 2800106318118A
Coding: 3D3F0340070002
VCID: 2A0D059FD0F67D17B73-807E
Reset counter: 81
Mileage: 491361 km
Time: 07:40:39
01304 - Radio
Reset counter: 81
Mileage: 491361 km
Time: 07:40:43
Reset counter: 81
Mileage: 491361 km
Time: 07:40:43
Component: IMMO VDD 4312
Shop #: WSC 07320 444 12178
Address 37: Navigation
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN2.lbl
Part No: 1K0 959 701 K
Component: Tuer-SG 024 2373
Coding: 0001205
VCID: 363521EF144E29F723B-8062
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 333318FB073C3CDF045-8066
02546 - Steering Limit Stop
Mileage: 1360 km
Temperature: 18.0°C
Voltage: 11.70 V
Voltage: 11.50 V
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AF
Component: KSG 0401
Coding: 13C803083F09058F880F048050CC
Shop #: WSC 07437 444 12591
VCID: 74B1DBE742B27BE7DDF-8020
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN2.lbl
Part No: 1K0 959 702 K
Coding: 0001205
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN2.lbl
Part No: 1K0 959 703 F
Component: Tuer-SG 021 2438
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN2.lbl
Part No: 1K0 959 704 F
Coding: 0000144
VCID: 34311BE702323BE71DF-8060
End----(Elapsed Time: 01:00, VBatt start/end: 12.7V/11.9V. VIgn 11.9V)-----
