jimmyb_123
New Member
Evening all,
Long time lurker, first time poster - I recently bought a second hand HEX-V2 (never used or registered, I can register to me if needed) to try and fix a botched recoding job done to my T5 (7E/7F, 2014, panel van) a few years back.
Short backstory: I fitted a towbar with 7 pin wiring when I bought the van but never got around to sorting the recoding since the lights worked fine and I was only moving a bike carrier. Took it to an independent garage who had it for a day, failed to do the very simple steps needed, couldn't follow the instructions, wiped most of the modules when trying to do a firmware update (never established why), needed two trips back to get them to turn on stuff like cruise control and hill start assist again...and still don't have a coded towbar module. The garage went bust shortly after and life got in the way of sorting things completely.
The other week I bought a HEX-V2 and got cracking, and I now have two problems to put to you good people...
I enabled the towbar in the places needed (added 69 to the list, enabled towbar in the engine module, enabled removable towbar in the parking sensors module) and ran into the same problem as the garage - the module thinks there's always a trailer attached, and permanently disables the sensors/shows the trailer graphic on the stereo. An afternoon with probes and spanners, checking fuses, plugging different trailers in, rewiring the plugs etc and I can't find any hint of a fault...the module just thinks there's always a trailer there (going from the diagnostic LED and the behaviour with the stereo).
Any thoughts on that one?
Hopefully a simple one...the indicator lights don't flash when I lock the van. They flash when I unlock it, but that's it. I enabled the audible warning on lock/unlock to test, and it pips on lock but not unlock. I have a suspicion on this one - according to the central electrics measuring values, the left door is operating fine but the right door doesn't exist. And according to the CAN gateway, the van is coded as a shortback/hatchback, which wouldn't have a right door. Does the van think it's a different type, and isn't expecting the other door, and is getting confused when I try to lock it? Would setting the model to something else (e.g cityvan) be better? I don't want to change that setting blindly if it's already correct for a two rear door panel van.
Screenshots and autoscan below.
Help much appreciated!
Thursday,24,October,2019,16:59:44:61211
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ7HZFH045062 License Plate:
Mileage: 101970km-63361mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 69 77 0B
VIN: WV1ZZZ7HZFH045062 Mileage: 101970km-63361miles
Address 01: Engine (J623-CAAB) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GG HW: 03L 907 309 M
Component: R4 2,0L EDC H45 6291
Revision: 26H45--- Serial number: 00000000000000
Coding: 01114010232400080000
ASAM Dataset: EV_ECM20TDI01103L906019GG 003004
ROD: EV_ECM20TDI01103L906019FG_003.rod
VCID: 76B5E74F4849CC07E3B-8022
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 708724AD89A80E9A24A29177696010
Shop #: WSC 12345 123 49177
VCID: 3A2D337F3C516867C73-806E
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 02091404650812
Coding: 01
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5FF6F60798447BBB-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 7CA1F5677665965795F-8028
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 P HW: 7H0 937 087
Component: BCM T5GP H+4 H34 0424
Revision: BO034001 Serial number: 0673 251140017
Coding: A024303A0A613431922848106C2B8C540080632F60840000320000000800
VCID: 41DF449351873BBF869-8014
Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8653
Serial number: KU0KU006081442180852
Coding: 1000B0
Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8653
Serial number: KU0KU003091442463319
Coding: 0000A0
Subsystem 3 - Part No: 7E1 951 172
Subsystem 5 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32901421100867
Coding: 108001
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A2D337F3CD16867C73-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00SGE8L
Shop #: WSC 02734 790 50316
VCID: 3537204315CF871F2A1-8060
Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
Component: KOMBI H03 0805
Coding: 460A00
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 H34 0424
Revision: BO034001
Coding: 042300
VCID: 70B9D1572AADE237397-8024
Component: IMMO H03 0805
VCID: 6A8DC33F0CF118E7773-803E
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: RCD310 EU T H06 5007
Revision: -----10S Serial number: VWZ4Z2P1329298
Coding: 05000200020014
Shop #: WSC 02734 790 00000
VCID: 33331E5B1B3B992F045-8066
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 30391157EA2DA237797-8064
Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
Component: TELEFON H16 4217
Revision: 1B001001 Serial number: 00007666627180
Coding: 0201010000010101
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3C21356736E55657D5F-8068
End----(Elapsed Time: 01:28, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
