Results 1 to 4 of 4
Thread: New to forum; Audi Q5 camshaft adjustment values
    Pirate
    Nov 2019
    Hello, I would like to ask for help regarding the VCDS readings on the camshaft adjustments (timing chain) for my Audi Q5 2009 3.2L. I want to see if there is a problem with the timing chain., i.e. whether it needs replacement. The picture below shows the readings, but they are in a different format from typical camshaft readings(channel 91,92,93) that I see in forums and it is a bit difficult for me to interpret the measurements. So I know that deviations above +/- 4 means there is a problem - I can see zeros for intlet/exhaust bank 1 and 2 actual, which looks positive to me. But then I am bit concerned regarding the specified values (-132.00 and 137.750) for intlet/exhaust and the exhaust phase/intlet phase values (-47.250, -46.875, -47.625, -47.250).
    Any help will be appreciated.
    The auto-scan gives no fault codes.
    Thank you!
    Quote Originally Posted by angevel View Post
    Please post it anyway for context.
  3. Likes PetrolDave liked this post
    Pirate
    Nov 2019
    Removed. Data from a clone/pirate copy of VCDS is not welcome here.
    Getting help in this forum requires the use of a legitimate VCDS system.
    http://www.ross-tech.com/distributors.php#uk
    Let us know if/when you get one and we'll adjust your forum status.
