Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: 01 MK4 Jetta 1.8T Immobilizer (first time poster....)
    Jun 2019
    CA, USA
    2001 MK4 Jetta 1.8T. Manual trans. California vehicle, not a rust bucket. 125K miles. Immobilizer initiated.
    Vehicle condition: extensive service and upkeep, 4K miles ago.
    New windshield 4 weeks ago. Car wash today (2nd or 3rd wash).
    This was abrupt, never had these symptoms.
    1/2 hour after car wash, vehicle went into immobilization mode while attempting to start from warm condition. Two avail factory keys, neither solve problem.
    While key is in switch and turned on [car is dead cold at this point]: fans are running full speed, tach and speedo are pegged, immobilization yellow light is on or flashing.
    The mileage changed to KM and odometer significantly reduced.
    STEPS: Like a dummy I should have grabbed my VCDS and scanned it first. Instead I disconnected the battery terminals (both) and shorted them together for 15 minutes. No change.
    Ran a scan (while the fans are humming away....). Posted scan below.
    From the scan results I think I have too many intermittents. I need to check grounds. I need to check the oil level sensor wiring.
    I'd like to check the ignition key coil via VCDS without digging around the wiring, but can't seem to find how to do that.
    (the radio and door lock faults were existing...never mind the man behind the curtain)
    Do you think I'm on the right track? Thank you in advance.
    Eric
    Saturday,02,November,2019,19:16:52:23523
    Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
              76
       Mileage: 69940km-43458miles (this is not correct, actual mileage is 125,010. Went wonky during immobilization).
    Address 01: Engine        Labels: 06A-906-032-AWW.lbl
       Part No: 06A 906 032 DL
       Component: 1.8L R4/5VT     G   0006
       Coding: 07500
       Shop #: WSC 22110
       VCID: 6B83C6759A904E6F0C5-5184
    Readiness: 0110 1101
    Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
       Part No: 1C0 907 379 D
       Component: ASR FRONT MK60      0103
       Coding: 0018945
       VCID: 2B0306755F108E6F4C5-5184
       Part No: 6Q0 909 605 F
       Component: 04 AIRBAG VW6  0202 0004
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A2D3331A54A27E7C73-4B3C
    Address 17: Instruments        Labels: None
       Part No: 1j0 920 905 j
       Component: A4-KOMBIINSTR. VDO V53
       Coding: 10432
       Shop #: WSC 00098
       VCID: 6E85CF61A982BB472BB-5184
       Subsystem 1 - Part No: IMMO
       Component: IDENTNR: VwZ7Z0A3253560
       IMMO-IDENTNR: VwZ7Z0A3253560
    6 Faults Found:
    65535 - Internal Control Module Memory Error
                00-00 - -
                29-10 - Short to Ground - Intermittent
    01128 - Immobilizer Pickup Coil (D2)
                35-10 - - - Intermittent
    01176 - Key
                65-10 - Unauthorized - Intermittent
    01177 - Engine Control Unit
    Address 19: CAN Gateway        Labels: None
       Part No: 6n0 909 901
       Coding: 04102
       Shop #: WSC 08258
       VCID: 1079B199D376CDB7597-5184
    Address 46: Central Conv.        Labels: 1J0-959-799.lbl
       Part No: 1J0 959 799 AJ
       Component: 61 Zentral-SG Komf. 0001
       Coding: 04096
       Shop #: WSC 00066
       VCID: 065597C1A1329307F3B-4B1E
       Subsystem 1 - Part No: 1J1959801C
       Component: 61 Tőrsteuerger. FS0002r
       Subsystem 2 - Part No: 1J1959802D
       Component: 61 Tőrsteuerger. BF0002B
       Subsystem 3 - Part No: 1J4959811C
       Component: 61 Tőrsteuerger. HL0002r
       Subsystem 4 - Part No: 1J4959812C
       Component: 61 Tőrsteuerger. HR0002r
    01358 - Internal Central Locking Switch; Driver Side (E150)
    Address 56: Radio        Labels: 1J0-035-18x-56.lbl
       Part No: 1JM 035 157 A
       Component:  Radio DE2         0005
       Coding: 02043
       Shop #: WSC 22503
       VCID: 3E253F21B9620BC7FBB-51F2
    00856 - Radio Antenna
    End----(Elapsed Time: 05:12, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    Hello & welcome to the VCDS Forum OP!
    Sounds like after using the alleged, wink wink nudge nudge car wash or unapproved tool to read or even rewrite the instrument cluster has been corrupted in the cluster eeprom with a byte offset and your or someone's poor attention to details huh?
    Don't lie to me or this forum it doesn't instill trust and next time use the CAPS Key okay?
    NostraJackASS has Spoken a series of Questions!
    Did you JPPSG yet?
    Jun 2019
    CA, USA
    Jack,
    I've read enough of your posts to enjoy your sometimes gentle humor and other times your Captain Obvious persona (and quite clever).
    I'm reading between the lines on your reply and honestly I tried to present my post with as much information as possible. (Costco car @ $7.99, but fiercly crowded on weekends).
    Unapproved tool? Um...no.
    I don't understand the CAPS key reference, I don't type with CAPS on. (that was a bit cyrptic even from you).
    What is JPPSG?
    Based on the VCDS report, please enlighten me and the other readers what the 'ole crystal ball says.
    This isn't sounding too good.
    Thank you.
    Quote Originally Posted by Dunwood View Post
    What is JPPSG?
    See how JPPSG is bold green underlined? On this forum that means if you hover your mouse over it a popup will appear with an explanation
  5. Likes Jack@European_Parts liked this post
    Indeed JPPSG and especially for FOD!
    Coding: 10432
    Shop #: WSC 00098
    How did you marry keys & did you check ignition switch or load reduction relays!
    How are ground or battery connections since maybe got wet from car wash that contains soap conductive properties?
    Why have you not addressed the D2 first in WD?
    Looks to my like the cluster has lost some of its marbles.
    Jun 2019
    CA, USA
    The keys (2) have not been re-marry'd to the vehicle since we have owned it; purchased @ 70K.
    The ground and battery connections have in the past been excellant, a result of having a CA vehicle; however I'll review them again.
    (I think the car wash was simply coincidental, I drove it about 2 miles and parked it prior to the incident. I only mentioned it from the numerous online posts from mechanics who complain about customers not giving them the entire story).
    Will review the D2 and load reduction relays. After your flagging of WSC, it is perhaps possible this vehicle has prior history of "poking" around in the
    Instrument panel (and different shop codes). I have a prior VCDS log from June that may be helpful?
    You have given me some hope. Thank you.
  9. #8
    Yes please post those old scans they maybe helpful, right?
    You could always check the the D2 coil and or replace faulty cluster or rewrite the binary proper by doing some math and lock the CAPS key?
    Or
    There is Immobilizer Solutions defeat?
    There is absolutely tampering by someone at sometime!
  10. #9
    Jun 2019
    CA, USA
    When the vehicle was purchased, most of the service was done by the local VW dealer and I did verify the service records.
    Been a couple of repairs in the Bay Area, when my son was attending school (O2 sensors, fuel pump, std service).
    Vehicle has been problem free since I performed and completed all the "deferred maintanence" starting in January.
    Log from 122K. I fixed the below mis-fires (installed one of the check valves backwards....)
    (other than a bad cat which i have yet to fix).
    Monday,12,August,2019,18:54:33:23523
    Chassis Type: 9M - VW Jetta IV (1998 > 2014)
              75 76
       Mileage: 196560km-122136miles
       Coding: 07500
       Shop #: WSC 22110
       VCID: 6B83C6759A904E6F0FB-5184
    7 Faults Found:
                P0300 - 35-00 -
    16685 - Cylinder 1
                P0301 - 35-00 - Misfire Detected
    16686 - Cylinder 2
                P0302 - 35-00 - Misfire Detected
    17608 - Boost Pressure Control Valve (N249)
                P1200 - 35-10 - Mechanical Malfunction - Intermittent
    17584 - Bank1: O2 (Lambda) Correction Behind Catalyst
                P1176 - 35-00 - Control Limit Reached
    16687 - Cylinder 3
                P0303 - 35-00 - Misfire Detected
    16688 - Cylinder 4
                P0304 - 35-00 - Misfire Detected
    Readiness: 0000 1101
       Coding: 0018945
       VCID: 2B0306755F108E6F4FB-5184
       Coding: 12340
       Shop #: WSC 00066
       VCID: 3A2D3331A54A27E7C4D-4B3C
       Part No: 1J0 920 905 J
       Coding: 07232
       Shop #: WSC 00066
       VCID: 2E050F616902FB47685-5184
       Component: IDENTNR: VWZ7Z0A3253560
       IMMO-IDENTNR: VWZ7Z0A3253560
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 00066
       VCID: 70B9D119B3B6ADB73A9-5184
       Coding: 04096
       Shop #: WSC 00066
       VCID: 065597C1A1329307F05-4B1E
       Component: 61 Tőrsteuerger. BF0002r
    00912 - Window Regulator Switch; Front Left (E40)
       Coding: 02043
       Shop #: WSC 22503
       VCID: 3E253F21B9620BC7F85-51F2
                36-00 - Open Circuit
    End----------(Elapsed Time: 05:21, VBatt start/end: 12.6V/12.6V)-----------
  11. #10
    Well this confirms my suspicions, someone has tampered sir.
    Thanks for playing & let me know when you are ready to tell the rest of the back story, okay?
    BEFORE
    Coding: 07232
    Shop #: WSC 00066
    Coding: 00006
    Shop #: WSC 00066
    AFTER
    Coding: 10432
    Shop #: WSC 00098
    6 Faults Found:
    00-00 - -
    01176 - Key
    Coding: 04102
    Shop #: WSC 08258
