Results 1 to 5 of 5
Thread: IDE06141-Adapting Injector Minimum Deviation Quantity
    Aug 2016
    Newry, NI
    How long does this Basic test run for when select this?
    Customer got 4 second-hand injectors but diesel knock when accelerating.
    I was able to recode the injectors in Adaptions.
    Then tried this IDE006141 but this been going on over an hour.
    Does this test take this long?
    Saturday,02,November,2019,16:35:27:46973
    VCDS Version: 19.6.2.0  HEX-NET CB: 0.4508.4
    Workshop Code: 000 18261 018261
    VIN: WVWZZZ1KZBP006698   License Plate:
    Chassis Type: 1K-VW36 (7N0)
    VIN: WVWZZZ1KZBP006698   Mileage: 191100km-118744miles
    Address 01: Engine (J623-CAYB)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 A    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 9630
       Revision: --H23---    Serial number: 00000000000000
       Coding: 00114014030500080000
       Shop #: WSC 00028 028 00024
       ASAM Dataset: EV_ECM16TDI02103L906023A 003009
       ROD: EV_ECM16TDI02103L997557M.rod
       VCID: A404A5CDAF6C026F63-80F0
       Part No SW: 1K0 907 379 AT    HW: 1K0 907 379 AT
       Component: ESP MK60EC1   H30 0105
       Revision: 00H30001
       Coding: 133B200D09220000C81104ED90210081310000
       Shop #: WSC 00028 028 00001
       VCID: 8444C54D07ACE26F03-80D0
       Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000000002
       ROD: EV_ClimaBasis_VW36.rod
       VCID: ED9280E93C260327FC-80B8
    Address 09: Cent. Elect.
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRAAJF3-
       Coding: 00003133
       Shop #: WSC 00156 210 89782
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: BB367EB132D25D9732-80EE
       Serial number: 3572MSME03391454ZZZM
       Serial number: 3582MSME44421454ZZZM
       Serial number: 3512QSME062C626CZZZ.
       Serial number: 3522QSME20513852ZZZI
       Part No SW: 5K0 953 507 AS    HW: 5K0 953 549 C
       Component: Lenks.Modul   007 0080
       Revision: --------    Serial number:  90440JF1000IM
       Coding: 5080040000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 814ACC5910BEF74728-80D4
       Part No SW: 5K0 920 961 A    HW: 5K0 920 961 A
       Component: KOMBI         H03 0405
       Coding: 470B00
       VCID: AC144DEDC7BCCA2FAB-80F8
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 0602
       Revision:   H27       Serial number: 290510F2002403
       Coding: E9801F0600020200000003
       VCID: ED9280E9F4260327FC-80B8
       Component: IMMO          H03 0405
       VCID: EA988BF50DC8141F99-80BE
       Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
       Component: Tuer-SG         009 2140
       Coding: 0000564
       VCID: B3265691D28295D7EA-80E6
       Part No: 1K0 909 144 J
       Revision: 00H17000
       VCID: B12A5C99289EA7C798-80E4
    Address 46: Central Conv.
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Coding: 0000564
       VCID: B424558DD78C92EFF3-80E0
       Part No SW: 5K0 035 156     HW: 5K0 035 156
       Component: Radio         H30 0072
       Revision: R0000000    Serial number: VWZAZ1K0621013
       Coding: 0000020002
       VCID: E484E5CDE7EC426FA3-80B0
    End----------(Elapsed Time: 00:44, VBatt start/end: 12.2V/12.1V)-----------
    ;SW:03L-906-023-A   HW:03L-906-023-A ---  Engine
    ;Component:1	6l R4 CR td H23 9630	 Coding:00114014030500080000
    ;EV_ECM16TDI02103L906023A	3009	EV_ECM16TDI02103L997557M.rod
    ;Saturday	2	November	2019	16:50:24:46973
    ;VCDS Version: Release 19.6.2  Data version: 20190930 DS308.0
    ;VCID: A404A5CDAF6C026F63-80F0
    IDE00263-Injector 1 correction value	7EFCDC0 	7
    IDE00264-Injector 2 correction value	AEKEHK0 	7
    IDE00265-Injector 3 correction value	BFJJKL0 	7
    IDE00266-Injector 4 correction value	96KDFF0 	7
    IDE00275-Particle filter initialization	39.4256 g	4
    IDE00820-Activating and deactivating all development messages	not active 	1
    IDE01637-Service regeneration of particulate filter while driving	00 00 	2
    IDE01711-Blocking of particle filter regeneration	not active 	1
    IDE02247-Static maximum speed limit	190.0 km/h	2
    IDE02248-Individually adjustable maximum speed limit	190.0 km/h	2
    IDE02632-MAS00478-Activation of static maximum speed limit-Reserved	0	1
    IDE02632-Activation of static maximum speed limit-	OFF 	1
    IDE02633-Deactivation of static maximum speed limit	00 00 	2
    IDE02635-MAS00478-Activation of A/C-Reserved	0	1
    IDE02635-Activation of A/C-	OFF 	1
    IDE03237-Compensation for empty stroke	00 00 00 00 00 0E 00 00 00 04 00 00 00 00 03 E8 00 00 00 00 1D 87 00 00 1D 7C 00 E9 F9 04 00 00 1D 87 00 0F 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 04 00 28 00 28 00 51 00 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	78
    Elapsed Time: 00:03
    Group	Description	Actual
    IDE00018-ENG99300	Voltage terminal 15-V_IGK	14	 V
    IDE00019	Voltage terminal 30	13.892	 V
    IDE00021	Engine speed	782	 /min
    IDE00025	Coolant temperature	87	 C
    IDE00030	Status of actuator test	not active
    IDE00075	Vehicle speed	0	 km/h
    IDE00076	Status of initial fuel filling	Default
    IDE00078	Time since engine start	151	 s
    IDE00083	Throttle valve position (absolute)	89	 %
    IDE00084	Absolute load value	44.3	 %
    IDE00085	Normed load value	38	 %
    IDE00086	Accelerator position	14	 %
    IDE00090-ENG100708	selected gear-DRI	0
    IDE00097	OBD - requirements for which this vehicle is designed	Euro-OBD
    IDE00100-ENG101842	Engine torque-TQI_SP	46.94	 Nm
    IDE00102-ENG103182	Control Module temperature-TECU	37	 C
    IDE00167	Exhaust temperature 1 bank 1	124.5	 C
    IDE00169	Exhaust temperature 2 bank 1	124.5	 C
    IDE00172-ENG99317	A/C compressor torque-TQ_LOSS_ACC	0	 Nm
    IDE00173-ENG102035	Cruise Control System: specified speed-Vehicle speed: specified	0	 km/h
    IDE00182-ENG103031	Camshaft adaptation intake bank 1: phase position-Camshaft adjustment: inlet phase: bank 1	1.125
    IDE00188-ENG102817	Fuel high pressure: actual value-FUP_FIL	40.118	 MPa
    IDE00190-ENG100128	Charge air pressure specified value-MAP_SP_MMV	950.15	 hPa
    IDE00191-ENG103684	Charge air pressure: actual value-MAP_MMV	949.99	 hPa
    IDE00192-ENG99381	Coolant temperature at radiator outlet: actual value-TCO_2	66	 C
    IDE00196-ENG100000	Engine oil temperature-TOIL	83	 C
    IDE00198-ENG111631	Refrigerant pressure-ACP_MES	6.5	 bar
    IDE00201-ENG102664	High fuel pressure: specified value-FUP_SP_KPA	40295.41	 kPa
    IDE00304-ENG101210	Fuel level-FTL_CAN	6	 l
    IDE00322-ENG100540	Status of basic setting-Basic Settings Status	was not yet started
    IDE00347	Air mass: actual value:	5.38	 g/s
    IDE00348	Intake air temperature	32	 C
    IDE00349	Throttle valve position: normed	96	 %
    IDE00350-ENG99082	Air mass: specified value-MAF_SP_MMV	213.3	 mg/stroke
    IDE00351-ENG100251	Main injection: start of activation-SOI_MAIN_SP	5.79
    IDE00352-ENG99257	Main injection: duration of activation-TI_MAIN_BAS	0.468	 ms
    IDE00353-ENG102974	Engine start: start quantity-TQI_ST	0	 Nm
    IDE00354-ENG102395	Engine start: start synchronization-LV_SYN_VLD	1
    IDE00355-ENG103498	Cruise Control System (CCS): status-Binary 8 Bit	0
    IDE00356-ENG102448	Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS	10
    IDE00357-ENG99842	Fuel temperature-TFU	45	 C
    IDE00358-ENG100184	Limitation: torque-TQI_LIM_MIN	109.81	 Nm
    IDE00359-ENG102866	Limitation: smoke-TQI_SLM	109.78	 Nm
    IDE00361-ENG99319	Ambient air pressure-Ambient pressure	953.05	 hPa
    IDE00362-ENG100099	Charge Pressure Actuator: activation-ANG_SP_BPA[0]	79.999	 %
    IDE00363-ENG102107	Glow status-STATE_GLOW	255
    IDE00364-ENG102834	Preheat time-T_GL_ES	0	 s
    IDE00365-ENG99400	Injection amount deviation cylinder 1-FAC_CYL_BAL1	-1.1219	 mg/stroke
    IDE00366-ENG101187	Injection amount deviation cylinder 2-FAC_CYL_BAL2	0.3528	 mg/stroke
    IDE00367-ENG101684	Injection amount deviation cylinder 3-FAC_CYL_BAL3	3.369	 mg/stroke
    IDE00368-ENG103465	Injection amount deviation cylinder 4-FAC_CYL_BAL4	-2.2912	 mg/stroke
    IDE00371-ENG100275	Fuel consumption-FCO_T	0.125	 ml/s
    IDE00373-ENG99620	Electric auxiliary heater: shut-off conditions-Binary 16 Bit	00000000 01000001
    IDE00374-ENG100674	Electric auxiliary heater: relay activation-COUNT_ACT_HEAT_ELEMS	0
    IDE00375-ENG103823	Generator: load signal-ALTPWM	42.393	 %
    IDE00380-ENG102782	Coolant fan 1: activation-Radiator fan 1: activation	9.8	 %
    IDE00381-ENG101514	Coolant fan 2: activation-Radiator fan 2: activation	9.8	 %
    IDE00383-ENG104210	Pre-injection 1: activation start-SOI_PREV_SP[0]	5.79
    IDE00384-ENG101378	Pre-injection 1: activation duration-TI_PREV_BAS[0]	0	 ms
    IDE00385-ENG99181	Pre-injection 2: activation start-SOI_PREV_SP[1]	-2.34
    IDE00386-ENG99911	Pre-injection 2: activation duration-TI_PREV_BAS[1]	0.2144	 ms
    IDE00387-ENG99235	Post-injection 1: activation start-SOI_POST_SP[0]	17.74
    IDE00388-ENG102772	Post-injection 1: activation duration-TI_POST_BAS[0]	0	 ms
    IDE00389-ENG103789	Post-injection 2: activation start-SOI_POST_SP[1]	5.79
    IDE00390-ENG102792	Post-injection 2: activation duration-TI_POST_BAS[1]	0	 ms
    IDE00392-ENG100739	Accelerator pedal: sensor voltage 1-V_PVS_1_BAS	0.737	 V
    IDE00393-ENG102348	Accelerator pedal: sensor voltage 2-V_PVS_2_BAS	0.366	 V
    IDE00396-ENG103408	Charge Pressure Actuator: acknowledgment-ANG_BPA[0]	80.078	 %
    IDE00400-ENG99245	Intake manifold Runner Control (IMRC): activation-ANG_SP_PORT[0]	14.999	 %
    IDE00401-ENG102947	Intake manifold Runner Control (IMRC): acknowledgment-ANG_PORT[0]	99.908	 %
    IDE00404-ENG102559	Throttle valve: activation-PWM_HBR_THR[0]	-7.657	 %
    IDE00405-ENG98787	Crankshaft speed (RPM)-N	784	 /min
    IDE00406-ENG102227	Camshaft speed (RPM)-N_CAM	389.5	 /min
    IDE00407-ENG101894	Rail pressure regulation: status-LV_VCV_CTL	0
    IDE00413-ENG100922	Starter control: Interlock- or P/N-signal-LV_CLU_SWI_2_PN	0
    IDE00414-ENG100800	Starter control: relay 1-Starter: start relay 1	0
    IDE00415-ENG99979	Starter control: relay 2-Starter: start relay 2	0
    IDE00420-ENG101443	Service regeneration: current duration-T_RGN_ACT_PF	0	 s
    IDE00423-ENG103230	Service regeneration: Release conditions 2-Binary 32 Bit	11111111 11111110 11111111 11011111
    IDE00425-ENG102682	Service regeneration: phase-STATE_RGN_PF	0
    IDE00427-ENG101722	Particle filter: difference pressure-DIP_PF	5.8	 hPa
    IDE00428-ENG100917	Particle filter: offset for differential press.-DIP_PF_AD[0]	0	 hPa
    IDE00430-ENG102682	Particle filter: field regeneration request status-STATE_RGN_PF	0
    IDE00431-ENG102952	Particle filter: field regeneration lock status-LV_STATE_TEST_RGN_PF_INH_HLD	0
    IDE00432-ENG103847	Particle filter: time since last regeneration-T_WOUT_RGN	18892	 s
    IDE00433-ENG103279	Particle filter: oil ash volume-MASS_ASH_PF	39.4254947	 g
    IDE00434-ENG102050	Particle filter: soot mass calculated-MASS_SOOT_SIM_PF	11.94	 g
    IDE00435-ENG101197	Particle filter: soot mass measured-MASS_SOOT_PHY_PF	0.32	 g
    IDE00436-ENG102397	Particle filter: kilometers since last regeneration-DIST_RGN	59.8	 km
    IDE00437-ENG99390	Injector valve 1: capacity-CAPA_INJ_MAIN[0]	6.1671	 F
    IDE00438-ENG103101	Injector valve 2: capacity-CAPA_INJ_MAIN[1]	6.3102	 F
    IDE00439-ENG102776	Injector valve 3: capacity-CAPA_INJ_MAIN[2]	6.4958	 F
    IDE00440-ENG104221	Injector valve 4: capacity-CAPA_INJ_MAIN[3]	6.4694	 F
    IDE00445	Unlearning counter according OBD	255
    IDE00450	Operating Instructions	--no display--
    IDE00451	Currently running routine	Unknown (0)
    IDE00472-ENG99569	Mean injection quantity-MF_INJ_SUM	6.368	 mg/stroke
    IDE00473-ENG102104	EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]	34.717	 %
    IDE00474	Ambient air pressure	95	 kPa abs
    IDE00475-ENG99518	Fuel Pressure Regulator Valve-PCV	18.185	 %
    IDE00476-ENG104101	Fuel Metering Valve-VCV	19.681	 %
    IDE00477-ENG99523	Torque request: sum of auxiliary aggregate-TQ_LOSS_ADD	-4.38	 Nm
    IDE00478-ENG104104	Engine-drag torque-TQFR_BAS	-14.03	 Nm
    IDE00481-ENG103062	Limitation: status of clutch protection-LV_TQI_LIM_CLU_PROT_ACT	1
    IDE00482-ENG101051	Limitation: torque of clutch protection-TQI_LIM_CLU_PROT	1023.97	 Nm
    IDE00495-ENG99873	Calculated oil temperature-TOIL_MDL	87	 C
    IDE00541-ENG103835	Acceleration-AC_VEH_CLC	0	 m/s
    IDE00545-ENG102287	maximum permissible engine torque-TQI_TQL	125	 Nm
    IDE00556	Outside air temperature	9	 C
    IDE00558	Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor)	0.503 Lambda / 0.000 V
    IDE00581	EGR specified value	33.7	 %
    IDE00583	Throttle valve specified value	96	 %
    IDE00584	Distance driven since erasing DTC memory	91	 km
    IDE00585	Dist. driven with exh. Malfunction Indicator Lamp activated	0	 km
    IDE00586	Deviation of exh.gas recirc. rate	-1.6	 %
    IDE00589	Fuel pressure	40940	 kPa rel
    IDE00594	Absolute intake pressure	95	 kPa abs
    IDE00595	Allocation of oxygen sensors	B1S1
    IDE00600	Conversion factors
    IDE00601	Monitoring status since erasing DTC memory
    IDE00602	Monitoring status in current driving cycle
    IDE00603	Number of driving cycles since erasing DTC memory	4
    IDE00606	Oper. time with exh. Malfunction Indicator Lamp activated	0	 min
    IDE00607	Time since erasing DTC memory	366	 min
    IDE00608	Type of fuel	Diesel
    IDE00611	Malfunction that has caused the ambient data to be stored	00 00
    IDE00727	Test steps still to be performed	0
    IDE00787	Cause for cancellation	0
    IDE00973-ENG103910	Outside air temperature-Ambient temperature	9	 C
    IDE01259-ENG101906	EGR Solen.val.: actual value-ANG_EGRV[0]	33.459	 %
    IDE01260-ENG99807	Generator power-GEN_LOAD_CAN	41.4	 %
    IDE01360-ENG103054	Service regeneration: Release conditions 3-FRF_STATE_RGN	1
    IDE01361-ENG102606	exh.gas recirc. (EGR) cooler pump: specified value-PWM_EGRCP[0]	95.001	 %
    IDE01362-ENG99381	Cooler for exh.gas recirc.: temperature-TCO_2	66	 C
    IDE01366-ENG101906	Exhaust flap: actual value-ANG_EGRV[0]	34.021	 %
    IDE01367-ENG99571	Turbocharger boost control: offset closed-V_BPA_TOL[0]	3.452	 V
    IDE01368-ENG100522	Turbocharger boost control: offset open-V_BPA_BOL[0]	0.498	 V
    IDE01369-ENG100116	Intake manifold runner control (IMRC): offset closed-V_PORT_TOL[0]	4.58	 V
    IDE01370-ENG99995	Intake manifold runner control (IMRC): offset open-V_PORT_BOL[0]	0.332	 V
    IDE01373-ENG102590	EGR valve: offset closed-V_EGRV_BOL[0]	0.977	 V
    IDE01374-ENG103179	EGR valve: offset open-V_EGRV_TOL[0]	3.999	 V
    IDE01375-ENG101848	Throttle valve adapter: offset closed-V_THR_BOL[0]	0.708	 V
    IDE01376-ENG103692	Throttle valve adapter: offset open-V_THR_TOL[0]	4.6	 V
    IDE01377-ENG100929	Throttle valve adapter: actual value-ANG_THR[0]	95.996	 %
    IDE01378-ENG100595	High fuel pressure: control deviation-PFU_DIF	0.25	 MPa
    IDE01380-ENG103961	Pre-injection 3: activation start-SOI_PREV_SP[2]	1.03
    IDE01381-ENG99178	Pre-injection 3: activation duration-TI_PREV_BAS[2]	0.2112	 ms
    IDE01382-ENG103886	Post-injection 3: activation start-SOI_POST_SP[2]	5.77
    IDE01383-ENG100997	Post-injection 3: activation duration-TI_POST_BAS[2]	0	 ms
    IDE01385-ENG101283	Wear index-WEAR_EQU_TMP_SRV_INTL	4	 m
    IDE01405-ENG102759	Status of starter activation-FRF_ST_RL	1
    IDE01406-ENG99620	Service regeneration: status-Binary 16 Bit	00000000 00000000
    IDE01407-ENG100958	Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN	9.27	 l
    IDE01409-ENG102169	Charge limit for service regeneration-Ash Mass Diag	40	 g
    IDE01410-ENG102169	Charge limit over-charge-Ash Mass Diag	45	 g
    IDE01671-ENG100919	Starter control: clutch switch-Starter control: interlock switch	0
    IDE01673-ENG101111	Starter control: readiness bits-LV_STA_RLS	0
    IDE01834	Battery voltage	14	 V
    IDE01877-ENG102109	Operating condition of idle speed control-LV_REQ_IS_CTL	1
    IDE01880	Accelerator position 2	15	 %
    IDE01881-ENG101073	Adaptation of kick-down shifting point-LV_KD_AD_OK	0
    IDE02228-ENG100386	Fuel pressure regulator valve: specified value rail pressure-LV_PCV_CTL	1
    IDE02229-ENG102154	Exh.gas temp.sen 1-TEG_MES[0]	124.54	 C
    IDE02234-ENG102117	Exh.gas temp.sen 3-TEG_MES[1]	101.6	 C
    IDE02236-ENG102786	Exh.gas temp.sen 4-TEG_MES[2]	84.16	 C
    IDE02609-ENG102086	Coding in the engine control module-FRF_VARCOD	1
    IDE03015-ENG100927	Compression test cylinder 1-N_CMP_TEST[0]	0	 /min
    IDE03016-ENG100124	Compression test cylinder 2-N_CMP_TEST[1]	0	 /min
    IDE03017-ENG103600	Compression test cylinder 3-N_CMP_TEST[2]	0	 /min
    IDE03018-ENG102802	Compression test cylinder 4-N_CMP_TEST[3]	0	 /min
    IDE03270-ENG111636	Exh.gas temp.sen 1: unconditioned voltage-VP_TEG[0]	3.2581	 V
    IDE03273-ENG111637	Exh.gas temp.sen 3: unconditioned voltage-VP_TEG[1]	0.7126	 V
    IDE03275-ENG111638	Exh.gas temp.sen 4: unconditioned voltage-VP_TEG[2]	0.6853	 V
    IDE03361-ENG103541	Driver request torque-TQI_DRIV_SUB	0	 Nm
    IDE03362-ENG103557	Requested transmission torque-TQI_REQ_ETCU	1023.97	 Nm
    IDE03712-ENG103230	Engine diagnostic status in curr driving cycle (end-of-line)-Binary 32 Bit	00000000 00000001 00000000 00001100
    IDE03767-ENG99531	Engine status-SF_ENG_STATE	IS
    IDE03892-ENG102868	Fuel high pressure sensor: unconditioned voltage-VP_PFU	1.3124	 V
    IDE03893-ENG101196	Injection valve 1: voltage-V_INJ_MAIN[0]	119.73	 V
    IDE03894-ENG104143	Injection valve 2: voltage-V_INJ_MAIN[1]	118.75	 V
    IDE03895-ENG101536	Injection valve 3: voltage-V_INJ_MAIN[2]	116.33	 V
    IDE03896-ENG102925	Injection valve 4: voltage-V_INJ_MAIN[3]	116.82	 V
    IDE03949-ENG102262	Air mass: actual value (mg/stroke)-MAF_MES	215.615	 mg/stroke
    IDE03998-ENG101893	Clutch Position Sensor-Starter control: clutch switch	0
    IDE04005-ENG103719	Accelerator position: normalized-Accelerator position	0	 %
    IDE04105-ENG124676	Environmental conditions-TQI_MSR_REQ_MON	0	 Nm
    IDE04105-ENG124673	Environmental conditions-TQI_GS_REQ_MON	0	 Nm
    IDE04105-ENG124668	Environmental conditions-N_SP_IS_ETCU_CAN_MON	0	 /min
    IDE04105-ENG124666	Environmental conditions-LV_CRASH	0
    IDE04105-ENG124681	Environmental conditions-VS_AC	0	 m/s
    IDE04105-ENG124675	Environmental conditions-TQI_LIM_CTL_SECU	0	 Nm
    IDE04105-ENG112089	Environmental conditions-VS_RAW_CAN_AC_MON	0	 km/h
    IDE04105-ENG112086	Environmental conditions-LV_ERR_N_SP_XSC_MON	0
    IDE04105-ENG124672	Environmental conditions-TQI_EGS_SUB	0	 Nm
    IDE04105-ENG124669	Environmental conditions-PREV_STATE_IV	1
    IDE04105-ENG102360	Environmental conditions-TQ_LOSS_ALTER	-5.06	 Nm
    IDE04105-ENG124671	Environmental conditions-TQFR_ADD_ENV	-0.31	 Nm
    IDE04105-ENG124657	Environmental conditions-DCC_AC	3.01	 m/s
    IDE04105-ENG124674	Environmental conditions-TQI_I_IS_CTL	47.56	 Nm
    IDE04105-ENG124667	Environmental conditions-LV_TQI_MON_ACT_MON	1
    IDE04105-ENG124677	Environmental conditions-TQI_REQ_CAN_ETCU	1023.96875	 Nm
    IDE04105-ENG112087	Environmental conditions-LV_VS_RAW_CAN_VLD_AC_MON	1
    IDE04105-ENG124678	Environmental conditions-TQ_LOSS_TCU1	0	 Nm
    IDE04105-ENG124682	Environmental conditions-VS_MON	0	 km/h
    IDE04105-ENG102494	Environmental conditions-Engine speed: actual	768	 /min
    IDE04105-ENG124663	Environmental conditions-LF_TQI_N_MAX_MON_1_ENVD	0
    IDE04105-ENG124658	Environmental conditions-LF_CAN_MON_1_ENVD	16418
    IDE04105-ENG100863	Environmental conditions-FAC_COR_SLOP_CHA_CAL[0]	0.98276
    IDE04105-ENG103478	Environmental conditions-PFU	40.192	 MPa
    IDE04105-ENG124664	Environmental conditions-LF_TQ_LOSS_MON_1_ENVD_0	11
    IDE04105-ENG124659	Environmental conditions-LF_CRU_MON_1_ENVD	2
    IDE04105-ENG124679	Environmental conditions-VP_MC_AN_DIG_MON	0.3662	 V
    IDE04105-ENG124680	Environmental conditions-VP_MU_AN_DIG_MON	0.3711	 V
    IDE04105-ENG124665	Environmental conditions-LF_TQ_LOSS_MON_1_ENVD_1	2827
    IDE04105-ENG124662	Environmental conditions-LF_TI_MON_1_ENVD	0
    IDE04105-ENG124661	Environmental conditions-LF_PVS_MON_1_ENVD	1
    IDE04105-ENG124660	Environmental conditions-LF_FCUT_MON_1_ENVD	0
    IDE04257-ENG100212	High pressure EGR actuator: activation-PWM_HBR_EGRV[0]	14.069	 %
    IDE04258-ENG100888	Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]	0
    IDE04259-ENG99492	High press EGR actuator: actual unconditioned volt val-V_EGRV[0]	1.846	 V
    IDE04263-ENG102014	Sensor for particle filter differential press: raw value-DIP_PF_RAW[0]	5.89	 hPa
    IDE04264-ENG99088	Throttle valve adapter: status-LF_STATE_THR_DISP[0]	0
    IDE04265-ENG104156	Throttle valve adapter: uncond voltage actual value-V_THR[0]	4.463	 V
    IDE04266-ENG104017	High press turbocharger actuator: activation-CTL_LIM_BPA[0]	68.842	 %
    IDE04267-ENG100274	High press turbocharger actuator: status-LF_STATE_BPA_DISP[0]	0
    IDE04268-ENG102598	High press turbocharger actuator: actual uncond volt value-V_BPA[0]	3.276	 V
    IDE04269-ENG103982	Intake manifold runner actuator: activation-PWM_HBR_PORT[0]	0	 %
    IDE04271-ENG100727	Intake manif runner actuator: uncond volt actual value-V_PORT[0]	4.995	 V
    IDE04272-ENG100854	Counter for regeneration time of diesel particle filter-T_INT_RGN_ACT_INI_PF_ENVD_H	0	 s
    IDE04551-ENG103251	Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP	960.35	 hPa
    IDE04557-ENG99620	ECM system status-Binary 16 Bit	00000001 00000010
    IDE04650-ENG111633	Particle filter: differential pressure: dynamic offset-DIP_PF_DYN_AD_VALUE[0]	0	 hPa
    IDE04673-ENG103030	O2 sensor 1 bank 1: duty cycle O2 heater-LSHPWM_UP[1]	3.125	 %
    IDE04678-ENG102558	Oxygen sensor 1 Bank 1: Status Calibration O2-Signal-LV_LSL_AD_STATE	1
    IDE04680-ENG99353	O2 sensor 1: bank 1: voltage raw value O2 signal-Lambda probe voltage: bank 1: probe 1 (broadband probe)	2.012	 V
    IDE04682-ENG99526	Allowed number of injections-LV_INJ_MON_ENA_AC_MON	0
    IDE04683-ENG99537	Injection release status-LF_INJ_AD_ACT	0
    IDE04684-ENG104138	Desired injection characteristic-PFU_SP_INJ_AD	40.326	 MPa
    IDE04689-ENG99620	Starter control: Start interruption status-Binary 16 Bit	00011001 00000000
    IDE04695	Immobilizer snapshot A	FF FF
    IDE04696	Immobilizer snapshot B	FF FF
    IDE04706-ENG101896	ACC interface activation condition-STATE_DT_MNG_CDN_1	0
    IDE04707-ENG103676	Status of reversible switch-off condition ACC_2-STATE_DT_MNG_CDN_2	0
    IDE04708-ENG99795	Status of reversible switch-off condition ACC_3-STATE_DT_MNG_CDN_3	0
    IDE04709-ENG101874	Status of ACC/CCS acceleration interface-STATE_CRU_AC	0
    IDE04710-ENG101150	ACC control module received status-STATE_AD_DIST_CTL	4
    IDE04711-ENG102746	Next status of ACC/CCS finite state machine-STATE_CRU_PLAUS	3
    IDE04712-ENG102726	Active brake system error status-STATE_ERR_BRAKE	0
    IDE04713-ENG100230	Active brake system status-STATE_BRAKE_ACT	0
    IDE04937-ENG102996	Sensor for engine block temperature: raw value-Coolant temperature	87	 C
    IDE04938-ENG102512	Sensor for temp after charge air cooler: raw value-TBA_MES	32	 C
    IDE05134-ENG100869	ACC target acceleration-AC_SP_CRU_EXT	3.0098	 m/s
    IDE05139-ENG101726	Shut-off timer: last ECM after-run time-T_ES_FCT_DIAG	0	 s
    IDE05466-ENG103340	Oxy sensor 1 bank 1 offset spec value-VLS_OFS_LSL[1]	0	 V
    IDE05468-ENG102329	Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]	500	 C
    IDE05632-ENG101485	Fuel pressure regulator valve actual value-CFB_PCV_MES	0.413	 A
    IDE05633-ENG100012	Valve for fuel metering: feedback value measured-CFB_VCV_MES	0.747	 A
    IDE05634-ENG103637	Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0]	742.6	 As
    IDE05635-ENG99789	Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]	747.4	 As
    IDE05636-ENG103475	Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]	754.6	 As
    IDE05637-ENG101402	Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3]	754.9	 As
    IDE05638-ENG100023	Oxygen sensor interface: counter for failed write cycles-CTR_ERR_LSL_IF_SPI_WR[1]	0
    IDE05639-ENG100771	Number of resets of main unit-CTR_RST_MC	0
    IDE05640-ENG104219	Number of resets of monitoring unit-CTR_RST_MU	0
    IDE05642-ENG100743	Rule deviation of energy control cylinder 1-EGY_INJ_CTL_DIF[0]	-0.064	 mJ
    IDE05643-ENG101114	Rule deviation of energy control cylinder 2-EGY_INJ_CTL_DIF[1]	0.04	 mJ
    IDE05644-ENG103009	Rule deviation of energy control cylinder 3-EGY_INJ_CTL_DIF[2]	-0.072	 mJ
    IDE05645-ENG102758	Rule deviation of energy control cylinder 4-EGY_INJ_CTL_DIF[3]	0.008	 mJ
    IDE05646-ENG101723	Measured energy of main injection cylinder 1-EGY_INJ_MAIN[0]	44.432	 mJ
    IDE05647-ENG101584	Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]	44.751	 mJ
    IDE05648-ENG103761	Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]	44.257	 mJ
    IDE05649-ENG100583	Measured energy of main injection cylinder 4-EGY_INJ_MAIN[3]	44.257	 mJ
    IDE05650-ENG102923	Energy control injector 1 specified value-EGY_INJ_SP[0]	42.342	 mJ
    IDE05651-ENG101270	Energy control injector 2 specified value-EGY_INJ_SP[1]	40.132	 mJ
    IDE05652-ENG100278	Energy control injector 3 specified value-EGY_INJ_SP[2]	41.752	 mJ
    IDE05653-ENG101718	Energy control injector 4 specified value-EGY_INJ_SP[3]	40.858	 mJ
    IDE05654-ENG100606	Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1]	0.9581
    IDE05655-ENG101493	Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL	1
    IDE05656-ENG99849	CAN controller status byte-FRF_CAN_CTR	0
    IDE05657-ENG100224	EEPROM malfunction status-FRF_EEPROM	0
    IDE05658-ENG101840	Hardware monitoring of EEPROM status-FRF_HWMT_EEPROM	0
    IDE05659	Departure lock Snapshot C	FF FF
    IDE05660-ENG102585	Energy control cylinder 1: integral part-I_CTL_EGY[0]	0.516	 %
    IDE05661-ENG99987	Energy control cylinder 2: integral part-I_CTL_EGY[1]	0.845	 %
    IDE05662-ENG104135	Energy control cylinder 3: integral part-I_CTL_EGY[2]	0.946	 %
    IDE05663-ENG103697	Energy control cylinder 4: integral part-I_CTL_EGY[3]	0.912	 %
    IDE05664-ENG101228	Smallest amount calibration: current adaptation value-IDX_TI_OFS_CMB_AD	0
    IDE05665-ENG103851	Oxygen value calculated-LAMB_EXT_CLC_FIL	1.876
    IDE05666-ENG101688	Incorrect information on selected Piezo power level-LF_STATE_PPS_SPI[0]	0
    IDE05667-ENG101827	Brake status monitoring level-LV_BRAKE_MON	0
    IDE05668-ENG103061	Transmission control module torque request-LV_ETCU_INC_40	0
    IDE05669-ENG99348	ASR-torque request-LV_TCS_INC_40	0
    IDE05670-ENG103153	Cruise control torque intervention-LV_TQ_CRU_ACT	0
    IDE05671-ENG103889	Cruise control torque request-LV_TQ_CRU_ACT_40	0
    IDE05672-ENG103337	Fuel mass deviation of the last adapted specified value-MF_DE_AD_LST_CMB_AD	-2	 mg/stroke
    IDE05673-ENG101139	RPM monitoring level-N_32_MON	768	 /min
    IDE05674-ENG101163	Transm. control module RPM specified value monit. level-N_SP_ETCU_MON	0	 /min
    IDE05675-ENG103796	Short trip RPM specified value-N_SP_IS_EOL	850	 /min
    IDE05676-ENG103974	Idle regulator RPM value-N_SP_IS_FIL	780	 /min
    IDE05677-ENG102856	Idle regulator RPM value monitoring level-N_SP_IS_MON	1248	 /min
    IDE05678-ENG102371	Pre-control for regulating valve for fuel pressure-PCV_PCTL	18.886	 %
    IDE05679-ENG101916	Accelerator monitoring level-PV_AV_MON	0	 %
    IDE05680-ENG99397	OBD-1 Malfunction status-STATE_ERR_EL_LSL_UP[1]	NO_FAULT
    IDE05681-ENG100704	Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]	228
    IDE05682-ENG103046	Oxygen sensor plausibility status-STATE_SYM_DIAG_PUC_LSL_UP[1]	VLS_OK
    IDE05683-ENG99980	Oxygen sensor diagnosis status-STATE_SYM_OBD_LSL_LSH_UP[1]	NO_SYM
    IDE05684-ENG100115	Timer offset oxygen sensor adaptation active-T_DIAG_ACT_OFS[1]	0	 s
    IDE05685-ENG100166	Time too low oxygen sensor voltage-T_VLS_UP_MIN_DIAG_OC_LSL_UP[1]	0	 s
    IDE05686-ENG100966	Null amount calibration current adaptation value-TI_OFS_UPD_CMB_AD	0	 ms
    IDE05687-ENG99851	Torque losses-TQ_LOSS	-18.91	 Nm
    IDE05688-ENG103834	Torque filtered-TQI_DT1_IS_CTL	0	 Nm
    IDE05689-ENG101315	Torque at idle-TQI_IS	48	 Nm
    IDE05690-ENG103219	ESP torque intervention-TQI_MSR_REQ	0	 Nm
    IDE05691-ENG100034	Supply voltage of analog output 1-VCC_1	4.99	 V
    IDE05692-ENG102036	Supply voltage of analog output 2-VCC_2	5	 V
    IDE05693-ENG102409	Volume intervention of valve for fuel metering-VFF_VCV_PCTL	41.4	 ml/min
    IDE05694-ENG102432	Environmental pressure sensor gross voltage-VP_AMP	3.8184	 V
    IDE05695-ENG101654	Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV	3.2416	 V
    IDE05696-ENG101599	Voltage equivalent of valve for fuel metering-VP_CFB_VCV	3.1807	 V
    IDE05697-ENG103427	Cruise control: main switch position-LV_PIN_CRU_OFF_MON	1
    IDE06059-ENG103279	Particulate filter: oil ash mass-MASS_ASH_PF	39.4255402	 g
    IDE06060-ENG111632	Particulate filter ash load limit-C_MASS_ASH_PF_LIM_TEST	70	 g
    IDE07085-ENG113811	Learning cycle counter of min. deviation quant. of injectors-CTR_AD_TOT_CMB_AD[0]	0
    IDE08288-ENG99620	Minimum deviation quantity: adapted points adaptation limit-Binary 16 Bit	00000000 00000000
    IDE08289-ENG99620	Minimum deviation quantity: adapted points-Binary 16 Bit	00000000 00000000
    IDE08750-ENG124670	Adaptation freq. ratio per thousand kilometers-RATIO_DIST_CYC_OK_CMB_AD	25.5	 1/1000 km
    ENG103226	Accelerator pedal sender 1: voltage ratio	0.737	 V
    ENG103029	Accelerator pedal sender 2: voltage ratio	0.366	 V
    ENG99612	AEB_PWM	10	 %
    ENG99746	BYTE_A_OBD	0
    ENG101194	BYTE_B_OBD	14
    ENG103896	BYTE_C_OBD	232
    ENG99936	BYTE_D_OBD	0
    ENG103825	CTR_EOL	0
    ENG102980	CTR_EOL_MAF	0
    ENG100462	CTR_RGN_PF_PTL	2
    ENG101500	CTR_RGN_PF_PTL_HLD	255
    ENG102921	CTR_RGN_PF_SUC_SUM	72
    ENG101140	CTR_RGN_PF_SUM	252
    ENG103437	CTR_SECU_ERR	0
    ENG100764	CTR_SUM_SRV_INTL	0
    ENG103065	CUR_MES_STB_PWL_LOCK_CDN	0
    ENG102309	ECTPWM	0	 %
    ENG106081-ENG101789	EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG	-7.001	 %
    ENG106082-ENG102398	EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG	7.001	 %
    ENG106083-ENG102565	EGR_deviation-EGR_DIF	0.302	 %
    ENG101084	EGRCP_TEMP	66	 C
    ENG101205	EGY_INJ_POST[0.0]	0	 mJ
    ENG102922	EGY_INJ_POST[1.0]	0	 mJ
    ENG103643	EGY_INJ_POST[2.0]	0	 mJ
    ENG100653	EGY_INJ_POST[3.0]	0	 mJ
    ENG103089	EGY_INJ_PREV[0.0]	0	 mJ
    ENG104162	EGY_INJ_PREV[1.0]	0	 mJ
    ENG100215	EGY_INJ_PREV[2.0]	0	 mJ
    ENG100587	EGY_INJ_PREV[3.0]	0	 mJ
    ENG99118	EMV_DCC_CAN	0
    ENG103947	EMV_EILU_CAN	0
    ENG101678	EMV_SMLS_CAN	0
    ENG104178	EMV_VECU_CAN	0
    ENG102855	ESI (extended service intervals) oil level	120	 mm
    ENG101942	ESI (extended service intervals) oil warning threshold	51.5625	 mm
    ENG102595	FAC_CTL_TEG_PF_DOWN	0
    ENG102816	FAC_MASS_ASH_PF	0.95
    ENG102671	FAC_MF_POST_1_COR_PF_DOWN_CTL	0.99998
    ENG102577	FAC_MF_POST_2_COR_PF_DOWN_CTL	0.99998
    ENG102402	FAC_PI_VALUE_TEG_PF_UP_CTL	0
    ENG103715	FAC_PI_VALUE_TEG_TUR_UP_CTL	0
    ENG102041	FCO_T_RAW	0.197	 ml/s
    ENG106675-ENG100872	Freeze_Frame_1_for_processor_monitoring_error-ENVD_MON_3__1	0
    ENG106676-ENG104249	Freeze_Frame_2_for_processor_monitoring_error-ENVD_MON_3__2	0
    ENG111634	FRF_E2P_READ	0
    ENG111635	FRF_E2P_WRITE	0
    ENG106693-ENG101000	Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD	24993.896	 kPa
    ENG99728	LF_STATE_ACC	3
    ENG104069	LF_TEMP_GLP_DR_READY_CAN	0
    ENG107396-ENG102158	Load_class_for_particulate_filter-LOAD_PF_CLAS	3
    ENG102236	LOAD_PF_BAS	9.38	 %
    ENG101747	LOIL_DYN	0	 mm
    ENG102180	LOIL_DYN_TMP	0	 mm
    ENG103837	LOIL_MAX_SRV_INTL	0	 mm
    ENG102184	LOIL_MIN_SRV_INTL	0	 mm
    ENG101445	LV_ACT_EOL	0
    ENG104064	LV_CMD_EGR_COOL	1
    ENG101399	LV_EGR_COOL_OFF	1
    ENG103560	LV_KD_SWI_DISP	0
    ENG103290	LV_LAMB_LS_UP_VLD[1]	0
    ENG100044	LV_LOIL_L_WARN	0
    ENG103908	LV_LOIL_L_WARN_TMP	0
    ENG101737	LV_LSL_AD	1
    ENG103479	LV_LSL_FIRST_GAIN_AD[1]	0
    ENG103152	LV_STA_STOP	1
    ENG102161	M_TUR_KGH	30.91	 kg/h
    ENG103084	MAF_CYL_KGH_OBD	30.5	 kg/h
    ENG102795	MAF_SP_COR_TEG_PF_DOWN_CTL	0	 mg/stroke
    ENG101783	MAF_SP_COR_TEG_TUR_UP_CTL	0	 mg/stroke
    ENG103125	MASS_SOOT_EQU_TOT_FIL_PHY_PF	0.81	 g
    ENG101922	MF_MAIN_SP	8.096	 mg/stroke
    ENG99843	MF_POST_COR_PHY_PF_UP_CTL	0	 mg/stroke
    ENG104252	MF_POST_COR_PHY_TUR_UP_CTL	0	 mg/stroke
    ENG103624	MF_POST_INJ_SUM	0	 mg/stroke
    ENG101033	MF_PREV_INJ_SUM	2	 mg/stroke
    ENG102904	MF_TOT	8.164	 mg/stroke
    ENG100340	MPF_SOOT_DEC_HEAT_PF	0	 g/s
    ENG101244	MPF_SOOT_DEC_NOX_PF	0	 g/s
    ENG100561	MPF_SOOT_EMI_PF	0.0001498	 g/s
    ENG100865	N_SP_IS_ADD_SAVE_EXT_ADJ	0	 /min
    ENG108161-ENG103220	Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H	59	 km
    ENG99137	PV_AV_2	0	 %
    ENG100560	PWM_EGRCP_RAW	95.001	 %
    ENG100435	PWM_EGRCP_SP	99.997	 %
    ENG101432	R_IT_ADJ_CLC[0]	75	 Ohm
    ENG103027	STATE_ADD_HEAT	0
    ENG109084-ENG101970	State_boost_pressure_control-STATE_BPA_CTL	0
    ENG101776	STATE_CMP_TEST	0
    ENG103861	STATE_CRU_SWI_2	0
    ENG101028	STATE_CRU_SWI_3	0
    ENG99491	STATE_DCC_CAN	0
    ENG104046	STATE_DCC_MVB	0
    ENG103504	STATE_ECU_1	1
    ENG100335	STATE_ECU_CAN	0
    ENG99653	STATE_ECU_ERR_1	0
    ENG101505	STATE_ECU_ERR_2	100000
    ENG101745	STATE_ECU_ERR_VCC_MAX	100000
    ENG101853	STATE_ECU_ERR_VCC_MIN	100000
    ENG101677	STATE_EGR_COOL_CDN	59
    ENG103882	STATE_EGR_COOL_DIS	0
    ENG101430	STATE_EGR_CTL_DIAG	0
    ENG102424	STATE_INJ_DEAC	0
    ENG100900	STATE_LAMB_ERR	0
    ENG101468	STATE_LSH	1
    ENG99651	STATE_LSL_IF_SPI	11100100
    ENG99845	STATE_MAF_DIAG	0
    ENG102508	STATE_PF_RGN_CDN	0
    ENG102701	STATE_PVS	1000
    ENG103011	STATE_TCS_DIAG	0
    ENG100504	STATE_TCS_DIAG_2	100
    ENG102191	STATE_TCU	1000000
    ENG101441	STATE_VS_CTL	11
    ENG104148	T_COOL_LOIL	0	 ms
    ENG101325	T_TEMP_SIG_LOIL	61.2	 ms
    ENG99126	T_VS_TOL_LOCK	0	 min
    ENG102431	TCE	87	 C
    ENG101250	TEG_DYN_LS_UP[0]	103.1	 C
    ENG102857	TEG_PF_UP_SP	590.66	 C
    ENG103349	TEMP_HEAT_TOL_ACT	9	 C
    ENG130724-ENG112088	Tester_communication_activ-LV_XSC_MSG_OK_MON	1
    ENG109429-ENG102608	Throttle_actuator_commanded_value-ANG_SP_THR[0]	96.001	 %
    ENG103853	TI_MAIN_TUN[0]	0.4248	 ms
    ENG103104	TI_MAIN_TUN[1]	0.4792	 ms
    ENG101104	TI_MAIN_TUN[2]	0.372	 ms
    ENG103756	TI_MAIN_TUN[3]	0.44	 ms
    ENG103540	TI_POST_TUN[0.0]	0	 ms
    ENG103688	TI_POST_TUN[0.1]	0	 ms
    ENG102269	TI_POST_TUN[1.0]	0	 ms
    ENG104129	TI_POST_TUN[1.1]	0	 ms
    ENG100726	TI_POST_TUN[2.0]	0	 ms
    ENG102673	TI_POST_TUN[2.1]	0	 ms
    ENG100955	TI_POST_TUN[3.0]	0	 ms
    ENG103058	TI_POST_TUN[3.1]	0	 ms
    ENG99903	TI_PREV_TUN[0.0]	0	 ms
    ENG104263	TI_PREV_TUN[0.1]	0.2144	 ms
    ENG99420	TI_PREV_TUN[1.0]	0	 ms
    ENG99442	TI_PREV_TUN[1.1]	0.2056	 ms
    ENG102563	TI_PREV_TUN[2.0]	0	 ms
    ENG99966	TI_PREV_TUN[2.1]	0.2112	 ms
    ENG100993	TI_PREV_TUN[3.0]	0	 ms
    ENG104083	TI_PREV_TUN[3.1]	0.208	 ms
    ENG99994	TQ_DRIV_ADD_WHL	-270	 Nm
    ENG102784	TQ_LIM_GB_PROT	1023.97	 Nm
    ENG99846	TQ_REQ_BRAKE_CRU_CTL	0	 Nm
    ENG102534	TQ_SUM_WHL	1498	 Nm
    ENG102961	TQI_ASR_REQ_SLOW	297.66	 Nm
    ENG102009	TQI_CRU_REQ	-1004.78125	 Nm
    ENG100822	TQI_N_MAX	1023.97	 Nm
    ENG101322	V_KD_AD_MAX	0	 V
    ENG99611	V_TEMP_LS_UP[1]	4.976	 V
    ENG102561	VLS_OFS_LSL_L_GAIN[1]	0	 V
    ENG110143-ENG100688	X_Acceleration_slip_regulation_desired_torque-TQI_ASR_SLOW	1023.97	 Nm
    ENG110145-ENG101310	X_Air_condition_pressure_sensor_pressure_actual_value-ACP_CAN	6.4	 bar
    ENG110153-ENG101887	X_Cruise_control_brake_torque-TQ_REQ_BRAKE_CAN	0	 Nm
    ENG110154-ENG101690	X_Cruise_control_irreversible_disable_conditions-STATE_CRU_DEAC_IRV	99
    ENG110155-ENG102010	X_Cruise_control_operation_status-STATE_CRU_SWI_1	0
    ENG110157-ENG101921	X_Cruise_control_reversible_disable_conditions-STATE_CRU_DEAC_RV	0
    ENG110162-ENG104134	X_ECU_TYPE-LV_SWMD_ISSAMPLEMODE	production
    ENG110175-ENG103404	X_Engine torque at the wheel requested by cruise control-TQDR_REQ_CRU	-65536	 Nm
    ENG110176-ENG99273	X_Engine_calculated_value_ecu_idle_speed_commanded_value_absolute-Engine speed: specified	780	 /min
    ENG110177-ENG100690	X_Engine_drag_torque_control_desired_torque-TQI_MSR_SLOW	0	 Nm
    ENG110178-ENG99147	X_Engine_torque_limitation_mechanical-TQI_MAX	125	 Nm
    ENG110181-ENG103059	X_Exhaust Gas Recirculation Actuator Duty Factor Set Value-CTL_LIM_EGRV[0]	-15.002	 %
    ENG110193-ENG100210	X_Exhaust_gas_temperature_control_state-LF_STATE_TEG_CTL	384
    ENG110194-ENG103099	X_Exhaust_gas_temperature_upstream_atl:_commanded_value-TEG_TUR_UP_SP	603.79	 C
    ENG110195-ENG99504	X_Filtered vehicle speed for cruise control-VS_FIL_CRU	0	 km/h
    ENG110196-ENG102930	X_Fuel_mass_correction_of_exhaust_gas_temperature_control_post_1-MF_ADD_TEG_CTL[0]	0	 mg/stroke
    ENG110197-ENG103680	X_Fuel_mass_correction_of_exhaust_gas_temperature_control_post_2-MF_ADD_TEG_CTL[1]	0	 mg/stroke
    ENG110198-ENG103001	X_Fuel_mass_correction_value_based_on_empirical_calculation_-MF_POST_COR_IPT_PF_UP_CTL	0	 mg/stroke
    ENG110199-ENG99408	X_Fuel_mass_correction_value_based_on_empirical_calculation_-MF_POST_COR_IPT_TUR_UP_CTL	0	 mg/stroke
    ENG110203-ENG101465	X_Fuel_Mean_Value_Adaptation_Learning_Index-CTR_MF_DIF_AD_LAMB	61
    ENG110205-ENG101442	X_Fuel_Mean_Value_Adaptation_Value 1-MF_DIF_AD_LAMB_MES_0	0	 mg/stroke
    ENG110206-ENG101195	X_Fuel_Mean_Value_Adaptation_Value 2-MF_DIF_AD_LAMB_MES_1	0	 mg/stroke
    ENG110231-ENG100304	X_Intermediate_basic_regeneration_level_for_the_particulate_filter-STATE_LEVEL_RGN_PF_INTER	0
    ENG110236-ENG102138	X_Maximal_allowed_fuel_mass_quantity_of_the_post_1_injection-MF_POST_1_MAX_LAMB_MIN	0	 mg/stroke
    ENG110237-ENG100754	X_Maximal_allowed_fuel_mass_quantity_of_the_post_2_injection-MF_POST_2_MAX_LAMB_MIN	0	 mg/stroke
    ENG110242-ENG104261	X_Particulate_filter_load_class_determined_by_soot_load-LOAD_PF_CLAS_SOOT	3
    ENG110243-ENG99978	X_Particulate_filter_load_class_determined_distance:_time_and_consumption-LOAD_PF_CLAS_RGL_END	0
    ENG110244-ENG99556	X_Particulate_filter_regeneration_state_level-STATE_LEVEL_RGN_PF	0
    ENG110245-ENG101979	X_Particulate_filter_state_regeneration_successful-LF_STATE_RGN_PF_SUC	0
    ENG110246-ENG101284	X_Precontrol_correction_for_exhaust_gas_temperature_upstream_particulate_filter_control-MF_POST_TEG_PF_UP_PCTL_COR	0	 mg/stroke
    ENG110247-ENG101460	X_Precontrol_correction_for_exhaust_gas_temperature_upstream_turbocharger_turbine_control-MF_POST_TEG_TUR_UP_PCTL_COR	0	 mg/stroke
    ENG110251-ENG102356	X_Received_acceleration_setpoint_from_distance_cruise_contro-LV_DCC_AC_SP_CAN_DFT	0
    ENG110254-ENG103435	X_Regeneration_interlock_is_active-LV_RGN_LOCK	0
    ENG110255-ENG99110	X_Regeneration_of_particulate_filter_active_interrupt_conditions-LF_INTR_RGN_PF	144
    ENG110256-ENG102620	X_Regeneration_timer_locked_state-T_RGN_LOCK_PF	6.5536	 s
    ENG110257-ENG99193	X_Required_regeneration_level_for_particulate_filter-STATE_RGN_PF_REQ	0
    ENG110258-ENG99928	X_Soot_equivalent_of_ash_mass-MASS_SOOT_EQU_ASH_PF	0.49	 g
    ENG110259-ENG99255	X_Soot_in_the_particulate_filter_is_dry-LV_STATE_SOOT_PF_DRY	0
    ENG110260-ENG100801	X_Soot_mass_state_of_calculation-LF_STATE_MASS_SOOT_CLC_PF	247
    ENG110292-ENG102321	X_Variable Swirl Actuator Duty Factor Set Value-CTL_LIM_PORT[0]	0	 %
    Elapsed Time: 00:39
  2. Likes Uwe liked this post
  3. #2
    Quote Originally Posted by Souriau View Post
    I don't know; I've never done that.
    But one problem with installing used injectors is: When you "code" them in (using Adaptation) the ECU assumes they are brand-spanking new and have no wear. Injectors do wear, and the ECU compensates for this over time.
    PS: I changed "DE06141" to "IDE06141". I'm not sure why the 'I' got dropped, but this will make it easier for searches.
  4. Likes Souriau liked this post
  5. #3
    Aug 2016
    Newry, NI
    Update, Injectors change and running very rought with diesel knocks.
    Adapted injector coding, made no different
    then I carried out IDE06141 in Basic setting.
    This procedure run for 75 minutes before compled, ir vever said, successful or aborted.
    I ended it after 20 minutes idle.
    Took car doe dive and check next moring, it is running sweet and no rought idle or diesel knocking.
    ;Monday	4	November	2019
    IDE00018-ENG99300	Voltage terminal 15-V_IGK	13.6	 V
    IDE00019	Voltage terminal 30	13.44	 V
    IDE00025	Coolant temperature	95	 C
    IDE00078	Time since engine start	4572	 s
    IDE00084	Absolute load value	69	 %
    IDE00085	Normed load value	35.3	 %
    IDE00086	Accelerator position	69	 %
    IDE00100-ENG101842	Engine torque-TQI_SP	44.28	 Nm
    IDE00102-ENG103182	Control Module temperature-TECU	42	 C
    IDE00167	Exhaust temperature 1 bank 1	145.3	 C
    IDE00169	Exhaust temperature 2 bank 1	145.3	 C
    IDE00182-ENG103031	Camshaft adaptation intake bank 1: phase position-Camshaft adjustment: inlet phase: bank 1	0.75
    IDE00188-ENG102817	Fuel high pressure: actual value-FUP_FIL	39.24	 MPa
    IDE00190-ENG100128	Charge air pressure specified value-MAP_SP_MMV	993.68	 hPa
    IDE00191-ENG103684	Charge air pressure: actual value-MAP_MMV	993.68	 hPa
    IDE00192-ENG99381	Coolant temperature at radiator outlet: actual value-TCO_2	95	 C
    IDE00196-ENG100000	Engine oil temperature-TOIL	104	 C
    IDE00198-ENG111631	Refrigerant pressure-ACP_MES	6	 bar
    IDE00201-ENG102664	High fuel pressure: specified value-FUP_SP_KPA	39086.914	 kPa
    IDE00304-ENG101210	Fuel level-FTL_CAN	17	 l
    IDE00347	Air mass: actual value:	8.22	 g/s
    IDE00348	Intake air temperature	34	 C
    IDE00350-ENG99082	Air mass: specified value-MAF_SP_MMV	1388.98	 mg/stroke
    IDE00351-ENG100251	Main injection: start of activation-SOI_MAIN_SP	5.81
    IDE00352-ENG99257	Main injection: duration of activation-TI_MAIN_BAS	0.4264	 ms
    IDE00355-ENG103498	Cruise Control System (CCS): status-Binary 8 Bit	11
    IDE00357-ENG99842	Fuel temperature-TFU	97	 C
    IDE00358-ENG100184	Limitation: torque-TQI_LIM_MIN	111.06	 Nm
    IDE00359-ENG102866	Limitation: smoke-TQI_SLM	111.06	 Nm
    IDE00361-ENG99319	Ambient air pressure-Ambient pressure	973.62	 hPa
    IDE00365-ENG99400	Injection amount deviation cylinder 1-FAC_CYL_BAL1	0.0602	 mg/stroke
    IDE00366-ENG101187	Injection amount deviation cylinder 2-FAC_CYL_BAL2	0.3642	 mg/stroke
    IDE00367-ENG101684	Injection amount deviation cylinder 3-FAC_CYL_BAL3	-1.1453	 mg/stroke
    IDE00368-ENG103465	Injection amount deviation cylinder 4-FAC_CYL_BAL4	0.9381	 mg/stroke
    IDE00371-ENG100275	Fuel consumption-FCO_T	0.4055	 ml/s
    IDE00375-ENG103823	Generator: load signal-ALTPWM	49.9	 %
    IDE00380-ENG102782	Coolant fan 1: activation-Radiator fan 1: activation	14.1	 %
    IDE00383-ENG104210	Pre-injection 1: activation start-SOI_PREV_SP[0]	5.81
    IDE00386-ENG99911	Pre-injection 2: activation duration-TI_PREV_BAS[1]	0.2104	 ms
    IDE00387-ENG99235	Post-injection 1: activation start-SOI_POST_SP[0]	17.65
    IDE00389-ENG103789	Post-injection 2: activation start-SOI_POST_SP[1]	5.81
    IDE00392-ENG100739	Accelerator pedal: sensor voltage 1-V_PVS_1_BAS	3.481	 V
    IDE00393-ENG102348	Accelerator pedal: sensor voltage 2-V_PVS_2_BAS	1.743	 V
    IDE00404-ENG102559	Throttle valve: activation-PWM_HBR_THR[0]	-10.135	 %
    IDE00405-ENG98787	Crankshaft speed (RPM)-N	782	 /min
    IDE00406-ENG102227	Camshaft speed (RPM)-N_CAM	391	 /min
    IDE00423-ENG103230	Service regeneration: Release conditions 2-Binary 32 Bit	11111111 11111110 11111111 11010100
    IDE00427-ENG101722	Particle filter: difference pressure-DIP_PF	15.01	 hPa
    IDE00428-ENG100917	Particle filter: offset for differential press.-DIP_PF_AD[0]	-0.33	 hPa
    IDE00432-ENG103847	Particle filter: time since last regeneration-T_WOUT_RGN	33555.8	 s
    IDE00433-ENG103279	Particle filter: oil ash volume-MASS_ASH_PF	39.4658533	 g
    IDE00434-ENG102050	Particle filter: soot mass calculated-MASS_SOOT_SIM_PF	16.56	 g
    IDE00435-ENG101197	Particle filter: soot mass measured-MASS_SOOT_PHY_PF	2.82	 g
    IDE00436-ENG102397	Particle filter: kilometers since last regeneration-DIST_RGN	117.2	 km
    IDE00437-ENG99390	Injector valve 1: capacity-CAPA_INJ_MAIN[0]	8.0104	 F
    IDE00438-ENG103101	Injector valve 2: capacity-CAPA_INJ_MAIN[1]	7.8586	 F
    IDE00439-ENG102776	Injector valve 3: capacity-CAPA_INJ_MAIN[2]	8.0138	 F
    IDE00440-ENG104221	Injector valve 4: capacity-CAPA_INJ_MAIN[3]	8.0388	 F
    IDE00472-ENG99569	Mean injection quantity-MF_INJ_SUM	8.04	 mg/stroke
    IDE00473-ENG102104	EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]	0	 %
    IDE00474	Ambient air pressure	97	 kPa abs
    IDE00475-ENG99518	Fuel Pressure Regulator Valve-PCV	20.226	 %
    IDE00476-ENG104101	Fuel Metering Valve-VCV	31.653	 %
    IDE00477-ENG99523	Torque request: sum of auxiliary aggregate-TQ_LOSS_ADD	-7.44	 Nm
    IDE00478-ENG104104	Engine-drag torque-TQFR_BAS	-13.63	 Nm
    IDE00481-ENG103062	Limitation: status of clutch protection-LV_TQI_LIM_CLU_PROT_ACT	0
    IDE00495-ENG99873	Calculated oil temperature-TOIL_MDL	85	 C
    IDE00558	Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor)	0.728 Lambda / 0.000 V
    IDE00581	EGR specified value	0	 %
    IDE00584	Distance driven since erasing DTC memory	4	 km
    IDE00586	Deviation of exh.gas recirc. rate	99.2	 %
    IDE00589	Fuel pressure	37890	 kPa rel
    IDE00594	Absolute intake pressure	99	 kPa abs
    IDE00603	Number of driving cycles since erasing DTC memory	1
    IDE00607	Time since erasing DTC memory	102	 min
    IDE01259-ENG101906	EGR Solen.val.: actual value-ANG_EGRV[0]	1.129	 %
    IDE01260-ENG99807	Generator power-GEN_LOAD_CAN	51.6	 %
    IDE01361-ENG102606	exh.gas recirc. (EGR) cooler pump: specified value-PWM_EGRCP[0]	99.997	 %
    IDE01362-ENG99381	Cooler for exh.gas recirc.: temperature-TCO_2	95	 C
    IDE01366-ENG101906	Exhaust flap: actual value-ANG_EGRV[0]	1.129	 %
    IDE01367-ENG99571	Turbocharger boost control: offset closed-V_BPA_TOL[0]	3.447	 V
    IDE01373-ENG102590	EGR valve: offset closed-V_EGRV_BOL[0]	0.952	 V
    IDE01377-ENG100929	Throttle valve adapter: actual value-ANG_THR[0]	96.118	 %
    IDE01378-ENG100595	High fuel pressure: control deviation-PFU_DIF	-0.153	 MPa
    IDE01380-ENG103961	Pre-injection 3: activation start-SOI_PREV_SP[2]	1.08
    IDE01381-ENG99178	Pre-injection 3: activation duration-TI_PREV_BAS[2]	0.2144	 ms
    IDE01382-ENG103886	Post-injection 3: activation start-SOI_POST_SP[2]	5.81
    IDE01407-ENG100958	Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN	18.13	 l
    IDE01834	Battery voltage	13.3	 V
    IDE01880	Accelerator position 2	69	 %
    IDE02229-ENG102154	Exh.gas temp.sen 1-TEG_MES[0]	145.35	 C
    IDE02234-ENG102117	Exh.gas temp.sen 3-TEG_MES[1]	157.91	 C
    IDE02236-ENG102786	Exh.gas temp.sen 4-TEG_MES[2]	154.04	 C
    IDE03270-ENG111636	Exh.gas temp.sen 1: unconditioned voltage-VP_TEG[0]	3.2315	 V
    IDE03273-ENG111637	Exh.gas temp.sen 3: unconditioned voltage-VP_TEG[1]	0.797	 V
    IDE03275-ENG111638	Exh.gas temp.sen 4: unconditioned voltage-VP_TEG[2]	0.7921	 V
    IDE03712-ENG103230	Engine diagnostic status in curr driving cycle (end-of-line)-Binary 32 Bit	00000000 00000011 00000011 00001011
    IDE03892-ENG102868	Fuel high pressure sensor: unconditioned voltage-VP_PFU	1.3091	 V
    IDE03893-ENG101196	Injection valve 1: voltage-V_INJ_MAIN[0]	104.71	 V
    IDE03894-ENG104143	Injection valve 2: voltage-V_INJ_MAIN[1]	105.68	 V
    IDE03895-ENG101536	Injection valve 3: voltage-V_INJ_MAIN[2]	105.92	 V
    IDE03896-ENG102925	Injection valve 4: voltage-V_INJ_MAIN[3]	103.98	 V
    IDE03949-ENG102262	Air mass: actual value (mg/stroke)-MAF_MES	354.228	 mg/stroke
    IDE04005-ENG103719	Accelerator position: normalized-Accelerator position	98.44	 %
    IDE04105-ENG102360	Environmental conditions-TQ_LOSS_ALTER	-7.63	 Nm
    IDE04105-ENG124671	Environmental conditions-TQFR_ADD_ENV	0	 Nm
    IDE04105-ENG124674	Environmental conditions-TQI_I_IS_CTL	44.28	 Nm
    IDE04105-ENG124658	Environmental conditions-LF_CAN_MON_1_ENVD	0
    IDE04105-ENG100863	Environmental conditions-FAC_COR_SLOP_CHA_CAL[0]	0.98672
    IDE04105-ENG103478	Environmental conditions-PFU	39.746	 MPa
    IDE04105-ENG124664	Environmental conditions-LF_TQ_LOSS_MON_1_ENVD_0	0
    IDE04105-ENG124659	Environmental conditions-LF_CRU_MON_1_ENVD	0
    IDE04105-ENG124679	Environmental conditions-VP_MC_AN_DIG_MON	1.7432	 V
    IDE04105-ENG124680	Environmental conditions-VP_MU_AN_DIG_MON	1.7383	 V
    IDE04105-ENG124665	Environmental conditions-LF_TQ_LOSS_MON_1_ENVD_1	0
    IDE04105-ENG124661	Environmental conditions-LF_PVS_MON_1_ENVD	0
    IDE04257-ENG100212	High pressure EGR actuator: activation-PWM_HBR_EGRV[0]	-15.958	 %
    IDE04258-ENG100888	Actuator for high pressure EGR: status-LF_STATE_EGRV_DISP[0]	6
    IDE04259-ENG99492	High press EGR actuator: actual unconditioned volt val-V_EGRV[0]	0.981	 V
    IDE04263-ENG102014	Sensor for particle filter differential press: raw value-DIP_PF_RAW[0]	14.76	 hPa
    IDE04265-ENG104156	Throttle valve adapter: uncond voltage actual value-V_THR[0]	4.453	 V
    IDE04266-ENG104017	High press turbocharger actuator: activation-CTL_LIM_BPA[0]	74.969	 %
    IDE04268-ENG102598	High press turbocharger actuator: actual uncond volt value-V_BPA[0]	3.271	 V
    IDE04271-ENG100727	Intake manif runner actuator: uncond volt actual value-V_PORT[0]	4.99	 V
    IDE04551-ENG103251	Exh gas press sensor 1: uncond voltage value-PRS_EX_PCAT_UP	992.27	 hPa
    IDE04673-ENG103030	O2 sensor 1 bank 1: duty cycle O2 heater-LSHPWM_UP[1]	45.3125	 %
    IDE04680-ENG99353	O2 sensor 1: bank 1: voltage raw value O2 signal-Lambda probe voltage: bank 1: probe 1 (broadband probe)	2.92	 V
    IDE04684-ENG104138	Desired injection characteristic-PFU_SP_INJ_AD	39.319	 MPa
    IDE04937-ENG102996	Sensor for engine block temperature: raw value-Coolant temperature	96	 C
    IDE04938-ENG102512	Sensor for temp after charge air cooler: raw value-TBA_MES	33	 C
    IDE05466-ENG103340	Oxy sensor 1 bank 1 offset spec value-VLS_OFS_LSL[1]	0.0058	 V
    IDE05468-ENG102329	Oxygen sensor 1 bank 1 ceramic temp-TTIP_MES_LS_UP[1]	830.0625	 C
    IDE05632-ENG101485	Fuel pressure regulator valve actual value-CFB_PCV_MES	0.473	 A
    IDE05633-ENG100012	Valve for fuel metering: feedback value measured-CFB_VCV_MES	1.007	 A
    IDE05634-ENG103637	Voltage load of main injection cylinder 1-CHR_INJ_MAIN[0]	828.7	 As
    IDE05635-ENG99789	Voltage load of main injection cylinder 2-CHR_INJ_MAIN[1]	822.4	 As
    IDE05636-ENG103475	Voltage load of main injection cylinder 3-CHR_INJ_MAIN[2]	843.8	 As
    IDE05637-ENG101402	Voltage load of main injection cylinder 4-CHR_INJ_MAIN[3]	834.4	 As
    IDE05642-ENG100743	Rule deviation of energy control cylinder 1-EGY_INJ_CTL_DIF[0]	0.016	 mJ
    IDE05643-ENG101114	Rule deviation of energy control cylinder 2-EGY_INJ_CTL_DIF[1]	-0.048	 mJ
    IDE05644-ENG103009	Rule deviation of energy control cylinder 3-EGY_INJ_CTL_DIF[2]	0.072	 mJ
    IDE05645-ENG102758	Rule deviation of energy control cylinder 4-EGY_INJ_CTL_DIF[3]	0.048	 mJ
    IDE05646-ENG101723	Measured energy of main injection cylinder 1-EGY_INJ_MAIN[0]	43.419	 mJ
    IDE05647-ENG101584	Measured energy of main injection cylinder 2-EGY_INJ_MAIN[1]	44.097	 mJ
    IDE05648-ENG103761	Measured energy of main injection cylinder 3-EGY_INJ_MAIN[2]	44.863	 mJ
    IDE05649-ENG100583	Measured energy of main injection cylinder 4-EGY_INJ_MAIN[3]	43.172	 mJ
    IDE05650-ENG102923	Energy control injector 1 specified value-EGY_INJ_SP[0]	42.693	 mJ
    IDE05651-ENG101270	Energy control injector 2 specified value-EGY_INJ_SP[1]	42.047	 mJ
    IDE05652-ENG100278	Energy control injector 3 specified value-EGY_INJ_SP[2]	40.747	 mJ
    IDE05653-ENG101718	Energy control injector 4 specified value-EGY_INJ_SP[3]	42.262	 mJ
    IDE05654-ENG100606	Oxygen sensor enhancement adaptation factor-FAC_LSL_GAIN_AD[1]	0.95856
    IDE05655-ENG101493	Air mass proportion filtered-FAC_MAF_CYL_KGH_RATIO_FIL	1.02728
    IDE05660-ENG102585	Energy control cylinder 1: integral part-I_CTL_EGY[0]	1.682	 %
    IDE05661-ENG99987	Energy control cylinder 2: integral part-I_CTL_EGY[1]	1.959	 %
    IDE05662-ENG104135	Energy control cylinder 3: integral part-I_CTL_EGY[2]	2.35	 %
    IDE05663-ENG103697	Energy control cylinder 4: integral part-I_CTL_EGY[3]	1.956	 %
    IDE05665-ENG103851	Oxygen value calculated-LAMB_EXT_CLC_FIL	3.2607
    IDE05667-ENG101827	Brake status monitoring level-LV_BRAKE_MON	1
    IDE05678-ENG102371	Pre-control for regulating valve for fuel pressure-PCV_PCTL	21.661	 %
    IDE05679-ENG101916	Accelerator monitoring level-PV_AV_MON	98.4375	 %
    IDE05681-ENG100704	Oxygen sensor controller register-STATE_LSL_IF_SPI_RD[1]	108
    IDE05687-ENG99851	Torque losses-TQ_LOSS	-20.69	 Nm
    IDE05689-ENG101315	Torque at idle-TQI_IS	44.78	 Nm
    IDE05693-ENG102409	Volume intervention of valve for fuel metering-VFF_VCV_PCTL	49.8	 ml/min
    IDE05694-ENG102432	Environmental pressure sensor gross voltage-VP_AMP	3.9111	 V
    IDE05695-ENG101654	Voltage equiv. current of regulating valve for fuel pressure-VP_CFB_PCV	3.232	 V
    IDE05696-ENG101599	Voltage equivalent of valve for fuel metering-VP_CFB_VCV	3.0524	 V
    IDE06059-ENG103279	Particulate filter: oil ash mass-MASS_ASH_PF	39.4658533	 g
    ENG103226	Accelerator pedal sender 1: voltage ratio	3.477	 V
    ENG103029	Accelerator pedal sender 2: voltage ratio	1.743	 V
    ENG99936	BYTE_D_OBD	64
    ENG103825	CTR_EOL	0
    ENG106081-ENG101789	EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG	-89.999	 %
    ENG106082-ENG102398	EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG	89.999	 %
    ENG106083-ENG102565	EGR_deviation-EGR_DIF	-66.241	 %
    ENG101084	EGRCP_TEMP	95	 C
    ENG102855	ESI (extended service intervals) oil level	52.5	 mm
    ENG101942	ESI (extended service intervals) oil warning threshold	51.3125	 mm
    ENG102041	FCO_T_RAW	0.206	 ml/s
    ENG106693-ENG101000	Fuel high pressure commanded value_1-FUP_SP_KPA_ENVD	0	 kPa
    ENG107396-ENG102158	Load_class_for_particulate_filter-LOAD_PF_CLAS	4
    ENG102236	LOAD_PF_BAS	31.44	 %
    ENG103290	LV_LAMB_LS_UP_VLD[1]	1
    ENG102161	M_TUR_KGH	32.22	 kg/h
    ENG103084	MAF_CYL_KGH_OBD	31.81	 kg/h
    ENG103125	MASS_SOOT_EQU_TOT_FIL_PHY_PF	3.33	 g
    ENG101922	MF_MAIN_SP	4.444	 mg/stroke
    ENG102904	MF_TOT	7.456	 mg/stroke
    ENG100561	MPF_SOOT_EMI_PF	0.0001404	 g/s
    ENG108161-ENG103220	Particle filter kilometers since last regeneration_1-DIST_RGN_ENVD_H	0	 km
    ENG99137	PV_AV_2	98.83	 %
    ENG101432	R_IT_ADJ_CLC[0]	65	 Ohm
    ENG101468	STATE_LSH	10
    ENG99651	STATE_LSL_IF_SPI	1101100
    ENG102701	STATE_PVS	0
    ENG101325	T_TEMP_SIG_LOIL	68.3	 ms
    ENG102431	TCE	96	 C
    ENG101250	TEG_DYN_LS_UP[0]	157.35	 C
    ENG102857	TEG_PF_UP_SP	581.6	 C
    ENG103853	TI_MAIN_TUN[0]	0.4112	 ms
    ENG103104	TI_MAIN_TUN[1]	0.3728	 ms
    ENG101104	TI_MAIN_TUN[2]	0.4208	 ms
    ENG103756	TI_MAIN_TUN[3]	0.416	 ms
    ENG104263	TI_PREV_TUN[0.1]	0.2168	 ms
    ENG99442	TI_PREV_TUN[1.1]	0.2136	 ms
    ENG99966	TI_PREV_TUN[2.1]	0.2104	 ms
    ENG104083	TI_PREV_TUN[3.1]	0.2144	 ms
    ENG99994	TQ_DRIV_ADD_WHL	-290	 Nm
    ENG102534	TQ_SUM_WHL	1478	 Nm
    ENG102009	TQI_CRU_REQ	-1003.125	 Nm
    ENG99611	V_TEMP_LS_UP[1]	0.923	 V
    ENG102561	VLS_OFS_LSL_L_GAIN[1]	0.0029	 V
    ENG110145-ENG101310	X_Air_condition_pressure_sensor_pressure_actual_value-ACP_CAN	5.6	 bar
    ENG110155-ENG102010	X_Cruise_control_operation_status-STATE_CRU_SWI_1	11
    ENG110194-ENG103099	X_Exhaust_gas_temperature_upstream_atl:_commanded_value-TEG_TUR_UP_SP	601.98	 C
    ENG110203-ENG101465	X_Fuel_Mean_Value_Adaptation_Learning_Index-CTR_MF_DIF_AD_LAMB	4
    ENG110242-ENG104261	X_Particulate_filter_load_class_determined_by_soot_load-LOAD_PF_CLAS_SOOT	4
    ENG110255-ENG99110	X_Regeneration_of_particulate_filter_active_interrupt_conditions-LF_INTR_RGN_PF	80
    IDE00264-Injector 2 correction value	8ADEFD0 	7
    IDE00265-Injector 3 correction value	96KDFF0 	7
    IDE00266-Injector 4 correction value	AEKEHK0 	7
    IDE00275-Particle filter initialization	39.4659 g	4
    IDE03237-Compensation for empty stroke	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 51 C3 00 00 14 87 00 00 14 8A 00 00 18 69 00 0F 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 00 00 51 00 28 00 28 00 51 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	78
  6. Likes Uwe liked this post
  7. #4
    Aug 2016
    Newry, NI
    Hello, I have another VW Golf that need the injectors adapted like I did above but I can not see the IDE06141 Adaption this this list.
    1 year younger and different engine code CAYB and CAYC.
    IS IDE06141 not vailable or is my VCDS not showing it properly?
    Wednesday,15,January,2020,12:41:25:46973
    VIN: WVWZZZ1KZAP111779   License Plate:
    Chassis Type: 1K-VW36 (1K0)
    VIN: WVWZZZ1KZAP111779   Mileage: 140850km-87520miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 B    HW: 03L 906 023 A
       Component: 1,6l R4 CR td H23 5863
       ASAM Dataset: EV_ECM16TDI02103L906023B 001005
       ROD: EV_ECM16TDI02103L906023A_001.rod
       VCID: A502B8C9A456FB6774-80F0
    Readiness: 1010 0000
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 133B200D092300FBC81204EB90220080300000
       VCID: F8BCA1BD4B64B68F1F-80AC
       Revision: 00009001
       Coding: 0000000002
       Part No SW: 1K0 937 085 D    HW: 1K0 937 085 D
       Component: BCM PQ35  B+  103 0575
       Revision: 00103 AG
       Coding: 40180A3A9833189044000080100080E447210088524D8160648000200000
       VCID: B02C599DE394AECF97-80E4
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 21120  21  0512
       Coding: 009795
       Serial number: 003FKD03NF9F
       Coding: 00003133
       Shop #: WSC 01383 790 00061
       Serial number: 3572MSME1E51724EZZZ+
       Serial number: 3582MSME213A524EZZZZ
       Serial number: 3512QSME1A004A3CZZZV
       Serial number: 3522QSME30134A2CZZZR
       Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
       Component: J0527           053 0111
       Coding: 0000004
       VCID: 8346C651C2A2E5573A-80D6
       Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
       Component: KOMBI         H04 0308
       Coding: 470B00
       VCID: B83C61BD03E4768FDF-80EC
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H07 0112
       Revision:   H07 01    Serial number: 040110F1000755
       Coding: E9801F06000202000003
       VCID: E99AF4F9C0CE1F0790-80BC
       Component: IMMO          H04 0308
       Coding: 0000564
       Revision: 00H17000
       Coding: 0000564
       Part No SW: 1K0 035 156 B    HW: 1K0 035 156 B
       Component: Radio         H21 0057
       Revision: R0000000    Serial number: VWZAZ1I8636952
       Coding: 0000020002
       VCID: A208A3D5BD780C5F11-80F6
    End----------(Elapsed Time: 00:44, VBatt start/end: 14.2V/14.2V)-----------
    ;SW:03L-906-023-B   HW:03L-906-023-A ---  Engine
    ;Component:1	6l R4 CR td H23 5863	 Coding:00114014030500080000
    ;EV_ECM16TDI02103L906023B	1005	EV_ECM16TDI02103L906023A_001.rod
    ;Wednesday	15	January	2020	12:18:17:46973
    ;VCID: A502B8C9A456FB6774-80F0
    IDE00259-Idle RPM correction	0 /min	1
    IDE00263-Injector 1 correction value	BADGKM0 	7
    IDE00264-Injector 2 correction value	A0DEHH0 	7
    IDE00265-Injector 3 correction value	A4DEHJ0 	7
    IDE00266-Injector 4 correction value	A7DEJJ0 	7
    IDE00275-Particle filter initialization	27.6443 g	4
    IDE02247-Static maximum speed limit	250.0 km/h	2
    IDE02248-Individually adjustable maximum speed limit	250.0 km/h	2
    IDE03237-Compensation for empty stroke	00 00 00 33 FF 25 00 00 00 06 00 00 03 E8 03 E8 00 00 00 00 10 D6 00 9E 60 FF 00 9E 80 E2 00 00 0F D2 00 0F 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 7F FF 00 06 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 	78
    Elapsed Time: 00:03
    ;Wednesday	15	January	2020	12:17:26:46973
    IDE00019	Voltage terminal 30	14.231	 V
    IDE00021	Engine speed	779	 /min
    IDE00030-ENG102351	Status of actuator test-Actuator Test Status	not active
    IDE00078	Time since engine start	363	 s
    IDE00083	Throttle valve position (absolute)	88.6	 %
    IDE00084	Absolute load value	68	 %
    IDE00085	Normed load value	40.4	 %
    IDE00086	Accelerator position	15	 %
    IDE00100-ENG101842	Engine torque-TQI_SP	50.03	 Nm
    IDE00167	Exhaust temperature 1 bank 1	121.5	 C
    IDE00169	Exhaust temperature 2 bank 1	122.1	 C
    IDE00188-ENG102817	Fuel high pressure: actual value-FUP_FIL	41.437	 MPa
    IDE00190-ENG100128	Charge air pressure specified value-MAP_SP_MMV	1003.05	 hPa
    IDE00191-ENG103684	Charge air pressure: actual value-MAP_MMV	1003.3	 hPa
    IDE00192-ENG99381	Coolant temperature at radiator outlet: actual value-TCO_2	32	 C
    IDE00201-ENG102664	High fuel pressure: specified value-FUP_SP_KPA	41235.352	 kPa
    IDE00347	Air mass: actual value:	8.25	 g/s
    IDE00348	Intake air temperature	9	 C
    IDE00350-ENG99082	Air mass: specified value-MAF_SP_MMV	328.58	 mg/stroke
    IDE00351-ENG100251	Main injection: start of activation-SOI_MAIN_SP	5.51
    IDE00352-ENG99257	Main injection: duration of activation-TI_MAIN_BAS	0.4216	 ms
    IDE00357-ENG99842	Fuel temperature-TFU	16	 C
    IDE00358-ENG100184	Limitation: torque-TQI_LIM_MIN	118.78	 Nm
    IDE00359-ENG102866	Limitation: smoke-TQI_SLM	120	 Nm
    IDE00362-ENG100099	Charge Pressure Actuator: activation-ANG_SP_BPA[0]	85.001	 %
    IDE00365-ENG99400	Injection amount deviation cylinder 1-FAC_CYL_BAL1	2.4978	 mg/stroke
    IDE00366-ENG101187	Injection amount deviation cylinder 2-FAC_CYL_BAL2	0.6693	 mg/stroke
    IDE00367-ENG101684	Injection amount deviation cylinder 3-FAC_CYL_BAL3	-1.2182	 mg/stroke
    IDE00368-ENG103465	Injection amount deviation cylinder 4-FAC_CYL_BAL4	-2.3308	 mg/stroke
    IDE00371-ENG100275	Fuel consumption-FCO_T	0.2258	 ml/s
    IDE00373-ENG100936	Electric auxiliary heater: shut-off conditions-SF_HEAT	193
    IDE00375-ENG103823	Generator: load signal-ALTPWM	41.163	 %
    IDE00383-ENG104210	Pre-injection 1: activation start-SOI_PREV_SP[0]	-24.49
    IDE00385-ENG99181	Pre-injection 2: activation start-SOI_PREV_SP[1]	-6.52
    IDE00386-ENG99911	Pre-injection 2: activation duration-TI_PREV_BAS[1]	0.2072	 ms
    IDE00387-ENG99235	Post-injection 1: activation start-SOI_POST_SP[0]	5.51
    IDE00389-ENG103789	Post-injection 2: activation start-SOI_POST_SP[1]	5.51
    IDE00392-ENG100739	Accelerator pedal: sensor voltage 1-V_PVS_1_BAS	0.747	 V
    IDE00393-ENG102348	Accelerator pedal: sensor voltage 2-V_PVS_2_BAS	0.376	 V
    IDE00396-ENG103408	Charge Pressure Actuator: acknowledgment-ANG_BPA[0]	85.547	 %
    IDE00401-ENG102947	Intake manifold Runner Control (IMRC): acknowledgment-ANG_PORT[0]	6.403	 %
    IDE00405-ENG98787	Crankshaft speed (RPM)-N	788	 /min
    IDE00406-ENG102227	Camshaft speed (RPM)-N_CAM	390.5	 /min
    IDE00413-ENG102094	Starter control: Interlock- or P/N-signal-LV_PN	0
    IDE00423-ENG103230	Service regeneration: Release conditions 2-Binary 32 Bit	01111001 11110101 10111111 11011111
    IDE00427-ENG101722	Particle filter: difference pressure-DIP_PF	1.41	 hPa
    IDE00428-ENG100917	Particle filter: offset for differential press.-DIP_PF_AD[0]	-1.33	 hPa
    IDE00432-ENG103847	Particle filter: time since last regeneration-T_WOUT_RGN	671088.63	 s
    IDE00433-ENG103279	Particle filter: oil ash volume-MASS_ASH_PF	27.6442725	 g
    IDE00434-ENG102050	Particle filter: soot mass calculated-MASS_SOOT_SIM_PF	655.34	 g
    IDE00435-ENG101197	Particle filter: soot mass measured-MASS_SOOT_PHY_PF	0	 g
    IDE00436-ENG102397	Particle filter: kilometers since last regeneration-DIST_RGN	0	 km
    IDE00472-ENG99569	Mean injection quantity-MF_INJ_SUM	11.664	 mg/stroke
    IDE00475-ENG99518	Fuel Pressure Regulator Valve-PCV	17.03	 %
    IDE00476-ENG104101	Fuel Metering Valve-VCV	18.886	 %
    IDE00477-ENG99523	Torque request: sum of auxiliary aggregate-TQ_LOSS_ADD	-4.09	 Nm
    IDE00478-ENG104104	Engine-drag torque-TQFR_BAS	-14.25	 Nm
    IDE00495-ENG99873	Calculated oil temperature-TOIL_MDL	93	 C
    IDE00556	Outside air temperature	6	 C
    IDE00558	Voltage of oxygen sensor bank 1 sensor 1 (broadband sensor)	0.000 Lambda / 0.000 V
    IDE00583	Throttle valve specified value	4	 %
    IDE00584	Distance driven since erasing DTC memory	0	 km
    IDE00586	Deviation of exh.gas recirc. rate	-65.6	 %
    IDE00589	Fuel pressure	39640	 kPa rel
    IDE00594	Absolute intake pressure	100	 kPa abs
    IDE00603	Number of driving cycles since erasing DTC memory	0
    IDE00606	Oper. time with exh. Malfunction Indicator Lamp activated	0h 0min
    IDE00607	Time since erasing DTC memory	0h	0min
    IDE00611	Malfunction that has caused the ambient data to be stored	P0000
    IDE01259-ENG101906	EGR Solen.val.: actual value-ANG_EGRV[0]	-5.261	 %
    IDE01260-ENG99807	Generator power-GEN_LOAD_CAN	40	 %
    IDE01361-ENG102606	exh.gas recirc. (EGR) cooler pump: specified value-PWM_EGRCP[0]	95.233	 %
    IDE01362-ENG99381	Cooler for exh.gas recirc.: temperature-TCO_2	32	 C
    IDE01366-ENG101906	Exhaust flap: actual value-ANG_EGRV[0]	-5.261	 %
    IDE01367-ENG99571	Turbocharger boost control: offset closed-V_BPA_TOL[0]	3.511	 V
    IDE01373-ENG102590	EGR valve: offset closed-V_EGRV_BOL[0]	1.001	 V
    IDE01375-ENG101848	Throttle valve adapter: offset closed-V_THR_BOL[0]	0.688	 V
    IDE01377-ENG100929	Throttle valve adapter: actual value-ANG_THR[0]	95.868	 %
    IDE01378-ENG100595	High fuel pressure: control deviation-PFU_DIF	0.049	 MPa
    IDE01380-ENG103961	Pre-injection 3: activation start-SOI_PREV_SP[2]	-1.29
    IDE01381-ENG99178	Pre-injection 3: activation duration-TI_PREV_BAS[2]	0.2088	 ms
    IDE01382-ENG103886	Post-injection 3: activation start-SOI_POST_SP[2]	5.48
    IDE01407-ENG100958	Particle filter: fuel consumption since last regeneration-FCO_SUM_RGN	655.35	 l
    IDE01410-ENG102169	Charge limit over-charge-Ash Mass Diag	327.67	 g
    IDE02229-ENG102154	Exh.gas temp.sen 1-TEG_MES[0]	122.1	 C
    IDE02234-ENG102117	Exh.gas temp.sen 3-TEG_MES[1]	124.48	 C
    IDE02236-ENG102786	Exh.gas temp.sen 4-TEG_MES[2]	112.54	 C
    IDE03362-ENG103557	Requested transmission torque-TQI_REQ_ETCU	0	 Nm
    IDE03712-ENG103230	Engine diagnostic status in curr driving cycle (end-of-line)-Binary 32 Bit	00000000 00000001 00000000 00000000
    IDE03949-ENG103150	Air mass: actual value (mg/stroke)-MAF_MMV	327.01	 mg/stroke
    IDE04105-ENG99709	Environmental conditions-AC_SP_CRU_EXT_ENVD	-27.9	 m/s
    IDE04105-ENG102466	Environmental conditions-AC_VEH_CLC_ENVD	-27.9	 m/s
    IDE04105-ENG102621	Environmental conditions-AD_BPA_MMV_ENVD	0.3	 %
    IDE04105-ENG101830	Environmental conditions-AMP_ENVD	0	 hPa
    IDE04105-ENG102752	Environmental conditions-AMP_MES_ENVD	0	 hPa
    IDE04105-ENG100395	Environmental conditions-ANG_BPA_ENVD	0.3	 %
    IDE04105-ENG102461	Environmental conditions-ANG_EGRV_ENVD	0.3	 %
    IDE04105-ENG102092	Environmental conditions-ANG_PORT_ENVD	0.3	 %
    IDE04105-ENG102835	Environmental conditions-ANG_SLOP_ROAD_ENVD	0	 rad
    IDE04105-ENG101088	Environmental conditions-ANG_SP_BPA_ENVD	0	 %
    IDE04105-ENG103092	Environmental conditions-ANG_SP_EGRV_ENVD	0	 %
    IDE04105-ENG103071	Environmental conditions-ANG_SP_PORT_ENVD	0	 %
    IDE04105-ENG103480	Environmental conditions-ANG_SP_THR_ENVD	0	 %
    IDE04105-ENG103771	Environmental conditions-ANG_THR_ENVD	0.3	 %
    IDE04105-ENG102239	Environmental conditions-BPA_PWM_ENVD	0	 %
    IDE04105-ENG100145	Environmental conditions-CONC_O2_ADJ_CLC_ENVD	0.3	 %
    IDE04105-ENG102119	Environmental conditions-CTL_LIM_THR_ENVD	0.3	 %
    IDE04105-ENG102216	Environmental conditions-DIP_PF_ENVD	0	 hPa
    IDE04105-ENG100269	Environmental conditions-DIP_PF_AD_ENVD	0	 hPa
    IDE04105-ENG104080	Environmental conditions-DIST_RGN_ENVD	0	 km
    IDE04105-ENG99250	Environmental conditions-EGR_SP_ENVD	0	 %
    IDE04105-ENG100985	Environmental conditions-EGRV_PWM_COR_ENVD	0.3	 %
    IDE04105-ENG100422	Environmental conditions-EGRV_PWM_ENVD	0	 %
    IDE04105-ENG101210	Environmental conditions-FTL_CAN	22	 l
    IDE04105-ENG103072	Environmental conditions-EGY_INJ_SP_ENVD[0]	0	 mJ
    IDE04105-ENG103934	Environmental conditions-EGY_INJ_SP_ENVD[1]	0	 mJ
    IDE04105-ENG101367	Environmental conditions-EGY_INJ_SP_ENVD[2]	0	 mJ
    IDE04105-ENG102256	Environmental conditions-EGY_INJ_SP_ENVD[3]	0	 mJ
    IDE04105-ENG102815	Environmental conditions-FAC_MAF_CYL_KGH_RATIO_FIL_ENVD	0
    IDE04105-ENG100664	Environmental conditions-PFU_ENVD	0	 MPa
    IDE04105-ENG101582	Environmental conditions-LAMB_LS_UP_ENVD	0	 MPa
    IDE04105-ENG103781	Environmental conditions-MASS_SOOT_PF_ENVD	-230.4	 g
    IDE04105-ENG101509	Environmental conditions-MAF_ENVD	0	 mg/stroke
    IDE04105-ENG103333	Environmental conditions-MAF_MES_ENVD	0	 mg/stroke
    IDE04105-ENG101708	Environmental conditions-MAF_INT_PUC_ACT_ENVD	0	 mg/stroke
    IDE04105-ENG101981	Environmental conditions-MAF_KGH_MES_ENVD	0	 mg/stroke
    IDE04105-ENG100906	Environmental conditions-MAF_MMV_ENVD	0	 mg/stroke
    IDE04105-ENG103109	Environmental conditions-MAF_SP_ENVD	0	 mg/stroke
    IDE04105-ENG103376	Environmental conditions-MAF_SP_MMV_SUB_ENVD	0	 mg/stroke
    IDE04105-ENG100090	Environmental conditions-MAP_MES_ENVD	0	 hPa
    IDE04105-ENG102412	Environmental conditions-MAP_SP_ENVD	0	 hPa
    IDE04105-ENG101487	Environmental conditions-PRS_EX_ENVD	0	 hPa
    IDE04105-ENG99644	Environmental conditions-PRS_EX_PCAT_UP_ENVD	0	 hPa
    IDE04105-ENG103762	Environmental conditions-PSN_CAM_IN_ENVD	-96
    IDE04105-ENG102429	Environmental conditions-PSN_ENG_CRK_ENVD	0
    IDE04105-ENG101373	Environmental conditions-PV_AV_ENVD	0	 %
    IDE04105-ENG102872	Environmental conditions-PV_AV_1_ENVD	0	 %
    IDE04105-ENG103546	Environmental conditions-T_AST_ENVD	0	 s
    IDE04105-ENG100785	Environmental conditions-T_DCA_MAIN_ENVD[0]	0	 ms
    IDE04105-ENG101329	Environmental conditions-T_DCA_MAIN_ENVD[1]	0	 ms
    IDE04105-ENG103556	Environmental conditions-T_DCA_MAIN_ENVD[2]	0	 ms
    IDE04105-ENG103901	Environmental conditions-T_DCA_MAIN_ENVD[3]	0	 ms
    IDE04105-ENG100699	Environmental conditions-T_ES_FCT_DIAG_ENVD	0	 s
    IDE04105-ENG102124	Environmental conditions-T_INT_RGN_ACT_INI_PF_ENVD	0	 s
    IDE04105-ENG103902	Environmental conditions-T_SEG_CAM_IN_ENVD	0	 s
    IDE04105-ENG99604	Environmental conditions-T_TOOTH_ENVD	0	 s
    IDE04105-ENG101786	Environmental conditions-TEG_PF_ENVD	0	 C
    IDE04105-ENG104098	Environmental conditions-TEG_PF_DOWN_ENVD	0	 C
    IDE04105-ENG100670	Environmental conditions-TEG_PF_UP_ENVD	0	 C
    IDE04105-ENG101431	Environmental conditions-TEG_TUR_UP_ENVD	0	 C
    IDE04105-ENG100780	Environmental conditions-THR_PWM_ENVD	0	 %
    IDE04105-ENG100767	Environmental conditions-TQ_PERC_REQ_BRAKE_CRU_ENVD	0	 %
    IDE04105-ENG100397	Environmental conditions-TQI_WITH_EXT_ENG_CAN_ENVD	0	 %
    IDE04105-ENG104240	Environmental conditions-TQI_DRIV_SUB_ENVD	4	 Nm
    IDE04105-ENG99383	Environmental conditions-TQI_TQL_ENVD	4.00063	 Nm
    IDE04105-ENG99687	Environmental conditions-TRT_ENVD	0
    IDE04105-ENG100686	Environmental conditions-TTIP_MES_LS_UP_ENVD	-50	 C
    IDE04105-ENG103081	Environmental conditions-V_BPA_ENVD	0	 V
    IDE04105-ENG101994	Environmental conditions-V_BPA_BOL_ENVD	0	 V
    IDE04105-ENG100343	Environmental conditions-V_BPA_TOL_ENVD	0	 V
    IDE04105-ENG99460	Environmental conditions-V_EGRV_ENVD	0	 V
    IDE04105-ENG103713	Environmental conditions-V_EGRV_BOL_ENVD	0	 V
    IDE04105-ENG103401	Environmental conditions-V_EGRV_TOL_ENVD	0	 V
    IDE04105-ENG100474	Environmental conditions-V_PORT_ENVD	0	 V
    IDE04105-ENG99295	Environmental conditions-V_PORT_BOL_ENVD	0	 V
    IDE04105-ENG103103	Environmental conditions-V_PORT_TOL_ENVD	0	 V
    IDE04105-ENG102880	Environmental conditions-V_PVS_1_BAS_ENVD	0	 V
    IDE04105-ENG100539	Environmental conditions-V_PVS_2_BAS_ENVD	0	 V
    IDE04105-ENG102319	Environmental conditions-V_THR_ENVD	0	 V
    IDE04105-ENG101647	Environmental conditions-V_THR_BOL_ENVD	0	 V
    IDE04105-ENG102485	Environmental conditions-V_THR_TOL_ENVD	0	 V
    IDE04105-ENG103292	Environmental conditions-VCC_1_ENVD	0	 V
    IDE04105-ENG102444	Environmental conditions-VCC_2_ENVD	0	 V
    IDE04105-ENG100871	Environmental conditions-VLS_UP_ENVD	0	 V
    IDE04105-ENG101480	Environmental conditions-VLS_UP_RAW_ENVD	0	 V
    IDE04105-ENG102205	Environmental conditions-VP_PFU_ENVD	0	 V
    IDE04105-ENG103128	Environmental conditions-CTR_EDGE_CAM_IN_1	101
    IDE04105-ENG100023	Environmental conditions-CTR_ERR_LSL_IF_SPI_WR[1]	0
    IDE04105-ENG101824	Environmental conditions-CFB_PCV_MES_ENVD	0	 A
    IDE04105-ENG100771	Environmental conditions-CTR_RST_MC	0
    IDE04105-ENG99902	Environmental conditions-ERR_SYM_ES_FCT_ENVD	NO_SYM
    IDE04105-ENG100015	Environmental conditions-ERR_SYM_VCC_1_ENVD	NO_SYM
    IDE04105-ENG102290	Environmental conditions-ERR_SYM_VCC_2_ENVD	NO_SYM
    IDE04105-ENG98594	Environmental conditions-Gear	0
    IDE04105-ENG100510	Environmental conditions-GEN_LOAD	39.5	 %
    IDE04105-ENG101711	Environmental conditions-IDX_EDGE_CAM_IN_1	7
    IDE04105-ENG100833	Environmental conditions-IV_ON_ENVD	0
    IDE04105-ENG104044	Environmental conditions-Engine load	41.2	 %
    IDE04105-ENG103030	Environmental conditions-LSHPWM_UP[1]	3.125	 %
    IDE04105-ENG103554	Environmental conditions-LV_ACT_AJ	1
    IDE04105-ENG100763	Environmental conditions-Brake Light Switch	0
    IDE04105-ENG103466	Environmental conditions-Brake test switch	0
    IDE04105-ENG100514	Environmental conditions-LV_INI_PPS[0]	1
    IDE04105-ENG102558	Environmental conditions-LV_LSL_AD_STATE	1
    IDE04105-ENG100889	Environmental conditions-LV_SYM_ERR_AC_DCRU_PLAUS	0
    IDE04105-ENG100659	Environmental conditions-LV_REQ_ES_THR	0
    IDE04105-ENG103153	Environmental conditions-LV_TQ_CRU_ACT	0
    IDE04105-ENG103031	Environmental conditions-Camshaft adjustment: inlet phase: bank 1	3.75
    IDE04105-ENG99531	Environmental conditions-SF_ENG_STATE	IS
    IDE04105-ENG104219	Environmental conditions-CTR_RST_MU	0
    IDE04105-ENG101371	Environmental conditions-EGRVPWM_ENVD	0	 %
    IDE04105-ENG99787	Environmental conditions-SF_SYN_STATE	255
    IDE04105-ENG100748	Environmental conditions-STATE_BRAKE_DCC	1
    IDE04105-ENG101874	Environmental conditions-STATE_CRU_AC	0
    IDE04105-ENG102185	Environmental conditions-STATE_CRU_DCC	4
    IDE04105-ENG103497	Environmental conditions-STATE_DCC_SYS	DCC_OFF
    IDE04105-ENG101337	Environmental conditions-STATE_EGRV	128
    IDE04105-ENG99397	Environmental conditions-STATE_ERR_EL_LSL_UP[1]	NO_FAULT
    IDE04105-ENG101587	Environmental conditions-FAC_COR_SLOP_CHA_CAL_ENVD[0]	0
    IDE04105-ENG102819	Environmental conditions-STATE_LAMB_DIAG	132
    IDE04105-ENG100704	Environmental conditions-STATE_LSL_IF_SPI_RD[1]	228
    IDE04105-ENG102463	Environmental conditions-STATE_PPS_DIAG_INI[0]	128
    IDE04105-ENG103046	Environmental conditions-STATE_SYM_DIAG_PUC_LSL_UP[1]	VLS_OK
    IDE04105-ENG99980	Environmental conditions-STATE_SYM_OBD_LSL_LSH_UP[1]	NO_SYM
    IDE04105-ENG103910	Environmental conditions-Ambient temperature	5.25	 C
    IDE04105-ENG102512	Environmental conditions-TBA_MES	9	 C
    IDE04105-ENG102996	Environmental conditions-Coolant temperature	87	 C
    IDE04105-ENG99707	Environmental conditions-TCO_2_MES	32	 C
    IDE04105-ENG103523	Environmental conditions-TCO_MES	87	 C
    IDE04105-ENG103378	Environmental conditions-TCE_SP	90	 C
    IDE04105-ENG101531	Environmental conditions-TFU_MES	16	 C
    IDE04105-ENG99300	Environmental conditions-V_IGK	14.1	 V
    IDE04105-ENG103165	Environmental conditions-Battery voltage	14.1	 V
    IDE04105-ENG99527	Environmental conditions-Vehicle speed: actual	0	 km/h
    IDE04105-ENG100823	Environmental conditions-MF_DE_AD_LST_CMB_AD_ENVD	0.512	 mg/stroke
    IDE04105-ENG101497	Environmental conditions-LAMB_EXT_CLC_FIL_ENVD	0
    IDE04105-ENG99537	Environmental conditions-LF_INJ_AD_ACT	0
    IDE04105-ENG101299	Environmental conditions-LF_STATE_ACT_INJ[0]	6
    IDE04105-ENG101827	Environmental conditions-LV_BRAKE_MON	0
    IDE04105-ENG103061	Environmental conditions-LV_ETCU_INC_40	0
    IDE04105-ENG99526	Environmental conditions-LV_INJ_MON_ENA_AC_MON	0
    IDE04105-ENG99348	Environmental conditions-LV_TCS_INC_40	0
    IDE04105-ENG103889	Environmental conditions-LV_TQ_CRU_ACT_40	0
    IDE04105-ENG101139	Environmental conditions-N_32_MON	768	 /min
    IDE04105-ENG101163	Environmental conditions-N_SP_ETCU_MON	0	 /min
    IDE04105-ENG102625	Environmental conditions-N_SP_IS_EOL_ENVD	0	 /min
    IDE04105-ENG101176	Environmental conditions-N_SP_IS_FIL_ENVD	0	 /min
    IDE04105-ENG102856	Environmental conditions-N_SP_IS_MON	1248	 /min
    IDE04105-ENG101610	Environmental conditions-PFU_MES_ENVD	0	 MPa
    IDE04105-ENG101145	Environmental conditions-PFU_SP_ENVD	0	 MPa
    IDE04105-ENG101916	Environmental conditions-PV_AV_MON	0	 %
    IDE04105-ENG103182	Environmental conditions-TECU	16	 C
    IDE04105-ENG100086	Environmental conditions-TI_OFS_UPD_CMB_AD_ENVD	0.051	 ms
    IDE04105-ENG101361	Environmental conditions-TQ_LOSS_ENVD	4.001	 Nm
    IDE04105-ENG104001	Environmental conditions-TQI_DT1_IS_CTL_ENVD	4.001	 Nm
    IDE04105-ENG103630	Environmental conditions-TQI_MSR_REQ_ENVD	0	 Nm
    IDE04105-ENG101316	Environmental conditions-VFF_VCV_PCTL_ENVD	0	 ml/min
    IDE04105-ENG101839	Environmental conditions-VP_AMP_ENVD	0	 V
    IDE04105-ENG103199	Environmental conditions-VP_CFB_PCV_ENVD	0	 V
    IDE04105-ENG99689	Environmental conditions-EGY_INJ_CTL_DIF_0_ENVD	1.021	 mJ
    IDE04105-ENG100169	Environmental conditions-EGY_INJ_CTL_DIF_1_ENVD	1.021	 mJ
    IDE04105-ENG101100	Environmental conditions-EGY_INJ_CTL_DIF_3_ENVD	1.021	 mJ
    IDE04105-ENG102084	Environmental conditions-I_CTL_EGY_0_ENVD	0.391	 %
    IDE04105-ENG101228	Environmental conditions-IDX_TI_OFS_CMB_AD	0
    IDE04105-ENG104199	Environmental conditions-I_CTL_EGY_1_ENVD	0.391	 %
    IDE04105-ENG104028	Environmental conditions-I_CTL_EGY_2_ENVD	0.391	 %
    IDE04105-ENG100737	Environmental conditions-I_CTL_EGY_3_ENVD	0.391	 %
    IDE04105-ENG101688	Environmental conditions-LF_STATE_PPS_SPI[0]	0
    IDE04105-ENG103427	Environmental conditions-LV_PIN_CRU_OFF_MON	1
    IDE04105-ENG101596	Environmental conditions-PCV_ENVD	0	 %
    IDE04105-ENG103629	Environmental conditions-TQI_IS_ENVD	4.001	 Nm
    IDE04105-ENG100386	Environmental conditions-LV_PCV_CTL	1
    IDE04105-ENG104116	Environmental conditions-FAC_LSL_GAIN_AD_ENVD	0
    IDE04105-ENG102879	Environmental conditions-T_DIAG_ACT_OFS_ENVD	0	 s
    IDE04105-ENG101447	Environmental conditions-T_VLS_UP_MIN_DIAG_OC_LSL_ENVD	0	 s
    IDE04105-ENG99624	Environmental conditions-V_INJ_MAIN_0_ENVD	2.5	 V
    IDE04105-ENG100866	Environmental conditions-V_INJ_MAIN_1_ENVD	2.5	 V
    IDE04105-ENG99546	Environmental conditions-V_INJ_MAIN_2_ENVD	2.5	 V
    IDE04105-ENG102997	Environmental conditions-V_INJ_MAIN_3_ENVD	2.5	 V
    IDE04105-ENG99206	Environmental conditions-VLS_OFS_LSL_ENVD	0.02	 V
    IDE04105-ENG102875	Environmental conditions-LF_STATE_ACT_INJ[1]	1
    IDE04105-ENG100299	Environmental conditions-LF_STATE_ACT_INJ[2]	0
    IDE04105-ENG100626	Environmental conditions-CFB_VCV_MES_ENVD	0	 A
    IDE04105-ENG100591	Environmental conditions-PCV_PCTL_ENVD	0	 %
    IDE04105-ENG99854	Environmental conditions-VP_CFB_VCV_ENVD	0	 V
    IDE04105-ENG99538	Environmental conditions-PFU_SP_INJ_AD_ENVD	0	 MPa
    IDE04105-ENG99086	Environmental conditions-EGY_INJ_CTL_DIF_2_ENVD	1.021	 mJ
    IDE04105-ENG99981	Environmental conditions-CAPA_INJ_MAIN_0_ENVD	0	 F
    IDE04105-ENG102910	Environmental conditions-CAPA_INJ_MAIN_1_ENVD	0	 F
    IDE04105-ENG100838	Environmental conditions-CAPA_INJ_MAIN_2_ENVD	0	 F
    IDE04105-ENG102517	Environmental conditions-CAPA_INJ_MAIN_3_ENVD	0	 F
    IDE04105-ENG99639	Environmental conditions-CHR_INJ_MAIN_0_ENVD	12.8	 As
    IDE04105-ENG101219	Environmental conditions-CHR_INJ_MAIN_1_ENVD	12.8	 As
    IDE04105-ENG101812	Environmental conditions-CHR_INJ_MAIN_2_ENVD	12.8	 As
    IDE04105-ENG101876	Environmental conditions-CHR_INJ_MAIN_3_ENVD	12.8	 As
    IDE04105-ENG101894	Environmental conditions-LV_VCV_CTL	0
    IDE04105-ENG101320	Environmental conditions-VCV_ENVD	0	 %
    IDE04105-ENG103159	Environmental conditions-EGY_INJ_MAIN_0_ENVD	0	 mJ
    IDE04105-ENG103555	Environmental conditions-PWM_HBR_PORT_0_ENVD	0.391	 %
    IDE04105-ENG103034	Environmental conditions-V_DCDC_VCT_ENVD[0]	0	 V
    IDE04105-ENG103302	Environmental conditions-TQI_SP_ENVD	4.001	 Nm
    IDE04105-ENG99109	Environmental conditions-FRF_STATE_ECU_1	1
    IDE04105-ENG99628	Environmental conditions-FRF_STATE_CRU_SWI_POS	2
    IDE04105-ENG104109	Environmental conditions-FRF_BYTE_A_OBD	0
    IDE04105-ENG101660	Environmental conditions-FRF_STATE_ACC	0
    IDE04105-ENG102231	Environmental conditions-FRF_STATE_VCV	0
    IDE04105-ENG100687	Environmental conditions-FRF_LF_STR_SWI_1	0
    IDE04105-ENG99662	Environmental conditions-FRF_LF_STR_SWI_2	95
    IDE04105-ENG103054	Environmental conditions-FRF_STATE_RGN	7
    IDE04105-ENG100749	Environmental conditions-FRF_STATE_RGN_LOCK	0
    IDE04105-ENG99716	Environmental conditions-FRF_LV_TQ_LIM_CLU_ACT	0
    IDE04105-ENG99321	Environmental conditions-FRF_POIL_SWI_1	0
    IDE04105-ENG102324	Environmental conditions-FRF_POIL_SWI_2	0
    IDE04105-ENG99278	Environmental conditions-FRF_STATE_ECU_2	2
    IDE04105-ENG103635	Environmental conditions-FRF_ASR_MMT	4
    IDE04105-ENG102571	Environmental conditions-FRF_ASR_MMT_RDC_TRS_EGM_1	0
    IDE04105-ENG102697	Environmental conditions-FRF_ASR_MMT_RDC_TRS_EGM_2	0
    IDE04105-ENG99849	Environmental conditions-FRF_CAN_CTR	0
    IDE04105-ENG100224	Environmental conditions-FRF_EEPROM	0
    IDE04105-ENG99975	Environmental conditions-FRF_EGR_ZP_ADP_1	128
    IDE04105-ENG103683	Environmental conditions-FRF_EGR_ZP_ADP_2	0
    IDE04105-ENG99155	Environmental conditions-FRF_FCL_PL	1
    IDE04105-ENG99602	Environmental conditions-FRF_GLT_CTR_1	32
    IDE04105-ENG102641	Environmental conditions-FRF_GLT_CTR_2	8
    IDE04105-ENG101840	Environmental conditions-FRF_HWMT_EEPROM	0
    IDE04105-ENG100513	Environmental conditions-FRF_HWMT_VCC	0
    IDE04105-ENG102384	Environmental conditions-FRF_INPUT	0
    IDE04105-ENG99093	Environmental conditions-FRF_KLM_SCH_1	0
    IDE04105-ENG103141	Environmental conditions-FRF_KLM_SCH_2	0
    IDE04105-ENG101992	Environmental conditions-FRF_MD_ANA_CIT_LMP_1	72
    IDE04105-ENG103969	Environmental conditions-FRF_MD_ANA_CIT_LMP_2	50
    IDE04105-ENG103145	Environmental conditions-FRF_MSR_MMT	4
    IDE04105-ENG103060	Environmental conditions-FRF_OFF_ADP_BPA_ACT	1
    IDE04105-ENG101227	Environmental conditions-FRF_SF_HEAT_1	193
    IDE04105-ENG100064	Environmental conditions-FRF_SF_HEAT_2	0
    IDE04105-ENG102759	Environmental conditions-FRF_ST_RL	1
    IDE04105-ENG99456	Environmental conditions-FRF_START_INT_1	25
    IDE04105-ENG100466	Environmental conditions-FRF_START_INT_2	0
    IDE04105-ENG102374	Environmental conditions-FRF_STATE_ADP_LMP	0
    IDE04105-ENG99663	Environmental conditions-FRF_STATE_DCC_SYS	0
    IDE04105-ENG100428	Environmental conditions-FRF_SWP_DRVP	0
    IDE04105-ENG99207	Environmental conditions-FRF_TURBO_CHARGER_1	0
    IDE04105-ENG99411	Environmental conditions-FRF_TURBO_CHARGER_2	0
    IDE04105-ENG102086	Environmental conditions-FRF_VARCOD	1
    IDE04105-ENG99422	Environmental conditions-FRF_VS_CTR_SYS	0
    IDE04105-ENG103644	Environmental conditions-FRF_IMMO_SNAPSHOT_BYTE1	255
    IDE04105-ENG102892	Environmental conditions-FRF_IMMO_SNAPSHOT_BYTE2	255
    IDE04105-ENG100521	Environmental conditions-FRF_IMMO_SNAPSHOT_BYTE3	255
    IDE04105-ENG101852	Environmental conditions-FRF_IMMO_SNAPSHOT_BYTE4	255
    IDE04105-ENG99312	Environmental conditions-FRF_IMMO_SNAPSHOT_BYTE5	255
    IDE04105-ENG103956	Environmental conditions-FRF_IMMO_SNAPSHOT_BYTE6	255
    IDE04105-ENG99609	Environmental conditions-FRF_RC	255
    IDE04105-ENG103091	Environmental conditions-FRF_PCLASS2	255
    ENG102297	Accelerator Pedal Position E	14.5	 %
    ENG103226	Accelerator pedal sender 1: voltage ratio	0.742	 V
    ENG103029	Accelerator pedal sender 2: voltage ratio	0.371	 V
    ENG103896	BYTE_C_OBD	160
    ENG99936	BYTE_D_OBD	160
    ENG99390	CAPA_INJ_MAIN[0]	6.1632	 F
    ENG103101	CAPA_INJ_MAIN[1]	6.0457	 F
    ENG102776	CAPA_INJ_MAIN[2]	6.151	 F
    ENG104221	CAPA_INJ_MAIN[3]	6.0319	 F
    ENG103637	CHR_INJ_MAIN[0]	701	 As
    ENG99789	CHR_INJ_MAIN[1]	701.4	 As
    ENG103475	CHR_INJ_MAIN[2]	699.8	 As
    ENG101402	CHR_INJ_MAIN[3]	696.7	 As
    ENG99533	CONC_O2_ADJ_CLC[0]	-0.397	 %
    ENG102063	CTR_CAN_DIAG_1	84
    ENG103825	CTR_EOL	0
    ENG100462	CTR_RGN_PF_PTL	3
    ENG101140	CTR_RGN_PF_SUM	213
    ENG101723	EGY_INJ_MAIN[0]	40.252	 mJ
    ENG101584	EGY_INJ_MAIN[1]	40.324	 mJ
    ENG103761	EGY_INJ_MAIN[2]	40.635	 mJ
    ENG100583	EGY_INJ_MAIN[3]	40.316	 mJ
    ENG102855	ESI (extended service intervals) oil level	58.8125	 mm
    ENG101942	ESI (extended service intervals) oil warning threshold	49.9375	 mm
    ENG101493	FAC_MAF_CYL_KGH_RATIO_FIL	1.17072
    ENG102816	FAC_MASS_ASH_PF	0.97
    ENG102041	FCO_T_RAW	0.359	 ml/s
    ENG99170	Height correction	972.46	 hPa
    ENG103821	IV_ON	15
    ENG102763	Lambda probes actual: bank1	1.0205
    ENG102236	LOAD_PF_BAS	-42.93	 %
    ENG103837	LOIL_MAX_SRV_INTL	-127	 mm
    ENG102184	LOIL_MIN_SRV_INTL	127	 mm
    ENG104064	LV_CMD_EGR_COOL	0
    ENG100386	LV_PCV_CTL	1
    ENG102161	M_TUR_KGH	32.28	 kg/h
    ENG103084	MAF_CYL_KGH_OBD	36.14	 kg/h
    ENG103648	MAF_INT_PUC_ACT	2.22	 g
    ENG101748	MAF_KGH_MES	30.59	 kg/h
    ENG103125	MASS_SOOT_EQU_TOT_FIL_PHY_PF	-5.72	 g
    ENG100856	MASS_SOOT_SIM_FIL_VOL_PF	0	 g
    ENG101922	MF_MAIN_SP	5.516	 mg/stroke
    ENG102904	MF_TOT	8.988	 mg/stroke
    ENG100561	MPF_SOOT_EMI_PF	0.0001642	 g/s
    ENG103478	PFU	41.058	 MPa
    ENG102121	PFU_SP	41.083	 MPa
    ENG103251	PRS_EX_PCAT_UP	975.28	 hPa
    ENG102195	PV_AV_1	0	 %
    ENG99531	SF_ENG_STATE	IS
    ENG101893	Starter control: clutch switch	0
    ENG100919	Starter control: interlock switch	0
    ENG102520	Starter: measure-back wire term. 50 R	0
    ENG99368	Starter: starter request terminal 50	0
    ENG101677	STATE_EGR_COOL_CDN	63
    ENG104148	T_COOL_LOIL	612	 ms
    ENG101325	T_TEMP_SIG_LOIL	60.8	 ms
    ENG102431	TCE	87	 C
    ENG101250	TEG_DYN_LS_UP[0]	120.475	 C
    ENG100285	TEG_MES_0_ENVD	-273.15	 C
    ENG101267	TEG_MES_1_ENVD	-273.15	 C
    ENG102491	TEG_MES_2_ENVD	-273.15	 C
    ENG102857	TEG_PF_UP_SP	591.85	 C
    ENG103349	TEMP_HEAT_TOL_ACT	5	 C
    ENG103853	TI_MAIN_TUN[0]	0.4856	 ms
    ENG103104	TI_MAIN_TUN[1]	0.4056	 ms
    ENG101104	TI_MAIN_TUN[2]	0.404	 ms
    ENG103756	TI_MAIN_TUN[3]	0.4544	 ms
    ENG104263	TI_PREV_TUN[0.1]	0.2056	 ms
    ENG99442	TI_PREV_TUN[1.1]	0.2744	 ms
    ENG99966	TI_PREV_TUN[2.1]	0.2736	 ms
    ENG99994	TQ_DRIV_ADD_WHL	-242	 Nm
    ENG102360	TQ_LOSS_ALTER	-4.69	 Nm
    ENG102534	TQ_SUM_WHL	-40	 Nm
    ENG102009	TQI_CRU_REQ	-1005.28125	 Nm
    ENG101315	TQI_IS	49.34	 Nm
    ENG100184	TQI_LIM_MIN	118.91	 Nm
    ENG99611	V_TEMP_LS_UP[1]	4.98	 V
    ENG101020	VLS_UP_RAW[1]	2.007	 V
    ENG110144-ENG99972	X_Accumulated_timer_of_regeneration-T_INT_RGN_ACT_INI_PF	0	 s
    ENG110145-ENG101310	X_Air_condition_pressure_sensor_pressure_actual_value-ACP_CAN	3.8	 bar
    ENG110146-ENG102726	X_Brake_error_state-STATE_ERR_BRAKE	0
    ENG110147-ENG103835	X_Calculated vehicle acceleration-AC_VEH_CLC	0	 m/s
    ENG110149-ENG102598	X_Charge_pressure_positioner_raw_voltage-V_BPA[0]	3.53	 V
    ENG110152-ENG100869	X_Cruise control acceleration setpoint selected from externa-AC_SP_CRU_EXT	3.0098	 m/s
    ENG110156-ENG101183	X_Cruise_control_percentage_brake_torque-TQ_PERC_REQ_BRAKE_CRU	0	 %
    ENG110162-ENG104134	X_ECU_TYPE-LV_SWMD_ISSAMPLEMODE	SAMPLE
    ENG110163-ENG101789	X_EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG	0	 %
    ENG110164-ENG102398	X_EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG	0	 %
    ENG110165-ENG102565	X_EGR_deviation-EGR_DIF	0	 %
    ENG110166-ENG102215	X_EGR_valve_control_value-EGRV_PWM[0]	0	 %
    ENG110182-ENG99492	X_Exhaust Gas Recirculation Actuator Voltage Actual Value Ra-V_EGRV[0]	0.864	 V
    ENG110183-ENG99552	X_Exhaust gas temperature sensor 1-TEG_TUR_UP	120.91	 C
    ENG110184-ENG104014	X_Exhaust_calculated_value_of_dpf_temperature_actual_value-TEG_PF	122.23	 C
    ENG110194-ENG103099	X_Exhaust_gas_temperature_upstream_atl:_commanded_value-TEG_TUR_UP_SP	606.85	 C
    ENG110203-ENG101465	X_Fuel_Mean_Value_Adaptation_Learning_Index-CTR_MF_DIF_AD_LAMB	27
    ENG110234-ENG102158	X_Load_class_for_particulate_filter-LOAD_PF_CLAS	0
    ENG110240-ENG99881	X_Particle_filter_merged_soot_mass-MASS_SOOT_PF	0	 g
    ENG110242-ENG104261	X_Particulate_filter_load_class_determined_by_soot_load-LOAD_PF_CLAS_SOOT	0
    ENG110255-ENG99110	X_Regeneration_of_particulate_filter_active_interrupt_conditions-LF_INTR_RGN_PF	16
    ENG110258-ENG99928	X_Soot_equivalent_of_ash_mass-MASS_SOOT_EQU_ASH_PF	0.34	 g
    ENG110271-ENG101970	X_State_boost_pressure_control-STATE_BPA_CTL	0
    ENG110278-ENG99759	X_Throttle Valve Actuator Duty Factor Set Value-CTL_LIM_THR[0]	-11.157	 %
    ENG110279-ENG104156	X_Throttle Valve Actuator Voltage Actual Value Raw Value-V_THR[0]	4.434	 V
    ENG110280-ENG102608	X_Throttle_actuator_commanded_value-ANG_SP_THR[0]	96.001	 %
    ENG110282-ENG103670	X_Throttle_valve_control_value-THR_PWM	96.001	 %
    ENG110288-ENG104017	X_Turbo Charger Actuator High Pressure Duty Factor Set Value-CTL_LIM_BPA[0]	84.998	 %
    ENG110293-ENG100727	X_Variable Swirl Actuator Voltage Actual Value Raw Value-V_PORT[0]	0.322	 V
    Elapsed Time: 00:50
  8. #5
    Different software part numbers, different ASAM Dataset in the ECU software.
    And it looks like IDE06141 is indeed no longer present as a Basic setting in the data for the newer ECU.
  9. Likes Souriau liked this post
