Results 1 to 10 of 17
Thread: P0087 2014 passat wolfsburg 1.8
    New User
    Oct 2019
    hello im getting a 15059 - Fuel Rail/System Pressure error on my 2014 passat woflfsburg 1.8, so I brought a new fuel pressure sensor but cant seem to locate the sensor im thinking its under the intake manifold but not sure please advise. symptom's the car shuts off after starting and sometimes stalls at idle or while driving
    VCDS Version: 19.6.2.0 (x64)
    VIN: 1VWAS7A33EC072782   License Plate: VOLKS
    Mileage: 207790km-129114mi   Repair Order:
    Chassis Type: A3-VW41 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 2E 42 44 46 4F 52 56 62 72 75
              77
    VIN: 1VWAS7A33EC072782   Mileage: 207790km-129114miles
    Address 01: Engine (J623-CPKA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 070 H    HW: 06K 907 425
       Component: R4 1.8l TFS   H09 9365
       Revision: --H09---    Serial number:
       Coding: 001A0012242400160000
       Shop #: WSC 09003 957 00200
       ASAM Dataset: EV_ECM18TFS02006K906070H 001009
       ROD: EV_ECM18TFS02006K906070D.rod
       VCID: 2F43FA3E760D93370E-807A
              P0087 00 [101] - Too Low
                        Mileage: 207797 km
                        Date: 2019.10.29
                        Time: 18:34:04
                        Engine speed: 1539.00 /min
                        Normed load value: 22.0 %
                        Vehicle speed: 38 km/h
                        Coolant temperature: 93 C
                        Intake air temperature: 66 C
                        Voltage terminal 30: 13.359 V
                        T_AST_SAE: 1169 s
                        FAC_LAM_LIM[1]: 35.001 %
                        Fuel regulating valve: duty cycle: 99.998 %
                        FUP_H_SAE: 290.0 kPa
                        High-pressure system: status: MFP_MAX
                        TFU_HPP: 58.50 C
                        Lambda probes actual: bank1: 2.8975
    Readiness: 0000 0101
    Address 02: Auto Trans (J217)       Labels:* 09G-927-749-V1.clb
       Part No SW: 09G 927 749 B    HW: 09G 927 749 B
       Component: AISIN AG6 G3  101 2855
       Coding: 000348
       ASAM Dataset: EV_TCMAQ250031 001004
       ROD: EV_TCMAQ250031_001_VW25.rod
       VCID: 3851C1628343548F5F-806C
       Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
       Component: ESP MK60EC1   H46 0164
       Revision: 00H46001
       Coding: C54BC0F5492900FCA31203EC921B0041A0100012
       VCID: 7EDD177AE9E7AABFD5-802A
                        Fault Status: 01100101
                        Reset counter: 252
                        Mileage: 200143 km
                        Date: 2019.07.27
                        Time: 12:33:57
                        Count: 3
                        Count: 14
                        Count: 4096
                        Count: 295
                        Count: 42752
                        Count: 256
                        Reset counter: 252
                        Mileage: 200143 km
                        Date: 2019.07.27
                        Time: 12:34:06
                        Count: 7
                        Count: 14
                        Count: 4096
                        Count: 16390
                        Count: 42752
                        Count: 256
    Why do you think the problem is the sensor as opposed to an actual problem with the pressure being too low?
    You may want to monitor some measuring values:
    IDE00201 -- High fuel pressure: specified value
    IDE01378 -- High fuel pressure: control deviation
    IDE00202 -- Low fuel pressure: specified value
    IDE00589-ENG167462 -- Fuel pressure,OBD
    ... to try to get a handle on what's actually going on.
    New User
    Oct 2019
    you're right lol just starting out with this vagcom, how do i get to those locations is there a tutorial?
    [Select]
    [01-Engine]
    [Adv. Meas. Values]
    There you can scroll down the list, or just type 'fuel pressure' into the search/filter box to narrow things down.
    See also:
    https://www.ross-tech.com/vcds/tour/adv-meas-blocks.php
    New User
    Oct 2019
    thanks for the info and timely response
    New User
    Oct 2019
    Heres what I got
    Address 01: Engine (06K 906 070 H)
    15:49:01
    IDE00201 High fuel pressure: specified value 67.4 bar
    IDE00202 Low fuel pressure: specified value 3.999 bar
    IDE00589 Fuel pressure 6970 kPa rel
    IDE01378 High fuel pressure: control deviation -1.3 bar
  7. #7
    OK, but by "monitor", I don't mean just a single static reading. You'd like to see what's going on when the engine misbehaves.
    Forget IDE00589-ENG167462 Fuel pressure OBD, go for these:
    IDE00188 -- Fuel high pressure: actual value
    IDE00186 -- Fuel low pressure: actual value
    Use the [Log] button and drive the car.
  8. #8
    New User
    Oct 2019
    funny thing is it stopped its running normal the only thing i did was clean the map sensor
  9. #9
    New User
    Oct 2019
    thought my problem was fixed but the car shut off twice while stopped at the traffic light. I am no longer getting the low pressure error.
    I drove the car and have the log
    Friday,08,November,2019,10:02:37:04319
    Mileage: 208270km-129412mi   Repair Order:
              77
    VIN: 1VWAS7A33EC072782   Mileage: 208270km-129412miles
       Coding: 000348
       Revision: 00H46001
                        Reset counter: 120
                        Mileage: 207798 km
                        Date: 2014.03.21
                        Time: 12:17:53
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 295
                        Count: 49152
                        Count: 512
                        Count: 256
                        Reset counter: 120
                        Mileage: 207798 km
                        Date: 2014.03.21
                        Time: 12:18:02
                        Count: 3
                        Count: 12
                        Count: 12800
                        Count: 16390
                        Count: 48896
                        Count: 512
                        Count: 257
       Part No SW: 561 907 426 E    HW: 561 907 426 E
       Component: AC Manuell    H02 0303
       Revision: 00001K02
       Coding: 0010001002
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1D1F30F60CA111A7AC-8048
       Part No SW: 5K0 937 085 AB    HW: 5K0 937 085 AB
       Component: BCM PQ35 B+   122 0173
       Revision: BH122001
       Coding: EF200E18802B2AD4098000010600044800F1A08640801D20648060000C70
       Shop #: WSC 02212 001 1048576
       VCID: 73CB364ED2A5F7D7AA-8026
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 7
                        Mileage: 202121 km
                        Date: 2019.08.01
                        Time: 09:27:49
                        Voltage: 12.20 V
    02742 - Bulb for Brake/Turn Signal Light; Left
                        Fault Frequency: 9
                        Reset counter: 96
                        Mileage: 203450 km
                        Date: 2019.08.14
                        Time: 16:32:01
                        Voltage: 13.15 V
    03188 - Bulb for Side Marker Light; Front Left
                        Reset counter: 7
                        Mileage: 202121 km
                        Date: 2019.08.01
                        Time: 10:55:57
                        Voltage: 12.10 V
       Part No SW: 5C0 959 655 AE    HW: 5C0 959 655 AE
       Component: AirbagVW10G   014 0851
       Serial number: 003MWM046P0S
       Coding: 00004D4A
       Shop #: WSC 55547 001 1048576
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 75CF0856D4D1E9E784-8020
       Serial number: 6940000Y1400011T6U0$
       Coding: 303044
       Serial number: 3572MSME7B2F307EZZZ9
       Serial number: 3582MSME460C767FZZZ8
       Serial number: 3516KSME65045B29ZZZV
       Serial number: 3526KSME62244E29ZZZX
       Serial number: 3556LSME7900032AZZZP
       Serial number: 3566LSME4740032AZZZP
       Part No SW: 1K5 953 521 AL    HW: 5K0 953 569 B
       Revision: FF010042    Serial number: 20131008300145
       Coding: 488A140000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 77D3025ECEDD9BF796-8022
       Subsystem 1 - Part No SW: 561 959 537     HW: 561 959 537
       Component: E221__MFL-YVJ  H07 0022
       Coding: 620000
    Address 17: Instruments (J285)       Labels:| 5K0-920-XXX-17.clb-SRI1
       Part No SW: 561 920 960 D    HW: 561 920 960 D
       Component: KOMBI         H04 0809
       Coding: 230E01
       VCID: 1A153BEA1D8F669F49-804E
       Part No SW: 7N0 907 530 AM    HW: 7N0 907 530 AM
       Component: J533  Gateway H55 1642
       Revision:   H55       Serial number: 17011403000614
       Coding: 461000
       VCID: 7BDB1E6EFAF5BF97F2-802E
       Component: IMMO          H04 0809
       VCID: 6AF52B2A8D6F361F19-803E
    Address 2E: Media Player 3
       Component: TUER-SG FT    002 0525
       Revision: 13110009    Serial number: 0007659876
       Coding: 0404D5
       ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
       ROD: EV_TSGFPQ25BRFVW46X.rod
       VCID: 5B9B7EEE52355F9792-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG_HL  006 5470
       Serial number: 14102630140110174212
       Coding: 800000
       Part No: 1K0 909 144 R
       Component: EPS_ZFLS Kl. 288    3501
       Revision: 00H22000
       VCID: 3957C46670494D87A0-806C
       Part No SW: 7N0 907 532     HW: 7N0 907 530 AM
       Component: EZE_2         H55 1642
       Coding: 00000008
       VCID: 6FC33A3EBE8DD3374E-803A
       Subsystem 1 - Part No SW: 561 919 204 B    HW: 561 919 204 B
       Component: Analoguhr  008 0005
       Component: TUER-SG BT    002 0525
       Revision: 15110009    Serial number: 0007636211
       Coding: 0404D4
       ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
       ROD: EV_TSGBPQ25BRFVW46X.rod
       VCID: 5C997DF2573B58AF9B-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG_HR  006 5470
       Serial number: 14202631140117104035
       Coding: 800000
       Part No SW: 1K0 035 164 F    HW: 1K0 035 164 F
       Component: LOW NAR SDARS H04 0005
       Revision: -----08S    Serial number: VWZ4Z6P3719168
       Coding: 0100040002000B
       VCID: 256F18162CF1D967F4-8070
       Part No SW: 561 035 285     HW: 561 035 285
       Component: OCULowUSA     014 0102
       Serial number: 000003554140513
       Coding: 02140102C2161A107F1606000000
       ROD: EV_OCULow_001.rod
       VCID: 538B96CE3AE597D74A-8006
    2103041 - Control Module
                        Fault Priority: 8
                        Reset counter: 135
                        Mileage: 208275 km
                        Date: 2019.11.08
                        Time: 09:59:03
       Component: TELEFON       H05 0592
       Revision: 1B001001    Serial number: 00007665584774
       Coding: 0A10030080010110
       ROD: EV_UHVUMI.rod
       VCID: 2E7DE73A71079A3F05-807A
    End-------------------------(Elapsed Time: 02:11)--------------------------
  10. #10
    New User
    Oct 2019
    Uwe I have a log but I don't know how to upload it
