Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Non-encrypted label files for MK25E1 ABS module?
    Quote Originally Posted by jsola View Post
    I am replacing my rear differential with no diff-lock for a unit with differential lock.
    Your car WV2ZZZ7HZ8H133087 from factory has diff.lock, PR-code 1Y4
    OP are you sure your rear diff is a no diff lock version, the PR code for your car suggests otherwise...
  2. Likes Uwe, Jack@European_Parts, jsola liked this post
  3. #12
    Jan 2019
    Barcelona, Catalonia
    No that is not correct. See post #6
    MK25E coding is not the same as yours MK25E1.
    [22] coding 0000002 is with diff.lock, 0000001 is without.
    Your [03] coding 0000607 is with diff.lock, like other Transporter with same equipment as yours is coded 0000607.
    Again, is there a problem ?
    Oh, thanks NETech, this is really helpful.
    It seems that I do not have to change any coding then.
    Up to now, there is no problem because I have not swapped differentials yet. I just wanted to make sense of everything before starting so that I do not do anything wrong. And after testing all the pieces the only thing that remained was determining whether my 03ABS needed recoding or not.
    So thanks a lot.
  4. #13
    Jan 2019
    PetrolDave, Indeed, it's a PR1Y4 . The thing is, the previous owner replaced the lockable diff by a non-lockable one. It seems though as when doing so he never recoded the ABS module to indicate that there was no longer a diff-lock.
    Now I am just refitting a lockable diff on it to bring it back to factory specs.
    I already plugged the lockable unit to the VCDS (just put it under the van and connect it) so that I could read the 00002 coding of the unit I want to install. Everything is fine:
    Existing differential without diff-lock
       Part No: 7H0 907 554 F
       Component: HALDEX 4Motion      2110
       Shop #: WSC 49856 001 1048576
       VCID: 33331D04772445EF045-5160
    New differential with diff-lock
       Shop #: WSC 02756 790 00000
    The doubts were on the ABS module but now I think all is clear. This module is responsible for enabling the diff-lock to engage if certain conditions are met at the time of depressing the diff-lock button: max speed of 40kmh, and max difference of wheel speeds L-R of 7kmh. This is why the ABS module needs to know whether diff lock is available or not. The coding I have is as so:
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0000607
       VCID: 44D14ED8228AF257ADF-5160
    According to NETech this code 607 is normal for the MK25E1, that is it corresponds to units with diff-lock, so I will leave it as it is.
    So it seems that all the coding is correct so I'll only have to carry out the mechanical work. The previous owner did not re-code the ABS module, so I should be fine if I just do not touch it.
  6. #14
    Jan 2019
    Trying to embed photos now...
    Here´s the non-lockable diff coming out...
    And here the lockable diff coming in!!!
    Thank you all guys!
  7. Likes Uwe, PetrolDave, Jack@European_Parts liked this post
  8. #15
    Jan 2019
    Here's a happy man!
    https://imgur.com/YdWSTh8.mp4
    https://i.imgur.com/cqUoCma.mp4
    I finally did not do any recoding at all. The diff lock works great!
  9. Likes Jack@European_Parts, Boki Ar, Uwe liked this post
  10. #16
    SO WAS FOD!
