Results 1 to 10 of 16
Thread: Non-encrypted label files for MK25E1 ABS module?
    Jan 2019
    Barcelona, Catalonia
    Hi. I am trying to make sense of the codings in my 7H multivan 4motion.
    In particular, I'd like to interpret the coding of the ABS module. This is needed because I am fitting a diff-lock and there is one bit in the ABS module that requires re-coding. However, the labels I have (shipped with VCDS) are in a CLB file which I cannot read since it is apparently encrypted. Many other files are .LBL files which are easy to read, but not this one.
    Is it possible to have this CLB file unencrypted, that is, as a LBL file?
    The file is precisely 7H0-907-37x-ABS.CLB, and I would like to have 7H0-907-37x-ABS.LBL.
    Thank you
    Jan 2019
    I attach an autoscan for reference.
    Wednesday,30,October,2019,15:27:59:04823
    VIN: WV2ZZZ7HZ8H133087   License Plate: 0027KHD
    Mileage: 244520km-151937mi   Repair Order: 201910302326
    Chassis Type: 7H (7H - VW Multivan 4motion)
    Scan: 01 03 08 09 15 17 18 19 22 46 6E 6E
    VIN: WV2ZZZ7HZ8H133087   Mileage: 244520km-151937miles
    Address 01: Engine        Labels: 070-906-016-BPC.clb
       Part No SW: 070 906 016 DR    HW: 070 906 016 DR
       Component: R5 2,5L EDC  000SG  1584
       Revision: --H06---    Serial number: VWZ7Z0H6297210
       Coding: 0001172
       Shop #: WSC 36843 001 1048576
       VCID: 6393AD448744956FB45-5184
    Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
       Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
       Component: ESP MK25E1          0104
       Revision: 00H31001
       Coding: 0000607
       Shop #: WSC 02756 790 00000
       VCID: 44D14ED8228AF257ADF-5160
    Address 08: Auto HVAC        Labels: Redir Fail!
       Part No: 7H5 820 045 P
       Component: CLIMA/AC            0303
       VCID: 372B2914635CA9CF38D-5160
    Address 09: Cent. Elect.        Labels:. 7H0-937-049.lbl
       Part No: 7H0 937 049 AD
       Component: BORDNETZ SGVER 1.0  2101
       Coding: 0000103
       VCID: 74B1DE1832AA02D7DDF-5160
       Part No: 1C0 909 605 F
       Component: 11 AIRBAG VW61 0R   0004
       Coding: 12593
       Shop #: WSC 02756
       VCID: 270BF954B6FC394FA8D-5160
    Address 17: Instruments        Labels: 7Hx-920-xxx-17.lbl
       Part No: 7H0 920 861 E
       Component: KOMBI+WEGFAHRSP VDO V03
       Coding: 06113
       Shop #: WSC 00186
       VCID: 2E050C70990668076BB-5160
       WV2ZZZ7HZ8H133087     VWZ7Z0H6297210
    Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
       Part No: 7H0 819 008 R
       Component: Standheizung        0209
       VCID: 3B2335245F748DAFDC5-5160
       Part No: 6N0 909 901
       Coding: 00022
       Shop #: WSC 02756
       VCID: 70B9D20843B23EF7397-5160
       Part No: 7H0 907 554 F
       Component: HALDEX 4Motion      2110
       Shop #: WSC 49856 001 1048576
       VCID: 33331D04772445EF045-5160
    Address 46: Central Conv.        Labels: 7H0-959-433.lbl
       Part No: 7H0 959 433 B
       Component: C11 Komfortgerát     0004
       Coding: 00025
       Shop #: WSC 02756
       VCID: 323D18008D3E4CE70F3-4B1E
    Address 6E: Ctrl Head Roof        Labels: 7H5-919-044-W1.clb
       Part No SW: 7H5 919 044 J    HW: 7H5 919 044 J
       Component: J702  Dachdisplay   0500
       Revision: 1010007S    Serial number: 00000000060769
       Coding: 0000003
       VCID: 392F2F2C5548BFBFCE9-5160
       Coding: 0000003
    End----------(Elapsed Time: 02:16, VBatt start/end: 12.1V/12.1V)-----------
    I'm not sure I understand how having a plain-text one would help you, because there is no coding info in that file at all.
    Tartu, Estonia
    Try coding: 0016991
    The world is my oyster...
    Jan 2019
    Uwe, there are files for the MK25 and MK25E in which I can see codings for the different options in the ABS module.
    For example, for the MK25E, there is the file 7H0-907-37x-ABS-A.LBL with contents:
    ; coding information
    C00,Brake Electronics (J104) Coding (MK25 ABS/EDS AWD)
    C01,Model/Wheelbase:
    C02,+0000025 = Van with Short Wheelbase (PR-0E1)
    C03,+0000026 = Van with Long Wheelbase (PR-0E2)
    C04,+0000027 = Pickup/Cab with Short Wheelbase (PR-0E1)
    C05,+0000028 = Pickup/Cab with Long Wheelbase (PR-0E2)
    C06,
    C07,Differential Lock:
    C08,+0000512 = without Differential Lock for Rear Axle Transmission
    C09,+0000000 = with Differential Lock for Rear Axle Transmission (PR-1Y4)
    C10,
    C11,Suspension I:
    C12,+0007168 = 16" Suspension (PR-2E3)
    C13,+0015360 = 17" Suspension (PR-2E4)
    C14,
    C15,Suspension II:
    C16,+0000000 = Normal/Bad Road Suspension (PR-1BA/1BB/1BH/1BJ/2MF/2MG/2MK/2ML/2MQ/2MR)
    C17,+0000128 = Sport Suspension (PR-1BV/2MD)
    where the bit that interests me is 512: diff lock. However, for my exact ABS module MK25E1, there is no such LBL file, and there is a CLB file instead.
    AutoScan tells me the labels file for the module is precisely this CLB file.
    I don't understant precisely what is this CLB file. But since it's a labels file, and the LBL file for the MK25E contains the codes, I supposed the CLB file contains them too, just encripted.
    Anyway, what I am after is the codes for the MK25E1 module. Where can I find them? Are they the same as for the MK25E module (I guess not).
    Your Coding should be with Diff-lock and there also no faults.
    What is the problem ?
  8. Likes Jack@European_Parts, jsola liked this post
    Jan 2019
    I never coded anything with the VCDS and therefore I am confused and a bit scared of doing something wrong. My guess is the following:
    I have code 607 in the ABS module, currently.
    I am replacing my rear differential with no diff-lock for a unit with differential lock. The codings for these two AWD modules are identical: 00002.
    Therefore I only have to tell the ABS module that now I'll be having differential lock.
    This seems to be done by setting the 512 bit to zero. So the new coding would be:
    607 - 512 = 95.
    My guess is that now I should code 95 in the ABS module.
    Is this correct?
  10. #8
    Quote Originally Posted by jsola View Post
    It shows the same information as if it was LBL file!
    As you can see, it shows "Contact Ross-Tech"
    It should be in erwin.
    There could also coding in different "wiring shorts" to ABS connector, see WD.
    No, if so, that LBL file could be used.
  11. #9
    Jan 2019
    Thanks NEtech. Did you read my last post? All I need to know is there.
  12. #10
    Is this correct?
    No that is not correct. See post #6
    MK25E coding is not the same as yours MK25E1.
    [22] coding 0000002 is with diff.lock, 0000001 is without.
    Your car WV2ZZZ7HZ8H133087 from factory has diff.lock, PR-code 1Y4
    Your [03] coding 0000607 is with diff.lock, like other Transporter with same equipment as yours is coded 0000607.
    Again, is there a problem ?
  13. Likes Uwe, Jack@European_Parts, jsola liked this post
