Greetings,
I've been struggling with a CEL. In the last 6 months I had the Allroad serviced at a dealership; at which time I had to replace the timing chain and had all 4 injectors done. This was in response to a series of fault codes that ended catastrophically. The Allroad was disabled in my driveway and I had to have it towed for service; wouldn't start.
Since that repair I have been trying to track down gremlins that presented similarly to the catastrophic event. Getting a rough idle in the morning and sometimes after the car has warmed up in stop and go traffic. I was seeing too rich / too lean codes, misfires, etc. Over the last 6 months I have replaced the upstream 02 sensor, replaced spark plugs, replaced coil packs, replaced pcv, replaced MAF sensor and visually verified the air filter resulting in a couple of weeks on/off running smoothly while the CEL is on. I think - hey, lets clear that and check everything again causing the car to relearn the right mixture (I'm assuming) and then the rough idle returns. I thought I had narrowed everything down to a bad catalytic converter, and then last night happened. I'm stumped and the last time I saw these errors I had to replace the timing chain and injectors. So I'm hoping to avoid another expensive visit to the dealer; that clearly never fixed the root cause in the first place. Thoughts?
Thursday,31,October,2019,17:03:01:05213
VIN: WA1VFAFL0DA0XXXXX License Plate:
Mileage: 218940km-136043mi Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 47 52 53 56 5F
62 6C 6D 72
VIN: WA1VFAFL0DA0XXXXX Mileage: 218940km-136043miles
Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb
Part No SW: 8K5 907 115 F HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0008
Revision: ECH09---
Coding: 722A0013242600062000
Shop #: WSC 61325 002 1048576
ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
ROD: EV_ECM20TFS0118K5907115F.rod
VCID: 353722E965C0337F2A1-8060
13 Faults Found:
5580 - Oil Pressure Switch
P164B 00 [167] - Malfunction
Mileage: 218947 km
Date: 2019.10.31
Time: 16:53:39
Engine speed: 2707.00 /min
Normed load value: 26.7 %
Vehicle speed: 52 km/h
Coolant temperature: 87 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.324 V
Median injection timing: 0.916 ms
Engine operating condition: Part. load
Engine operating condition-Test_Program_Channel 87: 6
5646 - Leak in Air Intake System
P2279 00 [096] - -
Mileage: 218866 km
Date: 2019.10.30
Time: 16:15:27
Engine speed: 797.50 /min
Normed load value: 13.3 %
Coolant temperature: 81 °C
Intake air temperature: 54 °C
Voltage terminal 30: 13.853 V
Median injection timing: 0.807 ms
Driver-side belt buckle status-Bits 0-7: 233
Engine torque: 29.6 Nm
4113 - Camshaft Position Sensor (G40)
P0341 00 [174] - Implausible Signal
Fault Frequency: 19
Mileage: 218936 km
Date: 2019.10.31
Time: 16:30:34
Engine speed: 1463.50 /min
Normed load value: 23.9 %
Vehicle speed: 9 km/h
Intake air temperature: 42 °C
Voltage terminal 30: 14.465 V
Median injection timing: 1.004 ms
2822 - Bank 1; System Too Rich off Idle
P2178 00 [175] - -
Mileage: 218865 km
Date: 2019.10.30
Time: 13:11:23
Engine speed: 1664.00 /min
Normed load value: 21.2 %
Coolant temperature: 91 °C
Intake air temperature: 32 °C
Median injection timing: 0.847 ms
4010 - Idle Control System
P0506 00 [175] - RPM Lower than Expected
Mileage: 218889 km
Date: 2019.10.31
Time: 06:41:53
Engine speed: 780.00 /min
Normed load value: 62.4 %
Coolant temperature: 15 °C
Intake air temperature: 12 °C
Voltage terminal 30: 13.640 V
Median injection timing: 3.620 ms
4601 - Cold Start Idle Air Control System
P050A 00 [237] - Malfunction
Mileage: 218889 km
Date: 2019.10.31
Time: 06:41:12
Engine speed: 896.00 /min
Normed load value: 68.2 %
Coolant temperature: 7 °C
Intake air temperature: 13 °C
Voltage terminal 30: 12.745 V
Median injection timing: 3.410 ms
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [172] - -
Mileage: 218839 km
Date: 2019.10.30
Time: 08:59:34
Engine speed: 799.50 /min
Normed load value: 11.0 %
Coolant temperature: 88 °C
Intake air temperature: 63 °C
Voltage terminal 30: 14.536 V
Median injection timing: 0.552 ms
Driver-side belt buckle status-Bits 0-7: 129
Engine torque: 24.1 Nm
10591 - Cylinder 1
P0301 00 [172] - Misfire Detected
Mileage: 218839 km
Date: 2019.10.30
Time: 09:00:32
Engine speed: 704.50 /min
Median injection timing: 4.463 ms
10593 - Cylinder 3
P0303 00 [172] - Misfire Detected
Mileage: 218839 km
Date: 2019.10.30
Time: 09:00:32
10594 - Cylinder 4
P0304 00 [172] - Misfire Detected
Mileage: 218839 km
Date: 2019.10.30
Time: 09:00:32
10592 - Cylinder 2
P0302 00 [172] - Misfire Detected
Mileage: 218866 km
Date: 2019.10.30
Time: 16:39:01
Median injection timing: 0.536 ms
Driver-side belt buckle status-Bits 0-7: 118
Engine torque: 23.2 Nm
4106 - Bank 1; System too Rich at Idle
P2188 00 [175] - -
Mileage: 218932 km
Date: 2019.10.31
Time: 16:10:50
Engine speed: 842.50 /min
Normed load value: 16.9 %
Coolant temperature: 90 °C
Intake air temperature: 38 °C
Voltage terminal 30: 14.442 V
Median injection timing: 0.509 ms
A/C compressor: load current: act. value: -575.50 A
4201 - Fuel Level too Low
P1250 00 [032] - -
Readiness: 0000 0101
Part No SW: 8K1 927 158 HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1002
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002018
VCID: 74B1DFED2E3A6A77DDF-8020
Part No SW: 8K9 907 379 M HW: 8K9 907 379 M
Component: ESP8 quattro H09 0100
Coding: 0E1D18
Shop #: WSC 06335 000 00000
VCID: 4CC1670D16CA52B765F-8018
Part No SW: 8K0 907 064 GP HW: 8K0 907 064 FP
Component: BCM2 2.0 H11 0621
Coding: 0D824000000000000000
VCID: 04518F2D7E1A5AF7EDF-8050
Subsystem 1 - Part No SW: 8K0 959 754 B HW: 8K0 959 754 B
Serial number: 0512000038266011
Serial number: 2312000114720010
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01070620121806
Coding: 6480208000
VCID: 392F2ED94958D71FCE9-806C
Fault Status: 00101101
Reset counter: 207
Mileage: 218866 km
Date: 2019.10.30
Time: 16:17:49
Temperature: 15.0°C
RPM: 800 /min
Component: BCM1 1.0 H16 0103
Revision: 09016001 Serial number: 00000431027402
Coding: 26000091863CAFE00700480300003D0D0F9C4708A2090221000008004000010200020030000000
Shop #: WSC 06335 123 12345
VCID: 7AADF1D50CDE1C07873-802E
Component: WWS 030612 H07 0070
Serial number: SWF12060035560
Coding: 00FD11
Component: G397_RLFS H06 0002
Serial number: 20329176
Coding: 02005D
Component: E1 - LDS H03 0031
Serial number: 00000000002605120343
Component: USHL4.2 H30 0030
Serial number: 0000002274555R1Y0002
Subsystem 5 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 6 - Part No SW: 8K5 941 329 HW: 8K5 941 329
H01 0031
Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: 14280236000000000001
Part No SW: 8K0 959 655 M HW: 8K0 959 655 M
Component: AirbagVW-AU10 H46 0610
Serial number: 003KEDA01DWK
Coding: 303844354A32303030304A55304C384B3053
Shop #: WSC 07924 002 1048576
VCID: 47CB58210F2CB1EF48D-8012
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1200008T0G
Serial number: 6334MSME6E761444J
Serial number: 6344MSME70010514Z
Serial number: 6352QSME4118105C9
Serial number: 6362QSME07184856H
Serial number: 63732SME66153448-
Serial number: 63832SME17181150O
Revision: 00000000 Serial number: 20120614000900
Coding: 000037
VCID: 4FFB7001E7DC69AF00D-801A
Component: E221 - MFL H03 0003
Part No SW: 8K0 920 982 D HW: 8K0 920 982 D
Component: KOMBIINSTR. H35 0553
Revision: 00000000 Serial number: RBI34G46D
Coding: 8BB629020B01D705020000
VCID: 353722E96540337F2A1-8060
Part No SW: 8R0 907 468 J HW: 8R0 907 468 D
Component: GW-BEM 5CAN-M H11 0051
Revision: 1Z090025 Serial number: 2541Z12509012E
Coding: 80C303FF00
VCID: 46D5552508A6A8E7B3B-8012
Serial number: 6732957401
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0076
Revision: AA000000 Serial number: 00000030150295
Coding: 00581B00000000000000
VCID: 3B2334D14364E50FDC5-806E
Part No SW: 8T0 907 566 A HW: 8T0 907 566
Component: SWA Master H16 0040
Serial number: 0177660840
Coding: 010211
Shop #: WSC 06334 000 00000
VCID: 3E253DC550F6F027FBB-806A
Subsystem 1 - Part No SW: 8T0 907 568 A HW: 8T0 907 568
Component: SWA Slave H16 0040
Serial number: 0177657689
Coding: 010211
Part No SW: 8K0 959 793 R HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000032090403
Coding: 011C13205E00410001
Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
Component: RCEPS H36 0507
Revision: 00001000 Serial number: 0021598393
Coding: 100000000001
Shop #: WSC 63374 000 1048576
ROD: EV_RCEPSAU48X_008.rod
VCID: 34311FED6EBA2A771DF-8060
Revision: 00002001 Serial number: 0177694537
Coding: 0126023A20BA709580B0023200000000
Shop #: WSC 06334 123 12345
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000523024
Subsystem 3 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J245 PS150 H08 0043
Subsystem 4 - Part No SW: 8K0 959 591 B HW: 8K0 959 591
Component: J394 PS240 H08 0043
02764 - Access/Start Authorization Switch (E408)
Reset counter: 208
Mileage: 218889 km
Date: 2019.10.31
Time: 06:41:48
Component: DSP Prem H05 0030
Revision: 00005001 Serial number: 94813003158901
VCID: 2D070A898D107BBF521-8078
Part No SW: 8K0 959 792 R HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000032126870
VCID: 4EC56D05E0D660A70BB-801A
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 10000000039228
ROD: EV_ParkiBrake_AU48.rod
VCID: 38292BDD72D2CE17317-806C
Part No SW: 4G0 035 082 D HW: 4G0 035 082
Component: Radio U SIRIU H60 0112
Revision: AB001007 Serial number: 156FU0C7603251
Coding: 020007010000000001
VCID: 211FE6B9C1C8AFDFE69-8074
Reset counter: 207
Mileage: 218866 km
Date: 2019.10.30
Time: 15:41:24
Bin. Bits: 00000000 00101100
Part No SW: 8R1 035 746 B HW: 8R1 035 746 B
Component: H-BNT-NA H43 0552
Revision: -------- Serial number: 204FT0C7505273
Coding: 010200050006E1EF55028F4E00000403140000000000000000
VCID: 363525E57846386723B-8062
Subsystem 1 - Part No: 8R0 060 884 AM
Component: NAR 2012 0605
Subsystem 2 - Part No SW: 8R0 919 604 HW: 8R0 919 604
Component: DU7 High H41 0104
Serial number: A130FG0CS189870
Subsystem 3 - Part No SW: 8T0 919 611 C HW: 8T0 919 611 C
Component: E0380 Bedient H02 0020
Serial number: 00000001174897
Subsystem 4 - Part No: 8R0 060 961 D
Component: CD-Database 4353
Fault Frequency: 15
Reset counter: 207
Mileage: 218866 km
Date: 2019.10.30
Time: 15:41:24
Bin. Bits: 10111110 10000010
Bin. Bits: 00000100 10011111
Bin. Bits: 00000000 00000000
Fault Frequency: 8
Reset counter: 207
Mileage: 218866 km
Date: 2019.10.30
Time: 15:41:44
Bin. Bits: 00011110 00010000
Bin. Bits: 00000000 00011010
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000032030548
Coding: 010C13204000210001
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H07--- Serial number: 525PA8-J2591A8
Coding: 1000007
VCID: 38292BDD7E52CE17317-806C
Part No SW: 8K9 827 851 A HW: 8K9 827 851 A
Component: J605 Master H52 0330
Revision: -------- Serial number: 8K9827851A
VCID: 3C2137CD466AE237D5F-8068
Subsystem 1 - Part No SW: 8K9 827 852 A HW: 8K9 827 852 A
Component: J756 Slave H52 0330
Serial number: 8K9827852A
Component: TSG HR H01 0506
Revision: Serial number: 0000032030332
End----------(Elapsed Time: 02:14, VBatt start/end: 14.4V/14.5V)-----------
