2008 Audi Q7 Alarm System Indicates Break-in Condition After Locking with FOB
pauljs33
C?ID=385174
Hi All,
My Q7 has an issue where the alarm system keeps beeping 45 seconds after locking the car. This precludes me from locking the car which is a bit more than an annoyance. I purchased a Ross-Tech cable and ran a scan on the vehicle. I would appreciate a little help with some of the intricacies of some of the error codes. This is my first attempt at using this system, so it appears a little overwhelming with the amount of data that is presented in the scan. First of all, I was surprised by the number of fault codes which came up on my scan. The one which looks most interesting and possibly related to this problem is Address 46: Central Conv.
This address indicates there is a Subsytem 1 which is Component: LIN BACKUP HORN H03 1301. I suspect I may need to replace the horn at this point. the fault found at this address is:
01403 - Glass-Break Sensors; Rear
Reset counter: 220
All 4 of the door sensors indicate OK. The electric trunk also indicates OK.
Any advice on this fault or other possible faults that I am overlooking, would be greatly appreciated. There are certainly a lot of fault codes to choose from in this scan! I am posting the full scan info below:
Tuesday,29,October,2019,18:13:02:04546
VIN: WA1AY74L28D042453   License Plate: 1HYZ20
Mileage: 240040km-149153mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 1E 42 46 47 4F 52 56
          61 62 65 6D 6F 72
VIN: WA1AY74L28D042453   Mileage: 240040km-149153miles
Address 01: Engine (BHK)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 CA    HW: 03H 906 032 G
   Component: Q7 3.6-FSI-LEV2 G   1379
   Revision: 5CH05---    Serial number:
   Coding: 0001175
   Shop #: WSC 31414 790 00001
   VCID: 6393A8C17754A43FB45-8036
7 Faults Found:
008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
               P2098 - 002 - Too Lean - Intermittent
                    Mileage: 239221 km
                    Date: 2019.10.18
                    Time: 08:25:29
                    RPM: 2012 /min
                    Load: 32.5 %
                    Speed: 86.0 km/h
                    Temperature: 96.0°C
                    Temperature: 19.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
               P0300 - 008 -  - Intermittent
                    Mileage: 239951 km
                    Date: 2019.10.28
                    Time: 06:26:09
                    RPM: 1795 /min
                    Load: 24.7 %
                    Speed: 45.0 km/h
                    Temperature: 69.0°C
                    Temperature: 18.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.716 V
000769 - Cylinder 1
               P0301 - 008 - Misfire Detected - Intermittent
                    Mileage: 239951 km
                    Date: 2019.10.28
                    Time: 06:26:18
                    RPM: 1788 /min
                    Load: 51.0 %
                    Speed: 60.0 km/h
                    Temperature: 70.0°C
                    Temperature: 16.0°C
                    Voltage: 13.589 V
000773 - Cylinder 5
               P0305 - 008 - Misfire Detected - Intermittent
                    Mileage: 239951 km
                    Date: 2019.10.28
                    Time: 06:26:18
                    RPM: 1788 /min
                    Load: 51.0 %
                    Speed: 60.0 km/h
                    Temperature: 70.0°C
                    Temperature: 16.0°C
                    Voltage: 13.589 V
000771 - Cylinder 3
               P0303 - 008 - Misfire Detected - Intermittent
                    Mileage: 239951 km
                    Date: 2019.10.28
                    Time: 06:26:18
                    RPM: 1788 /min
                    Load: 51.0 %
                    Speed: 60.0 km/h
                    Temperature: 70.0°C
                    Temperature: 16.0°C
                    Voltage: 13.589 V
000770 - Cylinder 2
               P0302 - 008 - Misfire Detected - Intermittent
                    Mileage: 239951 km
                    Date: 2019.10.28
                    Time: 06:26:18
                    RPM: 1788 /min
                    Load: 51.0 %
                    Speed: 60.0 km/h
                    Temperature: 70.0°C
                    Temperature: 16.0°C
                    Voltage: 13.589 V
000772 - Cylinder 4
               P0304 - 008 - Misfire Detected - Intermittent
                    Mileage: 239951 km
                    Date: 2019.10.28
                    Time: 06:26:18
                    RPM: 1788 /min
                    Load: 51.0 %
                    Speed: 60.0 km/h
                    Temperature: 70.0°C
                    Temperature: 16.0°C
                    Voltage: 13.589 V
   Part No SW: 4L0 910 156 B    HW: 0AT 927 156
   Component: AG6 0AT 3,6 FSI USA 0010
   Revision: --H04---    Serial number:        4035629
   VCID: 2809FFED4EF20767A17-807C
   Part No SW: 4L0 910 517 B    HW: 4L0 614 517 D
   Component: ESP ALLRAD MK25E1   0010
   Revision: 00H30001
   Coding: 0099345
   VCID: 290FFAE955F83E6FBE9-807C
   Component: FBSAUDIC6 ELV   H31 0230
   Revision: 09010701    Serial number: 10601500957792
   Coding: 0000131
   Subsystem 1 - Part No: 4F0 910 131 J
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H01 0040
Address 07: Control Head        Labels: Redir Fail!
   Part No SW: 4L0 910 730 Q    HW: 4L0 035 730 C
   Component: MMI Cockpit     H80 0410
   Revision: C61120EU    Serial number: AUZ6Z2GBMD36I3
   Coding: 0444222
   VCID: 3537269989406A8F2A1-8060
   Subsystem 2 - Serial number: 00000001337903
   Subsystem 3 - Serial number: 0123.06.090000000100010489ÿ
   Subsystem 4 - Serial number: 010489ÿ
                    Bin. Bits:  0000010
   Part No SW: 4L0 910 043 B    HW: 4L0 820 043 L
   Component: KLIMABETAETIGUNGH07 0030
   Revision: 00---013    Serial number: 00000030075150
   Coding: 0524326
   VCID: 2313E8C137D4E43FF45-8076
   Part No SW: 4F0 910 279 K    HW: 4F0 907 279
   Component: ILM Fahrer      H18 0250
   Coding: 0010103
   VCID: 313F12897D2846AF769-8064
   Component: Wischer AU716   H14 0100
   Coding: 00064792
   Shop #: WSC 31414
   Subsystem 2 - Part No: 4E0 910 557 B  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH13 0100
   Coding: 00150059
   Shop #: WSC 31414
Address 0E: Media Player 1        Labels: None
   Coding: 0444222
Address 0F: Digital Radio        Labels: 4E0-910-593-SIR.lbl
   Part No SW: 4E0 910 593 K    HW: 4E0 035 593 F
   Component: SDAR SIRIUS     H07 0140
   Revision: 00000000    Serial number: AUZ4Z7G0215383
   Coding: 0000100
   VCID: 2F3B14F16B1C505F60D-807A
                    Fault Frequency: 14
                    Time Indication: 15
   Component: 73 AIRBAG AUDI8RH42 0230
   Revision: 06H42000    Serial number: 0038QD07AHFD
   Coding: 0014131
   VCID: 2B0300E15F042C7F4C5-807E
   Subsystem 1 - Part No: 4L0 910 339 A
   Component: BF-Gewichtsens. H03 0030
   Subsystem 2 - Serial number: 6332QSME474D250BL
   Subsystem 3 - Serial number: 6342QSME4B21413BD
   Subsystem 4 - Serial number: 6352QSME45182D47L
   Subsystem 5 - Serial number: 6362QSME506E3709M
   Subsystem 6 - Serial number: 63734SME49611F3B8
   Subsystem 7 - Serial number: 63834SME4B212911X
   Revision: 00H03000    Serial number: 90055073260076
   Coding: 0002022
   VCID: 270BFCD143EC081FA8D-8072
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 C    HW: 4L0 920 950 E
   Component: KOMBIINSTR. M73 H16 0240
   Revision: 00200000    Serial number: 65U11K4D7
   Coding: 1555283
   Shop #: WSC 01126 067 57207
   VCID: 2019E7CD26C2FF27E97-8074
   Part No SW: 4L0 910 468 A    HW: 4L0 907 468 B
   Component: J533__Gateway   H06 0060
   Revision: 00H06000    Serial number: 1100B07B278015
   Coding: E557BE57700A0200
   VCID: 2D070EF96110224F521-8078
Address 1E: Media Player 2        Labels: 4E0-910-111.lbl
   Part No SW: 4L0 910 110 A    HW: 4L0 035 110
   Component: MP3-Changer     H45 0350
   Revision: 00045007    Serial number: AUZ5ZBG1242540
   VCID: 1D67DE3911B0D2CFC21-8048
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0150
   Revision: 00-00000
   Coding: 0035403
   Part No SW: 4L0 910 289 F    HW: 4L0 907 289 C
   Component: Komfortgeraet   H07 0050
   Revision: 0050 ---    Serial number: 01084767680000
   Coding: 7370781
   VCID: 33331881873474BF045-8066
                    Reset counter: 220
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4L0 910 223 H    HW: 4L0 035 223 C
   Component: DSP-AU716-RD  H07 0250
   Revision: S0900000
   Coding: 060000
   VCID: 290FFAE959F83E6FBE9-807C
02559 - Rear Right Mid-Range/Woofer Loudspeaker (R160)
                    Fault Status: 00101011
                    Reset counter: 2
                    Mileage: 232297 km
                    Date: 2019.06.03
                    Time: 08:01:45
                    Voltage: 12.20 V
                    Temperature: 19.0°C
                    Bin. Bits: 00000011
   Component: ILM Beifahrer   H12 0100
   Revision:             Serial number: 00000000022253
   Coding: 0012001
   VCID: 5EE599355C3689D79BB-800A
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0150
   Revision: 00-00000
   Coding: 0035403
Address 56: Radio        Labels: None
   Coding: 0444222
   Part No SW: 4L0 910 181 A    HW: 4L0 915 181
   Component: J0644 BEM       H12 0690
   Revision: --------    Serial number: 00000000043063
   Shop #: WSC 07109 444 57830
   VCID: 2517F6D939E01A0F9A1-8070
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2711240739
   Coding: 344630393135313035432056413032373131323430373339
                    Mileage: 239059 km
                    Date: 2019.10.15
                    Time: 12:36:44
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Component: TSG HL          H21 0150
   Coding: 0035338
   Revision: 00050100    Serial number: 00000900061728
   Coding: 0062424
   VCID: 221DEDC528CEED37FF3-8076
   Part No SW: 4L0 910 945     HW: 4L0 827 851 C
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C3FD9A8AEB4705F-8038
   Subsystem 3 - Serial number: RD07.12.07--H25001001B0054ÿ
   Subsystem 4 - Serial number: 1B0054ÿ
   Revision: AAH05061    Serial number: 003314871-----
   Coding: 0000009
   VCID: 2615F1D544E6111793B-8072
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Component: TSG HR          H21 0150
   Coding: 0035338
End----------(Elapsed Time: 01:42, VBatt start/end: 13.6V/13.6V)-----------
"Glass-Break Sensors; Rear -- Open Circuit" does not indicate a break-in, but rather a fault with the glass-break sensor or the wiring thereto.
If you live someplace where break-ins are not a worry, and you don't want to fix this, you could try disabling the whole alarm system. To do this, change the coding in the 46 module from 7370781 to 7370765.
Oh, and for an 11 year old vehicle with ~150,000 miles on it, it doesn't have that many fault codes. If it were mine, I'd clear 'em and see what comes back.
pauljs33
C?ID=385174
Many thanks for the advice! I will clear fault codes and see what happens. Shows my inexperience with fault codes and possibly what they really mean.
Paul
Paul you could also install resistor or set adaption channel if available to bypass zone and not lose entire alarm.
I've looked at the data we have for that CCM and I don't see anything like that.
pauljs33
C?ID=385174
My progress so far:
The manual shows 3 glass breakage sensors in series with each other. Rear Left Side Window sensor (G183), Rear Right Side Window sensor (G184), Rear Window sensor (G304). This series circuit is grounded on 1 end and on the other end is attached to the Convenience system central control unit (J393). This connection is made on pin 27 of T32. I assume J393 just senses whether the circuit is intact by applying a current or voltage to these sensors. The other thing I noticed on the schematic is that the Rear Lid Contact Switch for Anti-theft Alarm (F123) connects to J393 thru Pin 22 of the same connector. The words "for Anti-theft Alarm" caught my attention. I removed the Rear lid contact switch from the car and took some resistance measurements on it. Both switches in the assembly indicated a short circuit relative to the common line no matter what the switch position was. It was pretty apparent that these switches were broken..... So, I closed the gate and locked the car with no switch in place. The alarm system armed as before, but after 45 seconds it did not go blaring with the horn anymore. The security system was working just fine. The security system must check for the tail gate to be closed using this switch, but I believe there is also some interdependence between this switch and the breakage sensors. Not quite sure why this cured the alarm system at this point, but it's a step forward in the process. My fix for the glass breakage sensor will be to bypass it with a short or a resistor of the same value as 1 of the other 2 sensors once I measure them.
I called my local stealer for a replacement switch, but no dice. He didn't have one in stock, so I ordered one on line. My wife has been using the car without the rear switch in place for about a week and has had no issues with the security system acting up. She's happy she can lock the car now. And when Momma's happy====> Everyone's happy.
I will update things when the new switch arrives.
I cleared all previous errors and ran a new scan. Note there are 2 additional error codes due to the switch being removed. Scan is below:
Monday,04,November,2019,17:45:38:04546
          61 62 65 6D 6F 72
VIN: WA1AY74L28D042453   Mileage: 240210km-149259miles
   Coding: 0001175
Readiness: 0110 0101
   Revision: 00H30001
   Coding: 0099345
   Coding: 0000131
   Coding: 0444222
   Coding: 0524326
   Coding: 0010103
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0444222
   Coding: 0000100
                    Time Indication: 15
   Coding: 0014131
   Coding: 0002022
   Coding: 1555283
   Revision: 00-00000
   Coding: 0035403
   Coding: 7370781
                    Reset counter: 229
   Revision: S0900000
   Coding: 060000
   Coding: 0012001
   Revision: 00-00000
   Coding: 0035403
   Coding: 0444222
   Coding: 0035338
   Coding: 0062424
   Coding: 0000009
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 229
                    Mileage: 240216 km
                    Date: 2019.11.04
                    Time: 19:24:19
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 229
                    Mileage: 240216 km
                    Date: 2019.11.04
                    Time: 19:24:19
   Coding: 0035338
End----------(Elapsed Time: 01:41, VBatt start/end: 13.7V/13.7V)-----------
pauljs33
C?ID=385174
My progress so far:
          61 62 65 6D 6F 72
   Coding: 0001175
   Revision: 00H30001
   Coding: 0099345
   Coding: 0000131
   Coding: 0444222
   Coding: 0524326
   Coding: 0010103
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Coding: 0444222
   Coding: 0000100
                    Time Indication: 15
   Coding: 0014131
   Coding: 0002022
   Coding: 1555283
   Revision: 00-00000
   Coding: 0035403
   Coding: 7370781
                    Reset counter: 229
   Revision: S0900000
   Coding: 060000
   Coding: 0012001
   Revision: 00-00000
   Coding: 0035403
   Coding: 0444222
   Coding: 0035338
   Coding: 0062424
   Coding: 0000009
                    Reset counter: 229
                    Mileage: 240216 km
                    Date: 2019.11.04
                    Time: 19:24:19
                    Reset counter: 229
                    Mileage: 240216 km
                    Date: 2019.11.04
                    Time: 19:24:19
   Coding: 0035338
I forgot to reply with my final outcome. After installing the new switch the behavior of the alarm system is normal. There must be some sort of interdependence with that switch.
