Results 1 to 6 of 6
Thread: Need HELP with Traffic Sign recognition on Skoda Superb 3FL
    Unverified
    Oct 2019
    Moldova
    Hi all, I activated Lane Assist on new Skoda Superb 3 FL, it work ok, when I activated Traffic Sign Asist on dash board is error, in block 5F is this error: U111100 ($1C21 / 7201) Function limitation due to missing message
    DTC text: Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful
    Everything is coded corectly. ECU: 005F - Information Control Unit 1
    Coding 03 84 01 01 00 00 00 00 41 11 00 02 00 10 2A 00 2F 01 03 E4 01 20 84 00 DF
    Jun 2014
    Swansea, UK
    Please can you post a full Auto-Scan so we can see how the car is configured
  3. Likes Uwe liked this post
    Unverified
    Oct 2019
    Moldova
    VIN: TMBCJ6NP7L702xxxx  License Plate:
    Mileage: 850km-528 mileage
    Chassis Type: NP-SK48 (3Q0)
    Scan: 01 02 03 05 08 09 10 13 14 15 17 19 22 23 2B 36 3C 42 44 47
              4B 52 5F 6C 6D A5 BB BC
    VIN: TMBCJ6NP7L702xxxx   Mileage: 850km-528mileage
    02-Transmission Control Module -- Status: OK 0000
    17-Instruments -- Status: contains malfunctions 0010
    19-CAN Gateway -- Status: Status: OK 0000
    22-Four-wheel drive electronics -- Status: OK 0000
    47-Acoustic system -- Status: OK 0000
    5F-Information Electr. -- Status:  contains malfunctions 0010
    A5-Frt Sens. Drv. Assist -- Status: OK 000
    Address 01: Engine  (J623-DFHA)      Labels: None
       Part No SW: 04L 906 027 P    АО: 04L 907 309 P
       Component: R4 2.0l TDI   H26 9497
       Revision: B4H26---
       Coding: 01250512036605083000
       Shop  #: WSC 00033 790 00177
       ASAM Dataset: EV_ECM20TDI01104L906027P 005003
       ROD: EV_ECM20TDI01104L906027P_SK48.rod
    Address 02: Transmission Control Module (J743)            Labels:. 0BH-927-711.clb
       Part No SW: 0GC 300 013 K    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2405
       Revision: 00H06V09
       ASAM Dataset: EV_TCMDQ381061 001
       Rod: EV_TCMDQ381061_VW37.rod
       Part No SW:  5Q0 614 517 FA    HW: 5Q0 614 517 BR
       Component: ESC           H82 0190
       Revision: 00000000    Serial number: 62439000003082
       Coding: 1D077A9C31223B6C477B070360CA49B85E8CDCE2E0069275386150B8D2894A0B0003000012121212B835351919323200
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
       ROD EV_Brake1UDSContiMK100IPB_038.rod
    Address 05: Acc/Start Auth. (J518)      Labels:| 5Q0-959-435.clb
       Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
       Component: VWKESSYMQB    037 1307
       Revision: 00037000    Serial number: 0526918593
       Coding: 0F20000723
       ASAM Dataset: EV_KessyHellaMQBAB 004052
       Subsystem 1 - Part No Sw: 3AA 962 243 G    HW: 3AA 962 243 G
       Component: GEB.F.Heckoef  H16 0903
       Serial Number: 84620022
       Part No SW: 3V0 907 044 FG    HW: 3V0 907 044 FG
       Component: AC Automat    H34 4803
       Revision: 20K10000    Serial number: 00000B01450150
       Coding: 11010104002400011005100D0010512A
       ASAM Dataset: EV_ACClimaPrehVW37X 002027
       ROD: EV_ACClimaPrehVW37X.rod
       Subsystem 1 -Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
       Component: G238 _AQS  H30 0119
       Serial number: 91013828
       Subsystem 2 - Part No Sw: 3V0 907 049 E   HW: 3V0 907 049 E
       Component: E265KlimaHeck  H02 0101
       Serial Number:       06051501850797
       Part No SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
       Component: BCM PQ37BOSCH 038 0303
       Revision: --------    Serial number: J53F22081900IB
       ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
       ROD: EV_BCMBOSCH_020_VW27.rod
       Subsystem 1 - Part No Sw: 3V1 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
       Component: 48x LL 190723  032  0121
       Serial number: 00000001907190303621
       Coding: 165DDD
       Subsystem 2 - Part no SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Файл QML: 5Q0-955-547.CLB
       Component: RLHS  051  0206
       Serial number: S4Y19M09D04H08M21S33
       Coding: 0088DF
       Steering Column Switch:
       Subsystem 4 - Part No SW: 5Q1 953 521 DF    HW: 5Q1 953 569 C
       Component: Lenks.Modul  H33  0170
       Serial number: 0100030820190C301403
       Subsystem 5 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Component: SysNameFanLin  014  0101
       Serial number: ESE0939654
       Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0941323
       Subsystem 7 -  Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0541443
       Subsystem 8 -Part No SW: 3G0 963 345     HW: 3G0 963 345
       Serial number: ESE0658015
       Part No SW: 5QA 919 294 G    HW: 5QA 919 294
       Componentт: PDC 8 Kanal   H08 0061
       Serial number: 000150058319255
       Coding: 0471155851
       ASAM Dataset: EV_EPHVA18AU3700000 009046
       Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
       Component: ACC BOSCH MQB H01 0771
       Coding: 320467D259FFC428949C812480300600000000000000000046
       Shop #: WSC 00046 000 00000
       ASAM Dataset: EV_ACCBOSCHVW416 003014
       ROD: EV_ACCBOSCHVW416_003.rod
       Serial number: 28071941350222
       ROD: EV_DRCONTITEMIC_VW37.rod
       Part No SW: 5Q0 959 655 BR    HW: 5Q0 959 655 BR
       Component: AirbagVW21    007 0403
       Serial number: 003FLR5G69L.
       Coding: 88CCC000000000005C5400CF000800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
       ROD: EV_AirbaVW20SMEVW37X.rod
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: -----------    HW: 480 000 709 19
       Serial number 35700000000C5780DF3Z
       Subsystem 2 - Part No SW: -----------    HW: 480 000 709 19
       Serial number: 35800000000ED780DF33
       Subsystem 3 - Part No SW: -----------    HW: 480 400 609 19
       Component: SideSensor_Dr  004 6149
       Serial number: 35100012A2C9EFD6B4BX
       Subsystem 4 - Part No SW: -----------    HW: 480 400 609 19
       Component: SideSensor_Pr  005 6149
       Serial number: 3520001BCF271E74DB2O
       Subsystem 5 - Part No SW: -----------    HW: 480 400 609 19
       Subsystem: FrontSensor_D  005 6149
       Serial number: 3550001C4F27DCC288D-
       Part No SW: 3V0 920 790 D    HW: 3V0 920 790 D
       Component: KOMBI         502 4191
       Coding: 05A5001AFF8C00080188630B5001000080000000
       Shop #: WSC 00046 123 12345
       ASAM Dataset: EV_DashBoardVDDMQBA0 001042
       ROD: EV_DashBoardVDDMQBA0_VW37.rod
    1 fault code:
    U111000 ($FFFF34 / 16777012) Function restriction due to communication interruption
    DTC text: BAP_VZA_0x21 keine Kommunikation
         DTC ambient conditions
             Date 12:52:04 - 31.10.2019
             Odometer reading 837 km
             Priority 6
             Malfunction frequency counter 1
             Unlearning counter 25
       Part No SW: 3Q0 907 530 AC    HW 3Q0 907 530 C
       Component: GW MQB High   521 5388
       Serial number: 08091911601327
       Coding: 0B0100045F087300A90002DA9C0F00010001070000000000000000000000
       Shop #: WSC 00033 790 00138
       ASAM Dataset: EV_GatewNF 013026
       ROD: EV_GatewNF.rod
       Component: 4-01-09-01-04
       Subsystem 2 - Part No SW: 3V0 919 719 G    HW: 3V0 919 719 G
       Component: E221__MFL-PR6  H03 0180
       Serial number 000000000D0266280819
       Serial number: 1056912405
       Power Converter DC AC:
       Subsystem 4 - Part No SW: 5Q0 907 155 B    HW: 5Q0 907 155 B
       Component: U13DCAC  H27 0810
       Serial number: 2153696
    Аdress 22: Four-wheel drive electronics (J492)       Labels:* 0CQ-907-554.clb
       Component: Haldex4Motion H55 7084
       Serial number: HA1-00029.07.19
       Coding: 0301
    Adress 23: Brake Booster (J539)       Labels: None
       Part No SW: 3Q0 909 059 G    HW: 3Q0 909 059 A
       Component: EBKV          H06 0069
       Serial number: BPA085070819013
       Coding: 0102C500340000C618638C31000049922449920400
       ASAM Dataset: EV_BrakeBoostG2BoschVW48X 011019
       ROD: EV_BrakeBoostG2BoschVW48X_011_VW41.rod
       Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
       Component: ELV-MQBB      H05 0020
       Serial number: 19000232040015
       Coding: 0800000000000000
       ROD: EV_ELVMarqMQBA0_AU37.rod
       Part No SW: 3Q0 959 760 C    HW: 3Q0 959 760 C
       Component: Sitzmemory    H06 0026
       Serial number: Y0007SH221374
       Coding: 0010000000000500818280808080000000008181000000D400
       ASAM dataset: EV_SeatMemorDriveSide 002022
    Address 3C: Lane Change (J1086)       Labels:* None
       Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
       Component: HRE3_Kl15_Mst H06 0149
       Serial number: 00000524685562
       Coding: 52954640
       ASAM Dtataset: EV_HREntryHellaGen3Kl15 002001
       ROD: EV_HREntryHellaGen3Kl15.rod
       Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
       Component: TSG FS        007 0485
       Serial number: 0000388435933
       Coding: 001D8920DE00020000001100
    Аdress 44:  Steering Assist (J500)       Labels:| 5Q0-910-143.clb
       Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
       Component: MQB_VWBS_GEN2 212 2211
       Serial number: 956032 00
       Coding: 0100001100400110
       ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
       ROD: EV_SteerAssisVWBSMQBGen2_VW37.rod
    Аdress 47:  Acoustic system (J525)       Labels:| 81A-035-466.clb
       Part No SW: 81A 035 223     HW: 81A 035 223
       Component: MIB2_amp_P_SK H10 0410
       Revision: 00000001    Serial number: SKZ8Z1KJE08AJ79
       Coding: 0384010000AA002FAA0000000000
       ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
       ROD: EV_AMPMst16C5Gen2ALPI.rod
       Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
       Component: FCM MQB Low   003 0367
       Serial number: 03071910801912
       Coding: 00000007090008F206003D13010000000000000000000000000000000000
       Shop #: WSC 00033 790 00120
       ASAM Dataset: EV_MultiModulContiVW48X 003003
       ROD: EV_MultiModulContiVW48X_003.rod
       Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
       Componet: TSG BFS       007 0485
       Serial number: 0000388209181
       Coding: 001D8120DE00020000001100
       ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
       Part No SW: 565 035 020 E    HW: 565 035 020
       Componnet: MU-H-ND-EU    H55 1440
       Serial number: A855F0KB027938
       Coding: 03840101000000004111000200102A002F0103E401208400DF
       Subsystem 1 - Part No SW: 3V0 919 606 D    HW: 3V0 919 606 D
       Component: ABT_High-2  H52 9130
       Serial number: SKZ6ZHW2520418
       subsystem 2 - Part No SW: V03 959 803 TF    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote2  --- 1017
    1 fault code:
             Priority 6
       Component: RVC Compact   H18 0231
       Coding: 04840101A2002017000040
       Part Noo SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
       Component: HDSG-Modul    H13 0271
       Revision: --------    Serial number : A2-C737-6291-8
       Coding: 1008
       ROD: EV_DeckLidCONTIAU736_AU73.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 2Q0 980 653     HW: 2Q0 980 653
       Component: MQB MFK 3.0   H11 1027
       Serial number: E33417008192560
       Coding: 0002088821684028B0DF10001030008000210000000000000000000000000000
       ASAM Dataset: EV_MFK3ValeoMQB 005035
       ROD: EV_MFK3ValeoMQB_005_AU37.rod
       Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
       Component: TSG HFS       010 0384
       Serial number: 0000388696285
       Coding: 001C81208000020000001100
    ddress BC: Door Rear Pass (J389)       Labels:* None
       Component: TSG HBFS      010 0384
       Serial number: 0000388691588
    End---------------------(Elapsed Time: 05:54)-----------------------
    Quote Originally Posted by georgexs View Post
    This is Auto-scan
    That scan smells of fish, and the fish is not fresh.
  6. Likes downtime liked this post
    Unverified
    Oct 2019
    Moldova
    Translate from russian sorry
    If you have a legitimate interface, you can use the English version from this page:
    https://www.ross-tech.com/vcds/download/current.php
    Please do so, and post a complete, un-edited scan.
