02 MK IV Wagon Electric Mirrors
Tunacan406
C?ID=324267
I just looked up ErWin fuse location for non heated outside mirrors in my Jetta '02 wagon. Anyone know about this?
Jef
HQ
I know of fuses but I'm not sure I understand your question... What issue are you trying to resolve? Can you provide an Auto-Scan w/VIN so we can have more information about the vehicle?
Tunacan406
C?ID=324267
Thanks for answering! I'm not finding the location for the fuse supplying the outside mirrors on this 2002 Jetta Wagon. neither of them is working. I poured over ErWin for two hours. Found the diagram for the Fuseblock in the left side of the dash. Nothing there as I read it.
Friday,01,November,2019,14:25:30:20071
Dealer/Shop Name: Accurate Garage
Workshop Code: 444 11757 000000
VIN: WVWSG61JX2W109063   License Plate: HTZ8151
Mileage: 224040km-139212mi   Repair Order: 11.01.19
Chassis Type: 1J (1J - VW Golf/Bora IV (1998 > 2006))
          76
VIN: WVWSG61JX2W109063   Mileage: 224040km-139212miles
Address 01: Engine        Labels: 021-906-018-AFP.lbl
   Part No: 021 906 018 AA
   Component: MOTRONIC ME7.1  G   6763
   Coding: 00033
   Shop #: WSC 06532
   VCID: 4DC7942E94C5F81F721-5160
   WVWSG61JX2W109063     VWZ7Z0A3726200
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 KR
   Component: AG4 Getriebe 01M    4889
   Coding: 00000
   VCID: 0A4D5F32252BAF27973-0962
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRONT MK60      0103
   Coding: 0018945
   Shop #: WSC 01317 785 00200
   VCID: 2B03FAB6CF11D62F4C5-5160
   Part No: 6Q0 909 605 F
   Component: 03 AIRBAG VW6  0202 0004
   Coding: 12339
   Shop #: WSC 01317
   VCID: 3A2DCFF2354B7FA7C73-513C
   Part No: 1J0 920 906 K
   Component: KOMBI+WEGFAHRSP VDO V02
   Coding: 07232
   Shop #: WSC 06434
   VCID: 3039EDDAE337B5F7797-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 01317
   VCID: 70B92DDA23B7F5F7397-513C
   Part No: 1C0 959 799 C
   Component: 8A Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 04940
   VCID: 372BD6C6065962CF38D-4B1E
   Component: 1G Tõrsteuer.FS KLO 0003
   Component: 1G Tõrsteuer.BF KLO 0002
   Component: 1G Tõrsteuer.HL KLO 0002
   Component: 1G Tõrsteuer.HR KLO 0002
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1J0 035 180 B
   Component:  Radio DE2         0005
   Coding: 02041
   Shop #: WSC 01317
   VCID: 1E65236289A33387DBB-51CE
End----(Elapsed Time: 04:49, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
          76
   Coding: 00033
   Shop #: WSC 06532
   Coding: 00000
   Coding: 0018945
   Coding: 12339
   Shop #: WSC 01317
   Coding: 07232
   Shop #: WSC 06434
   Coding: 00006
   Shop #: WSC 01317
   Coding: 00258
   Shop #: WSC 04940
   Coding: 02041
   Shop #: WSC 01317
   VCID: 1E65236289A33387DBB-51F2
End----------(Elapsed Time: 05:02, VBatt start/end: 13.6V/13.4V)-----------
Samz09
NJ, USA
Message me your email and i will send you 3 diagrams, there's more but these should answer you questions
dieseldub
Gresham, OR
C?ID=28764
The reason you're not seeing fuses for only the mirror adjustment is because they aren't directly fused. On power window mk4s, everything passes through the door control module. The door control module is part of the window motor. The door control module is what's directly powering the mirror adjustment motors.
Seeing as how there are no codes in the 46 central convenience module and that all the subsystems are recognized and are the correct matching part numbers and color code, I would not suspect there is a fuse issue. It's possible it's a bad switch, in which case you can view in Measured Values in the 46 central convenience module if the mirror adjust switch is being recognized at all. If it's not being recognized, then the likely answer is either the switch isn't plugged in or it's broken, though I believe typically when it's not plugged in a code WOULD get set.
I believe it is measured value block 003 on the 1C0959799C module.
