Results 1 to 4 of 4
Thread: Jetta 7speed DSG basic setting
    Apr 2015
    South Africa
    Had the gearbox repaired, new mechatronics fitted & clutch fork repaired. Oil filled correctly. Basic setting runs through 100% (060). Can engage reverse but as soon as ~D~ is selected the fault code appears with no positve torque afterwards. Fault can be cancelled and basic settings runs perfectly.
    Any suggestions?
    Wednesday,16,October,2019,08:30:21:48706
    VIN: WVWZZZ16ZDM083969   License Plate: CWJ 485 L
    Mileage: 190520km-118383mi   Repair Order:
    Chassis Type: 16-VW32 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: WVWZZZ16ZDM083969   Mileage: 190520km-118383miles
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 MP    HW: 03L 907 425 C
       Component: 1,6l R4 CR td H43 9970
       Revision: --H43---    Serial number: 00000000000000
       Coding: 10254014032500080000
       Shop #: WSC 00066 000 00186
       ASAM Dataset: EV_ECM16TDI02103L906023MP 003010
       ROD: EV_ECM16TDI02103L906023ML_003.rod
       VCID: 004C65ED9BBD414FA7-8054
    7332 - Mass Air Flow Sensor (G70)
              P0103 00 [165] - Signal too High
                        Time: 00:00:00
                        Coolant temperature: 54 C
                        Intake air temperature: 34 C
                        Ambient air pressure: 930 mbar
                        Voltage terminal 30: 12.085 V
                        Engine speed: 0 /min
                        Battery voltage: 11.9 V
                        EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]: 0.000 %
                        Throttle_actuator_commanded_value-ANG_SP_THR[0]: 3.999 %
                        Air mass: specified value-MAF_SP_MMV: 269.87 mg/stroke
                        Air mass: actual value (mg/stroke)-MAF_MES: 0 mg/stroke
    7366 - Cylinder 1 Glow Plug Circuit (Q10)
              P0671 00 [037] - Electrical Fault
                        Mileage: 190527 km
                        Date: 2019.10.16
                        Time: 00:00:20
                        Coolant temperature: 19 C
                        Intake air temperature: 20 C
                        Ambient air pressure: 940 mbar
                        Voltage terminal 30: 11.633 V
                        Glow status-STATE_GLOW: 48
                        Fuel temperature-TFU: 19 C
                        Sensor for engine block temperature: raw value-Coolant temperature: 19 C
    7419 - Cylinder 2 Glow Plug Circuit (Q11)
              P0672 00 [037] - Electrical Fault
                        Mileage: 190527 km
                        Date: 2019.10.16
                        Time: 00:00:20
    7368 - Cylinder 3 Glow Plug Circuit (Q12)
              P0673 00 [037] - Electrical Fault
                        Mileage: 190527 km
                        Date: 2019.10.16
                        Time: 00:00:20
    7367 - Cylinder 4 Glow Plug Circuit (Q13)
              P0674 00 [037] - Electrical Fault
                        Mileage: 190527 km
                        Date: 2019.10.16
                        Time: 00:00:20
    6088 - No Communication with Transmission Control Module
              U0101 00 [036] - -
                        Mileage: 190527 km
                        Date: 2019.10.16
                        Time: 00:00:22
                        Driver request torque-TQI_DRIV_SUB: 0.00 Nm
                        Control Module temperature-TECU: 33 C
       Part No SW: 0AM 300 058 R    HW: 0AM 927 769 D
       Component: GSG DSG AG7     431 5270
       Revision: 00043014    Serial number: CU501410275184
       Shop #: WSC 28747 001 1048576
       VCID: 40CCA5ED133D814FE7-8014
    006293 - Functional Restriction due to Pressure Drop
                   P1895 - 000 -  - Intermittent
                        Reset counter: 5
                        Mileage: 190524 km
                        Date: 2014.03.08
                        Time: 12:08:19
    001851 - Gear 6
                   P073B - 008 - Not Selectable - Intermittent - MIL ON
                        Fault Status: 10101000
                        Reset counter: 40
                        Mileage: 190524 km
                        Date: 2014.03.08
                        Time: 12:08:20
    001850 - Gear 5
                   P073A - 000 - Not Selectable - Intermittent
                        Reset counter: 40
                        Mileage: 190524 km
                        Date: 2014.03.08
                        Time: 12:08:23
       Revision: 00H31001
       Coding: A33B20F8092A00FDC51404EA90220081251000
       Shop #: WSC 00066 000 00000
       VCID: 7DB21C19E44F2CA7CC-8028
       Part No SW: 7N0 907 426 BH    HW: 7N0 907 426 BH
       Component: AC Manuell    H20 0505
       Revision: 00001018
       Coding: 0010002002
       Shop #: WSC 00066 000 00120
       ROD: EV_ACManueBHBVW36X_VW32.rod
       VCID: 7BB61201F25B2297F2-802E
       Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
       Component: BCM PQ35 M    021 0068
       Revision: BC021001
       Coding: 00000A3A802DE1C040880080140081640170008850A085605C8000000040
       VCID: 3E30DB15A9C9F7BF95-806A
       Component: RLS 210313 05  54  0403
       Coding: 02300A
       Subsystem 2 - Part No: 1K8 951 171
                010 - Open or Short to Plus
                        Fault Status: 01101010
                        Reset counter: 212
                        Mileage: 169854 km
                        Date: 2013.07.15
                        Time: 12:56:48
                            Term 15 On
                        Voltage: 13.60 V
                        Fault Status: 00101010
                        Fault Frequency: 9
                        Reset counter: 4
                        Mileage: 189738 km
                        Date: 2014.02.26
                        Time: 12:41:26
                            Term 15 On
                        Voltage: 12.90 V
       Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
       Component: AirbagVW10    013 0613
       Serial number: 003G6M09BP17
       Coding: 00003241
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3228FF25659123DF61-8066
       Serial number: 3572MSME64095177ZZZW
       Serial number: 3582MSME65095177ZZZY
       Subsystem 3 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
       Serial number: 3516KSME12450D23ZZZJ
       Serial number: 3526KSME682A7023ZZZS
       Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
       Component: Lenks.Modul   008 0090
       Revision: --------    Serial number:  90440MCB0019K
       Coding: 0892140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 42C8AFE5D531935FF1-8016
       Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS  H30 0036
       Serial number: 0007866 FLE 20130306
       Coding: 830000
       Part No SW: 5C6 920 872 A    HW: 5C6 920 872 A
       Component: KOMBI         H07 0705
       Coding: 171B01
       VCID: 2B16E24142BB721722-807E
       Part No SW: 7N0 907 530 AF    HW: 7N0 907 530 AF
       Component: J533  Gateway H52 1634
       Revision:   H52       Serial number: 28041303270720
       Coding: 351003
       VCID: 74A4393DD7056DEFB3-8020
                        Reset counter: 3
                        Mileage: 190527 km
                        Date: 2014.03.08
                        Time: 00:00:23
       Component: IMMO          H07 0705
       VCID: 6A9827458DC1AB1F19-803E
       Part No SW: 561 959 701     HW: 3C0 959 793 B
       Component: TUER-SG FT    002 0515
       Revision: 13110009    Serial number: 0006621326
       Coding: 0002B5
       Shop #: WSC 01383 790 50316
       VCID: 5BF67281529BC29792-800E
       Slave Driver:
       Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  009 1508
       Serial number: 00000007806972
       Coding: 000290
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 219
    67074 - Motors for Central Locking
              B122B 01 [009] - Electrical Failure
                        Fault Frequency: 9
                        Reset counter: 196
                        Mileage: 180534 km
                        Date: 2019.06.21
                        Time: 14:31:07
    67330 - Switch for Central Locking
              B122D 29 [008] - Signal Implausible
                        Reset counter: 4
       Part No: 1K0 909 144 P
       Component: EPS_ZFLS Kl. 70     3305
       Revision: 00H22000
       Shop #: WSC 02069 000 90108
       VCID: 373ECE3146F3C6F756-8062
                000 - - - MIL ON
                        Fault Status: 11100000
                        Battery Volts: 12.3 V
                            PD
                        Temperature: 33.0C
                        Count: 2
                        Steering Angle: 0.00
                            SteerAng n.Init
       Part No SW: 561 959 702     HW: 3C0 959 792 B
       Component: TUER-SG BT    002 0515
       Revision: 15110009    Serial number: 0006633546
       Coding: 0002B4
       VCID: 5CF4719D5795C5AF9B-8008
       Slave Passenger:
       Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  008 1508
       Serial number: 00000007719042
       Coding: 000290
                        Reset counter: 219
    67589 - Turn Signal in Exterior Mirror
              B11FD 01 [009] - Electrical Failure
                        Reset counter: 219
                        Mileage: 120668 km
                        Date: 2017.09.08
                        Time: 15:47:26
    132610 - Motors for Rear Central Locking
              B122C 01 [008] - Electrical Failure
                        Reset counter: 4
                        Mileage: 165967 km
                        Date: 2019.01.18
                        Time: 12:14:28
    132866 - Switch for Rear Central Locking
              B122E 29 [008] - Signal Implausible
                        Reset counter: 4
                        Mileage: 165967 km
                        Date: 2019.01.18
                        Time: 12:14:28
       Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
       Component: Radio RCD510  005 0236
       Revision: 00000001    Serial number: VWZ1Z3N1972880
       Coding: 05000400040006
       VCID: 2404097D2765BD6FE3-8070
       Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
       Component: TELEFON       H15 3200
       Revision: 1B001001    Serial number: 00007664389147
       Coding: 0A01000000010101
       ASAM Dataset: EV_UHVNA 002720
       ROD: EV_UHVNA_002.rod
       VCID: 393AC809B8E7D087A0-806C
    End----(Elapsed Time: 01:19, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
    Thursday,31,October,2019,14:07:06:48706
    Did you check grounds and connectivity for load ability, could be faulty mechanical basic setting or control unit recheck work and pump/ports?
    United States
    I don't have any contributions but you may find the PDF linked in this thread helpful:
    https://forums.ross-tech.com/showthr...3D-P173E-P173F
  4. Likes Uwe, Jack@European_Parts liked this post
    Jun 2016
    Guyana
    Replace the valve body of the mechatronic (hydraulics) and that should solve this issue, are you sure this is a "New" mech unit? how did the installation go? as suggested recheck installation , common fault is valvebody of mech unit, i did a few over the year with similar faults to your nature, hope this helps.
  6. Likes Jack@European_Parts, Dana liked this post
