Results 1 to 9 of 9
Thread: Audi A6 AD Hello BLUE FAULT
    Oct 2019
    Ireland
    Hello I am having a problem with a 2014 Audi A6 , engine code :CHN .There is a ad blue system fault on the dash and not a ad blue refill fault on the dash. The customer was driving the car on the motorway when the fault light came on with a limit of 600 miles left on the count down.The customer drove another 100 miles and filled the ad blue to the top . When the car came to me there are no logged faults on vag com but the light was still on the dash.
    I have checked the pressure in the ad blue and it registers 5000 mbar when the reduction pump is activated .I took off the adblue injector ,and gave it a clean .I then activated it by using the SRC activation metering valve procedure and it sprayed perfectly .I have driven the car 70 miles and disconnected the battery for a half an hour but the fault light was still on.
    I did the SRC metering quality test .src lock test and checked the level of the SRC and all ok. Any help would be great .it seems like a software update but when I Audi was contacted i was told there are no software up dates but they are willing to book it in and look at it.
    VCDS Version: 19.6.2.0 (x64)
    Dealer/Shop Name: Ballinlough Motors
    VIN: WAUZZZ4G5EN161217   License Plate: 142 C 4948
    Mileage: 166103km-103211mi   Repair Order: DAMIEN CLIFFORD
    CODE Chassis Type: 4G-AU57 (4G5)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 5F 62 72 AC
    VIN: WAUZZZ4G5EN161217   Mileage: 166103km-103211miles
    Address 01: Engine (J623-CNHA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 FE    HW: 04L 907 309
       Component: R4 2,0L EDC   H23 8243
       Revision: 85H23---
       Coding: 0A194012242401080000
       Shop #: WSC 33529 001 1048576
       ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
       ROD: EV_ECM20TDI01104L906021FE_002.rod
       VCID: 6DDA0836BCAC59277C-8038
       Coding: 06A09F016005F9808B00
       VCID: 3A70F36ABD623E9FA9-806E
       Part No SW: 4H0 907 064 EG    HW: 4H0 907 064 EG
       Component: BCM2 2.0      H36 0521
       Coding: 03B83046000000000000
       VCID: 72E01B4AAD9286DFA1-8026
       Serial number: 0214000077556001
       Part No SW: 4G0 820 043 BA    HW: 4G0 820 043 BA
       Component: KLIMA 2 ZONEN H14 0096
       Serial number: 30041400111581
       Coding: 3421090821
       ASAM Dataset: EV_AirCondiBasisUDS 004002
       ROD: EV_AirCondiBasisUDS_004.rod
       VCID: 5FC662FE46003BB7FE-800A
       Part No SW: 4H0 907 063 CA    HW: 4H0 907 063 A
       Revision: 12012002    Serial number: 00000001866002
       Coding: 690000108034A7600405008000005F5F0F9D820827080201000004406000
       VCID: 69D27C268044450710-803C
       Component: WWS57X 140415  H37 0080
       Serial number:         140426093358
       Coding: 0045F7
       Serial number: 22587879
       Coding: 02006D
       Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
       Component: E1 - LDS  H07 0044
       Serial number: 16 04 2014  00001085
       Serial number: F2388927000000000001
       Revision: 11001001    Serial number: 61061412800321
       Coding: 08C205
       VCID: 71E21446A094BDC758-8024
       Revision: --------    Serial number: 003JG00HUU5Y
       Coding: 3032343631324E303235554A305234473053
       VCID: 3668E75A897ADAFF4D-8062
       Serial number: 3575HRB405N2M1H628UN
       Serial number: 3585HRB400Q50PASHOTT
       Serial number: 3515JRB400K510A0G9SZ
       Serial number: 3525JRB400K510A0IA3E
       Serial number: 3554VRB401G50VKQO97E
       Serial number: 3564VRB401050U86E8VM
       Revision: 00000000    Serial number: 20140509000314
       Coding: 000014
       VCID: 3064D142631EF4CF17-8064
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0010
       Part No SW: 4G8 920 950 S    HW: 4G8 920 950 S
       Component: MDieGb        H43 0411
       Revision: 27450259    Serial number: 658060514592019
       Coding: 33A40A0003412600010000
       ASAM Dataset: EV_RBC7KMID 004048
       ROD: EV_RBC7KMID.rod
       VCID: 3F86827EA6401BB79E-806A
       Part No SW: 4G5 907 468 C    HW: 4G5 907 468 B
       Revision: --------    Serial number: 00000001342465
       Coding: 00CD074400
       VCID: 356AE056947CD1E744-8060
       Serial number: 6369093303
       Voltage stabilizer:
       Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
       Serial number: 140226000000000002C0
       Component: SARA 3D       H03 0056
       Revision: --------    Serial number: EJ1BPA7209UMR5
       ASAM Dataset: EV_SARA2 005012
       ROD: EV_SARA2.rod
       VCID: 336EDE4E9A08CFD76A-8066
       Coding: 011C16004001620002080002
       VCID: 47969A9EF690537726-8012
       Component: RCEPS         H40 0010
       Revision: 00001000    Serial number: 0025524597
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 3260DB4A6512C6DF61-8066
       Revision: 00002001    Serial number: 0331642391
       Coding: 011B062280B900408320080400010E470000000000000000000000000000
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 26
                        Reset counter: 182
                        Mileage: 151912 km
                        Date: 2019.04.24
                        Time: 14:02:06
    02616 - Fuel Tank Cap; Unlock
                        Fault Frequency: 26
                        Reset counter: 182
                        Mileage: 151912 km
                        Date: 2019.04.24
                        Time: 14:10:09
       VCID: 4688979AF19A4A7FDD-8012
       Component: EPB-4         H03 0015
       Revision: --------    Serial number: 00000001059547
       ROD: EV_ParkiBrake_VW51.rod
       VCID: 2D5AC8367C2C99273C-8078
       Part No SW: 4G0 035 192 P    HW: 4G0 035 192 F
       Component: RMC Nav Plus  H55 RMC Nav Plus  H55 08180818
       Coding: 0101000001415B47082B060301010000010000
       VCID: 2F66D23E7E20EB370E-807A
       Subsystem 1 - Part No: 8X0 919 884 G
       Component: P24-50-13.06
       Subsystem 2 - Part No: 4G0 919 603 B
       Component: DU6 Basic
       Subsystem 3 - Part No: 4G2 919 710 B
       Component: E380 BDT C7
    No Faults Found
       VCID: 49929CA6E084A50730-801C
       Part No SW: 4G0 907 355 C    HW: 4G0 907 355 B
       Component: SCR-Stg-G2    H10 0010
       Revision: 00000000    Serial number: 141060503
       ROD: EV_RDCMA00100_008.rod
       VCID: 2B5EC62E4238971722-807E
    End-------------------------(Elapsed Time: 04:07)--------------------------
    ECU software version is 8243. There is a newer version 8286 for it.
    https://vag-flashinfo.de/
    If it were mine, I might try one or both of the following Basic Settings:
    IDE04567 -- Resetting of SCR tank level detection
    IDE04730 -- Reset SCR lock
    VCDS Distributor AIB Wolfgang's Avatar
    Sep 2014
    Hello
    Remember, most faults in the SCR system are only deleted after a successful regeneration
    -Wolfgang
    Drive more talk less
  4. Likes Uwe, PetrolDave, MartinsX liked this post
    Oct 2019
    Ireland
    Thanks for your replies .I forgot to mention that I had also reset the SRC lock and reset the tank level detection but still no joy. Just wondering Wolfgang are you suggesting to keep driving until it regenerates and it the codes will clear them self's .or should I do a forced regeneration.
    Oct 2019
    Ireland
    Mileage: Repair Order: AUDI A6 AD
    Address 01: Engine (04L 906 021 FE)
    08:42:55
    IDE00432 Particle filter: time since last regeneration 43509 s
    IDE00435 Particle filter: soot mass measured 9.46 g
    IDE00436 Particle filter: kilometers since last regeneration 224618 m
    IDE01408 Charge limit for field regeneration 22.77 g
    IDE01409 Charge limit for service regeneration 40.00 g
    IDE03142 Remaining vehicle distance until reducing agent deficiency 547.80 km
    IDE05232 Reducing agent fill level 96.61 %
    IDE05630 Reducing agent tank fill level indicator: raw value 100.00 %
    IDE05865 DPF statistics: soot mass measured at start of regeneration 0.00 g
    IDE05867 DPF statistics: soot mass calculated at start of regen 0.00 g
    IDE06839-ENG57549 Reducing agent fill level sensor: diag. status-Bits 0-7 0
    These are some of the measurement blocks .It shows that the adblue tank is full .My question is the value in km since the last regeneration is off.Is this normal?
    Jun 2014
    Swansea, UK
    Quote Originally Posted by HOWIE View Post
    If the reported units are to be believed the distance since regen is shown in meters, so it's only 224km?
    Oct 2019
    Ireland
    Thanks Mike , I never would have thought the measurement would be in meters.
  9. #8
    Jun 2014
    Swansea, UK
    Being described as "kilometers since last regeneration" does confuse things somewhat
  10. #9
    Quote Originally Posted by Mike@Gendan View Post
    VAG does silly stuff like this on occasion. Be glad it's all in metric. Imagine the fun it would be if it were described as "mileage since last regeneration" and the actual units were yards.
  11. Likes Mike@Gendan, PetrolDave liked this post
