Good Day Folks,
Has anyone seen or knows solution to diagnose and repair below symptom?
Every few times I drive, the power steering assist feels like is on and off during making a turn. It feels stiff, cuts out, then releases with a bit of force then cuts out again as per video below. There are no abnormal noises from power steering, fluid level is at max, no air bubbles in the tank and no leaks of PS fluid. The fluid is Audi OEM. I did VCDS scan, cleared DTCs, no change.
It does that sporadically, I can drive with no issues, and then it suddenly will start malfunctioning. I drove car 7 times today, it did that on last drive, otherwise everything was functioning normally.
https://www.youtube.com/watch?v=E7vgRDKrVPY
I tried to find as much info as I could on this topic, I suspect (don't have evidence yet) is that power steering assist is switching between highway speed setting and actual speed setting. One way this could be happening is when solenoid valve N119 would be malfunctioning by either getting incorrect speed signal, being faulty or have wiring issue. Below is quick video of the valve I am talking about. In my VCDS I wasn't able to locate this valve. Does anyone know where I could find it?
https://www.youtube.com/watch?v=MwVAbUn9WFQ
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 13 15 16 17 19 25 28 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E74N018426 Mileage: 148340km-92174miles
0E-Media Player 1 -- Status: Malfunction 0010
16-Steering wheel -- Status: Sporadic communication error 1000
38-Roof Electronics -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 1010
75-Telematics -- Status: Malfunction 1010
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V A 0070
Revision: 00000000 Serial number: AUX3Z0D0532620
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4DA645CEE490B7BE-804A
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
18107 - Powertrain Data Bus
P1699 - 008 - Missing Message from Steering Wheel Electronics - Intermittent
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0028755
VCID: 2447A9A9E782B36FE3-8070
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527) - Intermittent
RPM: 736 /min
RPM: 736 /min
(no units): 30.0
(no units): 26.0
Temperature: 72.0°C
T.B. Angle: 0.0°
Voltage: 12.24 V
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0007597
Shop #: WSC 91590 000 00000
VCID: 224BAFB1FD96BD5F91-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0532620
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58BFCD59EB4A278FBF-800C
Component: ELV XXXX
Fault Frequency: 14
Reset counter: 157
Mileage: 146544 km
Date: 2019.09.26
Time: 11:37:40
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
Shop #: WSC 00000 785 00200
VCID: 2345AAB5E28CB4579A-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.clb
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346BG057520451
Coding: 0000003
Shop #: WSC 24038 001 1048576
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000099389
Subsystem 3 - Serial number: 0120.10.150000000100010016ÿ
Subsystem 4 - Serial number: 010016ÿ
00658 - Control Head
Fault Frequency: 38
Reset counter: 157
Mileage: 146043 km
Date: 2019.09.18
Time: 16:52:42
02103 - Control Module 2 for Vehicle Electrical System (J520)
Reset counter: 155
Mileage: 148142 km
Date: 2019.10.24
Time: 12:56:00
01964 - Control Module for Seat & Steering Column Memory (J136)
Reset counter: 153
Mileage: 147968 km
Date: 2019.10.21
Time: 16:26:11
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000034031
Coding: 1151313
VCID: 5ABBD7519546359F89-800E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO17012004065A000000000038ÿ†89
Subsystem 5 - Serial number: 000038ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO17012004065A00000000
Subsystem 7 - Serial number: 65A000000000067ÿ
00657 - Positioning Motor for Central Vents (V102)
Fault Status: 00100011
Reset counter: 136
Mileage: 147868 km
Date: 2019.10.19
Time: 17:06:37
Voltage: 13.30 V
Temperature: 17.0°C
(no units): 100.0
(no units): 95.0
Temperature: -85.0°C
Fault Status: 00101100
Reset counter: 151
Mileage: 148204 km
Date: 2019.10.25
Time: 13:56:57
00066 - Rear Right Footwell Heater (Z43)
Reset counter: 155
Mileage: 148262 km
Date: 2019.10.26
Time: 13:59:44
Voltage: 13.00 V
Address 09: Cent. Elect. Labels: 4E0-910-279.clb
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111104
VCID: 2A5B479185A6651FD9-807E
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H40 0380
Coding: 00000035
Shop #: WSC 02313
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:09:17
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:10:46
Reset counter: 149
Mileage: 148169 km
Date: 2019.10.24
Time: 16:15:32
Fault Status: 00101101
Reset counter: 152
Mileage: 148204 km
Date: 2019.10.25
Time: 12:28:06
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7277578
VCID: 1B359255DAFC8C9752-804E
02446 - Disk Drive Mechanical Malfunction
Fault Status: 00101110
Reset counter: 39
Mileage: 143972 km
Date: 2019.08.21
Time: 14:13:52
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 E HW: 4E0 907 561 E
Component: ABSTANDSREGELUNGH02 0030
Coding: 0011228
004 - No Signal/Communication - Intermittent - MIL ON
Fault Status: 10110100
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:12:00
Temperature: 24.0°C
Voltage: 9.98 V
Bin. Bits: 00100010
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:13:00
Temperature: 27.0°C
Voltage: 11.78 V
Bin. Bits: 00100000
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 E
Component: Airbag 8.4E+ H10 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H13 0040
Coding: 0012251
VCID: 65C1F4ADAC388A6734-8030
Component: Lenkradmodul H04 0080
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 930 HW: 4E0 920 930 H
Component: KOMBIINSTR. VDO H51 0090
Revision: D14 Serial number: AUDID3CD000173
Coding: 0016333
Shop #: WSC 47694 000 1048576
VCID: 5FCDE6458E64D0B7FE-800A
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 D
Component: Gateway H06 0030
Revision: 06 Serial number: 01006032240084
Coding: FEFE7FDD1B2304
Shop #: WSC 91590 999 80175
VCID: 2643B3A191BE417FFD-8072
00384 - Optical Databus
Fault Status: 00101011
Reset counter: 125
Mileage: 144978 km
Date: 2019.08.29
Time: 11:02:26
00465 - Control Module for Telephone/Telematic (J526)
Fault Frequency: 111
Reset counter: 157
Mileage: 147966 km
Date: 2019.10.21
Time: 10:06:49
Reset counter: 155
Mileage: 148142 km
Date: 2019.10.24
Time: 12:55:20
Reset counter: 149
Mileage: 148153 km
Date: 2019.10.24
Time: 15:05:50
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:10:41
Fault Status: 00100111
Reset counter: 151
Mileage: 148204 km
Date: 2019.10.25
Time: 12:28:07
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
Fault Frequency: 14
Reset counter: 157
Mileage: 146544 km
Date: 2019.09.26
Time: 11:37:40
Part No SW: 4E0 910 158 HW: 4E0 919 158 A
Component: KLIMA-STG. FOND 015 0210
Revision: 00000014 Serial number: 00000000014509
Coding: 0000000
VCID: 61C9E0BDB810E647C8-8034
Address 34: Level Control Labels: 4E0-910-553.clb
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2541B4ADECB84A67F4-8070
Reset counter: 133
Mileage: 147710 km
Date: 2019.10.16
Time: 16:11:27
Component: Sitzmemory FS H07 0060
Coding: 4071650
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H43 0570
Revision: 00000000 Serial number: 355AJ047515209
VCID: 356164ED5C183AE744-8060
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0090
Serial number: 00000400700015
Coding: 0003989
VCID: 1D319C4DC4E882A7AC-8048
Fault Frequency: 15
Reset counter: 155
Mileage: 148140 km
Date: 2019.10.24
Time: 12:55:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM007 0110
Coding: 0028196
VCID: 5EB3DB41896ED9BFF5-800A
014 - Defective
Fault Status: 01101110
Reset counter: 109
Mileage: 148160 km
Date: 2019.10.24
Time: 16:13:40
Reset counter: 152
Mileage: 148192 km
Date: 2019.10.25
Time: 13:55:48
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040401090125
Coding: 0065086
VCID: 275DBEA596B45877C6-8072
Component: Heckdeckel H05 0050
Component: Neigungssensor H02 0020
01134 - Alarm Horn (H12)
Fault Status: 01101100
Reset counter: 117
Mileage: 57235 km
Date: 2013.11.04
Time: 09:05:00
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:12:49
01316 - ABS Control Module
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:14:43
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 117
Mileage: 140802 km
Date: 2019.07.12
Time: 17:51:33
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000678264
Coding: 0000016
00456 - Control Module for Access and Start Control (J518)
Reset counter: 149
Mileage: 148169 km
Date: 2019.10.24
Time: 16:15:08
Reset counter: 109
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000030823
Coding: 0010111
VCID: 1E339B41C9EE99BFB5-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0BB3E
Fault Frequency: 23
Reset counter: 155
Mileage: 262140 km
Date: 2018.07.10
Time: 20:19:00
Reset counter: 156
Mileage: 148140 km
Date: 2019.10.24
Time: 11:40:00
Fault Frequency: 21
Reset counter: 156
Mileage: 148304 km
Date: 2019.10.27
Time: 19:51:00
Fault Frequency: 31
Reset counter: 156
Mileage: 148304 km
Date: 2019.10.27
Time: 17:59:00
Fault Frequency: 20
Reset counter: 156
Mileage: 148304 km
Date: 2019.10.27
Time: 17:59:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM007 0110
Coding: 0028196
014 - Defective
Reset counter: 109
Mileage: 148160 km
Date: 2019.10.24
Time: 16:11:06
Reset counter: 152
Mileage: 148192 km
Date: 2019.10.25
Time: 13:55:48
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000001
VCID: 62CBEFB1BD16FD5FD1-8036
Part No SW: 4E0 910 541 C HW: 4E0 035 541 B
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304FI057609105
Coding: 0000000
VCID: 204FA5B9F39AAF4F87-8074
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H12 0480
Revision: 00000000 Serial number: 00000000012072
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 36060440KW
Coding: 303030393135313035444C56413033363036303434304B57
02272 - Quiescent Current Stage 1
Mileage: 132548 km
Date: 2019.03.03
Time: 23:50:20
02274 - Quiescent Current Stage 3
Fault Frequency: 8
Mileage: 148196 km
Date: 2019.10.25
Time: 02:50:14
02277 - Quiescent Current Stage 6
Mileage: 148347 km
Date: 2019.10.28
Time: 10:40:12
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:10:51
Fault Frequency: 9
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:09:20
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM007 0110
Coding: 0028196
VCID: 5DB1DC4D8468C2A7EC-8008
014 - Defective
Reset counter: 109
Mileage: 148160 km
Date: 2019.10.24
Time: 16:13:28
Reset counter: 152
Mileage: 148192 km
Date: 2019.10.25
Time: 13:55:48
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM007 0110
Coding: 0028196
014 - Defective
Reset counter: 109
Mileage: 148160 km
Date: 2019.10.24
Time: 16:15:50
Reset counter: 152
Mileage: 148192 km
Date: 2019.10.25
Time: 13:55:48
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616 A
Component: Telematik USA1 0070
Revision: 00000004 Serial number: 0000ATD3007652
Coding: 0000005
VCID: 60CFE5B9B01AEF4FC7-5140
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402100422
Coding: 0001208
VCID: 2149A0BDF890A64788-8074
Fault Frequency: 27
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:09:34
Fault Frequency: 7
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 16:14:43
Reset counter: 149
Mileage: 148168 km
Date: 2019.10.24
Time: 15:36:07
End-------------------------(Elapsed Time: 03:41)--------------------------
