Results 1 to 3 of 3
Thread: Can anyone help with transmission coding for an audi all road
    Dec 2018
    Currently the transmission control module is under water and has no communication. Can we fit a second hand unit ? and can someone assist us with the coding required? Please see below:
    Tuesday,29,October,2019,15:05:49:63423
    VIN: WAUZZZ4B55N026517   License Plate: KS05CUA
              75 76 77
    Address 01: Engine        Labels: 059-907-401-AKE.clb
       Part No: 8E0 907 401 J
       Component:  2.5l/4VTEDC G200AG  0006
       Coding: 06006
       Shop #: WSC 01242
       VCID: 2C14D881DEFC882F2B-4B1E
       WAUZZZ4B55N026517     AUZ7Z0E2716863
    00534 - Engine Oil Temperature Sensor (G8)
    18034 - Powertrain Data Bus
                P1626 - 35-10 - Missing Message from TCU - Intermittent
    01318 - Control Module for Injection Pump (J399)
    00546 - Data wiring faulty
                35-10 - - - Intermittent
    18062 - Please check DTC Memory of Instrument Cluster
                P1654 - 35-10 -  - Intermittent
    Readiness: 1 2 X 0 X
    Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
       Part No: 4Z7 907 389 A
       Component: ABS/ESP allrad      D66
       Coding: 06457
       Shop #: WSC 02335
       VCID: 4AD8BE197448B61F39-5160
    18256 - Please check DTC Memory of Engine Controller
                P1848 - 35-10 -  - Intermittent
    18265 - Load Signal
                P1857 - 35-10 - Error Message from ECU - Intermittent
    18031 - Powertrain Data Bus
                P1623 - 35-10 - No Communication - Intermittent
    01310 - Level Control System Control Module (J197)
                P1626 - 35-00 - Missing Message from TCU
    Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
       Part No: 4B0 820 043 AP
       Component: A6-Klimavollautomat 0208
       Coding: 00104
       Shop #: WSC 02335
       VCID: 689C64910984640F0F-2586
                57-00 - Electric Circuit Failure
    01312 - Powertrain Data Bus
                37-10 - Faulty - Intermittent
    Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
       Part No: 4Z7 959 655 M
       Component: Airbag 8.4EP        1000
       Coding: 0001106
       Shop #: WSC 02334 785 00200
       VCID: 59FA515591EECD8780-5184
    Address 16: Steering wheel        Labels: 4B0-907-487.lbl
       Part No: 4B0 907 487 H
       Component: Lenkradelektronik   D01
       Coding: 01012
       Shop #: WSC 02334
       VCID: 312AC9F5FADEE5C718-5184
    Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
       Part No: 4B0 920 981 J
       Component: KOMBI+WEGFAHRS. VDO D17
       Coding: 04460
       Shop #: WSC 00222
       VCID: 2D12D585E5E681273C-5160
                49-00 - No Communications
    Address 34: Level Control        Labels: 4Z7-907-553.lbl
       Part No: 4Z7 907 553 F
       Component:  - 2C1A1          X060
       Coding: 25500
       Shop #: WSC 02335
       VCID: 48DC84116A44440F2F-513C
    7 Faults Found:
                79-00 - Please Check Fault Codes
    01400 - Suspension Level Control
                11-00 - Control Limit Not Reached
                79-10 - Please Check Fault Codes - Intermittent
    02538 - Function Restriction due to Overload
    01577 - Turn-Off due to Over-Temp
    Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
       Part No: 4B0 962 258 N
       Component: Zentralverrieg.,DWA D38
       Coding: 06863
       Shop #: WSC 02335
       VCID: 3424C0E105CCD0EF73-4F0C
    8 Faults Found:
    01366 - Opened Due to Crash Signal
                35-00 - -
                35-00 - -
                35-00 - -
                35-00 - -
    01370 - Alarm triggered by Interior Monitoring
                35-00 - -
                35-00 - -
    01574 - Alarm triggered by Door Contact Switch; Rear Right
                35-00 - -
    01573 - Alarm triggered by Door Contact Switch; Rear Left
                35-00 - -
       Part No: 4B0 959 760 B
       Component: Sitzmemory R1 F     0204
       Coding: 00001
       VCID: 2C14D881DDFC882F2B-4B1E
                07-00 - Signal too Low
    Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
       Part No: 4B0 951 178 A
       Component: Innenraumueberw.    D04
       Coding: 00102
       Shop #: WSC 02334
       VCID: 26002AA9C310B27FFD-50F4
    01349 - Alarm via Theft Warning System; Front
                35-00 - -
       Part No: 4Z7 907 357
       Coding: 00030
       Shop #: WSC 02334
       VCID: 0444502115ECA06F83-4B1E
    Address 56: Radio        Labels: 8D0-035-1xx-56.lbl
       Part No: 4B0 035 186 P
       Component: concert II  GRO    0004
       Coding: 02005
       Shop #: WSC 02334
       VCID: 2D12D585E6E681273C-4B00
    End----------(Elapsed Time: 04:53, VBatt start/end: 14.3V/14.2V)-----------
    Coding is not the problem here you need a module.
    Vehicle Identification No. WAUZZZ4B55N026517
    Model Audi A6 Av.qu.2,5 TDI
    allroad
    A6AR
    Date of production 11.04.2005
    Model year 2005
    Sales type 4BH0FZ
    Engine Code BAU
    Transmission Code EYJ
    You need this 4Z7-927-156N
    https://www.ebay.com/itm/331907104827
    Send me old Unit I will hook you up with additional forum discount & unit will be plug and play pre coded and set.
    Aug 2016
    The Hague, NL
    Usually it's not a problem to fit a second-hand unit, but as you mention, coding it could be tricky.
    I'd suggest to get a unit. Then have a look at the label file or use the RT forum/Google to guesstimate a good coding.
    Or, even better, leave it all up to the Jack to fix it for you.
