Currently the transmission control module is under water and has no communication. Can we fit a second hand unit ? and can someone assist us with the coding required? Please see below:
Tuesday,29,October,2019,15:05:49:63423
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ4B55N026517 License Plate: KS05CUA
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998 > 2005))
75 76 77
Address 01: Engine Labels: 059-907-401-AKE.clb
Part No: 8E0 907 401 J
Component: 2.5l/4VTEDC G200AG 0006
Coding: 06006
Shop #: WSC 01242
VCID: 2C14D881DEFC882F2B-4B1E
WAUZZZ4B55N026517 AUZ7Z0E2716863
00534 - Engine Oil Temperature Sensor (G8)
18034 - Powertrain Data Bus
P1626 - 35-10 - Missing Message from TCU - Intermittent
01318 - Control Module for Injection Pump (J399)
00546 - Data wiring faulty
35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - Intermittent
Readiness: 1 2 X 0 X
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 4Z7 907 389 A
Component: ABS/ESP allrad D66
Coding: 06457
Shop #: WSC 02335
VCID: 4AD8BE197448B61F39-5160
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - Intermittent
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
18031 - Powertrain Data Bus
P1623 - 35-10 - No Communication - Intermittent
01310 - Level Control System Control Module (J197)
P1626 - 35-00 - Missing Message from TCU
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AP
Component: A6-Klimavollautomat 0208
Coding: 00104
Shop #: WSC 02335
VCID: 689C64910984640F0F-2586
57-00 - Electric Circuit Failure
01312 - Powertrain Data Bus
37-10 - Faulty - Intermittent
Address 15: Airbags Labels: 4B0-959-655-AI84.lbl
Part No: 4Z7 959 655 M
Component: Airbag 8.4EP 1000
Coding: 0001106
Shop #: WSC 02334 785 00200
VCID: 59FA515591EECD8780-5184
Address 16: Steering wheel Labels: 4B0-907-487.lbl
Part No: 4B0 907 487 H
Component: Lenkradelektronik D01
Coding: 01012
Shop #: WSC 02334
VCID: 312AC9F5FADEE5C718-5184
Address 17: Instruments Labels: 4B0-920-xxx-17.lbl
Part No: 4B0 920 981 J
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 04460
Shop #: WSC 00222
VCID: 2D12D585E5E681273C-5160
49-00 - No Communications
Address 34: Level Control Labels: 4Z7-907-553.lbl
Part No: 4Z7 907 553 F
Component: - 2C1A1 X060
Coding: 25500
Shop #: WSC 02335
VCID: 48DC84116A44440F2F-513C
7 Faults Found:
01316 - ABS Control Module
01400 - Suspension Level Control
11-00 - Control Limit Not Reached
79-10 - Please Check Fault Codes - Intermittent
02538 - Function Restriction due to Overload
01577 - Turn-Off due to Over-Temp
Address 35: Centr. Locks Labels:. 4B0-962-258.clb
Part No: 4B0 962 258 N
Component: Zentralverrieg.,DWA D38
Coding: 06863
Shop #: WSC 02335
VCID: 3424C0E105CCD0EF73-4F0C
8 Faults Found:
01366 - Opened Due to Crash Signal
35-00 - -
35-00 - -
35-00 - -
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01369 - Alarm triggered by Hood Switch
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
35-00 - -
Part No: 4B0 959 760 B
Component: Sitzmemory R1 F 0204
Coding: 00001
VCID: 2C14D881DDFC882F2B-4B1E
07-00 - Signal too Low
Address 45: Inter. Monitor Labels: 4B0-951-178.lbl
Part No: 4B0 951 178 A
Component: Innenraumueberw. D04
Coding: 00102
Shop #: WSC 02334
VCID: 26002AA9C310B27FFD-50F4
01349 - Alarm via Theft Warning System; Front
35-00 - -
Address 55: Headlight Range Labels: 4Z7-907-357.lbl
Part No: 4Z7 907 357
Component: dynamische LWR D09
Coding: 00030
Shop #: WSC 02334
VCID: 0444502115ECA06F83-4B1E
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 4B0 035 186 P
Component: concert II GRO 0004
Coding: 02005
Shop #: WSC 02334
VCID: 2D12D585E6E681273C-4B00
End----------(Elapsed Time: 04:53, VBatt start/end: 14.3V/14.2V)-----------
