Results 1 to 2 of 2
Thread: MK60EC1 ABS FAQ
    HQ
    MK60EC1 ABS FAQ
    The MK60EC1 ABS module has a complex soft coding structure that varies from vehicle to vehicle. Because of this, we strongly suggest everyone run an Auto-Scan BEFORE information is lost.
    • VCDS automatically saves Auto-Scans. If an Auto-Scan was performed prior to the soft coding being lost, you can retrieve that information. Details here.
    • If there is no past Auto-Scan that captured the soft coding information, you will need to post an Auto-Scan from the vehicle in the Car Repair Support section. Details here.
    Relevant fault codes:
    We get asked about installing used ABS module. For the 2009 and 2010 year models, I'd avoid this. Early MK60EC1 modules fail a lot and we have seen many cases of the used module failing soon after being installed, or just outright worse than what it was replacing.
    If you go with a used module... make sure the part numbers match 100%... and accept your fate when the used module is no good.
    Jef
  2. Likes Andy, Dana liked this post
  3. #2
    HQ
    Some screen shots of errors... ignore for now.
    https://imgur.com/a/NUQVarD
    Jef
