Phaeton 2007 dashboard
Pedja
Serbia
C?ID=48712
Phaeton 2007 dashboard security access key? I should change the can configuration in the dashboard and ask for security access.In helper there is none.
Chassis Type: 3D (6N0)
Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 34 36 37 38 42 46 47
          52 55 62 68 71 72 76 77
VIN: WVWZZZ3DZ88000556   Mileage: 185680km-115376miles
18-Aux. Heat -- Status: Cannot be reached 1100
68-Wiper Electr. -- Status: OK 0000
71-Battery Charger -- Status: OK 0000
Address 01: Engine (CAR)       Labels: None
   Part No SW: 3D0 907 401 D    HW: 3D0 907 401 D
   Component: 3.0TDI EDC17G100AG  0090
   Revision: --H01---    Serial number: VWX3Z0G1606278
   Coding: 0406002C190F0160
   Shop #: WSC 00399 211 80519
   VCID: 200CE6E1F23FC14F87-5160
   Part No SW: 09L 927 760 N    HW: GS1 911 4
   Component: AG6 09L 3,0 TDI RdW 3401
   Revision: --H03---    Serial number:        4330809
   VCID: 42C84C691C73F35FF1-5160
Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
   Part No: 3D0 614 517 AK
   Component: ESP 5.7 allrad  H33 0047
   Coding: 0008356
   Shop #: WSC 01065 000 00000
   VCID: 6B96C1CD4B79D21762-51CE
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406418    Serial number: VWX3Z0G1606278
   Coding: 0004328
   VCID: 281CFEC19F0F390FCF-807C
Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
   Part No: 3D0 959 759 CA
   Component: Sitzmemory D1 BF    1720
   Coding: 0000003
   VCID: 77BEEDBD023166F796-8022
00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
   Part No: 3D0 035 007 AJ
   Component:    ZAB COCKPIT      2215
   Coding: 0400527
   VCID: 618AA3E5B9B58847C8-5160
00483 - Control Module for Auxiliary Air Heater
Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
   Part No: 3D0 907 040 J
   Component: Climatronic D1      2031
   VCID: 2502F7F5E81D2467F4-8070
            014 - Defective
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
   Part No SW: 3D0 937 049 M    HW: 3D0 937 049 M
   Component: J519                6500
   Revision: -4004---    Serial number: --------------
   Coding: 610C0000EB2115060000000000000000
   VCID: 34241AB153C74DEF73-8060
   Part No: 3D0 909 601 E
   Component: 0H Airbag 8.4E+ H12 0935
   Coding: 0012360
   Part No: 7L6 953 549 K
   Component: J527                3601
   Coding: 0000012
   VCID: 47DE5D7D3251D67726-8012
Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
   Part No SW: 3D0 920 885 PX    HW: 3D0 920 885 PX
   Component: J285 KOMBI-INST.    5432
   Revision: KPH06V18
   Coding: 0007101
   Shop #: WSC 12345 123 23456
   VCID: 0F6EB55D1EA14E372E-805A
01207 - Control Module for Auxiliary Heater (J364)
                    Reset counter: 204
                    Mileage: 185686 km
                    Date: 2006.01.01
                    Time: 00:49:40
Address 18: Aux. Heat
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 3D0 920 885 PX
   Component: J533  GW-K-CAN TP20 5432
   Coding: 7FF2F7AE3B1002
   VCID: 70ACD6A1635F31CF57-8024
                    Reset counter: 204
                    Mileage: 185686 km
                    Date: 2006.01.01
                    Time: 00:49:40
Address 34: Level Control        Labels: 3D0-907-553-V2.clb
   Part No: 3D0 907 553 C
   Component: LUFTFDR.-CDC- 3C3V0 1122
   Coding: 0005521
   Shop #: WSC 00454 211 07993
   VCID: 271EFDFD92113677C6-8072
Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
   Part No: 3D0 959 760 CA
   Component: Sitzmemory D1 F     1720
   Coding: 0000004
   VCID: 6FAED5DD7A612E374E-803A
Address 37: Navigation        Labels: None
   VCID: 55E28735B8FD74E7A4-8000
No Faults Found
Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
   Part No: 3D0 907 135 D
   Component: Dachmodul           0802
   Coding: 0004159
   VCID: 2404EAF1E327DD6FE3-8070
00222 - Connection to Rain Sensor
Address 46: Central Conv.        Labels: 3D0-959-933.lbl
   Part No: 3D0 959 933 F
   Component: X3 HSG              0102
   Coding: 0000040
   VCID: 332619AD53C94AD76A-4B1E
   Subsystem 1 - Part No: 3D1 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 3D1 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 3D0 959 703 G
   Subsystem 4 - Part No: 3D0 959 704 G
   Subsystem 5 - Part No: 3D0 909 610 C
   Component: 3L HDSG             2330
   Subsystem 6 - Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 3D0 035 466 A
   Component: 12K-AUDIOVERST      0118
   VCID: 200CE6E1F73FC14F87-8074
Address 52: Door Elect, Pass.
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    X014
   Revision:   H01       Serial number:
   Coding: 2213953
   VCID: 393A2B8574A5B087A0-806C
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0002
   Coding: 00000033
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0002
   Coding: 00000033
Address 62: Door, Rear Left
Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
   Part No: 3D1 955 119 B
   Component: Front Wiper         2306
   Coding: 0013685
   Shop #: WSC 01065 000 376832
Address 71: Battery Charger        Labels: 3D0-915-181.lbl
   Part No: 3D0 915 181 D
   Component: Batteriemanagement  2800
Address 72: Door, Rear Right
Address 76: Park Assist        Labels: None
   Part No: 3D0 919 283 D
   Component: 01 Einparkhilfe     0907
   VCID: 2B1601CD8EF9121722-807E
Address 77: Telephone
End----------(Elapsed Time: 03:52, VBatt start/end: 12.3V/12.2V)-----------
More back-story here. Has the Aux Heater been removed?
I think you need to go to 19-CAN Gateway to take care of this, not 17-Instruments.
Pedja
Serbia
C?ID=48712
Aux Heater burned and unstuck.To clear the error in the instrument I needed a security code. The car is finished.tnx
Spacewalker
Poland
C?ID=159607
no, just remove it from can gateway
as it still existimng 18-Aux. Heat -- Status: Cannot be reached 1100
