Results 1 to 4 of 4
Thread: Phaeton 2007 dashboard
    Verified VCDS User Pedja's Avatar
    Dec 2015
    Serbia
    Phaeton 2007 dashboard security access key? I should change the can configuration in the dashboard and ask for security access.In helper there is none.
    Chassis Type: 3D (6N0)
    Scan: 01 02 03 05 06 07 08 09 15 16 17 18 19 34 36 37 38 42 46 47
              52 55 62 68 71 72 76 77
    VIN: WVWZZZ3DZ88000556   Mileage: 185680km-115376miles
    18-Aux. Heat -- Status: Cannot be reached 1100
    38-Roof Electronics -- Status: Malfunction 0010
    68-Wiper Electr. -- Status: OK 0000
    71-Battery Charger -- Status: OK 0000
    Address 01: Engine (CAR)       Labels: None
       Part No SW: 3D0 907 401 D    HW: 3D0 907 401 D
       Component: 3.0TDI EDC17G100AG  0090
       Revision: --H01---    Serial number: VWX3Z0G1606278
       Coding: 0406002C190F0160
       Shop #: WSC 00399 211 80519
       VCID: 200CE6E1F23FC14F87-5160
       Part No SW: 09L 927 760 N    HW: GS1 911 4
       Component: AG6 09L 3,0 TDI RdW 3401
       Revision: --H03---    Serial number:        4330809
       Coding: 0000001
       VCID: 42C84C691C73F35FF1-5160
    Address 03: ABS Brakes        Labels: 3D0-614-517.lbl
       Part No: 3D0 614 517 AK
       Component: ESP 5.7 allrad  H33 0047
       Coding: 0008356
       Shop #: WSC 01065 000 00000
       VCID: 6B96C1CD4B79D21762-51CE
       Part No SW: 3D0 909 139 B    HW: 5WK 485 04
       Component:    Kessy            6840
       Revision: 68406418    Serial number: VWX3Z0G1606278
       Coding: 0004328
       VCID: 281CFEC19F0F390FCF-807C
    Address 06: Seat Mem. Pass        Labels: 3D0-959-759.lbl
       Part No: 3D0 959 759 CA
       Component: Sitzmemory D1 BF    1720
       Coding: 0000003
       VCID: 77BEEDBD023166F796-8022
    00477 - Control Module; Display & Input; Comfort CAN; Front (J523)
    Address 07: Control Head        Labels: 3D0-035-00x-07.lbl
       Part No: 3D0 035 007 AJ
       Component:    ZAB COCKPIT      2215
       Coding: 0400527
       VCID: 618AA3E5B9B58847C8-5160
    00483 - Control Module for Auxiliary Air Heater
    Address 08: Auto HVAC        Labels: 3D0-907-040.lbl
       Part No: 3D0 907 040 J
       Component: Climatronic D1      2031
       Coding: 0000001
       VCID: 2502F7F5E81D2467F4-8070
                014 - Defective
                008 - Implausible Signal
    Address 09: Cent. Elect.        Labels:. 3D0-937-049-V2.clb
       Part No SW: 3D0 937 049 M    HW: 3D0 937 049 M
       Component: J519                6500
       Revision: -4004---    Serial number: --------------
       Coding: 610C0000EB2115060000000000000000
       VCID: 34241AB153C74DEF73-8060
    Address 15: Airbags        Labels: 3D0-909-601.lbl
       Part No: 3D0 909 601 E
       Component: 0H Airbag 8.4E+ H12 0935
       Coding: 0012360
    Address 16: Steering wheel        Labels: 7L6-953-549.lbl
       Part No: 7L6 953 549 K
       Component: J527                3601
       Coding: 0000012
       VCID: 47DE5D7D3251D67726-8012
    Address 17: Instruments        Labels: 3D0-920-xxx-17.lbl
       Part No SW: 3D0 920 885 PX    HW: 3D0 920 885 PX
       Component: J285 KOMBI-INST.    5432
       Revision: KPH06V18
       Coding: 0007101
       Shop #: WSC 12345 123 23456
       VCID: 0F6EB55D1EA14E372E-805A
                        Reset counter: 204
                        Mileage: 185686 km
                        Date: 2006.01.01
                        Time: 00:49:40
    Address 18: Aux. Heat
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 3D0 920 885 PX
       Component: J533  GW-K-CAN TP20 5432
       Coding: 7FF2F7AE3B1002
       VCID: 70ACD6A1635F31CF57-8024
                        Reset counter: 204
                        Mileage: 185686 km
                        Date: 2006.01.01
                        Time: 00:49:40
    Address 34: Level Control        Labels: 3D0-907-553-V2.clb
       Part No: 3D0 907 553 C
       Component: LUFTFDR.-CDC- 3C3V0 1122
       Coding: 0005521
       Shop #: WSC 00454 211 07993
       VCID: 271EFDFD92113677C6-8072
    Address 36: Seat Mem. Drvr        Labels: 3D0-959-760.lbl
       Part No: 3D0 959 760 CA
       Component: Sitzmemory D1 F     1720
       Coding: 0000004
       VCID: 6FAED5DD7A612E374E-803A
    Address 37: Navigation        Labels: None
       VCID: 55E28735B8FD74E7A4-8000
    No Faults Found
    Address 38: Roof Electronics        Labels: 3D0-907-135.lbl
       Part No: 3D0 907 135 D
       Component: Dachmodul           0802
       Coding: 0004159
       VCID: 2404EAF1E327DD6FE3-8070
    00222 - Connection to Rain Sensor
    Address 46: Central Conv.        Labels: 3D0-959-933.lbl
       Part No: 3D0 959 933 F
       Component: X3 HSG              0102
       Coding: 0000040
       VCID: 332619AD53C94AD76A-4B1E
       Subsystem 1 - Part No: 3D1 959 701 H
       Subsystem 2 - Part No: 3D1 959 702 H
       Subsystem 3 - Part No: 3D0 959 703 G
       Subsystem 4 - Part No: 3D0 959 704 G
       Subsystem 5 - Part No: 3D0 909 610 C
       Component: 3L HDSG             2330
       Subsystem 6 - Part No: 7L0 907 719 A
       Component:    Neigungssensor   0020
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No: 3D0 035 466 A
       Component: 12K-AUDIOVERST      0118
       VCID: 200CE6E1F73FC14F87-8074
    Address 52: Door Elect, Pass.
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
       Component: AFS-Steuergeraet    X014
       Revision:   H01       Serial number:
       Coding: 2213953
       VCID: 393A2B8574A5B087A0-806C
       Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul l    0002
       Coding: 00000033
       Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
       Component: AFS-Lst.-Modul r    0002
       Coding: 00000033
    Address 62: Door, Rear Left
    Address 68: Wiper Electr.        Labels: 3Dx-955-1xx-V2.clb
       Part No: 3D1 955 119 B
       Component: Front Wiper         2306
       Coding: 0013685
       Shop #: WSC 01065 000 376832
    Address 71: Battery Charger        Labels: 3D0-915-181.lbl
       Part No: 3D0 915 181 D
       Component: Batteriemanagement  2800
    Address 72: Door, Rear Right
    Address 76: Park Assist        Labels: None
       Part No: 3D0 919 283 D
       Component: 01 Einparkhilfe     0907
       VCID: 2B1601CD8EF9121722-807E
    Address 77: Telephone
    End----------(Elapsed Time: 03:52, VBatt start/end: 12.3V/12.2V)-----------
  2. Likes Boki Ar liked this post
  3. #2
    More back-story here. Has the Aux Heater been removed?
    I think you need to go to 19-CAN Gateway to take care of this, not 17-Instruments.
  4. Likes Jack@European_Parts liked this post
  5. #3
    Dec 2015
    Serbia
    Aux Heater burned and unstuck.To clear the error in the instrument I needed a security code. The car is finished.tnx
    Jun 2014
    Quote Originally Posted by Pedja View Post
    no, just remove it from can gateway
    as it still existimng 18-Aux. Heat -- Status: Cannot be reached 1100
  7. Likes Uwe liked this post
