Door Chime
1854sailor
C?ID=18366
Wondering if it's possible to disable the door chime on a MK IV Golf. The car was t-boned yesterday on the driver's side. The door closes and locks, but the chime wont stop. Thanks in advance!
PetrolDave
Westbury, UK
C?ID=1423
An Auto-Scan would help answer your question.
1854sailor
C?ID=18366
Here you go...
Monday,28,October,2019,16:01:21:21539
VCDS Version: 19.6.0.5 (x64)  HEX-NET CB: 0.4505.4
VIN: 9BWBP21J41M040959   License Plate: JTC215
Mileage: 188950km-117408mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Mileage: 188950km-117408miles
Address 01: Engine        Labels: 038-906-012-AGR.clb
   Part No: 038 906 012 CP
   Component: RC s01a EDC G400AG  2839
   Coding: 00001
   Shop #: WSC 00001
   VCID: 608CA6F8E217804FF6-4B1E
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 KA
   Component: AG4 Getriebe 01M    4836
   Coding: 00011
   VCID: 79BAEB9C618D7187D1-0964
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 C
   Component: ABS FRONT MK60      0103
   Coding: 0004097
   Shop #: WSC 00001 785 00200
   VCID: 2A1804D084AB0A1FE8-5184
   Part No: 6Q0 909 605 A
   Component: 14 AIRBAG VW5  02   0004
   Coding: 12596
   Shop #: WSC 00001
   VCID: 352227AC0D1555E775-4B3C
   Part No: 1J0 920 905 M
   Component: A4-KOMBIINSTR. VDO V06
   Coding: 07232
   Shop #: WSC 00113
   VCID: 312A13BCF97D79C729-5160
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2539613
   IMMO-IDENTNR: VWZ7Z0Y2539613
   Part No: 6N0 909 901
   Coding: 00007
   Shop #: WSC 00001
   VCID: 70ACD6B832F730CF66-5160
Address 35: Centr. Locks        Labels: 1C0-962-258-II.lbl
   Part No: 1C0 962 258 P
   Component: 06 Zentr.Verriegel. 0001
   Coding: 00257
   Shop #: WSC 00001
   VCID: 34241AA8066F4CEF42-4B7A
01179 - Incorrect Key Programming
            35-00 - -
Address 56: Radio        Labels: 1J0-035-18x-56.lbl
   Part No: 1J0 035 180 D
   Component:  RADIO 3CP         0002
   Coding: 01401
   Shop #: WSC 00001
   VCID: 200CE6F8A297C04FB6-4B1E
End----------(Elapsed Time: 04:39, VBatt start/end: 12.3V/12.3V)-----------
Wow, an Mk.4 with manual-crank windows. That's quite unusual.
I don't see any way to kill the door-chime in this car via the diagnostic API.
1854sailor
C?ID=18366
Thanks, Uwe. Yeah, crank-up windows and no sunroof, it was a lucky find. We bought it new, it's been Janet's daily driver for over 18 years and is still going strong. I've serviced the 01M with fluid and filter changes every 40K miles and it still shifts like new. Turns out that if I slam the door shut very hard it does stop chiming. Just have to really put a shoulder into the door to open it because of the damage.
Best, Paul
Mike@Gendan
Swansea, UK
C?ID=57030
I don't suppose it's as simple as bypassing the courtesy light switch on that door is it (so the car thinks the door is closed)?
Or do modern cars pick up something from the locking mechanism?
"Modern" cars definitely get it from the locking mechanism.
But an Mk.4 is hardly modern, and I don't recall whether that car still has a separate switch or not. I don't think I've ever seen an Mk.4 with manual crank windows in the flesh either.
MartinsX
Riga, Latvia
C?ID=268515
MK4 has door status (open/close) microswitch built-in in the door lock mechanism. The one outside the plastic "electric box". To bypass it is not necessary disassemble door, OP need WD and find what wire is it at CCM or at coupling station at A-pillar.
P.S. Picture is stolen from http://forums.tdiclub.com/
