Results 1 to 10 of 14
Thread: RS5 electrical fault, loss of power steering (B8.5)
    Nov 2018
    Hi, had a fluke accident last night where I accidentally caught an aftermarket relay wiring harness on the corner of something and it yanked the wire out of the connector as I was trying to locate it. The wire in question was the main hot wire and it touched the windshield wiper control module, causing a spark. Happened so fast but I knew I'd done some damage and it was stupid of me not to disconnect the battery.
    Anyway...I'm great at fixing many things but anything electronic is not my best area.
    I do have a full scan. The primary issue is the power steering is dead. No assist and the dash has lit up like a Christmas tree.
    I'll be attempting to move the car into a more opportune spot so I can check all the fuses (cheap stuff first!). Looking over the electrical FSM, I cannot tell if there's a relay for the active steering control module.
    I have a lot of codes as a result of all of this. Ignore the error with the seat and the radio, I've had those forever and a day. Changed the coding on the radio to enable it to use my phone as a wifi hotspot with other supporting hardware.
    As I said, I'll start with the fuses but after that, I'm not sure where to even begin. Will most likely clear the codes, disconnect the battery and go from there. And thanks for helping out, greatly appreciated.
    Here's the scan:
    Monday,28,October,2019,01:13:50:27520
    VIN: WUAC6AFR6DA902467   License Plate:
    Mileage: 101180km-62870mi   Repair Order:
    Chassis Type: FR-AU48 (8R0)
    Scan: 01 02 03 05 06 08 09 13 15 16 17 19 1B 22 36 3C 42 44 46 47
              52 53 56 5F 6C
    VIN: WUAC6AFR6DA902467   Mileage: 101180km-62870miles
    17-Instruments -- Status: Malfunction 1010
    1B-Active Steering -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Cannot be reached 1100
    Address 01: Engine (------CFSA)       Labels:. 079-907-560-CFS.clb
       Part No SW: 8T2 907 560 F    HW: 8T1 907 560
       Component: 4.2l JHM.9 /  H04 0005
       Revision: NAH04---
       Coding: 1A25003225C6080D3000
       ASAM Dataset: EV_ECM42FSI0118T2907560F 001004
       ROD: EV_ECM42FSI0118T2907560F.rod
       VCID: 3FDBBD3337FB04FFF0D-806A
    4327 - Function Restriction due to Faults in Other Modules
              U1113 00 [039] - -
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        Coolant temperature: 25 ∞C
                        Intake air temperature: 25 ∞C
                        Voltage terminal 30: 11.449 V
                        AFS dm: 0.0 kg/h
    4531 - Fan 1 Control Circuit
              P0691 00 [032] - Short to GND
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:14
                        Engine speed: 1409.00 /min
                        Normed load value: 68.6 %
                        Coolant temperature: 26 ∞C
                        Intake air temperature: 23 ∞C
                        Voltage terminal 30: 13.970 V
                        selected gear-Bits 0-7: 0
                        Cruise control switch actuation-Bits 0-7: 0
    5612 - Steering Effort Control Module
              U0130 00 [039] - No Communications
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        Voltage terminal 30: 11.591 V
                        AFS dm: 0.0 kg/h
    4729 - Steering Effort Control Module
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
       Part No SW: 8T0 927 156 H    HW: 0B5 927 156 J
       Component: 0B5 42 FSINAR H01 0005
       Revision: --H01---
       Coding: 000001
       Shop #: WSC 06325 000 00000
       ROD: EV_TCMDL501021.rod
       VCID: 42DDB4C7440969179F3-8016
       Part No SW: 8T0 907 379 F    HW: 8T0 907 379 F
       Coding: 302D1A
       VCID: 45D7AFDB55A75E2FBA1-8010
    03110 - Active Steering Control Module (J792)
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x0011
                        Hex Value: 0x858E
                        Hex Value: 0x0000
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x000F
                        Hex Value: 0x508E
                        Hex Value: 0x0000
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:10:37
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x000C
                        Hex Value: 0x468E
                        Hex Value: 0x0000
       Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
       Component: BCM2 2.0      H12 0633
       Coding: 0D804000000000000000
       VCID: 045172DF1E1DA727EDF-8050
       Serial number: 2313000016339008
       Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
       Component: MEM-BFS       H10 0076
       Revision: AA000000    Serial number: 00000051213831
       Coding: 00037025002C00000000
       Shop #: WSC 06342 000 00000
       Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
       Revision: C1000000    Serial number: 01200220130492
       Coding: 4802200000
       VCID: 392FD32B295F2ACFCE9-806C
                        Fault Status: 01100101
                        Reset counter: 78
                        Mileage: 100575 km
                        Date: 2019.10.12
                        Time: 13:55:42
                        Fault Status: 00100011
                        Fault Frequency: 11
                        Reset counter: 147
                        Mileage: 100634 km
                        Date: 2019.10.14
                        Time: 14:40:05
                        Voltage: 14.10 V
                        Temperature: 35.0∞C
                        Temperature: 39.0∞C
                        Count: 25000
                        Count: 10984
                        Bin. Bits: 01000000
                        Bin. Bits: 10001011
                        Time: 54.00 s
       Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
       Revision: 09016001    Serial number: 00000554864301
       Coding: 06000011043C9FF235004083000039090F9CD388A2090221000008004000010200040034000000
       Shop #: WSC 92630 444 123950
       VCID: 7AAD0C276CD9E1D7873-802E
       Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 150213  H15 0080
       Serial number: SWF13020150148
       Coding: 00FD11
       Serial number: 21004112
       Coding: 02005D
       Subsystem 3 - Part No SW: 8K0 941 531 AQ    HW: 8K0 941 531 AQ
       Component: E1 - LDS  H03 0031
       Serial number: 00000000000502130647
       Component: USHL4.2  H30 0030
       Serial number: 0000002274555R4SYJ02
       Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
    H01 0031
       Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
       Serial number: 7C48C296000000000001
                        Reset counter: 108
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:14
    03124 - Terminal 30 - 3
                        Fault Status: 00101011
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 00:25:52
    00926 - Terminal 30
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 00:40:33
                        Reset counter: 148
                        Mileage: 101183 km
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:45
    Address 13: Auto Dist. Reg (J428)       Labels: None
       Part No SW: 8K0 907 561 C    HW: 8K0 907 561 C
       Component: ACC3          H11 0100
       Coding: 00333E
       VCID: 323DE407F429D9970F3-8066
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Temperature: 19.0∞C
                        Voltage: 11.26 V
                        Hex Value: 0x00BE
                        Lateral Accel.: 0.00 m/s^2
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Temperature: 19.0∞C
                        Voltage: 11.39 V
                        Hex Value: 0x00C0
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Temperature: 19.0∞C
                        Voltage: 11.26 V
                        Hex Value: 0x0084
       Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
       Serial number: 003KJD91EW3S
       Coding: 303343334830303030304A55304C38543053
       VCID: 4ACD9CE77C39B157573-801E
       Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
       Component: BF-Gewichtss.  H02 0060
       Serial number: 5810000R130000CJ7S
       Serial number: 6334MSME780331656
       Serial number: 6344MSME78406157C
       Serial number: 6352QSME62282B44G
       Serial number: 6362QSME5F2C5372T
       Serial number: 63732SME712B0F585
       Serial number: 63832SME542B2F444
    12660736 - Steering Effort Control Module
              U0130 00 [009] - No Communications
              [Active Steering Control Unit no communication]
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
       Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
       Component: Lenks.Modul   H07 0171
       Revision: 00000000    Serial number: 20130219001040
       Coding: 00003E
       VCID: 51FF8B8B91EF828F169-8004
       Part No SW: 8T0 920 984 A    HW: 8T0 920 984 A
       Component: KOMBIINSTR.   H35 0556
       Revision: 00300000    Serial number: UVA266K2E
       Coding: 83BF0100AF03D705020000
       VCID: 3D27C73B3D7716EFE21-8068
                        Reset counter: 108
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:08
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
       Component: GW-BEM 5CAN-M H11 0055
       Revision: 1Z100027    Serial number: 2741Z13204008E
       Coding: 80E3031600
       VCID: 4CC19AFF76CDAF6765F-8018
       Serial number: 1367620003
    02256 - Quiescent Current
                        Fault Status: 00100001
                        Reset counter: 148
                        Mileage: 100600 km
                        Date: 2019.10.12
                        Time: 19:37:01
                        Fault Frequency: 24
                        Reset counter: 148
                        Mileage: 100626 km
                        Date: 2019.10.13
                        Time: 03:01:32
                        Bin. Bits:    00000
                        Voltage: 12.30 V
                        Count: 7
                        Reset counter: 108
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:01
                        Bin. Bits:    00000
                        Voltage: 11.60 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 01:04:10
                        Bin. Bits:    10000
                        Voltage: 11.70 V
                        Count: 9
                        Bin. Bits:    10000
                        Time: 5.30 s
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Bin. Bits:    10111
                        Voltage: 11.50 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 0.40 s
    Address 1B: Active Steering
    Address 22: AWD (J492)       Labels: 8K0-907-163.clb
       Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
       Component: 4 Wheel Drive H14 0100
       Serial number: 001302130001758
       ASAM Dataset: EV_AllWheelDiffeQSPCAN 003019
       VCID: 2F3BED73E79BF47F60D-807A
    0226 - Steering Effort Control Module
              U0130 00 [137] - No Communications
              [Steuerger‰t f¸r aktive Lenkung keine Kommunikation DTC_CAN_STEER_CTL_NO_COM]
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
    0059 - Please Check Fault Codes in Control Module for ABS Brakes
              U1017 00 [137] - -
              [ESP - Steuerger‰t nicht verf¸gbar DRC_CAN_ESP_01_SYS_ST]
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
       Component: MEM-FS        H10 0076
       Revision: AA000000    Serial number: 00000051211560
       Coding: 001B7B25002C00000000
       Shop #: WSC 11251 001 1048576
    03339 - Force Limit for Fore/Aft Seat Adjustment: Back
                        Reset counter: 78
                        Mileage: 100575 km
                        Date: 2019.10.12
                        Time: 13:55:42
       Part No SW: 8T0 907 566 B    HW: 8T0 907 566 B
       Component: SWA Master    H04 0060
       Serial number: 0192285845
       Coding: 010211
       Shop #: WSC 06324 000 00000
       Lane Change Assistant 2:
       Subsystem 1 - Part No SW: 8T0 907 568 B    HW: 8T0 907 568 B
       Component: SWA Slave  H04 0060
       Serial number: 0192294703
       Coding: 000102
       Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
       Component: TSG FA        H09 0304
       Coding: 011C13224E00120102
       VCID: 56F57897B801E5B7C3B-8002
    Address 44: Steering Assist
       Revision: 00002001    Serial number: 0301332569
       Coding: 0106069A00FAC10581B0003200000000
       Component: GTO BF  H01 0080
       Serial number: 00000000000000634856
       Component: J245EE20SKB13  H05 0220
       Subsystem 4 - Part No SW: 4G8 959 252     HW: 4G8 959 252
       Component: HSP-SG  H11 0028
       Serial number: WA104645000002650945
       Revision: 00005001    Serial number: 94813011143102
       VCID: 2D07F77BED17866F521-8078
       Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
       Component: TSG BF        H09 0304
       VCID: 55F77F9BA507EEAFCA1-8000
       Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
       Component: EPB-4         H01 0003
       Revision: --------    Serial number: 20000000227161
       ROD: EV_ParkiBrake_AU48.rod
       VCID: 3829D62F12D533C7317-806C
    464384 - Function Restriction due to Faults in Other Modules
              U1113 00 [009] - -
              [FC_SIGNAL_MO_QBIT_MOTORMOMENTE_QBIT]
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:10:37
                        Voltage terminal 30: 11.6 V
                        Internal Fault ID: 188
                        Function light in parking brake button: On
                        Red operating lamp: On
                        Red warning lamp: OFF
                        Green operating lamp: OFF
                        Yellow warning lamp: OFF
                        Terminal 15 status: On
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Auto Adjust: not active
                        Status ParkingBrake left: Set
                        Status ParkingBrake right: Set
       Part No SW: 4G0 035 082 H    HW: 4G0 035 082
       Component: Radio U SIRIU H60 0138
       Revision: AB001007    Serial number: 156B50D7693479
       Coding: 020007010000000001
       VCID: 25170F5BB5E7BE2F9A1-8070
       Part No SW: 8R1 035 746 K    HW: 8R1 035 746 B
       Component: H-BNT-NA      H44 1040
       Revision: --------    Serial number: 204BT0D7561283
       Coding: 150200020306A9EF75028B4E00000403140000000000000002
       VCID: 3FDBBD33377B04FFF0D-806A
       Subsystem 1 - Part No: 8R0 060 884 BA
       Component: NAR 2013  0703
       Component: DU7 High  H42 0104
       Serial number: A130BX0D2659970
       Serial number: 00000001419689
       Component: CD-Database  4949
                        Reset counter: 78
                        Mileage: 100575 km
                        Date: 2019.10.12
                        Time: 13:56:12
                        Text: DUA130,Front,M,0,0,6
    00384 - Optical Databus
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 01:03:45
                        Voltage: 11.80 V
       Revision: --H07---    Serial number: 525PA8-J2Z91FG
       Coding: 1021008
       VCID: 3829D62F1E5533C7317-806C
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                            Reverse OFF
                        Count: 3
    End----(Elapsed Time: 02:00, VBatt start/end: 11.4V/11.7V. VIgn 11.7V)-----
    Nov 2018
    All the fuses look intact on the driver's and passenger's side. Leaning towards a Can Bus module being blown and preventing connection to the active steering module (J792). Cannot connect to it with the VCDS. Most of the fault priorities are either 4 or 6.
    Cleared codes, disconnected battery, no change. Car starts and runs fine. Was able to "muscle" it out of the garage and into a better position so I could open the driver's door fully and pull fuses.
    I have the FSM electrical schematic but trying to figure out which applies to the RS5 is numbing to say the least.
    Nov 2018
    Looked at all the fuses in the trunk, no luck. Have the ECU pulled and now checking the fuses underneath. Next step, the power steering fuse underneath the dash.
    Nov 2018
    Checked the relay under the dash which I believe is the power steering relay and it's working. Tested for operation and resistance.
  5. Likes Uwe liked this post
    Nov 2018
    I buttoned everything back up and still had faults. Shockingly, the power steering came back and it feels like I'm getting both dynamic and normal steering. Strange.
    I still have steering faults, adaptive headlight faults, active differential faults and stability control faults on the dash and through the VCDS. I've tried clearing the faults in the individual modules.
    I am unable to connect to the active steering control module. I'll do another scan and post it as some of the items from the first scan have gone away.
    How can I tell if it's the CAN bus control module or the active steering module itself without physically checking the pins at the CAN bus?
    16.4905° S, 151.7375° W
    Use VCDS to go in to the [19-Gateway] controller, then use the [Meas.Blocks-08] and have a look at the Group [125 to 129] for the CAN-Data bus Powertrain (Communication).
    Everything that is installed and that is communicating should have a value of [1]. If any of these controllers have a [0], that is an indication the controller is not communication. A value that is flashing between [0] and [1], would indicate there is partial but corrupt communications.
    You can also perform the [Gateway Installation List] on the Auto-Scan to see if the Gateway controller reports either [Status: Malfunction 0010] or [Status: OK 0000]. If you see the [Status: Cannot be reached 1100], then you can confirm this with the measuring value blocks groups aforementioned.
    If you need more information, please post a New Auto-Scan, that way we can see the status of the vehicle now.
    Hope this helps,
    drpeter
  8. Likes Jack@European_Parts, Uwe liked this post
    Nov 2018
    Definitely helps. I've been driving around and the car seems just fine minus the dash light show. The steering seems to have both dynamic and normal. Here's the new scan.
              52 53 56 5F 6C
       Revision: NAH04---
              U1113 00 [039] - -
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        AFS dm: 0.0 kg/h
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:14
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        AFS dm: 0.0 kg/h
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
       Revision: --H01---
       Coding: 000001
       Coding: 302D1A
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x0011
                        Hex Value: 0x858E
                        Hex Value: 0x0000
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
                        Hex Value: 0x0000
                        Hex Value: 0x07A2
                        Hex Value: 0x000F
                        Hex Value: 0x508E
                        Hex Value: 0x0000
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:10:37
                        Hex Value: 0x0000
                        Hex Value: 0x02A2
                        Hex Value: 0x000C
                        Hex Value: 0x468E
                        Hex Value: 0x0000
       Coding: 4802200000
                        Reset counter: 78
                        Mileage: 100575 km
                        Date: 2019.10.12
                        Time: 13:55:42
                        Fault Frequency: 11
                        Reset counter: 147
                        Mileage: 100634 km
                        Date: 2019.10.14
                        Time: 14:40:05
                        Voltage: 14.10 V
                        Temperature: 35.0∞C
                        Temperature: 39.0∞C
                        Count: 25000
                        Count: 10984
                        Bin. Bits: 01000000
                        Bin. Bits: 10001011
                        Time: 54.00 s
       Coding: 00FD11
       Coding: 02005D
    H01 0031
    H01 0031
                        Reset counter: 108
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:14
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 00:25:52
    00926 - Terminal 30
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 00:40:33
                        Reset counter: 148
                        Mileage: 101183 km
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:45
       Coding: 00333E
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Temperature: 19.0∞C
                        Voltage: 11.26 V
                        Hex Value: 0x00BE
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Temperature: 19.0∞C
                        Voltage: 11.39 V
                        Hex Value: 0x00C0
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Temperature: 19.0∞C
                        Voltage: 11.26 V
                        Hex Value: 0x0084
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
       Coding: 00003E
                        Reset counter: 108
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:08
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
       Coding: 80E3031600
                        Reset counter: 148
                        Mileage: 100600 km
                        Date: 2019.10.12
                        Time: 19:37:01
                        Fault Frequency: 24
                        Reset counter: 148
                        Mileage: 100626 km
                        Date: 2019.10.13
                        Time: 03:01:32
                        Bin. Bits:    00000
                        Voltage: 12.30 V
                        Count: 7
                        Reset counter: 108
                        Mileage: 101183 km
                        Date: 2019.10.27
                        Time: 20:10:01
                        Bin. Bits:    00000
                        Voltage: 11.60 V
                        Count: 7
                        Bin. Bits:    10000
                        Time: 0.40 s
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 01:04:10
                        Bin. Bits:    10000
                        Voltage: 11.70 V
                        Count: 9
                        Bin. Bits:    10000
                        Time: 5.30 s
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Bin. Bits:    10111
                        Voltage: 11.50 V
                        Count: 6
                        Bin. Bits:    10000
                        Time: 0.40 s
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:38
              U1017 00 [137] - -
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                        Reset counter: 78
                        Mileage: 100575 km
                        Date: 2019.10.12
                        Time: 13:55:42
       Coding: 010211
       Coding: 000102
              U1113 00 [009] - -
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:10:37
                        RWU: not active
                        DSD: not active
                        HTR: not active
                        ECD: not active
                        Reset counter: 78
                        Mileage: 100575 km
                        Date: 2019.10.12
                        Time: 13:56:12
                        Reset counter: 148
                        Mileage: 101183 km
                        Date: 2019.10.28
                        Time: 01:03:45
                        Voltage: 11.80 V
       Coding: 1021008
                        Reset counter: 108
                        Mileage: 101182 km
                        Date: 2019.10.28
                        Time: 01:09:39
                            Reverse OFF
                        Count: 3
  10. #8
    Nov 2018
    Ran through the gateway controller measuring blocks. Most of the data was actually in the 150+ range. Is there a way to get a list of what all the measuring blocks are for my make/model? Assuming they change based on that criteria.
    Anyway...everything checked out except for the active steering module which had a value of 0. Can’t connect to it with the VCDS when I try to access that module. Other items like the ABS brakes, which has a 0010 malfunction shows a 1 through the gateway controller measuring block function.
    I’m thinking many of the malfunctions are tied into the active steering and I am unable to erase the dtc’s because of that. The backup cam error is strange though as it’s working.
    Not sure what my next step should be. Thanks again for the help.
    Michel
  11. #9
    Nov 2018
    Full log from this morning.
    Tuesday,29,October,2019,06:31:44:27520
    VIN: WUAC6AFR6DA902467 License Plate: GATEWAY INSTALL LIST
    Gateway Installation List: 8R0 907 468 P
    52 53 56 5F 6C
    VIN: WUAC6AFR6DA902467 Mileage: 101190km-62876miles
    Revision: NAH04---
    U1113 00 [047] - -
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:31
    Coolant temperature: 74 °C
    Intake air temperature: 61 °C
    Voltage terminal 30: 11.709 V
    AFS dm: 0.0 kg/h
    U0130 00 [047] - No Communications
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:32
    AFS dm: 0.0 kg/h
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:32
    Readiness: 0010 1101
    Revision: --H01---
    Coding: 000001
    Coding: 302D1A
    Reset counter: 109
    Mileage: 101191 km
    Date: 2019.10.28
    Time: 16:16:24
    Hex Value: 0x00C0
    Hex Value: 0x07A2
    Hex Value: 0x0011
    Hex Value: 0x858B
    Hex Value: 0x0000
    Reset counter: 109
    Mileage: 101191 km
    Date: 2019.10.28
    Time: 16:16:24
    Hex Value: 0x00C0
    Hex Value: 0x07A2
    Hex Value: 0x000F
    Hex Value: 0x508B
    Hex Value: 0x0000
    Reset counter: 109
    Mileage: 101197 km
    Date: 2019.10.29
    Time: 06:23:57
    Hex Value: 0x0000
    Hex Value: 0x02A2
    Hex Value: 0x000C
    Hex Value: 0x4693
    Hex Value: 0x0000
    Coding: 4802200000
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:27
    Fault Status: 01100011
    Reset counter: 109
    Mileage: 101191 km
    Date: 2019.10.28
    Time: 16:31:23
    Voltage: 14.10 V
    Temperature: 30.0°C
    Temperature: 31.0°C
    Count: 25000
    Count: 10988
    Bin. Bits: 01000000
    Bin. Bits: 10001011
    Time: 65.00 s
    Coding: 00FD11
    Coding: 02005D
    H01 0031
    H01 0031
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:28
    Coding: 00333E
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:28
    Temperature: 33.0°C
    Voltage: 11.52 V
    Hex Value: 0x00BE
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:28
    Temperature: 33.0°C
    Voltage: 11.52 V
    Hex Value: 0x00C0
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:28
    Temperature: 33.0°C
    Voltage: 11.52 V
    Hex Value: 0x0084
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:30
    Coding: 00003E
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:29
    Coding: 80E3031600
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:28
    Bin. Bits: 10111
    Voltage: 11.80 V
    Count: 6
    Bin. Bits: 10000
    Time: 25.40 s
    U1017 00 [137] - -
    [ESP - Steuergerät nicht verfügbar DRC_CAN_ESP_01_SYS_ST]
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:30
    [Steuergerät für aktive Lenkung keine Kommunikation DTC_CAN_STEER_CTL_NO_COM]
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:30
    0252 - Function Restricted due to Insufficient Voltage
    U1400 00 [008] - -
    [12V Unterspannung CAN Spannungsdiagnosegrenze DTC_CAN_LOW_VOLTAGE]
    Reset counter: 149
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:01:14
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:27
    Coding: 010211
    Coding: 000102
    Address 44: Steering Assist (J500) Labels:| 8K0-909-144.clb
    Part No SW: 8K0 909 144 F HW: 8K0 909 144 B
    Component: RCEPS H36 0507
    Revision: 00001000 Serial number: 0012646993
    Coding: 010000010001
    ROD: EV_RCEPSAU48X_008.rod
    VCID: 3431E21F0EBDD7A71DF-8060
    3158408 - Function Restricted due to Missing Message(s)
    U1111 00 [009] - -
    [Botschaftsausfall des SCU-Steuergeräts]
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:30
    Write only channel
    4208000 - Steering Angle Sensor
    B1168 F1 [008] - Synchronization Failed
    Reset counter: 149
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:01:14
    Write only channel
    U1113 00 [009] - -
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:30
    Voltage terminal 30: 11.8 V
    Red operating lamp: OFF
    RWU: not active
    DSD: not active
    HTR: not active
    ECD: not active
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:32
    Coding: 1021008
    Reset counter: 109
    Mileage: 101184 km
    Date: 2019.10.28
    Time: 16:00:27
    Reverse OFF
    Count: 3
    End----(Elapsed Time: 02:00, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
  12. #10
    Jan 2018
    Cheshire UK
    I think you really need to relook at the fuses and the location of other fuses for the power steering. Audi have done a good job of putting fuses in all sorts of locations. There is some high power fuses next to the jump start terminal in the engine bay, some are under the dash, either side of the dash panels, bottom of the A posts, in the rear and some in the ecu box that i can recall.
    being the power steering its going to be a high ampage one around 40A iirc which is for the motor which you say is working but there may also be another smaller amp fuse for its ecu so have a look on erwin and trace the power feeds for the steering system.
    No signal or no communication is either a power issue or a dead module
    i would also replace the relay you tested with another one from elsewhere in the car to test as it 'may' be damaged.
    A6 BiTdi Avant MTM
    Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Power Tailgate, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds, Electric Steering Column, LED Sill Plates, Ambient Lighting Pack, High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
  13. Likes Jack@European_Parts, Uwe liked this post
