Newbie member, long time user, 1st post
alexvr6
Canada
C?ID=27149
Good morning,
I have been a long time user of VCDS (B5 generation), currently in a newly acquired B9.
UPgranded the old tech to new, all connected and registered.
Below is my first auto-scan:
#VIN: WAUENAF45KN0xxxxx Mileage: 4737km-2943miles
CA-Sunroof -- Status: OK 0000
I was trying to the gear display in auto/trans / adaptation, and read that I need to leave the work shop code as defaul 12345....I did so, but still get an error and cannot change it..
Thanks,
ALex
Bruce
Near Philadelphia, PA, USA
Thanks for a good start... However, that is not a full auto-scan. That is the installed module list. Please run and post a full autoscan.
alexvr6
Canada
C?ID=27149
VIN: WAUENAF45KN019346   License Plate:
Mileage: 4737km-2943mi   Repair Order:
Chassis Type: F4-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 20 29 36 39 42 44 46 52 5F 6C 81
          BB BC CA D6 D7
Address 01: Engine (J623-CYMC)       Labels:. 06K-907-425-V2.clb
   Part No SW: 8W0 906 259 AB    HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0003
   Revision: --H15---
   Coding: 0A2500322326010E34080000000000000000000000000000
   ASAM Dataset: EV_ECM20TFS0208W0906259AB 001004
   ROD: EV_ECM20TFS0208W0906259AB.rod
   VCID: 014A9BF790367847A8-8054
   Part No SW: 8W2 927 155 CG    HW: 0HK 927 156 B
   Component: 0CL 20TFSINAR H01 0002
   Revision: --H01---    Serial number: 0000001497
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 085C86D3B30C490FEF-805C
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041190141000858
   Part No SW: 8W0 907 379 AF    HW: 8W0 907 379 J
   Component: ESP9 Plus     H16 0777
   Coding: 18AA409928A30A9F11A1489500835292E53580180214508812004A49A7AC01
   ASAM Dataset: EV_ESP9BOSCHCMP 002013
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: 095A83D7A8063007F0-805C
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
   Component: Klima Zone 3  H60 0251
   Coding: 140805095544000D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 44C452E3CFA4AD6FC3-8010
   Subsystem 1 - Part No SW: 4M1 820 021 C    HW: 4M1 820 021 C
   Component: J126 FLuftV  H09 0004
   Serial number: 00000000000003829263
   Component: AQ_Hum_Sensor  H02 0007
   Serial number: BE6116B900PAG0MUFU02
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 DG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0313
   Coding: 07501563E0691CCD05158714182C18BB110B1D08000000000000000020001A010A690122025605
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   VCID: 034691FF8A2A6A57BA-8056
   Subsystem 1 - Part No SW: 8W1 955 119 A    HW: 566 955 119
   Component: J400FRWISCH  051 0822
   Serial number: 887353F0401915704656
   Coding: 7DC727
   Serial number: 23166694X81A955555A0
   Coding: 02005D
   Light switch:
   Subsystem 3 - Part No SW: 4M0 941 531 AK    HW: 4M0 941 531 AK
   Component: E1 - LDS  H06 0008
   Serial number: 08 04 2019  01935811
   Subsystem 4 - Part No SW: 4N0 907 410 C    HW: 4M0 907 410 A
   Component: USHL5     GX1  H12 0210
   Serial number: 0000009600373Z00AF02
   Coding: 350000
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20190522001726 00031
   Interior Light Module:
   Subsystem 6 - Part No SW: 4K0 947 135 AQ    HW: 4K0 947 135 AQ
   Component: Dachmodul  H42 0415
   Serial number: B01232321
   Coding: 010104
   Subsystem 7 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 4919000063113005
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 M    HW: 8W0 959 655 M
   Component: Airbag10.44   H05 0109
   Serial number: 0030C001964Z
   Coding: BFCCF0C000800000A0000033D24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   VCID: 53E661BF3ACA3AD74A-8006
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2040
   Serial number: 8W0857705G0151T01853
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2040
   Serial number: 8W0857706J0151T01469
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H11 0022
   Serial number: IBH0000J19000BNCW10P
   Subsystem 4 - Part No SW: -----------    HW: 442 062 305 19
   Serial number: 3577Y009B3011711619K
   Subsystem 5 - Part No SW: -----------    HW: 442 062 305 19
   Serial number: 3587Y00993011715230C
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 406 19
   Serial number: 3517700C330D6213415X
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 406 19
   Serial number: 3527700B7318A383F12A
   Subsystem 8 - Part No SW: -----------    HW: 442 0C0 506 19
   Serial number: 3557500B9318F022121.
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C0 506 19
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500B9318F022C159
   Part No SW: 4N0 907 129     HW: 4N0 907 129
   ROD: EV_SMLSKLOAU736_007_AU49.rod
   VCID: 6E90D04BB1A8773F45-803A
   Part No SW: 8W5 920 770 D    HW: 8W5 920 770 D
   Component: MMA4T19BENRW  H14 0612
   Revision: 0612v4.0    Serial number:    U4ID51C6V
   Coding: 08A651C1288000080223E9401800000008000000
   ASAM Dataset: EV_DashBoardAU736 001032
   VCID: 41CA5BF7D0B6B847E8-8014
   Part No SW: 4M1 907 468 H    HW: 4M1 907 468 E
   Component: Gateway       H22 0144
   Revision: BA020002    Serial number: 024BA02FC19620
   Coding: 030100010000064029070000005900124C180000100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 003170
   ROD: EV_CGateCONTIAU491_003_AU49.rod
   VCID: 3C342A03B754D5AFBB-8068
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Serial number: 20190624171904 32287
   Serial number: 0107901505
Address 20: High Beam Assist. (J844)       Labels:* None
   Part No SW: 8W0 857 511 C    HW: 8W0 857 511 C
   Component: FLA           H10 0003
   Revision: AB001001
   Coding: 0404000400010001000002
   ASAM Dataset: EV_HighBeamAssisAU736 001015
   ROD: EV_HighBeamAssisAU736.rod
   VCID: 3D322707AC4EDCA78C-8068
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0024
   VCID: 78BCF613C3EC398F9F-802C
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000378929411
   Coding: 005C1B000000B0010000010101010000000000000000000000000000000000
   VCID: 79BAF317F8E62087E0-802C
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   Part No SW: 8W0 959 593 M    HW: 8W0 959 593 J
   Component: TSG FS        010 0384
   Serial number: 0000367997166
   Coding: 001F0B204200108000110002
   VCID: 54E462A33FC43DEF53-8000
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   VCID: 42C854FBD5B0A35FF1-8016
   Part No SW: 8W1 907 064 AC    HW: 8W1 907 064 C
   Component: BCM2 MLBevo   044 0529
   Coding: 013400004F300080650780002C01000003024000810022502F0400000B04803F001E0001000010
   ASAM Dataset: EV_BCM2HellaAU736 017017
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   VCID: 7EB0E00BE1C807BFD5-802A
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY191302DG9
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000047348425
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Serial number: 12197826
   Part No SW: 8W0 959 592 M    HW: 8W0 959 592 J
   Component: TSG BFS       010 0384
   Serial number: 0000368002967
   Coding: 001F0B204E00108000110000
   Part No SW: 8W5 035 880 E    HW: 8W5 035 880
   Component: MU-P-LNS-US   035 1316
   Serial number: A798F0KB158721
   Coding: 01940102FF0A000013220001041A00102F0002E401700904FE
   Subsystem 1 - Part No SW: V03 959 802 DM    HW: -----------
   Component: NAR 2019/2020  --- 0072
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9KBJ06CJH
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Serial number: APVAK108061900020589
   Component: Gracenote2  --- 3013
Address 6C: Back-up Cam. (J772)       Labels:* Redir Fail!
   Part No SW: 4M0 980 556 A    HW: 4M0 980 556 A
   Component: RVC Compact   H18 0250
   Coding: 0294010102002001400040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 005010
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   VCID: 3326013F9A0A1AD76A-8066
Address 81: Gear Shift (J587)       Labels: 4MX-713-041-81.clb
   Part No SW: 8W1 713 041 N    HW: 8W1 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 19062453311171
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3E30200BA148C7BF95-806A
   Part No SW: 8W0 959 595 M    HW: 8W0 959 595 J
   Component: TSG HFS       010 0384
   Serial number: 0000380365584
   Coding: 000F0B200000108040000000
   VCID: 56E098AB29382FFFAD-8002
   Component: TSG HBFS      010 0384
   Serial number: 0000380364965
   Part No SW: 4K0 907 594 AB    HW: 4K0 907 594
   Component: SAD_STG_1     006 0002
   Coding: 228000049100
   ASAM Dataset: EV_SunRoofCONTIAU736 009011
   ROD: EV_SunRoofCONTIAU736_009_AU49.rod
   VCID: 74A4C223DF845DEFB3-8020
   VCID: 1660D8ABE9B8EFFF6D-8042
End----------(Elapsed Time: 01:52, VBatt start/end: 12.3V/12.3V)-----------
PetrolDave
Westbury, UK
C?ID=1423
Strange? - the Installation List shows 44 as "Status: Malfunction 0010" but the scan shows 44 with "No fault code found." :confused:
alexvr6
Canada
C?ID=27149
weird, cannot figure it out, nor can I get passed the 12345 default workshop code to do anything
What exactly are you trying to do?
As for the "phantom" malfunction in the 44 module, I'd try going to 44 and clearing fault codes there. Sometimes the GW gets out of synch with the module.
alexvr6
Canada
C?ID=27149
Uwe,
I was trying to the gear display in auto/trans / adaptation, and read that I need to leave the work shop code as default 12345....I did so when it prompted me, but still get an error and cannot change it..
Should be:
IDE04111-ENG101799 -- Single gear display
Some modules have blocked the 12345/123/12345 combination.
Try setting WSC to the last four digits of your phone number (with a leading '0).
Set Importer Code to 999 (that's correct for Canada).
Set Equipment number to the last four digits of your interface serial number (with a leading '0').
This should ensure enough arbitrary randomness that it will never be blocked.
alexvr6
Canada
C?ID=27149
Should be:
Will try this weekend and report back, thank you
alexvr6
Canada
C?ID=27149
Uwe,
the last digits of the serial # is alphanumeric......please advise and thanks
Mike@Gendan
Swansea, UK
C?ID=57030
Uwe,
Try the short serial number from the interface label (Hxx-xxxxxx) instead of the long serial number from the software.
The 2nd half of the short S/N should be numeric.
Exactly. Everything after the dash in that serial number is numeric.
alexvr6
Canada
C?ID=27149
THank you Gents,
will try that
alexvr6
Canada
C?ID=27149
THank you Gents,
will try that
That did it gents. i was able to code a few things.....However, not this one.
Needle Sweep
Description: Perform gauge / needle sweep test on startup.
● 17 - Dashboard
● Long Coding
● Tap on the 1 on the top right where it looks like two buttons that say [0][1] to expose the individual bytes. By default the app displays a list of items.
● It'll then display in hexadecimal for the selected byte. Tap on the second byte (byte 1 from left, zero-based) to display a list of each of the 8 bits with checkmarks next to them
● Check Bit 0
● Basically Byte 1 Bit 0 “Gauge Test/Needle Sweep” check
● Press and hold green check mark to save.
● Source: AW Link
I just don't understand it perhaps.....
Those instructions should change your intstrument cluster's coding from:
to:
08A751C1288000080223E9401800000008000000
You may want to go back and look to see if it has actually changed.
alexvr6
Canada
C?ID=27149
to:
Uwe, current coding is 00E651C1288000080223EB401800000008000000, which is not what you have as the original code in your post.
That's not what the scan you posted indicates:
So it looks like you've changed something else in the meanwhile.
PS: Not all clusters actually support needle sweep.
alexvr6
Canada
C?ID=27149
I had disabled the seat belt chime and dash display
alexvr6
Canada
C?ID=27149
Uwe, all is good, changing the 6 to 7 worked..
Now I am trying to figure out how to disable the automatic door locks when in D or S/M....I did it in the B6 and B7, I am certain there is a way to do it in the B9....
I would think you could set that feature via the MMI controls without using a scan tool.
However, there are Adaptation Channels for "Personalization settings" "Autolock" and "autounlock" for each key in the Central Convenience Module at address 46 as well.
