Hello
I would like to to some configuration changes in my sahran:
- is it possible to have active Auto hold, but disabled Electrical Parking Brake engaging when leaving the car and gear selector is in P position. I want the car to be hold still when stopped, but when it is parked I do not want to engage parking brake automatically (in garage etc.),
- is it possible to have disabbled EPB auto engage at running engine and opened door with gear selector NOT in position P,
- is it possible to enable that climate, seat heating settings etc. beeing shown in 5F-Information Electronic as it is possible in sharan MY2015 with component 56-Radio installed.
Thanks for your support
Saturday,26,October,2019,12:35:44:38184
VCDS Version: 19.6.2.0 (x64)
VIN: WVWZZZ7NZHV239484 License Plate:
Mileage: 33490km-20809mi Repair Order:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 22 25 2B 36 3C 42 44
46 4C 52 53 55 5F 61 62 69 6C 6D 72 BE BF
VIN: WVWZZZ7NZHV239484 Mileage: 33490km-20809miles
18-Aux. Heat -- Status: Sporadic communication error 1000
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-DFMA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 016 JD HW: 04L 907 309 K
Component: R4 2.0l TDI H20 1999
Revision: 8AH20---
Coding: 0125003A047619083000
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_ECM20TDI01104L906016JD 004002
ROD: EV_ECM20TDI01104L906016HD_004_VW36.rod
VCID: 74EC3508DF2E07EFB3-8020
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BH 300 013 D HW: 0BH 927 711 G
Component: DSG DQ500-7A H11 5301
Revision: 00H11V01
ROD: EV_TCMDQ500021_VW36.rod
VCID: 254A184C24742E67F4-8070
Address 03: ABS Brakes (J104) Labels: 5N0-614-109-V1.clb
Part No SW: 5N0 614 109 CM HW: 5N0 614 109 CM
Component: ESC-EBC460iV1 H14 0014
Serial number: A01PPV8
Coding: 12F0449A4923C275087B480822C7924310394FF8500B4995
Shop #: WSC 22368 002 1048576
ASAM Dataset: EV_Brake1ESCEPBTRW 006353
ROD: EV_Brake1ESCEPBTRW_006.rod
VCID: 78F40138C346638F9F-802C
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 H HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1308
Revision: 00093000 Serial number: 0438516612
Coding: 03300C
Shop #: WSC 00020 999 39850
VCID: 3A70DB30BDCAB19FA9-806E
Part No SW: 7N0 907 044 BC HW: 7N0 907 044 BC
Component: Clima-Sharan H04 0606
Revision: 00001K06
Coding: 0210004449
Shop #: WSC 00020 999 12345
VCID: 72E03310A53A09DFA1-8026
Part No SW: 5K0 937 086 T HW: 5K0 937 086 T
Component: BCM PQ35 M 122 0184
Revision: BC122001
Coding: 40590A3FCD33E1C0508804C0B10009FC03FD0008672D2FB2E4848720A2C1
VCID: 458AB8CCCC34CE67D4-8010
Subsystem 1 - Part No SW: 7N1 955 119 B HW: 7N1 955 119 B Labels: 1KX-955-119.CLB
Component: WWS428 220317 024 0644
Serial number: 17031703019651
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S6Y17M04D12H10M21S09
Coding: 0228BB
Subsystem 3 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Subsystem 4 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Address 10: Park/Steer Assist (J791) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 E HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0005
Serial number: 000305183617096
Coding: 0071167251
ASAM Dataset: EV_EPHVA3CVW428GP00 001005
ROD: EV_EPHVA2CVW428GP00.rod
VCID: 3D7AD02CACE486A78C-8068
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 06041704403485
Coding: 00001900FE0739
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3668CF0089D255FF4D-8062
Part No SW: 7N0 959 655 D HW: 7N0 959 655 D
Component: VW10Airbag11M H15 0016
Serial number: 003PWP6Q7JKY
Coding: 00314D
ASAM Dataset: EV_AirbaVW10TS6VW428 A01010
ROD: EV_AirbaVW10TS6VW428.rod
VCID: 4084A9D8DB16EB4FE7-8014
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60ABC45D1D9DF
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS602EDD601DDD4
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS600781601D9DI
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60A76C5D1DDDB
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS606AA0541D9DM
Part No SW: 5K0 953 501 EL HW: 5K0 953 569 AN
Component: LENKS.MODUL 016 0180
Revision: FF010042 Serial number: 20170404200405
Coding: 1112C40008
Subsystem 1 - Part No SW: 6C0 959 442 B HW: 6C0 959 442 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 0811707095100700AE1B
Coding: 2D0000
Part No SW: 7N0 920 880 L HW: 7N0 920 880 L
Component: KOMBI H04 1109
Coding: 110F010800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
VCID: 3C7CDD28B7FE8FAFBB-8068
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
Shop #: WSC 00020 790 00000
VCID: 3874C1384BC6A38F5F-806C
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 060417F1000274
Coding: 468032
VCID: 7BFE1E34FA704897F2-802E
01207 - Control Module for Auxiliary Heater (J364)
Fault Status: 00110100
Reset counter: 120
Mileage: 33266 km
Date: 2019.10.19
Time: 08:15:01
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0AY 907 554 J HW: 0CQ 525 130
Component: Haldex4Motion H52 7540
Serial number: HA1-00007.03.17
Coding: 0401
VCID: 52A09390057A69DF41-8006
Component: IMMO H04 1109
Coding: 000007
VCID: 6AD02B708DEAC11F19-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 17000096980001
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 3162FC1C60BC72C718-8064
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 F HW: 3C8 959 760 F
Component: Sitzmemory H03 1301
Revision: 00H03000
Coding: 000018
Shop #: WSC 12336 024 394758
VCID: 3874C1388BC6A38F5F-806C
01902 - Lumbar Support Fore / Aft Adjustment Motor (V230)
Fault Status: 00101011
Reset counter: 43
Mileage: 25418 km
Date: 2019.07.09
Time: 18:00:24
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0436784372
Coding: 02012102
ROD: EV_HREntryHella_VW32.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0436177911
Coding: 020121
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 J HW: 7N0 959 793 G
Component: TSG FA H05 0561
Revision: Serial number: 0000250008183
Coding: 01152E20DE00411001
VCID: 4992B4FCE02C2A0730-801C
Part No SW: 5N1 909 144 S HW: 5N1 909 148 K
Component: J500__APA-BS KL.326 1501
Revision: 1BH04741 Serial number: 00170730193101
Coding: 0000258
VCID: 4280A3D01D1AF95FF1-8016
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 J HW: 7N0 959 792 G
Component: TSG BF H05 0561
Revision: Serial number: 0000250046240
Coding: 01152C20DE00411001
VCID: 4894B1F8FB26D30F2F-801C
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H05 0111
Coding: 058A00000B000200
ROD: EV_HeadlRegulVWAFSPt_VW32.rod
VCID: 3776C2048ED8ACF756-8062
Subsystem 1 - Part No: 1T0 941 329 Labels: 3D0-941-329.CLB
Subsystem 2 - Part No: 1T0 941 329 Labels: 3D0-941-329.CLB
Part No SW: 5C0 035 680 E HW: 5C0 035 680 E
Component: MU-S-ND-ER H31 0363
Serial number: VWZAZ2T5165726
Coding: 02240801FF0000001111110100880A001F01008400200100CF
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 234E06542A40D0579A-8076
Subsystem 1 - Part No SW: 5NA 919 866 AG HW: -----------
Component: ECE AS 2020 --- 1310
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 330F7873
VCID: 71E23C1CA83C32C758-8024
Subsystem 1 - Part No SW: 1K0 915 181 L HW: 1K0 915 181 L
Component: J367-BDM H07 0270
Serial number: 34088H15285831216223
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 L HW: 7N0 959 794 H
Component: TSG HL H03 0561
Revision: Serial number: 0000245909235
Coding: 01006C200000411001
VCID: 4C9C8DE8EF5E3F2F0B-8018
Address 69: Trailer (J345) Labels:. 7N0-907-383.clb
Part No SW: 7N0 907 383 A HW: 7N0 907 383
Component: Anhaenger H12 0130
Revision: 3I001001 Serial number: 00000435992700
Coding: 410C040003000000
VCID: 346CF50897AE47EF73-8060
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-907-441.clb
Part No SW: 7N0 907 441 B HW: 7N0 907 441 B
Component: VW428 RVC Mid H04 0040
Coding: 012408012301000700
ASAM Dataset: EV_CamSysRearPANAVW428 002002
ROD: EV_CamSysRearPANAVW428.rod
VCID: 3064F9186BB67BCF17-8064
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 G HW: 7N0 959 107 A
Component: HDSG-Modul H12 0250
Revision: 41012001 Serial number: 081701523
Coding: 0733334003
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
VCID: 3B7EDE34B2F08897B2-806E
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H03 0561
Revision: Serial number: 0000245908246
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Serial number: 17112824
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: 3874C13883C6A38F5F-806C
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
Serial number: 17112951
ROD: EV_AST.rod
