Results 1 to 8 of 8
Thread: Key Fob programming MK7 2015 Golf TDI
    Mar 2019
    I've added several key fobs to cars between 2009-2014, mostly Jettas. I typically have programmed an extra key fob like the following youtube video, in the adaptation section of either 9, 35 or 46:
    https://www.youtube.com/watch?v=xLKNg4yioFk
    I'm trying to do the same thing on a 2015 Golf, and it looks different and I can't find the Remote control section of the adaptation section in the Central Locking (9) area. The adaptation section itself looks different now, too, is it a new version of the VCDS software?
    Any ideas of how to make this one work?
    Thanks
    Jun 2014
    Quote Originally Posted by desmoinestdi View Post
    Thanks
    if we talking about MQB - you need immo tool , because remote is learn automatic after key lear to immo system
    in MQB remote can not be add just like that
    Is this true even in a "basic" car without any Kessy?
    Oct 2017
    Northwest UK
    Remotes are learned in the BCM now.
    Jun 2014
    as far as I know - yes
    because ODIS learn that automaticly while key learn
    no need any extra procedure after key re-learn , just leran to cluster and key / remote add automatic
  6. Likes Uwe, PetrolDave liked this post
    Mar 2019
    Sorry, I don't understand the terminology (MQB, ODIS, BCM). I'm not trying to program a key itself, just an extra key fob for the remote lock/unlock functions only. Is this not possible in VCDS for the 2015 Golf?
    Thanks
    Oct 2017
    Northwest UK
    Thanks
    Sorry yes it is. You need to open Module 09 BCM (Body Control Module) and select security access. Type in code 31347 and then do it.
    In the search box type in remote and then click on the drop down options and select remote control adaptation.
    Under channel "01", the Stored value field should show the number of remotes your car currently has, eg 2,3,6.
    In the New value field, enter 1 (if your car has one keyfob, 2 if there are two keyfobs, etc)
    Press Test and then press the unlock button on the keyfob(s).
    You have about 10-15 seconds to complete this step. If the keyfob registers, you'll get an acknowledgement signal as the indicators flash. If it fails then repeat the steps.
    Hope this helps
    P.S don't worry about the acronyms, you'll pick them up!
  9. Likes Uwe liked this post
  10. #8
    When they are bold, green, and have a broken underline, hover your cursor over them.
  11. Likes PetrolDave liked this post
