Page 1 of 3 123 LastLast
Results 1 to 10 of 30
Thread: Please help: Coding lane assist camera 3Q0 980 654 L on 2018 Golf 7
    Sep 2019
    Slovenia
    Cool Please help: Coding lane assist camera 3Q0 980 654 L on 2018 Golf 7
    Hello, I retrofited 3Q0 980 654 L lane assist camera on my golf 7 2018 and I cant get rid of these fault codes.
    First fault is ok, for the other two I dont know what to do.
    Do you have any idea what to do?
    Friday,25,October,2019,20:24:45:30226
                    Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
    Control Module Part Number: 3Q0 980 654 L    HW: 3Q0 980 654 A
      Component and/or Version: MQB_B_MFK     H12 0610
               Software Coding: 0003070000000401002200448150A90098000E00002000
                Work Shop Code: WSC 12345 123 12345
                  ASAM Dataset: EV_MFKBoschMQBB 002041 (VW48)
                           ROD: EV_MFKBoschMQBB_002_VW37.rod
                          VCID: 40D94134DA04A227897-8014
    0660 - No Basic Setting
              B2010 00 [009] - -
              [Initial_calibration_missing]
                        Reset counter: 99
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:01:39
                        Control Module temperature: 28 °C
                        Outside air temperature: 16.5 °C
                        Vehicle speed: 0.00 km/h
                        System run time: 29.6 s
                        Voltage terminal 15: 13.9 V
                        mid: 00 1E
                        Status of camera: operational
                        Engine_Running_Info: 1
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
    1122597 - Local Data Bus
              U1169 00 [009] - Missing Message
                        Reset counter: 99
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:01:39
                        System run time: 30.0 s
                        Voltage terminal 15: 14.0 V
                        mid: 01 43
                        Status of camera: System malfunction
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
    0659 - Steering
              C10AC F2 [009] - Lane-Holding Assistance Not Coded
              [HC_interface_at_the_steering_not_activated]
                        Reset counter: 99
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:01:39
                        System run time: 30.2 s
                        mid: 02 A6
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
    Oct 2014
    Arandjelovac, Serbia
    Lightbulb
    Hello and welcome!
    Please give us full Auto Scan.
  3. Likes Uwe liked this post
    Moved to Retrofits.
    Mar 2015
    Australia
    You need to run the calibration routine per the workshop guide using ODIS and the correct calibration board.
    Also your steering rack is not coded for HCA.
    2011 Skoda Octavia vRS TDI DSG wagon|Revo Stage 1|Race Blue|Leather|Dynamic Xenons w 6000K|THA475 Amp+active sub|Whiteline ALK|RVC|Discover Media
    2009 R36 wagon|Biscay Blue|RVC|Tailgate|ECU and DSG tune|LED DRL/Indicators|Full colour MFD|Quad LED tail rings| Climatronics upgrade| Dynaudio retrofit | B7 RLine Flat Steering Wheel|3AA CCM|B7 Adaptive Cruise with Front Assist|TPMS Direct|Discover Media retrofit|PLA 2.0|Lane Assist|BCM Retrofit|HBA/FLA
  6. Likes Uwe liked this post
    Jul 2014
    Tallinn, Estonia
    Did you run the sensor fusion CAN wires to ACC/Front Assist radar? The Local Data Bus DTC could be because of this.
    Sep 2019
    Slovenia
    Here is my full auto scan.
    I connected the wires from ACC to A5 module. I bought cables from Kufatech and connected per instructions.
    For calibration I need to have only one error.
    I coded the steering rack, so I dont know what else could be there. There are not a lot of options to change on that module.
    Errors in my autoscan are because of coding I guess. Error in ACC is present from new car, but the ACC is working with no problem. Error is not there all the time.
    Before coding there was Error in ACC and A5 camera.
    Saturday,26,October,2019,10:01:06:30226
    VIN: WVWZZZAUZKP038555   License Plate:
    Chassis Type: AU-VW37 (3Q0)
    Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F A5
    VIN: WVWZZZAUZKP038555   Mileage: 22999km-14290miles
    Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 026 NF    HW: 04L 907 309 P
       Component: R4 2.0l TDI   H25 6380
       Revision: B4H25---
       Coding: 01250412036405082000
       Shop #: WSC 00028 028 00030
       ASAM Dataset: EV_ECM20TDI01104L906026NF 004007
       ROD: EV_ECM20TDI01104L906026KM.rod
       VCID: 7BA3F6D8F36201FF9C5-802E
    17156 - Databus
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 19:31:25
                        Coolant temperature: 52 °C
                        Intake air temperature: 55 °C
                        Voltage terminal 30: 12.160 V
                        Drivetrain coordinator: brake function status-Bits 0-7: 0
                        Acceleration: 0.000 m/s˛
    34193 - Implausible Data Received from ESP Control Module
              U0416 00 [032] - -
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 19:31:25
                        Engine status: COENG_READY
    5604 - Park/Neutral Switch Input Circuit
              P0850 00 [032] - Open or Short to Plus
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 19:31:25
                        Starter control: Interlock- or P/N-signal-Bits 0-7: 1
                        Brake actuated status-Bits 0-7: 0
                        Selector lever position-Bits 0-7: 8
                        Transmission neutral position sensor: adaptation status-Bits 0-7: 0
    37682 - Internal Control Module Main Processor Performance
              P060C 00 [032] - -
                        Mileage: 22852 km
                        Date: 2019.10.21
                        Time: 12:47:39
                        Engine speed: 1373.00 /min
                        Normed load value: 33.3 %
                        Vehicle speed: 56 km/h
                        Coolant temperature: 89 °C
                        Intake air temperature: 70 °C
                        Voltage terminal 30: 14.120 V
                        Unlearning counter according OBD: 36
                        Engine status: COENG_RUNNING
                        Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
       Part No SW: 0GC 300 042 T    HW: 0GC 927 711 H
       Component: GSG DQ381     H06 2308
       Revision: 00H06V07
       ASAM Dataset: EV_TCMDQ381061 001
       ROD: EV_TCMDQ381061_VW37.rod
       VCID: 372B2AE88FCAE59F38D-8062
       Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
       Component: ESC           H25 0524
       Revision: 00000000    Serial number: 62798000002843
       Coding: 01FA62A124230974477C060560C82980462490E26006947338625078C202430B00000012121212B835351919323200
       Shop #: WSC 00028 028 00026
       VCID: 77ABEAE8CF4A259FF8D-8022
       Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
       Revision: 00001K08
       Coding: 00020104202110011005004000101022
       VCID: 6C81C584860C964705F-8038
       Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
       Component: BCM MQBAB B   H38 0273
       Serial number: 00001828900588
       ASAM Dataset: EV_BCMMQB 019001
       ROD: EV_BCMBOSCH_019_VW37.rod
       VCID: 7AADF3DCFC5838F7873-802E
       Component: WWS    180913  043 0551
       Serial number:         180917224719
       Component: RLHS  052 0107
       Serial number: S7Y18M10D12H17M51S57
       Coding: 00A8DD
       Steering Column Switch:
       Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
       Component: J527 SMLS MQB  004 0060
       Serial number: 00000018101808490440
       Serial number: 000308418618284
       Coding: 0471051811
       VCID: 4CC16504E64C764765F-8018
    12666384 - Databus
              [Diagnose-Interface für Datenbus-J533 - Diagnose_01 - kein Signal/keine Kommunikation]
                        Reset counter: 138
    13637426 - Databus
                        Reset counter: 138
       Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
       Component: ACC BOSCH MQB H11 0682
       Coding: 3300670111FFC728949C810580400600000000000000000004
       ASAM Dataset: EV_ACCBOSCHVW416 002008
       VCID: 44D14D24CE1CBE07ADF-8010
    10 Faults Found:
    0803 - Databus
              [FAULT_BV1_FEHLER]
                        Reset counter: 99
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:39:28
                        Control Module temperature: 52 °C
                        Voltage terminal 15: 12.2 V
                        Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                        Reset counter: 138
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 19:31:43
                        Control Module temperature: 32 °C
                        Voltage terminal 15: 12.1 V
                        Status_ACC_System: ACC_irreversible error
    1089 - Databus
              [FAULT_TIMEOUT_ESP_10]
                        Reset counter: 138
    1091 - Databus
              [FAULT_TIMEOUT_ESP_20]
                        Reset counter: 138
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 19:31:43
    1092 - Databus
              [FAULT_TIMEOUT_ESP_21]
                        Reset counter: 138
    0940 - Databus
              [FAULT_TIMEOUT_ESP_24]
                        Reset counter: 138
    1074 - Databus
              [FAULT_TIMEOUT_ESP_33]
                        Reset counter: 138
    1086 - Databus
              [FAULT_TIMEOUT_TSG_FT_02]
                        Reset counter: 138
    1797 - Internal Fault
              B200F F0 [008] - Unknown Error Elaboration
              [FAULT_TX_TIMEOUT_ACC_06]
                        Reset counter: 138
    1796 - Internal Fault
              [FAULT_TX_TIMEOUT_ACC_07]
                        Reset counter: 138
       Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
       Component: AirbagVW21    006 0336
       Serial number: 003VVR4MPJPF
       Coding: 98CCC000000000005C0000CF000800000065
       Shop #: WSC 00028 028 00003
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 074B9A28BFAA551F88D-8052
       Subsystem 1 - Part No SW: -----------    HW: 480 001 110 18
       Serial number: 3570000000037929353D
       Subsystem 2 - Part No SW: -----------    HW: 480 001 110 18
       Serial number: 358000000008A971253I
       Subsystem 3 - Part No SW: -----------    HW: 480 400 810 18
       Component: SideSensor_Dr  004 6149
       Serial number: 3510001302B76CF4237$
       Subsystem 4 - Part No SW: -----------    HW: 480 400 810 18
       Component: SideSensor_Pr  004 6149
       Serial number: 3520001302B76CF4B804
       Subsystem 5 - Part No SW: -----------    HW: 480 401 310 18
       Component: FrontSensor_D  003 6149
       Serial number: 3550001A52DA6D9266BL
       Part No SW: 5G1 920 741 D    HW: 5G1 920 741 D
       Component: KOMBI         211 2500
       Coding: 07A529082780000801883A0B1401000000000000
       Shop #: WSC 01545 995 12345
       ASAM Dataset: EV_DashBoardVDDMQBAB 009065
       VCID: 2809F99452747A67A17-807C
              U1014 00 [009] - -
                        Reset counter: 99
                        Mileage: 22999 km
                        Date: 2019.10.23
                        Time: 22:17:22
    16777008 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
              [BAP_SWA_0x1A keine Kommunikation]
                        Reset counter: 99
                        Mileage: 22999 km
                        Date: 2019.10.23
                        Time: 22:10:55
       Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5344
       Serial number: 13101810520466
       Coding: 030100045F086800FA0002481C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3D2738C0ADF6CFCFE21-8068
       Component: 1-01-13-01-04
       Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H17 0052
       Serial number: 39180001872480088376
       Coding: 2CFFFF
       Serial number: 5156179304
       Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
       Component: TSG FS        006 0246
       Serial number: 0000350037383
       Coding: 003003208000040000001000
       VCID: 46D5572CF8208C17B3B-8012
       Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  010 0004
       Serial number: 00000000000010292407
       Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
       Component: EPS_MQB_ZFLS  131 1082
       Coding: 111F0000
       ROD: EV_SteerAssisMQB_015.rod
       VCID: 74B1DDE4DE3C4E87DDF-8020
       Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
       Component: TSG BFS       006 0246
       Serial number: 0000348920928
       Coding: 003001208E00040000001000
       VCID: 47CB5A28FF2A951F48D-8012
       Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  010 0004
       Serial number: 00000000000010289930
       Coding: 090000
       Part No SW: 3Q0 035 819 C    HW: 3Q0 035 819 C
       Component: MU-S--ER      H41 0472
       Serial number: VWZAZ2U1231377
       Coding: 02731000FF0000005111000100080A001F0509C40120010001
       ROD: EV_MUStd4CTSAT_VW37.rod
       VCID: 313F14F061AE3BAF769-8064
       Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
       Component: ABT_Std-2  H52 8130
       Serial number: VWZ6ZJV2830893
       Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
       Component: MQB_B_MFK     H12 0610
       Serial number: 04071915P11366
              B2010 00 [009] - -
                        Fault Frequency: 13
                        Reset counter: 99
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:01:39
                        mid: 00 1E
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
                        Reset counter: 99
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:01:39
                        mid: 01 43
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
    0659 - Steering
              C10AC F2 [008] - Lane-Holding Assistance Not Coded
                        Reset counter: 139
                        Mileage: 22998 km
                        Date: 2019.10.23
                        Time: 20:01:39
                        mid: 02 A6
                        Software_Info_4: 0
                        Software_Info_3: 1
                        Software_Info_2: 6
                        Software_Info_1: 0
    End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
    Jul 2014
    Tallinn, Estonia
    There should be a documented (it has an appropriate label) coding bit in module 13 which turns on the sensor fusion CAN interface on the ACC side. After that the databus DTC should clear from A5, but ACC will cease to function. Then is the time for A5 calibration, if the steering DTC is also fixed. After calibration, A5 should be clear of DTC-s and ACC should also work. The "FAULT_BV1_FEHLER" DTC from ACC should also clear - at least it did in my experience.
  10. Likes Uwe liked this post
  11. #8
    Oct 2017
    Northwest UK
    Hi Maticmd
    Coding aside you need to calibrate the camera. Once this has been done most of the errors will disappear. Did you car have a camera before or is it a complete retrofit? If so did you change the windscreen?
  12. #9
    Sep 2019
    Slovenia
    @siLc Thank you for your insight, I will look for that tommorow.
    @myounus I did a complete retroifit and I changed the windscreen too. I have to solve almost all errors before calibrating otherwise calibration cant be done. Only one specific error is permitted.
  13. #10
    Oct 2017
    Northwest UK
    Quote Originally Posted by MaticMD View Post
    I've done many and it makes no difference with errors. Once calibrated the basic settings including VIN are stored to the camera. If you can clear all faults and re-scan we can see what's remaining.
