Please help: Coding lane assist camera 3Q0 980 654 L on 2018 Golf 7
MaticMD
Slovenia
Hello, I retrofited 3Q0 980 654 L lane assist camera on my golf 7 2018 and I cant get rid of these fault codes.
First fault is ok, for the other two I dont know what to do.
Do you have any idea what to do?
Friday,25,October,2019,20:24:45:30226
                Address A5: Frt Sens. Drv. Assist       Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654 L    HW: 3Q0 980 654 A
  Component and/or Version: MQB_B_MFK     H12 0610
           Software Coding: 0003070000000401002200448150A90098000E00002000
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_MFKBoschMQBB 002041 (VW48)
                       ROD: EV_MFKBoschMQBB_002_VW37.rod
                      VCID: 40D94134DA04A227897-8014
0660 - No Basic Setting
          B2010 00 [009] - -
          [Initial_calibration_missing]
                    Reset counter: 99
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:01:39
                    Control Module temperature: 28 °C
                    Outside air temperature: 16.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 29.6 s
                    Voltage terminal 15: 13.9 V
                    mid: 00 1E
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
1122597 - Local Data Bus
          U1169 00 [009] - Missing Message
                    Reset counter: 99
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:01:39
                    System run time: 30.0 s
                    Voltage terminal 15: 14.0 V
                    mid: 01 43
                    Status of camera: System malfunction
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [009] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 99
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:01:39
                    System run time: 30.2 s
                    mid: 02 A6
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Hello and welcome! :thumbs:
Please give us full Auto Scan.
Moved to Retrofits.
kamold
Australia
C?ID=241363
You need to run the calibration routine per the workshop guide using ODIS and the correct calibration board.
Also your steering rack is not coded for HCA.
siLc
Tallinn, Estonia
C?ID=330192
Did you run the sensor fusion CAN wires to ACC/Front Assist radar? The Local Data Bus DTC could be because of this.
MaticMD
Slovenia
Here is my full auto scan.
I connected the wires from ACC to A5 module. I bought cables from Kufatech and connected per instructions.
For calibration I need to have only one error.
I coded the steering rack, so I dont know what else could be there. There are not a lot of options to change on that module.
Errors in my autoscan are because of coding I guess. Error in ACC is present from new car, but the ACC is working with no problem. Error is not there all the time.
Before coding there was Error in ACC and A5 camera.
Saturday,26,October,2019,10:01:06:30226
VIN: WVWZZZAUZKP038555   License Plate:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 08 09 10 13 15 17 19 42 44 52 5F A5
VIN: WVWZZZAUZKP038555   Mileage: 22999km-14290miles
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 NF    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 6380
   Revision: B4H25---
   Coding: 01250412036405082000
   Shop #: WSC 00028 028 00030
   ASAM Dataset: EV_ECM20TDI01104L906026NF 004007
   ROD: EV_ECM20TDI01104L906026KM.rod
   VCID: 7BA3F6D8F36201FF9C5-802E
17156 - Databus
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 19:31:25
                    Coolant temperature: 52 °C
                    Intake air temperature: 55 °C
                    Voltage terminal 30: 12.160 V
                    Acceleration: 0.000 m/s˛
34193 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 19:31:25
                    Engine status: COENG_READY
5604 - Park/Neutral Switch Input Circuit
          P0850 00 [032] - Open or Short to Plus
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 19:31:25
                    Starter control: Interlock- or P/N-signal-Bits 0-7: 1
                    Brake actuated status-Bits 0-7: 0
                    Selector lever position-Bits 0-7: 8
                    Transmission neutral position sensor: adaptation status-Bits 0-7: 0
37682 - Internal Control Module Main Processor Performance
          P060C 00 [032] - -
                    Mileage: 22852 km
                    Date: 2019.10.21
                    Time: 12:47:39
                    Engine speed: 1373.00 /min
                    Normed load value: 33.3 %
                    Vehicle speed: 56 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 70 °C
                    Voltage terminal 30: 14.120 V
                    Unlearning counter according OBD: 36
                    Engine status: COENG_RUNNING
   Part No SW: 0GC 300 042 T    HW: 0GC 927 711 H
   Component: GSG DQ381     H06 2308
   Revision: 00H06V07
   ROD: EV_TCMDQ381061_VW37.rod
   VCID: 372B2AE88FCAE59F38D-8062
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 62798000002843
   Coding: 01FA62A124230974477C060560C82980462490E26006947338625078C202430B00000012121212B835351919323200
   Shop #: WSC 00028 028 00026
   VCID: 77ABEAE8CF4A259FF8D-8022
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 00020104202110011005004000101022
   VCID: 6C81C584860C964705F-8038
   Air quality sensor:
   Part No SW: 5Q0 937 084 DA    HW: 5Q0 937 084 CD
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001828900588
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AADF3DCFC5838F7873-802E
   Component: WWS    180913  043 0551
   Serial number:         180917224719
   Component: RLHS  052 0107
   Serial number: S7Y18M10D12H17M51S57
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507     HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000018101808490440
   Part No SW: 5QA 919 294 C    HW: 5QA 919 294
   Component: PDC 8 KanalH07 0050
   Serial number: 000308418618284
   Coding: 0471051811
   ASAM Dataset: EV_EPHVA18AU3700000 009039
   VCID: 4CC16504E64C764765F-8018
12666384 - Databus
          [Diagnose-Interface für Datenbus-J533 - Diagnose_01 - kein Signal/keine Kommunikation]
                    Reset counter: 138
13637426 - Databus
                    Reset counter: 138
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Coding: 3300670111FFC728949C810580400600000000000000000004
   VCID: 44D14D24CE1CBE07ADF-8010
10 Faults Found:
0803 - Databus
          [FAULT_BV1_FEHLER]
                    Reset counter: 99
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:39:28
                    Control Module temperature: 52 °C
                    Voltage terminal 15: 12.2 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
                    Reset counter: 138
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 19:31:43
                    Control Module temperature: 32 °C
                    Voltage terminal 15: 12.1 V
1089 - Databus
          [FAULT_TIMEOUT_ESP_10]
                    Reset counter: 138
1091 - Databus
          [FAULT_TIMEOUT_ESP_20]
                    Reset counter: 138
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 19:31:43
1092 - Databus
          [FAULT_TIMEOUT_ESP_21]
                    Reset counter: 138
0940 - Databus
          [FAULT_TIMEOUT_ESP_24]
                    Reset counter: 138
1074 - Databus
          [FAULT_TIMEOUT_ESP_33]
                    Reset counter: 138
1086 - Databus
          [FAULT_TIMEOUT_TSG_FT_02]
                    Reset counter: 138
1797 - Internal Fault
          B200F F0 [008] - Unknown Error Elaboration
          [FAULT_TX_TIMEOUT_ACC_06]
                    Reset counter: 138
1796 - Internal Fault
          [FAULT_TX_TIMEOUT_ACC_07]
                    Reset counter: 138
   Part No SW: 5Q0 959 655 BH    HW: 5Q0 959 655 BH
   Component: AirbagVW21    006 0336
   Serial number: 003VVR4MPJPF
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00003
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 074B9A28BFAA551F88D-8052
   Subsystem 1 - Part No SW: -----------    HW: 480 001 110 18
   Serial number: 3570000000037929353D
   Subsystem 2 - Part No SW: -----------    HW: 480 001 110 18
   Serial number: 358000000008A971253I
   Subsystem 3 - Part No SW: -----------    HW: 480 400 810 18
   Component: SideSensor_Dr  004 6149
   Serial number: 3510001302B76CF4237$
   Subsystem 4 - Part No SW: -----------    HW: 480 400 810 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001302B76CF4B804
   Subsystem 5 - Part No SW: -----------    HW: 480 401 310 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A52DA6D9266BL
   Part No SW: 5G1 920 741 D    HW: 5G1 920 741 D
   Component: KOMBI         211 2500
   Coding: 07A529082780000801883A0B1401000000000000
   Shop #: WSC 01545 995 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009065
   VCID: 2809F99452747A67A17-807C
          U1014 00 [009] - -
                    Reset counter: 99
                    Mileage: 22999 km
                    Date: 2019.10.23
                    Time: 22:17:22
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SWA_0x1A keine Kommunikation]
                    Reset counter: 99
                    Mileage: 22999 km
                    Date: 2019.10.23
                    Time: 22:10:55
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 13101810520466
   Coding: 030100045F086800FA0002481C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D2738C0ADF6CFCFE21-8068
   Component: 1-01-13-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001872480088376
   Coding: 2CFFFF
   Serial number: 5156179304
   Part No SW: 5Q4 959 393 F    HW: 5Q4 959 393 F
   Component: TSG FS        006 0246
   Serial number: 0000350037383
   Coding: 003003208000040000001000
   VCID: 46D5572CF8208C17B3B-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000010292407
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 111F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DDE4DE3C4E87DDF-8020
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000348920928
   Coding: 003001208E00040000001000
   VCID: 47CB5A28FF2A951F48D-8012
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000010289930
   Coding: 090000
   Part No SW: 3Q0 035 819 C    HW: 3Q0 035 819 C
   Component: MU-S--ER      H41 0472
   Serial number: VWZAZ2U1231377
   Coding: 02731000FF0000005111000100080A001F0509C40120010001
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 313F14F061AE3BAF769-8064
   Subsystem 1 - Part No SW: 5G6 919 605     HW: 5G6 919 605
   Component: ABT_Std-2  H52 8130
   Serial number: VWZ6ZJV2830893
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 04071915P11366
   Shop #: WSC 12345 123 12345
          B2010 00 [009] - -
                    Fault Frequency: 13
                    Reset counter: 99
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:01:39
                    mid: 00 1E
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
                    Reset counter: 99
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:01:39
                    mid: 01 43
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
0659 - Steering
          C10AC F2 [008] - Lane-Holding Assistance Not Coded
                    Reset counter: 139
                    Mileage: 22998 km
                    Date: 2019.10.23
                    Time: 20:01:39
                    mid: 02 A6
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
End----(Elapsed Time: 01:26, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
siLc
Tallinn, Estonia
C?ID=330192
There should be a documented (it has an appropriate label) coding bit in module 13 which turns on the sensor fusion CAN interface on the ACC side. After that the databus DTC should clear from A5, but ACC will cease to function. Then is the time for A5 calibration, if the steering DTC is also fixed. After calibration, A5 should be clear of DTC-s and ACC should also work. The "FAULT_BV1_FEHLER" DTC from ACC should also clear - at least it did in my experience.
myounus
Northwest UK
C?ID=321059
Hi Maticmd
Coding aside you need to calibrate the camera. Once this has been done most of the errors will disappear. Did you car have a camera before or is it a complete retrofit? If so did you change the windscreen?
MaticMD
Slovenia
@siLc Thank you for your insight, I will look for that tommorow.
@myounus I did a complete retroifit and I changed the windscreen too. I have to solve almost all errors before calibrating otherwise calibration cant be done. Only one specific error is permitted.
myounus
Northwest UK
C?ID=321059
I've done many and it makes no difference with errors. Once calibrated the basic settings including VIN are stored to the camera. If you can clear all faults and re-scan we can see what's remaining.
MaticMD
Slovenia
@myounus I heard from multiple sources that you cant calibrate the camera if you have more than one error in A5 camera. The only accepted error is calibration missing. Did you managed to calibrate it with more errors?
myounus
Northwest UK
C?ID=321059
Yes. I fitted one and had lots of errors.
Calibrated it first and then completed the coding afterwards. Ive calibrated cameras in 3 different garages here in the UK, the dealers, auto windscreens and Autoglass. Apart from VW who use ODIS, the others use third party equipment which all do the same job.
ODIS is tied down as GFF is a pain. Third party equipment allows more flexibility. Believe it or not I've been with a master tech who asked me to show him/ code with VCDS as he couldn't replicate a fault in ODIS. All equipment has its place and good points/ bad points.
MaticMD
Slovenia
You bought me, I will go and calibrate it tommorow :)
Maybe just ODIS needs only one error for calibration and others dont. I will go to CarGlass and I am almost certain that they dont use ODIS.
Edit: This evening I tried what @siLc said and after clearing all errors I was left with only one, calibration missing. Only thing I did was activating lane assist in ACC module. ACC is now not operational. I will report back after calibration. That is a great progress :)
MaticMD
Slovenia
I am back, calibration went trough without a problem. Lane assist, ACC, road sign recognition is now fully operational :)
Of course its never that easy: I now have problem with activation TJA. I went trough a lot of coding instructions and compare them so I could do mine. There is no TJA or lane assist on the Infotainment screen. On the MDF is only lane assist out of all new desired options. I realy tried a lot of things.
I dont have option to turn on TJA and heading control in module 44 - steering assist and no options to turn on TJA in A5 camera. I was told that parameters I got include TJA, is it possible that they dont?
Does somebody know anything about parameters, maybe could find them somewhere?
Do I need new parameters for module 44?
my camera is 3Q0980654L 0610
3Q0980654A H12
Any knowledge about that would be appreciated.
VIN: WVWZZZAUZKP038555   Mileage: 23160km-14390miles
   Revision: B4H25---
   Revision: 00H06V07
   Coding: 01FA62A124230974477C060560C82980462490E26006947338625078C222430B00000012121212B835351919323200
   Shop #: WSC 12345 123 61029
   Revision: 00001K08
   Air quality sensor:
   Coding: 00A8DD
   Coding: 0471051811
   Coding: 3319676195FFC728949C811D80400600000000000000000004
   Coding: 27A529086784000801883A031401000000000000
   ROD: EV_GatewNF.rod
   Coding: 2CFFFF
   Coding: 111F0000
   Coding: 090000
   Coding: 0003070000000401002200448150890098000E00002000
End----------(Elapsed Time: 01:17, VBatt start/end: 12.2V/12.2V)-----------
darkchina811
ITALY
C?ID=333184
in order to have TJA you need to upload dataset to the camera. that is not coding and VCDS cannot help you.
MaticMD
Slovenia
I know, I already uploaded data set that was suppose to include TJA, maybe it doesnt. Where can I get these data sets? Anybody?
downtime
C?ID=280813
You will not have any options to set TJA. Only thing from which you can tell TJA is working is when you activate ACC under 60km/h. The lane assist icon should turn green. from that you will know that it’s working.
Normally lane assist only activates when driving over 60km/h but with TJA it activates under that when ACC is activated.
myounus
Northwest UK
C?ID=321059
It sounds like you've got the correct camera as I don't think it's possible to parameterise the 5G0 cameras with TJA.
downtime
C?ID=280813
Yes he has. 3Q0 cameras from G version onwards support TJA.
And you’re right, no 5Q0 cameras support TJA.
MaticMD
Slovenia
@downtime - I know that about using it. But for coding I thought there must be some option to code TJA in A5 camera. Looks like there is nothing with "traffic jam" name in the A5 camera and thats ok.
Yesterday I managed to activate adaptive lane guidance and TJA. Before I had only lane assist. I was thinking how can I solve this problem and then I thought, my menus are not showing/working correctly, maybe this is blocking something and tried to change intervention from "early on menu" to just "early" and everything started to work like it should. I know its strange but that happened. Now Only thing left to do is to sort out the MMI and MFD menus for this retrofit.
I have exactly the same problem as @symb has/had, I read his thread about retrofiting the camera. There is lane assist in the MFD and says not available, there is adaptive lane guidance on the MMI and it is greyed out. I will go trough his adaptations and compare them to mine.
