Hi members.
I have Golf VII 2015 without RVC (5G6 827 469 F).
I bought used RVC (5G0 827 469 F) with harness.
First I install the RVC. Next connect all conectors. Then I connect two VIDEO wires to infotainment unit ( 5G0 035 819 A ) .....Black (pin1) - to unit PIN 12 and transparent wire (pin2) to unit PIN 6. Yellow wire to reverse light, red wire to 12V+.
After this steps I used VAG to activate RVC .....5F channel - long coding - BYTE 19 BIT 4 (from 0 to 1).
Turn ignition on , select reverse gear = RVC opened, display pop up camera view but without video. Just video option ....like brightness etc...
So, everything is working well, just video is not working....
Any ideas? thanks.
Any ideas? thanks.
Friday,25,October,2019,19:46:31:51262
VCDS Version: 19.6.2.0
VIN: WVWZZZAUZFP535298 License Plate: GOLFFF
Mileage: 93143km-57876mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZFP535298 Mileage: 93143km-57876miles
Address 01: Engine (J623-CRKB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 AN HW: 04L 907 309 E
Component: R4 1,6L EDC H22 7214
Revision: 86H22---
Coding: 01110012032415092000
Shop #: WSC 00028 028 00208
ASAM Dataset: EV_ECM16TDI01104L906021AN 002011
ROD: EV_ECM16TDI01104L906021AN_VW37.rod
VCID: 71EDE51FA06124C758-8024
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62144000003545
Coding: 04FA62A1242309710379060941CB2520462490C06082A4F300400078C002
VCID: 458561CFC469D867D4-8010
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 02020104202100011005000000101000
VCID: 73E1EF17DA7D16D7AA-8026
Air quality sensor:
197377 - Temperature Sensor for Right Vent
B1088 11 [009] - Short to Ground
Reset counter: 224
Mileage: 93143 km
Date: 2019.10.24
Time: 19:38:24
Voltage terminal 30: 11.4 V
Outside air temperature: 14.0 °C
B10CD 00 [009] - -
Reset counter: 224
Mileage: 93143 km
Date: 2019.10.24
Time: 19:38:24
CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
CAN input signal(s) status-Back-up light: On
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86580408140256
Coding: 00000846C24100DB4BE44004001C07081000000000000000000000000000
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_BodyContrModul1UDSBosc 013005
ROD: EV_BCMBOSCH_013.rod
VCID: 79FDDD3FF8116C87E0-802C
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 140719 043 0551
Serial number: 140726224229
Subsystem 2 - Part No SW: 8U0 955 559 HW: 8U0 955 559 Labels: 8U0-955-559.CLB
Component: G355_FeuchteS H07 0002
Serial number: 20821956
Part No SW: 5Q0 959 655 D HW: 5Q0 959 655 D
Component: AirbagVW20 014 0385
Serial number: 003F6R0A0L40
Shop #: WSC 00028 028 00062
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 418D75DFD041F447E8-8014
Subsystem 1 - Part No SW: ----------- HW: 480 000 708 14
Serial number: 3576700000078AA0701S
Subsystem 2 - Part No SW: ----------- HW: 480 000 708 14
Serial number: 35867000000DFB11701Z
Subsystem 3 - Part No SW: ----------- HW: 480 400 608 14
Serial number: 3516502C516DB802B1EK
Subsystem 4 - Part No SW: ----------- HW: 480 400 608 14
Serial number: 3526502B116DB804A0CE
Subsystem 5 - Part No SW: ----------- HW: 480 400 508 14
Serial number: 3556502B916DB801418D
Part No SW: 5Q0 953 521 EQ HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0175
Revision: FF032032 Serial number: 20140805400394
Coding: 1604
ROD: EV_SMLSVALEOMQB.rod
VCID: 0505A1CF84E9186794-8050
Part No SW: 5G1 920 741 HW: 5G1 920 741
Component: KOMBI 204 4270
Coding: 07A4120023800008000828001400000000000000
VCID: 64C39C4B6F93816F23-8030
Part No SW: 5Q0 907 530 R HW: 5Q0 907 530 K
Component: GW MQB Low 210 2186
Revision: -------- Serial number: 10081410801039
Coding: 030000040B087300EF000248080F00010001050000000000000000000000
ASAM Dataset: EV_GatewConti 011017
ROD: EV_GatewConti_011.rod
VCID: 408B70DBDB4BFD4FE7-8014
Subsystem 2 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3104694103
Part No SW: 5Q4 959 393 C HW: 5Q4 959 393 B
Component: TSG FS 009 0015
Serial number: 0000112888350
Coding: 003003208000020000001000
Shop #: WSC 00028 028 00068
VCID: 43817FD7CA5DE657FA-8016
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006268330
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 123 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
Part No SW: 5Q4 959 392 C HW: 5Q4 959 392 B
Component: TSG BFS 009 0015
Serial number: 0000113002689
Coding: 003001208000020000801000
VCID: 428F7AD3D547EF5FF1-8016
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000006276538
Coding: 090000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb
Part No SW: 5G0 035 819 A HW: 5G0 035 819 A
Component: MU-S--ER 041 0421
Serial number: V1C00708140444
Coding: 02730200FF00000011110001000800001F0106940100010001
ROD: EV_MUStd4CPASE_VW37.rod
VCID: 2759CB475E252A77C6-8072
Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605
Component: ABT_Std_Radio H60 0030
Serial number: VWZ8Z9PS203E18
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 224
Mileage: 93143 km
Date: 2019.10.24
Time: 19:38:24
Voltage terminal 30: 11.9 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
End-------------------------(Elapsed Time: 03:26)--------------------------
