Page 1 of 12 12311 ... LastLast
Results 1 to 10 of 113
Thread: Dreaded P0441 Evap Code
    Verified VCDS-Lite User
    Oct 2019
    Who has all got the dreaded p0441 evap code and there is no leak. I ran the groups 70 and 71 and my shop says there is an issue with evap system. No leak like I had hoped but could be anything. I already changed the small evap purge valave by the air filter. Im not sure what else to do. He said the signal could be bad to the purge valve or a block somewhere. How would I go about finding a block? Any help would be great. Thanks
    Oct 2019
    Sorry P0441
    Sorry p0441QUOTE=cschmitz20;180651]Who has all got the dreaded p0441 evap code and there is no leak. I ran the groups 70 and 71 and my shop says there is an issue with evap system. No leak like I had hoped but could be anything. I already changed the small evap purge valave by the air filter. Im not sure what else to do. He said the signal could be bad to the purge valve or a block somewhere. How would I go about finding a block? Any help would be great. Thanks[/QUOTE]
    It's will be difficult for anyone to give you any kind worthwhile feedback on this since you didn't even mention what kind of car you're having this problem on.
    Oct 2019
    PO441 CODE
    Anyone get this dreaded code? See it could be the purge valve but already changed that. Seems it could be a number of things. Mechanic mentioned a block? How do I clean out lines? Just run air through the lines?
    Yes, plenty of people have gotten it:
    https://duckduckgo.com/?q=P0441+site....ross-tech.com
    We also have a Wiki entry for it:
    http://wiki.ross-tech.com/wiki/index...5/P0441/001089
    But it might be helpful if you mentioned what kind of car you've got this in.
    PS: Threads merged. Please refrain from opening multiple threads with the same question.
  6. Likes Jack@European_Parts liked this post
    Hello and welcome to the VCDS forum OP!
    Mighty vac tester with vacuum plug caps to isolate zones anyone?
    Did you JPPSG yet in this forums sticky?
    Please post an auto-scan and consider the RTFB!
    Is the N80 purge valve you changed correct part and is it installed in correct direction?
    Are there any multiplicative vacuum leaks at intake or brake booster circuit?
    Oct 2019
    It is a 2003 Audi A4 Cabriolet 3.0
  9. #8
    Oct 2019
  10. #9
    Oct 2019
  11. #10
    Oct 2019
    The N80 valve I bought was from eBay and it was unbranded from China. Would it be worthwhile to try another one that isn't from China? I did test it with voltage and it seems to open and close as I can blow air through it but there could be more to it then that? It seems to easy to be a simple part like the N80 valve that's not expensive and easy to replace. my mechanic also mentioned there could be a block? Do I just blow air through the hoses to clear the out?
