Results 1 to 10 of 12
Thread: Problem retrofitting AID e-Golf 7
    Aug 2019
    Norway
    Ok, so I did this stupid thing..
    I want to retrofit the AID-cluster on my 2014 e-golf.. I have the cluster and the optical loop wire. I have stripped the interior, and was just test-fitting the AID.
    Didnt work of course because of the component protection. (The AID come from a crashed 2019 e-golf.)
    So I just refitted my original cluster, and then the problems started..
    I've got about a million faultcodes, and the car i almost impossible to drive.
    Yeah, and I did not backup my codes before I testfitted...
    I have my car at the dealer right now, and they have removed CP from the AID, but the faultcodes are still there.
    They have now remounted the original cluster, and are trying to remove the faultcodes..
    Q1: Can I clear the faultcodes myself, or does the dealer have to do this?
    Q2: If I try to mount the AID again, will the faultcodes reappear? Is this in the cluster or stored in the car? Dealer says the AID is a different communication protocol than the car.
    Here is the autoscan with the faultcodes..
    Tuesday,22,October,2019,18:51:22:58245
    VIN: WVWZZZAUZFW901768   License Plate:
    Chassis Type: AU-VW37 (5QE)
    Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F 75
              8C A5 BD C6
    VIN: WVWZZZAUZFW901768   Mileage: 58864km-36576miles
    23-Brake Booster -- Status: Malfunction 0010
    51-Electric Drive -- Status: Malfunction 0010
    BD-Hi Volt. Batt. Charg. -- Status: OK 0000
    C6-Batt. Chrg. -- Status: Malfunction 0010
    Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
       Part No SW: 0EA 906 016 A    HW: 0EA 907 309 A
       Component: E-Vehicle     H22 7907
       Revision: WMH22---
       Coding: 000D0012006404003000
       ASAM Dataset: EV_VCU00XXX0110EA906016A 002014
       ROD: EV_VCU00XXX0110EA906016A_002.rod
       VCID: 2D0708C73D9F063F521-8078
    17158 - Databus
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:27
                        Engine speed: 16383.75 /min
                        Normed load value: 100.0 %
                        Coolant temperature: 215 °C
                        Intake air temperature: 215 °C
                        Voltage terminal 30: 13.664 V
                        Acceleration: 0.000 m/s²
    24175 - Please Check Fault Codes in Control Module for ESP
              U102C 00 [039] - -
              [ESPRead out DTC]
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:15
                        Voltage terminal 30: 14.936 V
              U0428 00 [039] - -
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
                        Voltage terminal 30: 14.889 V
    4716 - No Communications with Parking Brake Control Module
              U0128 00 [039] - -
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:11
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
       Part No SW: 5Q0 907 379 N    HW: 5Q0 907 379 H
       Component: ESC           H31 0807
       Revision: 00000000    Serial number: 61954000000159
       ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
       ROD: EV_Brake1UDSContiMK100OMG_001_VW37.rod
       VCID: 47CB5A6FBF23CC6F48D-8012
    9 Faults Found:
    0195 - Control module not coded
              U1013 00 [167] - -
              [ECU marked as Not Configured because vehicle ID is invalid]
                        Date: 2019.10.21
                        Time: 21:36:14
    0212 - Longitudinal Acceleration Sensor
              C1017 54 [167] - Missing Calibration / Basic Setting
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
    0270 - Lateral Acceleration Sensor
              C1079 54 [167] - Missing Calibration / Basic Setting
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
    0279 - Brake Pressure Sensor 1
              C107A 54 [167] - Missing Calibration / Basic Setting
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
    0295 - Steering angle sensor
              B1168 54 [167] - Missing Calibration / Basic Setting
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
    8290 - Coding Not Possible
              U10BC 00 [167] - -
              [FCAN: Unplausible VIN number]
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
    8306 - Databus
              U1122 00 [167] - Implausible Message
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
    8314 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [047] - -
              [FCAN: Coding of ESP and TSK does not fit together]
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:13
    32848 - Control Module for Electric Parking Brake
              C10E2 F1 [175] - Switches/Motors Detected
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:14
       Revision: 00021000    Serial number: 0343294710
       Coding: 030C0C
       VCID: 3A2D339BFCD1A187C73-806E
       Part No SW: 5GE 907 044 S    HW: 5GE 907 044 S
       Component: Climatronic   H02 1103
       Revision: 00001K07
       Coding: 00022200200100010105000200101000
       ASAM Dataset: EV_ACClimaBHBVW37X 005132
       VCID: 4CC16543A6452F3765F-8018
       Subsystem 3 - Part No SW: 12E 963 231 E    HW: 12E 963 231 E
       Component: J848 HV-PTC  H09 0205
       Serial number:  T142203003805000024
       Air quality sensor:
    H01
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011421700904
       Coding: 00011B66C34102F32BA44080B11407201800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 00598173DA8D3B57C97-8054
       Component: WWS    140726  043 0551
       Serial number:         140801011851
       Component: RLHS  037 0059
       Serial number: S4Y14M08D18H13M41S56
       Coding: 00A8DD
       Serial number: 000000000ZY142021PV6
       Serial number: 00000000000060302941
       Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
       Component: PARKHILFE PLA H12 0047
       Revision: --------    Serial number: 39431421800859
       Coding: 2031161011
       ASAM Dataset: EV_EPHVA2CAU3700000 003019
       ROD: EV_EPHVA2CAU3700000_003.rod
       VCID: 42DD4B7B9401E9479F3-8016
    12658704 - Databus
              [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    13697024 - Control Module
              U110F 00 [009] - I'm sorry Dave; I'm afraid I can't do that!
              [Steuergerät für Bremse - ESP_02.ESP_Status_ESP_PLA - PLA-Codierung in Bremse prüfen]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    13637426 - Databus
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
       Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
       Component: ACC Bosch MQB H05 0304
       Serial number: 14081477030976
       Coding: 001C2700FE0739
       ASAM Dataset: EV_ACCMRRBoschVW372 001015
       VCID: 38292993C2DDB397317-806C
    1071 - Databus
              [FAULT_CIS_AXV_INVALID]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
                        Control Module temperature: 23 °C
                        Voltage terminal 15: 14.9 V
                        Vehicle speed: 0.00 m/s
                        Acceleration: 0.00 m/s²
    1058 - Databus
              [FAULT_CIS_ECD_NOTAVAILABLE]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1059 - Databus
              [FAULT_CIS_ESP_FAIL]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1078 - Databus
              [FAULT_CIS_SAS_INIT]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    0261 - Databus
              [FAULT_CIM_TIMEOUT_EPB_01]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1043 - Automatic Distance Control
              B10E7 F0 [009] - Disconnected
              [FAULT_CIS_TSK_IRREV_FAIL]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
       Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
       Component: AirbagVW20    009 0870
       Serial number: 003MFR003TAN
       Coding: 98FCC0C0002000005C5400CF004800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 50F971334A6D0BD7197-8004
       Belt Pretensioner left:
       Component: BeltPretRevFL  H35 0341
       Serial number: 34169667B20081440169
       Coding: 333135
       Belt Pretensioner right:
       Component: BeltPretRevFR  H35 0341
       Serial number: 34169668B20081441266
       Coding: 333135
       Subsystem 3 - Part No SW: -----------    HW: 480 001 408 14
       Serial number: 3570000000085835B01D
       Subsystem 4 - Part No SW: -----------    HW: 480 001 408 14
       Serial number: 358000000000E5B8C01O
       Subsystem 5 - Part No SW: -----------    HW: 480 401 408 14
       Serial number: 3510002A516FC222720W
       Subsystem 6 - Part No SW: -----------    HW: 480 401 108 14
       Serial number: 3520002A516DB810811Y
       Subsystem 7 - Part No SW: -----------    HW: 480 401 408 14
       Serial number: 3550002AB16DB80531EC
              B13BC F2 [137] - No function
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1049093 - Databus
              [NWD: 0x101 ESP_02 error value ESP_Querbeschleunigung]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1050117 - Databus
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1049094 - Databus
              [NWD: 0x101 ESP_02 error value ESP_Laengsbeschleunigung]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
    1049095 - Databus
              [NWD: 0x101 ESP_02 error value ESP_Gierrate]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
       Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 11081404400275
       Coding: 0C10
       ROD: EV_SMLSKLOMQB_010_VW37.rod
       VCID: 7BA3F69FB36B588F9C5-802E
    Address 17: Instruments (J285)       Labels:* None-SRI3
       Part No SW: 5GE 920 755     HW: 5GE 920 755
       Component: KOMBI         301 4280
       Coding: 072518186F940008008868031600000000000000
       VCID: 7DA7F887AD7F56BFA21-8028
    16776967 - Databus
              [EPB_02 keine Kommunikation]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:09
    16776973 - Databus
              [RKA_01 keine Kommunikation]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:09
    Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
       Part No SW: 5QE 907 530 B    HW: 5QE 907 530 A
       Component: GW MQB EV     312 3186
       Revision: --------    Serial number: 21071410800890
       Coding: 0201001746F81000EF001210081E00000001050100030000000000000000
       ASAM Dataset: EV_GatewEVConti 011017
       ROD: EV_GatewEVConti_011.rod
       VCID: 45D75067852FDE7FBA1-8010
       Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H16 0038
       Serial number: 27140002073650124341
       Coding: 2CFFFF
       Subsystem 2 - Part No SW: 5GE 915 181     HW: 5GE 915 181
       Component: J367-BDMHella  H03 8050
       Serial number: 7773663003
    Address 23: Brake Booster (J539)       Labels:* None
       Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
       Component: EBKV          H12 0160
       Serial number:   085430010046
       Coding: 01720100321900030002000500
       ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
       ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
       Brake Assistance Sub:
       Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
       Component: VX70BrakeAssi  H04 0140
       Serial number: 05802861160714213901
    163584 - No Communications with Parking Brake Control Module
              U0128 00 [047] - -
              [iBoVAG_ComScl_EPB_01_Timeout]
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:12
       Revision: 00000000    Serial number: 14000210624005
       Coding: 7900000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34311DA3DEB557F71DF-8060
       Serial number: 28071403110311
       Coding: 003F1220D000048000001000
       VCID: 40D941739A0DFB57897-8014
       Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003510459
       Component: EPS_MQB_ZFLS  123 1043
       Coding: D302
       ROD: EV_SteerAssisMQB_010.rod
       VCID: 41DF44779107F25F869-8014
    15873 - Steering angle sensor
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
                        Motor status: 00
                        Supply voltage: 14.75 V
                        Temperature: 15.0 °C
                        KFC: 3E
                        KFA: 00 01
                        Environmental conditions: 5B
                        uioUdNotFilt_xdu16: 14.88 V
                        uAdSensI_SwitchedKl30_xdu16: 14.88 V
    19204 - Databus
              [ESP_02 Botschaft - SNA_Check]
                        Reset counter: 55
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:50:49
                        Motor status: 00
                        System status: Driving mode
                        Temperature: 16.0 °C
                        KFC: 4B
                        KFA: 00 04
                        Environmental conditions: 21
                        uioUdNotFilt_xdu16: 15.03 V
                        uAdSensI_SwitchedKl30_xdu16: 15.03 V
       Part No SW: 5QE 907 080 B    HW: 5QE 907 080 B
       Component: VW370E2615010 H05 2453
       Revision: 00H05000
       Coding: C0020000000000000000
       ASAM Dataset: EV_DMCM09550115QE907080B 001018
       ROD: EV_DMCM09550115QE907080A.rod
    27161 - No Communication with ESP (Vehicle Dynamics) Control Module
              U0122 00 [039] - -
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:11
                        Voltage terminal 30: 14.902 V
                        Drive control condition: Standby
                        RPM of electric machine: 0 /min
                        Power electronics: IGBT module temp: phase U: 11.36 °C
                        E-machine: stator temperature: 10.45 °C
                        Power electronics: traction network voltage: 314.84 V
                        Torque: current value: -0.06 Nm
       Serial number: 07081404080747
       Coding: 003F1020DE00048000001000
       VCID: 3FDB428FE7F384AFF0D-806A
       Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000003470520
       Coding: 190000
       Coding: 051A000001010000
       VCID: 75B7E0A7954F0EFFEA1-8020
    13705992 - Databus
              [LWI_01: Fehlerwert im Signal LWI_Lenkradwinkel]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:59:55
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
       Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
       Component: MU-H-ND-EU    H43 0362
       Serial number: A310G0EB004179
       Coding: 027370010000000011111202000800001F0105B40100010097
       ASAM Dataset: EV_MUHig6C3HBAS 001041
       ROD: EV_MUHig6C3HBAS_VW37.rod
       VCID: 1A6DD31B5C118187273-804E
       Component: ABT_High  H61 0030
       Serial number: VWZ8Z9PS100H78
       Subsystem 2 - Part No SW: V03 959 806 F    HW: -----------
       Component: ECE 2019/2020  --- 0177
       Component: Gracenote  --- 1010
              U1111 00 [009] - -
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:15
                        Voltage terminal 30: 15.2 V
                        BAP-BAP_Function_ID: 02
    7206 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Brake (0x26) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:15
       Part No SW: 5QE 035 284     HW: 5QE 035 284
       Component: OCULowMQBEU   007 0535
       Coding: 0273700110829A01007800000000
       ROD: EV_OCULowMQB.rod
       VCID: 015F8477D187325FC69-8054
    Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
       Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
       Component: K8C           H13 0731
       Serial number: VWADEH600E
       ASAM Dataset: EV_BECM08820215QE915227M 003016
       ROD: EV_BECM08820215QE915227H.rod
       VCID: 52FD7B3B446179C72F3-8006
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
       Part No SW: 5Q0 980 653 F    HW: 5Q0 980 653
       Component: MQB_MFK       H06 0052
       Serial number: 10000115618
       Coding: 0101010001020303000500000100000100
       ROD: EV_MFKBoschAU370.rod
       VCID: 3B23369FF3EB988FDC5-806E
    6553600 - Databus
              [LH_EPS_03_BERECHN_LW_SIG_FAILURE]
                        Reset counter: 15
                        Mileage: 58864 km
                        Date: 2019.10.21
                        Time: 21:36:10
                        Control Module temperature: 39 °C
                        Outside air temperature: 4.5 °C
                        Vehicle speed: 0.00 km/h
                        Terminal 15 on: 489.6 s
    Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022.clb
       Part No SW: 5QE 915 022 E    HW: 12E 915 022 C
       Component: LMSG          H08 1072
       Serial number: 00920043010056
       Coding: CA0903
       ASAM Dataset: EV_HVChargManagVWMQB 001001
       ROD: EV_HVChargManagVWMQB_001.rod
       VCID: 43D34E7F8B1BE04F945-8016
    Address C6: Batt. Chrg. (JAX4)       Labels: 5QE-915-681.clb
       Part No SW: 12E 915 682 G    HW: 12E 915 682 G
       Component: OBC KOSTAL    H42 0142
       Revision: --------    Serial number: 2507140GI0000M
       ASAM Dataset: EV_OBCSinglPhaseKLOVW3707 002001
       ROD: EV_OBCSinglPhaseKLOVW3707_002.rod
       VCID: 2E050FCB30997D276BB-807A
    1048581 - Input Voltage Network Malfunction
              P31C6 00 [008] - -
                        Fault Frequency: 16
                        Reset counter: 55
                        Mileage: 58864 km
                        Date: 2019.10.22
                        Time: 07:00:25
    End----------(Elapsed Time: 02:16, VBatt start/end: 13.2V/13.3V)-----------
    You'll need to restore the ABS coding, then most of the other faults should be clear-able.
    If the AID still has another car's VIN, then the ABS will lose its coding again. If it has been properly matched by the dealer, I think it will be OK, but I've not done this kind of swap myself, so I'm not positive.
  3. Likes downtime liked this post
    May 2017
    Uwe is correct. Dealer can re-code the ABS with ODIS and running online coding guided function and that should get rid of most of the problems.
    They can match the AID to your car but they cannot online code it. Coding you need to do yourself.
  5. Likes Uwe liked this post
    Aug 2019
    Norway
    Ok, I will ask them to do that.
    Does the VIN need to be stored in the AID? Or should I just tell them to remove the VIN from the AID?
    As I understand they have removed the component protection, but the dealer is not so familiar with retro/custom.. They have never done this before..
    May 2017
    Removing CP from AID should also adapt the VIN. You cannot remove VIN from AID
  8. Likes Uwe liked this post
  9. #6
    Aug 2019
    Norway
    So my VIN should now be in the AID?
    I'm sorry if my questions are dumb.. I'm a noob...
  10. #7
    Tartu, Estonia
    I really didn't dig into Your scan, but I want to share few thought about this.
    Does Your cluster support Your MIB radio? Does Your gw support AID? Are You able to take on this epic journey retrofitting stuff to e-golf?
    There was this thread on drive2.ru, about golf GTE thought, but in the end he has to replace kinda everything to 7.5 level to get everything working. Also ECU flashed because MODE wasn't working correctly anymore due to newer GW needed to work with MIB2.5, but it not working with older ECU software.
    I honestly have 0 experience with GTE and E myself, but have taken notice from other people warnings.
    Why?
    VW Hybrides are annoying contemporaries.
    Much is completely different than regular burners, so you should rather stay away from a GTE and eGolf.
    - My Note to ALL Hybridists and Retrofiters -> DO NOT TOUCH THE GTE Gateway, Engine, AID, MIB2 ... everything will be a neverending story with no time, experience and good contacts!
    The world is my oyster...
  11. Likes Uwe, downtime liked this post
  12. #8
    Aug 2019
    Norway
    I have a MIB2 (5G0 919 606) and Dynaudio system.
    I know it have been done before on the e-golf..
  13. #9
    Jun 2014
    MIB 1 (5G0) not support MAP display via Fiber Wire
    5Q0 ACC not support Distance display on Virtual cluster
    but all must be do online, so waste of time asking what to do via VCDS
    There is few topic already about AID replace... try to look there and compare equipment's and read other people problems
  14. Likes downtime, PetrolDave, m87a liked this post
  15. #10
    Aug 2019
    Norway
    Ok, so now the dealer has reset my abs module.
    There is one fault. Is it the trailer hitch? I don't have that on my car..
    Tuesday,29,October,2019,23:16:57:58245
              8C A5 BD C6
    VIN: WVWZZZAUZFW901768   Mileage: 58924km-36613miles
       Revision: WMH22---
              U102C 00 [032] - -
              [ESPRead out DTC]
                        Mileage: 58923 km
                        Date: 2019.10.29
                        Time: 19:10:45
                        Voltage terminal 30: 14.913 V
                        Unlearning counter according OBD: 37
       Coding: 01FA40A12C20316D037E060641CB298002348CC0608294B3F881507AC242
       Shop #: WSC 36834 003 104857
    8299 - Databus
              U1121 00 [047] - Missing Message
              [FCAN: Anhaenger_01_alt veraltet bit is set]
                        Mileage: 58923 km
                        Date: 2019.10.29
                        Time: 19:10:42
       Coding: 030C0C
       Revision: 00001K07
       Coding: 00022200200100010105004200101000
       Air quality sensor:
    H01
       Coding: 00A8DD
       Coding: 2031161011
       Coding: 333135
       Coding: 333135
       Coding: 0C10
       Shop #: WSC 00185 218 00000
       Coding: 2CFFFF
       Coding: D302
       Shop #: WSC 36834 003 1048576
       Revision: 00H05000
       Coding: 190000
       Coding: 027370010000000011111202000802001F0105B40100010097
              U1101 00 [009] - Active
              [Anti-theft protection - component protection active (0xEA6300)]
                        Reset counter: 16
                        Mileage: 58922 km
                        Date: 2019.10.29
                        Time: 00:05:39
    7191 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                        Reset counter: 16
                        Mileage: 58922 km
                        Date: 2019.10.29
                        Time: 00:05:41
       Coding: CA0903
    End----------(Elapsed Time: 02:07, VBatt start/end: 14.8V/14.8V)-----------
