Hello from Italy (Audi TT mk3)
Jacopo79
New Member
Italy
Hi guys. I'm Jacopo from Italy and I read a lot in this wonderful forum! Now I am search information to activate TMC in my TT with retrofitted navi. A lot of guys told me to insert the value "15" in the adaptions in Fee traffic information. I Need free TMC, I don't have Audi connect!
Any idea about that?
Thank you and nice to meet you
Jacopo
PetrolDave
Westbury, UK
C?ID=1423
We are definitely going to need you to post a full unedited VCDS Auto-Scan to be able to help with your TMC activation.
Jacopo79
New Member
Italy
Sure PetrolDave, thank you! Can be good a Scan of my 5f? Thank you
Jacopo
PetrolDave
Westbury, UK
C?ID=1423
We need a FULL unedited Auto-Scan - understanding ALL the modules fitted is important as sometimes interactions between modules is important.
See my signature for a How-To.
Jacopo79
New Member
Italy
 OBDeleven vehicle history log
Date: 2019-10-27 16:58
    Car: Audi TT
    Year: 2015
    Body type: Coupe
    Engine: CHHC 169 kW (230 HP) 2.0 l
    Mileage: 22180 KM
Backup
    Control unit: 01 Engine Control Module 1
    System description: 2.0l R4 TFSI
    Software number: 8S0906259
    Software version: 0005
    Hardware number: 06K907425B
    Hardware version: H13
    ODX name: EV_ECM20TFS0208S0906259
    ODX version: 001006
    Backup name: Engine
    Long coding:
        0A1D00324426050B3002
    Adaptations:
        Idle RPM correction:
            Idle Speed Offset:
                0 1/min
        Engine run-in oil pressure:
                not active
        Deactivate production mode:
                000000
        Production mode:
                000000
        Activation of start-stop function:
                active
        Protective function:
                Enabled
        Timing deviation after other repairs, exhaust bank 1:
                0.00 °
        Timing deviation after other repairs, intake bank 1:
                0.00 °
        Timing deviation after chain replacement, exhaust bank 1:
                -2.38 °
        Timing deviation after chain replacement, intake bank 1:
                -1.13 °
        Chain elongation, initial values valid, exhaust bank 1:
                active
        Chain elongation, initial values valid, intake bank 1:
                active
        Chain elongation, no. of valid initial values, exhaust bank 1:
                3
        Chain elongation, no. of valid initial values, intake bank 1:
                5
        Timing deviation, current value exhaust bank 1:
                -2.63 °
        Timing deviation, current value intake bank 1:
                -1.13 °
        Roller test bench mode, functional:
                Not activated
        Operating mode selec.:
            CNG operation:
                Not activated
            DI operation:
                Not activated
                Not activated
    Advanced identification:
        Program memory status:
            Error in flash memory:
                No
            Flash memory faulty:
                No
            Communication error:
                No
            Flash memory not programmable:
                No
        Number of programming attempts:
            Bootloader:
            Application:
            Application 2:
            Application 3:
            Data record:
        Number of successful programming attempts:
            Bootloader:
            Application:
            Application 2:
            Application 3:
            Data record:
        Maximum number of possible update programming:
            Bootloader:
            Application:
            Application 2:
            Application 3:
            Data record:
        Workshop code and date of last update programming of SW module:
            Year:
                14
            Month:
                8
            Day:
                21
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                21
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                21
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                21
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                21
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
        FAZIT-identification:
            Manufacture location index:
                SME-RBG
            Day of manufacture:
                01.08.14
            Manufacturer- test stand number:
                2016
            Running manufacturer number:
                0199
        Manufacturer modification status:
            Control module family:
            Decoration variant:
            Construction version:
                H13
            Manufacture version:
        Identification of standard software:
            Standard software module:
                High Speed - Network management
            Primary version number:
            Secondary version number:
                12
            Revision number:
        Diagnostic mode:
                VW - diagnostic mode
        VW/Audi part number:
                8S0906259
        Software version:
                0005
        Vehicle Identification Number (VIN):
        Hardware part number:
                06K907425B
        System description:
                2.0l R4 TFSI
        Adaptation workshop code:
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
        ASAM/ODX file identification:
        ASAM/ODX file version:
                001006
        Hardware version:
                H13
        Coding workshop code:
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
        System abbreviation:
                J623
        Versions of software module:
            Bootloader:
                0021
            Application:
                0074
            Application 2:
                0074
            Application 3:
                0074
            Data record:
                0264
        Programmability status:
            Programmability:
                programmable
            Program consistency:
                Program present
        Coding length:
                10
        Engine code:
                CHHC
        Vehicle history data:
                hEpNeFhEbLgGpNiObDdOkJoNmIbJkHoJpEeAnHaKoFlCcEbKnJgMgInAiOnHfFkEaFgIlObJnGmPdFiGoOeDfDgNhIkCpNhKjFgNhGlNhHgBjBoNkLeOnEgJhBnGbLaMpFiKiLhBjKnPmOjHcHiPnApKfKnCjIkGiDnBhImMkNmIlOgPpHcOcJpJjHnEeIdJgEiEkNmJnFmHfMaHeMpNbLhEeEcNcHdPeIgOhGfOcHaGfGbAbJnGmDhAaPbPpOoDhEhDfAfGlEaIhAfDlHcLmHiOgCmNgImGhCoAiAgCcPhIjEkEhJnGiOcJnFmPnHlMcJnLfPgEoBeHdAjEoHkBjOfMgOaMdOcDbJiBcKnDdPjJcNiFcDlGfJeMlFbMjNaBdGdPdAnMoFiGhCjHpGbHlJjLgKgJoFgJoEeCeDhEmLdFfDlAnCeEfMgLgMgBpNiPfIfIaKdBcPmIdBeJjBjNiHhKpOfIhJaCkJaEfDbFnNaGpIhLaNdFbKnEfLmPoIeKaBcP
    Mileage: 22180 km
    Date: 2019-10-27 16:50
Backup
    Control unit: 02 Transmission Control Module
    System description: DQ250-6A MQB
    Software number: 0D9300012E
    Software version: 4504
    Hardware number: 02E927770AQ
    Hardware version: H53
    Serial number: TFK01407150047
    ODX name: EV_TCMDQ250021
    ODX version: 001001
    Backup name: Transmission
    Long coding:
        0014
    Adaptations:
                Not activated
            Bootloader:
            Application:
            Data record:
                3
            Bootloader:
            Application:
                1000
            Data record:
                1000
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                4
            Device number:
            Importer number:
            Dealership number:
                4864
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
                TFK-053
            Day of manufacture:
                15.07.14
                80A4
                0047
            Decoration variant:
                3
                253
                104
        Diagnostic mode:
                0D9300012E
        Software version:
                4504
                02E927770AQ
        System description:
                DQ250-6A MQB
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                EV_TCMDQ250021
                001001
        Hardware version:
                H53
            Device number:
                8
            Importer number:
                768
            Dealership number:
                4608
                J743
            Bootloader:
                0008
            Application:
                0045
            Data record:
                4504
            Programmability:
                programmable
                Program present
        Unknown:
    Mileage: 22180 km
Backup
    Control unit: 03 Brakes 1
    System description: ESC
    Software number: 8S0907379B
    Software version: 0504
    Hardware number: 8S0907379B
    Hardware version: H31
    Serial number: 61434000000141
    ODX name: EV_Brake1UDSContiMK100IPB
    ODX version: 052008
    Backup name: Brakes
    Long coding:
        32AA608D0A9915AA40950067C2939306444C0650A8020043C96022
    Adaptations:
        Tire pressure monitoring display:
            Warning thresholds, tire pressure monitoring system:
        Roller test bench mode:
                Manual activation, possible
            Status:
                activated
        Engine drag torque control:
                activated
        Activating and deactivating all development messages:
        Counter steer support:
                Weak
        Brake prefill:
            Brake prefill:
                activated
        Hydraulic brake assistant:
                activated
        Brake disk drying:
            Brake disk drying:
                medium
        Hill-start assistant:
                normal
        Brake pedal evaluation:
                activated
        Seat belt buckle scan:
                activated
        Dynamic starting assist:
                normal
        Driver door status:
            Driver door status:
                activated
        Automatic application during engine stalling:
                activated
        AUTO HOLD functionality:
                activated
        AUTO HOLD increase threshold, reduced tensioning force:
                0 %
        AUTO HOLD increase threshold, full tensioning force:
                10 %
        Developer_Function_1:
        Developer_Function_2:
                Access authorization required, perform Login
        Monitoring of functional lights:
            Indicator light in the button for electromech. parking brake:
                7
            Indicator light in AUTO HOLD button:
                7
                Not activated
        Overboost in brake system:
                activated
        Electromechanical parking brake, delay level:
                6
        Electromechanical parking brake:
            Automatic application:
                Not activated
            Driver presence recognition via brake pedal:
                Not activated
        Tire pressure monitoring display, tire selection:
        Developer_Function_3:
        Developer_Function_100:
        Developer_Function_102:
        AUTO HOLD slippage recognition:
                activated
        Expanded electronic differential lock:
                middle threshold
        Tire press. monitor. sys, position display:
                with display
        Developer_Function_110:
        fill_and_bleed_information:
            Bootloader:
            Application:
        Unknown:
    Mileage: 22180 km
Backup
    Control unit: 08 Air Conditioning
    System description: AC Automat
    Software number: 8S0820043
    Software version: 0020
    Hardware number: 8S0820043
    Hardware version: H05
    Serial number: 89300000000676
    ODX name: EV_AirCondiVAPrehAU33x
    ODX version: 003011
    Backup name: Air Conditioning
    Long coding:
        400040000011101100
    Adaptations:
        Runtime for compressor run-in basic setting:
                120 s
        Speed switch-off threshold for compressor run-in (engine speed):
                1800 1/min
        Deactivation of start-stop function:
                not active
        Stop release for start-stop function:
                According to function requirements
        Application characteristic curves:
                Matching coding
        Store recirculation air setting for terminal 15 off:
                Matching coding
        Driving program:
                Matching coding
        Window condensation reduction at high humidity:
                Matching coding
        Blower logic for manual adjustment:
                Matching coding
        Fresh air blower voltage offset:
                Default
        Temperature offset, summer operation:
                Default
        Temperature offset, winter operation:
                Default
        Ignore compressor switch-off by Engine Control Module:
                Do not ignore
        Gear ratio of engine - A/C compressor:
                0.00
        Blower voltage for voice operation:
                Not activated
        Retrofitting of parking heater without CAN:
                not installed
        Air quality sensor sensitivity:
                Little
        Time until heated seat power withdrawal stage 3 to stage 2:
                10 min
        Time until heated seat power withdrawal stage 2 to stage 1:
                0 min
        Reset all counters:
                Not activated
        Window condensation parameter for start-stop function:
                5
        A/C comfort parameter for start-stop function:
                5
        Production mode:
                Deactivating
                Deactivating
                Not activated
        Tolerance range for basic setting of flap end stops:
                15 °
        Tolerance range for flap end stops:
                10 °
        Blower voltage for production routines:
                7.0 V
        Interior target temperature for production routines:
                22 °C
        Air distribution for production routines:
                Air distribution upper body vents and footwell
        Recirculation air for production routines:
                Recirculating air
        Klima_OBD_activate:
                Not activated
        Klima_EW_IDs_activate:
                Not activated
        Analysis 9:
                Not activated
        Behavior of compressor during moderate outside temperatures:
                not active
        OBD_channel:
            Bootloader:
            Application:
            Application 2:
            Bootloader:
            Application:
            Application 2:
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                PRE-010
            Day of manufacture:
                26.05.14
                0001
                0045
            Decoration variant:
                007
                000
        Diagnostic mode:
                8S0820043
        Software version:
                0020
                8S0820043
        System description:
                AC Automat
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                003011
        Hardware version:
                H05
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                E87
            Bootloader:
                X300
            Application:
                0020
            Application 2:
                0020
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 09 Central Electrics
    System description: BCM MQBAB H
    Software number: 5Q0937084BR
    Software version: 0138
    Hardware number: 5Q0937084AJ
    Hardware version: H18
    Serial number: 01011419703223
    ODX name: EV_BCMCONTI
    ODX version: 013000
    Backup name: Central Electrics
    Long coding:
        04055D46C20106FD43044004001807A80080000000000000000000000000
    Adaptations:
        Driving light and parking light:
            Kontrollleuchte fuer Begrenzungslicht:
                separate
            Schlusslicht mit Bremslichtfunktion:
                active
            Standlicht aus:
                active
            Parklicht ueber LSS aktiviert:
                One-sided
            Standlichtreduzierung mit beidseitigem Parklicht:
                active
            Zahl der aktiven Scheinwerfer auf 2 limitieren:
                in Betrieb lassen
            Warnung Fahrt mit Standlicht:
                active
            Zeitwert Einschaltzeit Abbiegelicht:
                15 min
            Lichthupe bei Zuendung aus moeglich:
                not active
            Lichtwarnungsverhalten:
                klemmenabhaengig
            Menueeinstellung CHO LHO:
                Menuesteuerung aktivieren
            Allwetterlicht Einschaltgrenze:
                350 km/h
            Allwetterlicht Ausschaltgrenze:
                350 km/h
            Nebelschlusslicht Warngeschwindigkeit:
                60 km/h
        Transport mode:
                active
        Read parameter address:
                not active
        Auxiliary functions:
            Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT:
                not active
            Spoiler Einfahrunterdrueckung nach manuellem Ausfahren:
                not active
            Reserved_1:
                not active
            Signalhorn ohne KL15:
                not active
            Klemmenfehler auf CAN ausgeben:
                active
            reserved_2:
                not active
        Anti-theft device:
            Alarmsignal:
                frequency modulated
            Verzoegerung Panikalarm:
                keine verzoegerung
            DWA Alarmverzoegerung:
                driver door contact thatcham
            DWA Camper Modus:
                not active
            Ueberwachung Innenentriegelungshebel:
                not active
            Sirenen Alarmzahl:
                1 Alarm
            Akustischer Alarm Signalhorn:
                not active
        Acknowledgement signals:
            Akustische Rueckmeldung entriegeln:
                active
            Akustische Rueckmeldung verriegeln:
                active
            Dauer der Akustischen Rueckmeldung vom Einfachhorn:
                kurz
            Optical feedback during locking:
                Decelerate
            Optische Rueckmeldung Komfortschliessen:
                active
            Optische Rueckmeldung 3.Bremsleuchte:
                not active
            Menuesteuerung akustische Rueckmeldung:
                active
            Akustische Rueckmeldung global:
                active
            Akustische Rueckmeldung Signalhorn:
                active
        Access control 2:
            Komfortbedienung global:
                active
            Comfort opening:
                active
            Comfort closing:
                active
            Komfortoeffnen nur FH Fahrertuer:
                not active
            Nachsaven_nach_Verdecklauf:
                not active
            Funk Komfort schliessen:
                active
            Funk Komfort oeffnen:
                active
            Reserved_4:
                not active
            Schliesszylinder Komfort schliessen:
                active
            SAD Richtung Komfortoeffnen:
                tilting
            SAD Komfort schliessen:
                active
            SAD Komfort oeffnen:
                active
            Freigabenachlauf FH bei Kl 15 aus:
                active
            Freigabenachlauf FH bei Tueroeffnen abbrechen:
                active
            Regenschliessen_ein_aus:
                not active
            Regenschliessen_art:
                once
            Spiegelabsenkung bei Rueckwaertsfahrt:
                active
            Spiegelverstellung Synchron:
                not active
            Kessy Komfort oeffnen:
                active
            Kessy Komfort schliessen:
                active
            Kessy Komfortbedienung Reichweitenbegrenzung:
                active
            Menuesteuerung Spiegelabsenkung:
                active
            Funk Spiegelanklappen:
                not active
            Funk Spiegelanklappung Modus:
                by look command via remote control key
            Menuesteuerung synchrone Spiegelverstellung:
                not active
            Menuesteuerung Funk Spiegel anklappen:
                not active
            Menuesteuerung Komfortbedienung einstellbar:
                adjustable
            Menuesteuerung Regenschliessen:
                not active
            SAD PreCrash Konturschliessen:
                active
            FH SAD Kl15Aus Freigabezeit:
                600 s
            Fahrertuerbedienung Fensterheber oeffnen:
                not active
            Fahrertuerbedienung Fensterheber schliessen:
                not active
            Remote_Unlock_Lock:
                not active
            Profilfunktion fuer Anklappung der Aussenspiegel:
                not active
            Signalisierung_Spiegelanklappung:
                active
            virtuelles_pedal:
                not active
            virtuelles_pedal_HMI_einstellbar:
                not active
            Schliesszylinder Komfort oeffnen:
                active
        Access control:
            Funk bei Klemme 15 ein:
                not active
            Notschliessfunktion:
                not active
            Automatisches Verriegeln bei Geschwindigkeit:
                active
            automatisches Entriegeln:
                active
            Geschwindigkeitsabhaengige Tankdeckelverriegelung:
                not active
            ZV Tuerentriegelung:
                Globale Entriegelung
            CAN Wecken bei Softtouchbetaetigung:
                not active
            Wiederoeffnung Elektrische-Schiebetuer:
                not active
            Oeffnung Heckdeckel bei Wiederentriegelung:
                not active
            Heckdeckel-Bedienstellen nachCrash temporaer sperren:
                active
            Valet parking:
                not active
            Direkter Auswurf des Heckdeckels:
                active
            ZV entriegelt auch Heckdeckel:
                active
            Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt:
                active
            Autolock Autounlock wirkt auf Heck:
                active
            ZV Heck nur direkt auswerfen:
                not active
            Manuelle ZV Variantenprogrammierung:
                not active
            Wiederholte Heckansteuerung beim Schliessen FT oder BT:
                not active
            Schliessung der Schiebetuer bei geoeffneter Tankklappe:
                not active
            Bewusstes Safe mit 2. Betaetigung der FFB:
                not active
            ZV-Entriegelung nach Seitencrash:
                active
            Entsafen mit autorisierte Klemme 15 Ein:
                not active
            Elektrische Laderaumabdeckung:
                not active
            Menuesteuerung Tuerentriegelung:
                active
            Menuesteuerung ZV Autolock-Unlock:
                adjustable
            Autounlock NAR:
                not active
            Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster:
                not active
            Softtouch-Betaetigung senden:
                nur wenn freigegeben
            Servoheck Schlossansteuerung:
                immer
            Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster:
                active
            Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang:
                not active
            Vorrastenhaenger_Freigabe:
                not active
        Windshield wiper:
            Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung:
                20
            SRA Verzoegerungszeit:
                1000 ms
            SRA Waschzeit:
                700 ms
            SRA Einweichpausenzeit:
                900 ms
            SRA Nachwaschzeit:
                1100 ms
            SRA Pausenzeit:
                1000 ms
            SRA bei Waschwassermangel:
                active
            Frontwischer Referenzlauf:
                not active
            Variable Regensensoraktivierung:
                not active
            Wischer stop bei KL15 aus:
                not active
            Wischer abparken bei Oeffnen der Motorhaube:
                not active
            Regensensor aktivieren:
                Deactivating
            Menuesteuerung Frontwischer:
                active
            Frontwischer Notlaufprogramm:
                active
            Tippwischen mit erhoehter Wischfrequenz:
                active
            Geschwindigkeitsabhaengige Wischstufenrueckschaltung:
                active
            Traenenwischen Front Status:
                active
            Washer_Tipwiping_Variant:
            Adaptives Nachwischen bei SRA:
                active
            Wischer Stopp bei Oeffnen der Motorhaube:
                active
        Turn signal control:
            Warnblinken bei Verdeckentriegelung:
                not active
            Komfortblinken Blinkzyklen:
                5
            Sonderfunktionen:
                not enabled
            Signalprioritaet fuer Blinker:
                SMLS
            Blinkkontrolleuchte fuer Anhaenger:
                separte
            Warnblinktastersuchbeleuchtung Aktivierung:
                always active
            Komfortblinken:
                active
            Warnblinktastersuchbeleuchtung Grundwert:
                1.00 %
            Warnblinktastersuchbeleuchtung Faktor:
                0.25
        Production mode:
            Scheinwerferreinigung:
                not active
            Frontwischer deaktivieren:
                not active
            Heckwischer:
                not active
            Innenbeleuchtung:
                not active
            Aussenbeleuchtung:
                not active
            Zugangskontrolle:
                not active
            Virtuel_pedal:
                not active
        Light configuration:
            Lasttyp 0:
                33 - LED-Modul Blinkleuchten
            BAP Bitposition 0:
                34
            Reserved 0:
            Fehlerort mittleres Byte DTC-DFCC 0:
                14
            Lichtfunktion A 0:
            Lichtfunktion B 0:
            Dimmwert AB 0:
                127
            Lichtansteuerung HD AB 0:
                always
            Lichtfunktion C 0:
                3
            Lichtfunktion D 0:
            Dimmwert CD 0:
            Dimming Direction CD 0:
                maximize
            Lichtfunktion E 0:
            Lichtfunktion F 0:
            Dimmwert EF 0:
            Dimming Direction EF 0:
                maximize
            Lichtfunktion G 0:
            Lichtfunktion H 0:
            Dimmwert GH 0:
            Dimming Direction GH 0:
                maximize
            Lasttyp 1:
            BAP Bitposition 1:
                3e
            Reserved 1:
            Fehlerort mittleres Byte DTC-DFCC 1:
                15
            Lichtfunktion A 1:
                4
            Lichtfunktion B 1:
            Dimmwert AB 1:
                127
            Lichtansteuerung HD AB 1:
                always
            Lichtfunktion C 1:
                5
            Lichtfunktion D 1:
            Dimmwert CD 1:
            Dimming Direction CD 1:
                maximize
            Lichtfunktion E 1:
            Lichtfunktion F 1:
            Dimmwert EF 1:
            Dimming Direction EF 1:
                maximize
            Lichtfunktion G 1:
            Lichtfunktion H 1:
            Dimmwert GH 1:
            Dimming Direction GH 1:
                maximize
            Lasttyp 2:
                4 - LED Tagfahrlichtmodul Signal
            BAP Bitposition 2:
                48
            Reserved 2:
            Fehlerort mittleres Byte DTC-DFCC 2:
                4a
            Lichtfunktion A 2:
                8
            Lichtfunktion B 2:
                9
            Dimmwert AB 2:
                28
            Lichtansteuerung HD AB 2:
                always
            Lichtfunktion C 2:
                30
            Lichtfunktion D 2:
            Dimmwert CD 2:
                28
            Dimming Direction CD 2:
                maximize
            Lichtfunktion E 2:
                20
            Lichtfunktion F 2:
            Dimmwert EF 2:
                100
            Dimming Direction EF 2:
                maximize
            Lichtfunktion G 2:
                6
            Lichtfunktion H 2:
            Dimmwert GH 2:
            Dimming Direction GH 2:
                minimize
            Lasttyp 3:
            BAP Bitposition 3:
                4c
            Reserved 3:
            Fehlerort mittleres Byte DTC-DFCC 3:
                4c
            Lichtfunktion A 3:
                8
            Lichtfunktion B 3:
                10
            Dimmwert AB 3:
                28
            Lichtansteuerung HD AB 3:
                always
            Lichtfunktion C 3:
                30
            Lichtfunktion D 3:
            Dimmwert CD 3:
                28
            Dimming Direction CD 3:
                maximize
            Lichtfunktion E 3:
                20
            Lichtfunktion F3:
            Dimmwert EF 3:
                100
            Dimming Direction EF 3:
                maximize
            Lichtfunktion G 3:
                7
            Lichtfunktion H 3:
            Dimmwert GH 3:
            Dimming Direction GH 3:
                minimize
            Lasttyp 4:
                1 - LED Tagfahrlichtmodul Versorgung
            BAP Bitposition 4:
                48
            Reserved 4:
            Fehlerort mittleres Byte DTC-DFCC 4:
                49
            Lichtfunktion A 4:
                20
            Lichtfunktion B 4:
                8
            Dimmwert AB 4:
                127
            Lichtansteuerung HD AB 4:
                always
            Lichtfunktion C 4:
                30
            Lichtfunktion D 4:
                9
            Dimmwert CD 4:
                127
            Dimming Direction CD 4:
                maximize
            Lichtfunktion E 4:
            Lichtfunktion F 4:
            Dimmwert EF 4:
            Dimming Direction EF 4:
                maximize
            Lichtfunktion G 4:
                6
            Lichtfunktion H 4:
            Dimmwert GH 4:
            Dimming Direction GH 4:
                minimize
            Lasttyp 5:
            BAP Bitposition 5:
                4c
            Reserved 5:
            Fehlerort mittleres Byte DTC-DFCC 5:
                4b
            Lichtfunktion A 5:
                20
            Lichtfunktion B 5:
                8
            Dimmwert AB 5:
                127
            Lichtansteuerung HD AB 5:
                always
            Lichtfunktion C 5:
                30
            Lichtfunktion D 5:
                10
            Dimmwert CD 5:
                127
            Dimming Direction CD 5:
                maximize
            Lichtfunktion E 5:
            Lichtfunktion F5:
            Dimmwert EF 5:
            Dimming Direction EF 5:
                maximize
            Lichtfunktion G 5:
                7
            Lichtfunktion H 5:
            Dimmwert GH 5:
            Dimming Direction GH 5:
                minimize
            Lasttyp 6:
                5 - LED Abblendlicht
            BAP Bitposition 6:
                36
            Reserved 6:
            Fehlerort mittleres Byte DTC-DFCC 6:
                1a
            Lichtfunktion A 6:
                11
            Lichtfunktion B 6:
            Dimmwert AB 6:
                127
            Lichtansteuerung HD AB 6:
                always
            Lichtfunktion C 6:
                30
            Lichtfunktion D 6:
            Dimmwert CD 6:
                127
            Dimming Direction CD 6:
                maximize
            Lichtfunktion E 6:
            Lichtfunktion F 6:
            Dimmwert EF 6:
            Dimming Direction EF 6:
                maximize
            Lichtfunktion G 6:
            Lichtfunktion H 6:
            Dimmwert GH 6:
            Dimming Direction GH 6:
                maximize
            Lasttyp 7:
            BAP Bitposition 7:
                40
            Reserved 7:
            Fehlerort mittleres Byte DTC-DFCC 7:
                1b
            Lichtfunktion A 7:
                12
            Lichtfunktion B 7:
            Dimmwert AB 7:
                127
            Lichtansteuerung HD AB 7:
                always
            Lichtfunktion C 7:
                30
            Lichtfunktion D 7:
            Dimmwert CD 7:
                127
            Dimming Direction CD 7:
                maximize
            Lichtfunktion E 7:
            Lichtfunktion F 7:
            Dimmwert EF 7:
            Dimming Direction EF 7:
                maximize
            Lichtfunktion G 7:
            Lichtfunktion H 7:
            Dimmwert GH 7:
            Dimming Direction GH 7:
                maximize
            Lasttyp 8:
            BAP Bitposition 8:
                36
            Reserved 8:
            Fehlerort mittleres Byte DTC-DFCC 8:
                5d
            Lichtfunktion A 8:
                40
            Lichtfunktion B 8:
            Dimmwert AB 8:
                127
            Lichtansteuerung HD AB 8:
                always
            Lichtfunktion C 8:
                30
            Lichtfunktion D 8:
            Dimmwert CD 8:
                127
            Dimming Direction CD 8:
                maximize
            Lichtfunktion E 8:
            Lichtfunktion F 8:
            Dimmwert EF 8:
            Dimming Direction EF 8:
                maximize
            Lichtfunktion G 8:
            Lichtfunktion H 8:
            Dimmwert GH 8:
            Dimming Direction GH 8:
                maximize
            Lasttyp 9:
            BAP Bitposition 9:
                40
            Reserved 9:
            Fehlerort mittleres Byte DTC-DFCC 9:
                5e
            Lichtfunktion A 9:
                40
            Lichtfunktion B 9:
            Dimmwert AB 9:
                127
            Lichtansteuerung HD AB 9:
                always
            Lichtfunktion C 9:
                30
            Lichtfunktion D 9:
            Dimmwert CD 9:
                127
            Dimming Direction CD 9:
                maximize
            Lichtfunktion E 9:
            Lichtfunktion F 9:
            Dimmwert EF 9:
            Dimming Direction EF 9:
                maximize
            Lichtfunktion G 9:
            Lichtfunktion H 9:
            Dimmwert GH 9:
            Dimming Direction GH 9:
                maximize
            Lasttyp 10:
                not active
            BAP Bitposition 10:
            Reserved 10:
            Fehlerort mittleres Byte DTC-DFCC 10:
            Lichtfunktion A 10:
            Lichtfunktion B 10:
            Dimmwert AB 10:
            Lichtansteuerung HD AB 10:
                always
            Lichtfunktion C 10:
            Lichtfunktion D 10:
            Dimmwert CD 10:
            Dimming Direction CD 10:
                maximize
            Lichtfunktion E 10:
            Lichtfunktion F 10:
            Dimmwert EF 10:
            Dimming Direction EF 10:
                maximize
            Lichtfunktion G 10:
            Lichtfunktion H 10:
            Dimmwert GH 10:
            Dimming Direction GH 10:
                maximize
            Lasttyp 11:
                2 - Shutter, Diagnosesensierung für 'LED low'
            BAP Bitposition 11:
            Reserved 11:
            Fehlerort mittleres Byte DTC-DFCC 11:
                62
            Lichtfunktion A 11:
                63
            Lichtfunktion B 11:
            Dimmwert AB 11:
                127
            Lichtansteuerung HD AB 11:
                always
            Lichtfunktion C 11:
            Lichtfunktion D 11:
            Dimmwert CD 11:
            Dimming Direction CD 11:
                maximize
            Lichtfunktion E 11:
            Lichtfunktion F 11:
            Dimmwert EF 11:
            Dimming Direction EF 11:
                maximize
            Lichtfunktion G 11:
            Lichtfunktion H 11:
            Dimmwert GH 11:
            Dimming Direction GH 11:
                maximize
            Lasttyp 12:
                not active
            BAP Bitposition 12:
            Reserved 12:
            Fehlerort mittleres Byte DTC-DFCC 12:
            Lichtfunktion A 12:
            Lichtfunktion B 12:
            Dimmwert AB 12:
            Lichtansteuerung HD AB 12:
                always
            Lichtfunktion C 12:
            Lichtfunktion D 12:
            Dimmwert CD 12:
            Dimming Direction CD 12:
                maximize
            Lichtfunktion E 12:
            Lichtfunktion F 12:
            Dimmwert EF 12:
            Dimming Direction EF 12:
                maximize
            Lichtfunktion G 12:
            Lichtfunktion H 12:
            Dimmwert GH 12:
            Dimming Direction GH 12:
                maximize
            Lasttyp 13:
                not active
            BAP Bitposition 13:
            Reserved 13:
            Fehlerort mittleres Byte DTC-DFCC 13:
            Lichtfunktion A 13:
            Lichtfunktion B 13:
            Dimmwert AB 13:
            Lichtansteuerung HD AB 13:
                always
            Lichtfunktion  C 13:
            Lichtfunktion D 13:
            Dimmwert CD 13:
            Dimming Direction CD 13:
                maximize
            Lichtfunktion E 13:
            Lichtfunktion F 13:
            Dimmwert EF 13:
            Dimming Direction EF 13:
                maximize
            Lichtfunktion G 13:
            Lichtfunktion H 13:
            Dimmwert GH 13:
            Dimming Direction GH 13:
                maximize
            Lasttyp 14:
                not active
            BAP Bitposition 14:
            Reserved 14:
            Fehlerort mittleres Byte DTC-DFCC 14:
            Lichtfunktion A 14:
            Lichtfunktion B 14:
            Dimmwert AB 14:
            Lichtansteuerung HD AB 14:
                always
            Lichtfunktion C 14:
            Lichtfunktion D 14:
            Dimmwert CD 14:
            Dimming Direction CD 14:
                maximize
            Lichtfunktion E 14:
            Lichtfunktion F 14:
            Dimmwert EF 14:
            Dimming Direction EF 14:
                maximize
            Lichtfunktion G 14:
            Lichtfunktion H 14:
            Dimmwert GH 14:
            Dimming Direction GH 14:
                maximize
            Lasttyp 15:
                not active
            BAP Bitposition 15:
            Reserved 15:
            Fehlerort mittleres Byte DTC-DFCC 15:
            Lichtfunktion A 15:
            Lichtfunktion B 15:
            Dimmwert AB 15:
            Lichtansteuerung HD AB 15:
                always
            Lichtfunktion C 15:
            Lichtfunktion D 15:
            Dimmwert CD 15:
            Dimming Direction CD 15:
                maximize
            Lichtfunktion E 15:
            Lichtfunktion F 15:
            Dimmwert EF 15:
            Dimming Direction EF 15:
                maximize
            Lichtfunktion G 15:
            Lichtfunktion H 15:
            Dimmwert GH 15:
            Dimming Direction GH 15:
                maximize
            Lasttyp 16:
                36 - LED Kleinleistung
            BAP Bitposition 16:
            Reserved 16:
            Fehlerort mittleres Byte DTC-DFCC 16:
                b
            Lichtfunktion A 16:
                42
            Lichtfunktion B 16:
            Dimmwert AB 16:
                100
            Lichtansteuerung HD AB 16:
                always
            Lichtfunktion C 16:
            Lichtfunktion D 16:
            Dimmwert CD 16:
            Dimming Direction CD 16:
                maximize
            Lichtfunktion E 16:
            Lichtfunktion F 16:
            Dimmwert EF 16:
            Dimming Direction EF 16:
                maximize
            Lichtfunktion G 16:
            Lichtfunktion H 16:
            Dimmwert GH 16:
            Dimming Direction GH 16:
                maximize
            Lasttyp 17:
                46 - LED Kleinleistung
            BAP Bitposition 17:
            Reserved 17:
            Fehlerort mittleres Byte DTC-DFCC 17:
                4
            Lichtfunktion A 17:
                46
            Lichtfunktion  B 17:
            Dimmwert AB 17:
                100
            Lichtansteuerung HD AB 17:
                always
            Lichtfunktion C 17:
            Lichtfunktion D 17:
            Dimmwert CD 17:
            Dimming Direction CD 17:
                maximize
            Lichtfunktion E 17:
            Lichtfunktion F 17:
            Dimmwert EF 17:
            Dimming Direction EF 17:
                maximize
            Lichtfunktion G 17:
            Lichtfunktion H 17:
            Dimmwert GH 17:
            Dimming Direction GH 17:
                maximize
            Lasttyp 18:
            BAP Bitposition 18:
                8
            Reserved 18:
            Fehlerort mittleres Byte DTC-DFCC 18:
                16
            Lichtfunktion A 18:
            Lichtfunktion B 18:
            Dimmwert AB 18:
                127
            Lichtansteuerung HD AB 18:
                always
            Lichtfunktion C 18:
                3
            Lichtfunktion D 18:
            Dimmwert CD 18:
            Dimming Direction CD 18:
                maximize
            Lichtfunktion E 18:
            Lichtfunktion F 18:
            Dimmwert EF 18:
            Dimming Direction EF 18:
                maximize
            Lichtfunktion G 18:
            Lichtfunktion H 18:
            Dimmwert GH 18:
            Dimming Direction GH 18:
                maximize
            Lasttyp 19:
            BAP Bitposition 19:
                18
            Reserved 19:
            Fehlerort mittleres Byte DTC-DFCC 19:
                18
            Lichtfunktion A 19:
                4
            Lichtfunktion B 19:
            Dimmwert AB 19:
                127
            Lichtansteuerung HD AB 19:
                always
            Lichtfunktion C 19:
                5
            Lichtfunktion D 19:
            Dimmwert CD 19:
            Dimming Direction CD 19:
                maximize
            Lichtfunktion E 19:
            Lichtfunktion F 19:
            Dimmwert EF 19:
            Dimming Direction EF 19:
                maximize
            Lichtfunktion G 19:
            Lichtfunktion H 19:
            Dimmwert GH 19:
            Dimming Direction GH 19:
                maximize
            Lasttyp 20:
                34 - LED Bremsleuchten
            BAP Bitposition 20:
                9
            Reserved 20:
            Fehlerort mittleres Byte DTC-DFCC 20:
                2b
            Lichtfunktion A 20:
                24
            Lichtfunktion B 20:
            Dimmwert AB 20:
                127
            Lichtansteuerung HD AB 20:
                always
            Lichtfunktion C 20:
            Lichtfunktion D 20:
            Dimmwert CD 20:
            Dimming Direction CD 20:
                maximize
            Lichtfunktion E 20:
            Lichtfunktion F 20:
            Dimmwert EF 20:
            Dimming Direction EF 20:
                maximize
            Lichtfunktion G 20:
            Lichtfunktion H 20:
            Dimmwert GH 20:
            Dimming Direction GH 20:
                maximize
            Lasttyp 21:
            BAP Bitposition 21:
                19
            Reserved 21:
            Fehlerort mittleres Byte DTC-DFCC 21:
                2d
            Lichtfunktion A 21:
                24
            Lichtfunktion B 21:
            Dimmwert AB 21:
                127
            Lichtansteuerung HD AB 21:
                always
            Lichtfunktion C 21:
            Lichtfunktion D 21:
            Dimmwert CD 21:
            Dimming Direction CD 21:
                maximize
            Lichtfunktion E 21:
            Lichtfunktion F 21:
            Dimmwert EF 21:
            Dimming Direction EF 21:
                maximize
            Lichtfunktion G 21:
            Lichtfunktion H 21:
            Dimmwert GH 21:
            Dimming Direction GH 21:
                maximize
            Lasttyp 22:
                42 - LED dritte Bremsleuchte
            BAP Bitposition 22:
                29
            Reserved 22:
            Fehlerort mittleres Byte DTC-DFCC 22:
                2c
            Lichtfunktion A 22:
                24
            Lichtfunktion B 22:
            Dimmwert AB 22:
                100
            Lichtansteuerung HD AB 22:
                always
            Lichtfunktion C 22:
            Lichtfunktion D 22:
            Dimmwert CD 22:
            Dimming Direction CD 22:
                maximize
            Lichtfunktion E 22:
            Lichtfunktion F 22:
            Dimmwert EF 22:
            Dimming Direction EF 22:
                maximize
            Lichtfunktion G 22:
            Lichtfunktion H 22:
            Dimmwert GH 22:
            Dimming Direction GH 22:
                maximize
            Lasttyp 23:
                40 - allgemeine LED
            BAP Bitposition 23:
                a
            Reserved 23:
            Fehlerort mittleres Byte DTC-DFCC 23:
                29
            Lichtfunktion A 23:
                8
            Lichtfunktion B 23:
                30
            Dimmwert AB 23:
                100
            Lichtansteuerung HD AB 23:
                always
            Lichtfunktion C 23:
                9
            Lichtfunktion D 23:
            Dimmwert CD 23:
                100
            Dimming Direction CD 23:
                maximize
            Lichtfunktion E 23:
                20
            Lichtfunktion F 23:
            Dimmwert EF 23:
                100
            Dimming Direction EF 23:
                maximize
            Lichtfunktion G 23:
            Lichtfunktion H 23:
            Dimmwert GH 23:
            Dimming Direction GH 23:
                maximize
            Lasttyp 24:
                40 - allgemeine LED
            BAP Bitposition 24:
                1a
            Reserved 24:
            Fehlerort mittleres Byte DTC-DFCC 24:
                2a
            Lichtfunktion A 24:
                8
            Lichtfunktion B 24:
                30
            Dimmwert AB 24:
                100
            Lichtansteuerung HD AB 24:
                always
            Lichtfunktion C 24:
                10
            Lichtfunktion D 24:
            Dimmwert CD 24:
                100
            Dimming Direction CD 24:
                maximize
            Lichtfunktion E 24:
                20
            Lichtfunktion F 24:
            Dimmwert EF 24:
                100
            Dimming Direction EF 24:
                maximize
            Lichtfunktion G 24:
            Lichtfunktion H 24:
            Dimmwert GH 24:
            Dimming Direction GH 24:
                maximize
            Lasttyp 25:
                43 - allgemeine LED
            BAP Bitposition 25:
                28
            Reserved 25:
            Fehlerort mittleres Byte DTC-DFCC 25:
                30
            Lichtfunktion A 25:
                8
            Lichtfunktion B 25:
                30
            Dimmwert AB 25:
                100
            Lichtansteuerung HD AB 25:
                always
            Lichtfunktion C 25:
                20
            Lichtfunktion D 25:
            Dimmwert CD 25:
                100
            Dimming Direction CD 25:
                maximize
            Lichtfunktion E 25:
            Lichtfunktion F 25:
            Dimmwert EF 25:
            Dimming Direction EF 25:
                maximize
            Lichtfunktion G 25:
            Lichtfunktion H 25:
            Dimmwert GH 25:
            Dimming Direction GH 25:
                maximize
            Lasttyp 26:
                43 - allgemeine LED
            BAP Bitposition 26:
                c
            Reserved 26:
            Fehlerort mittleres Byte DTC-DFCC 26:
                2e
            Lichtfunktion A 26:
                24
            Lichtfunktion B 26:
            Dimmwert AB 26:
                60
            Lichtansteuerung HD AB 26:
                always
            Lichtfunktion C 26:
            Lichtfunktion D 26:
            Dimmwert CD 26:
            Dimming Direction CD 26:
                maximize
            Lichtfunktion E 26:
                26
            Lichtfunktion F 26:
            Dimmwert EF 26:
                100
            Dimming Direction EF 26:
                maximize
            Lichtfunktion G 26:
            Lichtfunktion H 26:
            Dimmwert GH 26:
            Dimming Direction GH 26:
                maximize
            Lasttyp 27:
                43 - allgemeine LED
            BAP Bitposition 27:
                1c
            Reserved 27:
            Fehlerort mittleres Byte DTC-DFCC 27:
                2f
            Lichtfunktion A 27:
                24
            Lichtfunktion B 27:
            Dimmwert AB 27:
                60
            Lichtansteuerung HD AB 27:
                always
            Lichtfunktion C 27:
            Lichtfunktion D 27:
            Dimmwert CD 27:
            Dimming Direction CD 27:
                maximize
            Lichtfunktion E 27:
                26
            Lichtfunktion F 27:
            Dimmwert EF 27:
                100
            Dimming Direction EF 27:
                maximize
            Lichtfunktion G 27:
            Lichtfunktion H 27:
            Dimmwert GH 27:
            Dimming Direction GH 27:
                maximize
            Lasttyp 28:
                40 - allgemeine LED
            BAP Bitposition 28:
                b
            Reserved 28:
            Fehlerort mittleres Byte DTC-DFCC 28:
                31
            Lichtfunktion A 28:
                25
            Lichtfunktion B 28:
            Dimmwert AB 28:
                100
            Lichtansteuerung HD AB 28:
                always
            Lichtfunktion C 28:
            Lichtfunktion D 28:
            Dimmwert CD 28:
            Dimming Direction CD 28:
                maximize
            Lichtfunktion E 28:
            Lichtfunktion F 28:
            Dimmwert EF 28:
            Dimming Direction EF 28:
                maximize
            Lichtfunktion G 28:
            Lichtfunktion H 28:
            Dimmwert GH 28:
            Dimming Direction GH 28:
                maximize
            Lasttyp 29:
                40 - allgemeine LED
            BAP Bitposition 29:
                1b
            Reserved 29:
            Fehlerort mittleres Byte DTC-DFCC 29:
                32
            Lichtfunktion A 29:
                25
            Lichtfunktion B 29:
            Dimmwert AB 29:
                100
            Lichtfunktion C 29:
            Lichtansteuerung HD AB 29:
                always
            Lichtfunktion D 29:
            Dimmwert CD 29:
            Dimming Direction CD 29:
                maximize
            Lichtfunktion E 29:
            Lichtfunktion F 29:
            Dimmwert EF 29:
            Dimming Direction EF 29:
                maximize
            Lichtfunktion G 29:
            Lichtfunktion H 29:
            Dimmwert GH 29:
            Dimming Direction GH 29:
                maximize
            Lasttyp 30:
            BAP Bitposition 30:
            Reserved 30:
            Fehlerort mittleres Byte DTC-DFCC 30:
            Lichtfunktion A 30:
                43
            Lichtfunktion B 30:
            Dimmwert AB 30:
                100
            Lichtansteuerung HD AB 30:
                always
            Lichtfunktion C 30:
            Lichtfunktion D 30:
            Dimmwert CD 30:
            Dimming Direction CD 30:
                maximize
            Lichtfunktion E 30:
            Lichtfunktion F 30:
            Dimmwert EF 30:
            Dimming Direction EF 30:
                maximize
            Lichtfunktion G 30:
            Lichtfunktion H 30:
            Dimmwert GH 30:
            Dimming Direction GH 30:
                maximize
            Lasttyp 31:
                not active
            BAP Bitposition 31:
            Reserved 31:
            Fehlerort mittleres Byte DTC-DFCC 31:
                3
            Lichtfunktion A 31:
                45
            Lichtfunktion B 31:
            Dimmwert AB 31:
                100
            Lichtansteuerung HD AB 31:
                always
            Lichtfunktion C 31:
            Lichtfunktion D 31:
            Dimmwert CD 31:
            Dimming Direction CD 31:
                maximize
            Lichtfunktion E 31:
            Lichtfunktion F 31:
            Dimmwert EF 31:
            Dimming Direction EF 31:
                maximize
            Lichtfunktion G 31:
            Lichtfunktion H 31:
            Dimmwert GH 31:
            Dimming Direction GH 31:
                maximize
            Lasttyp 32:
                not active
            BAP Bitposition 32:
            Reserved 32:
            Fehlerort mittleres Byte DTC-DFCC 32:
                4
            Lichtfunktion A 32:
                46
            Lichtfunktion B 32:
            Dimmwert AB 32:
                100
            Lichtansteuerung HD AB 32:
                always
            Lichtfunktion C 32:
            Lichtfunktion D 32:
            Dimmwert CD 32:
            Dimming Direction CD 32:
                maximize
            Lichtfunktion E 32:
            Lichtfunktion F 32:
            Dimmwert EF 32:
            Dimming Direction EF 32:
                maximize
            Lichtfunktion G 32:
            Lichtfunktion H 32:
            Dimmwert GH 32:
            Dimming Direction GH 32:
                maximize
            Lasttyp 33:
                not active
            BAP Bitposition 33:
            Reserved 33:
            Fehlerort mittleres Byte DTC-DFCC 33:
                5
            Lichtfunktion A 33:
                47
            Lichtfunktion B 33:
            Dimmwert AB 33:
                100
            Lichtansteuerung HD AB 33:
                always
            Lichtfunktion C 33:
            Lichtfunktion D 33:
            Dimmwert CD 33:
            Dimming Direction CD 33:
                maximize
            Lichtfunktion E 33:
            Lichtfunktion F 33:
            Dimmwert EF 33:
            Dimming Direction EF 33:
                maximize
            Lichtfunktion G 33:
            Lichtfunktion H 33:
            Dimmwert GH 33:
            Dimming Direction GH 33:
                maximize
            Lasttyp 34:
                not active
            BAP Bitposition 34:
            Reserved 34:
            Fehlerort mittleres Byte DTC-DFCC 34:
                6
            Lichtfunktion A 34:
                48
            Lichtfunktion B 34:
            Dimmwert AB 34:
                100
            Lichtansteuerung HD AB 34:
                always
            Lichtfunktion C 34:
            Lichtfunktion D 34:
            Dimmwert CD 34:
            Dimming Direction CD 34:
                maximize
            Lichtfunktion E 34:
            Lichtfunktion F 34:
            Dimmwert EF 34:
            Dimming Direction EF 34:
                maximize
            Lichtfunktion G 34:
            Lichtfunktion H 34:
            Dimmwert GH 34:
            Dimming Direction GH 34:
                maximize
        Comfort illumination:
            Coming Home Verbaustatus:
                automatic
            Menuesteuerung Coming Home Werkseinstellung:
                active
            Menueeinstellung Cominghome:
                20 seconds
            Coming home Leuchten:
                Low beam
            Coming-home Einschaltereignis:
                driver door
            Helligkeitsschwelle Infrarot-Messung:
                12 lx
            Leaving-Home Verbausstatus:
                Enabled
            Menuesteuerung Leaving-home Freischaltung per BAP:
                active
            Menueeinstellung Leaving-home Zeit per BAP:
                60 seconds
            Helligkeitsschwelle Forward-Messung:
                6400 lx
        Seat heater level current consumption allocation:
            Sitzheizung Stufe 1 untere Schaltschwelle:
                18.00 °C
            Sitzheizung Stufe 1 obere Schaltschwelle:
                20.00 °C
            Sitzheizung Stufe 2 untere Schaltschwelle:
                18.00 °C
            Sitzheizung Stufe 2 obere Schaltschwelle:
                20.00 °C
            Sitzheizung Stufe 3 untere Schaltschwelle:
                26.00 °C
            Sitzheizung Stufe 3 obere Schaltschwelle:
                28.00 °C
            Sitzheizung Stufe 4 untere Schaltschwelle:
                26.00 °C
            Sitzheizung Stufe 4 obere Schaltschwelle:
                28.00 °C
            Sitzheizung Stufe 5 untere Schaltschwelle:
                34.00 °C
            Sitzheizung Stufe 5 obere Schaltschwelle:
                36.00 °C
            Sitzheizung Stufe 6 untere Schaltschwelle:
                34.00 °C
            Sitzheizung Stufe 6 obere Schaltschwelle:
                36.00 °C
            Sitzheizung Filterkonstante fuer Waermefluss:
                1 s
            Sitzheizung Regeltemperaturkorrektur bei Waermefluss:
                0.00 °C
        Innenbeleuchtung KL 58xs max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.00
            y1:
                100.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xt min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                6.00
            y1:
                6.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xt max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                100.00
            y1:
                100.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xd log Bus:
            x0:
                0.00 %
            x1:
                6.00 %
            x2:
                16.00 %
            x3:
                30.00 %
            x4:
                60.00 %
            x5:
                100.00 %
            y0:
                10
            y1:
                10
            y2:
                100
            y3:
                150
            y4:
                220
            y5:
                253
        Innenbeleuchtung KL 58xd max:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                200 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                16.00
            y1:
                16.00
            y2:
                100.00
            y3:
                100.00
            y4:
                100.00
        Innenbeleuchtung KL 58xs PWM:
            x0:
                0.00 %
            x1:
                50.00 %
            x2:
                100.00 %
            y0:
                0.00 %
            y1:
                50.00 %
            y2:
                100.00 %
        Innenbeleuchtung KL 58xd PWM:
            x0:
            x1:
                10
            x2:
                100
            x3:
                150
            x4:
                220
            x5:
                253
            y0:
                6.00 %
            y1:
                6.00 %
            y2:
                16.00 %
            y3:
                30.00 %
            y4:
                60.00 %
            y5:
                100.00 %
        Innenbeleuchtung KL 58xt PWM:
            x0:
                0.00 %
            x1:
                50.00 %
            x2:
                100.00 %
            y0:
                0.00 %
            y1:
                50.00 %
            y2:
                100.00 %
        Rear Window Wiper:
            Komfortwischen Heck:
                active
            Menuesteuerung Komfortwischen HW:
                not active
            Automatisches Heckwischen:
                not active
            Traenenwischen Heck:
                not active
            Heckwischer Weiterlauf:
                not active
            Kein automatisches Abparken:
                not active
            Komofortwischen Heck Intervallpausenzeit Stufe Intervall:
                5 s
            Komofortwischen Heck Intervallpausenzeit Stufe Automatik:
                5 s
            Komofortwischen Heck Intervallpausenzeit Stufe 1:
                1 s
            Komofortwischen Heck Intervallpausenzeit Stufe 2:
                0 s
        upper turn position:
                171.49 °
        lower turn position:
                42.49 °
        Position during interval mode:
                41.49 °
        Alternating park position 1:
                30.00 °
        Alternating park position 2:
                33.49 °
        Service position:
                164.00 °
        Innenbeleuchtung Tasterdimmung:
            tasterdimmung x0:
                0 ms
            tasterdimmung x1:
                2000 ms
            tasterdimmung x2:
                3000 ms
            tasterdimmung x3:
                4000 ms
            tasterdimmung x4:
                5100 ms
            tasterdimmung y0:
                1.00 %
            tasterdimmung y1:
                5.00
            tasterdimmung y2:
                15.00
            tasterdimmung y3:
                40.00
            tasterdimmung y4:
                100.00
        Innenbeleuchtung Hochdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                0.00 %
            y1:
                1.00 %
            y2:
                3.00 %
            y3:
                5.00 %
            y4:
                11.00 %
            y5:
                22.00 %
            y6:
                40.00 %
            y7:
                80.00 %
            y8:
                95.00 %
            y9:
                100.00 %
            y10:
                100.00 %
        Innenbeleuchtung Fotosensor:
            x0:
            x1:
                50
            x2:
                100
            x3:
                200
            x4:
                253
            x5:
            x6:
            x7:
            x8:
            x9:
            x10:
            y0:
                0 lx
            y1:
                50 lx
            y2:
                100 lx
            y3:
                200
            y4:
                500
            y5:
            y6:
                0 lx
            y7:
                0 lx
            y8:
                0 lx
            y9:
                0 lx
            y10:
                0 lx
        Innenbeleuchtung KL 58xs min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                50 lx
            x3:
                500 lx
            y0:
                6.00
            y1:
                6.00
            y2:
                100.00
            y3:
                100.00
        Innenbeleuchtung KL 58xd min:
            x0:
                0 lx
            x1:
                8 lx
            x2:
                220 lx
            x3:
                300 lx
            x4:
                500 lx
            y0:
                6.00
            y1:
                6.00
            y2:
                100.00
            y3:
                100.00
            y4:
                100.00
        Innenbeleuchtung Abdimmen:
            x0:
                0 ms
            x1:
                200 ms
            x2:
                400 ms
            x3:
                600 ms
            x4:
                800 ms
            x5:
                1000 ms
            x6:
                1200 ms
            x7:
                1400 ms
            x8:
                1600 ms
            x9:
                1800 ms
            x10:
                2000 ms
            y0:
                100.00 %
            y1:
                100.00 %
            y2:
                95.00 %
            y3:
                80.00 %
            y4:
                40.00 %
            y5:
                20.00 %
            y6:
                10.00 %
            y7:
                5.00 %
            y8:
                3.00 %
            y9:
                1.00 %
            y10:
                0.00 %
        Static AFS light:
                Off
            Vorschrift:
                Off
            Untere Geschwindigkeitsschwelle:
                0.00 km/h
            Obere Geschwindigkeitsschwelle:
                32.00 km/h
            Steering wheel angle, offset:
                -0.25 °
            Unterer Lenkradwinkel:
                30 °
            Oberer Lenkradwinkel:
                90 °
            Abdimmgeschwindigkeit:
                50.00 %/s
            Maximaltemperatur:
                100.00 °C
            obere Grenztemperatur:
                95.00 °C
            untere Grenztemperatur:
                80.00 °C
        Assistance light functions:
            Notbremsanzeige NBA:
                active
            Menuesteuerung Fernlichtassistent:
                Present
            Fernlichtassistent Zeitverzoegerungswert:
                800 ms
            Umfeldleuchte als Manoevrierleuchte:
                not active
            Fernlichtassistent Reset:
                not active
            Menuesteuerung Fernlichtassistent Werkseinstellung:
                Present
            Assistenzfahrlicht bei Regen:
                active
            Fahrlichtwarnung_Hinweis_Konfig:
                Hinweis_in_LDS-Stellung_Null_und_SL
            LS_Error_Ausgabe:
                active
            AFL Zeitverzoegerung:
                500 ms
            Lichtsensorempfindlichkeit:
                normal
            Fahrlicht_Hinweis_mehrfach:
                not active
        Ambient lighting:
            Defaultwert Ambienteprofil Fussraum:
                80 %
            Defaultwert Ambienteprofil Tuer:
                80 %
            Defaultwert Ambienteprofil Vorn:
                80 %
            Tuerinnengriffbeleuchtung mit I-Tafel:
                not installed
            Tuerinnengriff mit Tuertafel:
                not installed
            Innenlichtinszenierung:
                not enabled
                not active
        LuB Lichtrouter Kennlinie 1:
            x0:
                0.00 %
            x1:
                5.00 %
            x2:
                50.00 %
            x3:
                75.00 %
            x4:
                110.00
            x5:
                126.50
            y0:
                0.00 %
            y1:
                6.00 %
            y2:
                16.00 %
            y3:
                30.00 %
            y4:
                60.00 %
            y5:
                100.00 %
        Characteristics in production mode:
            Headlamp washer system:
                2000 ms
        Kopfraumheizung:
            blower_speed:
            temperature:
                -2
        Convert. top oper.:
            Komfortbedienung Verdeck global:
                active
            Komfortbedienung Verdeck oeffnen:
                active
            Komfortbedienung Verdeck schliessen:
                active
            Verdeck oeffnen via Schliesszylinder:
                active
            Verdeck schliessen via Schliesszylinder:
                active
            Verdeck oeffnen via Funkfernbedienung:
                not active
            Verdeck schliessen via Funkfernbedienung:
                not active
            Verdeck oeffnen via Kessy:
                not active
            Verdeck schliessen via Kessy:
                active
            Doppelpuls nur Verdeck:
                not active
            Verdeck mit Schiebedach:
                not active
            Heckdeckel sperren bei Verdeckbetrieb:
                not active
            Heckschloss oeffnen durch Verdeck-SG:
                not active
            Reichweitenbegrenzung fuer Servoheck schliessen:
                not active
            ZV verriegeln bei Klemme 15 Ein:
                not active
        After-run for park light:
            Bedingungen zur Beendigung des Standlichtnachlaufs:
                abschalten nach der Nachlaufzeit
            Standlicht-Nachlaufzeit:
                30 min
        Dyn. turn signal modes:
            Schluessel_Anlern_Blinken:
                active
            UGDO_ Anlern_Blinken:
                active
            ZV_Blinken_zu:
                active
            ZV_Blinken_auf:
                active
            Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken:
                active
            DWA_Schaerfungsquittung:
                active
            DWA_Alarm_Blinken:
                active
            Taxialarmblinken:
                active
            Panikblinken:
                active
            Multi_kollisions_Blinken:
                not active
            Notwarn_blinken_NBA_Phase_2:
                not active
            Richtungs_blinken_rechts:
                active
            Richtungs_blinken_links:
                active
            ABBA_Blinken:
                active
            Crashblinken:
                not active
            Warnblinken_Zuendung_EIN:
                active
            Warnblinken_Zuendung_AUS:
                active
            Emergency_alert_blinken:
                active
        Interior lighting:
            Innenlicht bei offenem Heckdeckel einschalten:
                not active
            KL30G ohne PWM:
                not active
            KL58 Einschalten mit Rampe:
                not active
            KL58 Verriegelungsausschalten:
                not active
            Lichtsensor wirkt auf Suchbeleuchtung:
                active
            Suchbeleuchtung Festwert:
                50 %
        Int. light, 2nd generation:
            Aufloesung Dimmzeit:
                0.10 s
            weicher Farbwechsel:
                not active
            Tuertafelbeleuchtung mehrfarbig:
                not active
            Instrumententafelbeleuchtung mehrfarbig:
                not active
            Cockpitbeleuchtung mehrfarbig:
                not active
            Lautsprecherbeleuchtung mehrfarbig:
                not active
            Mittelkonsolenbeleuchtung mehrfarbig:
                not active
            Dachbeleuchtung mehrfarbig:
                not active
            Panoramaschiebedachbeleuchtung mehrfarbig:
                not active
            Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren:
                not active
            BAP Farbwert Farbe 1:
            BAP Farbwert Farbe 2:
                3
            BAP Farbwert Farbe 3:
            Defaultwert Ambienteprofil Mittelkonsole:
                80 %
            Defaultwert Ambienteprofil Dach:
                80 %
            Defaultwert Ambienteprofil Farbe:
            Helligkeit Tuertafelbeleuchtung nicht berechnen:
                not active
            Helligkeit Instrumententafelbeleuchtung nicht berechnen:
                active
            Helligkeit Cockpitbeleuchtung nicht berechnen:
                not active
            Helligkeit Lautsprecherbeleuchtung nicht berechnen:
                active
            Helligkeit Mittelkonsolenbeleuchtung nicht berechnen:
                active
            Helligkeit Dachbeleuchtung nicht berechnen:
                active
            Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen:
                active
            Farbausgabe Tuertafelbeleuchtung nicht berechnen:
                active
            Farbausgabe Instrumententafelbeleuchtung nicht berechnen:
                active
            Farbausgabe Cockpitbeleuchtung nicht berechnen:
                active
            Farbausgabe Lautsprecherbeleuchtung nicht berechnen:
                active
            Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen:
                active
            Farbausgabe Dachbeleuchtung nicht berechnen:
                active
            Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen:
                active
            Rotwert Farbe 1:
                225
            Gruenwert Farbe 1:
                225
            Blauwert Farbe 1:
                225
            Rotwert Farbe 2:
                225
            Gruenwert Farbe 2:
                225
            Blauwert Farbe 2:
                225
            Rotwert Farbe 3:
                225
            Gruenwert Farbe 3:
                225
            Blauwert Farbe 3:
                225
        Interior light, light configuration:
            Ambiente_Applikationsleisten_in_Tuertafel:
                installed
            Ambiente_Lautsprecher:
                not installed
            Ambiente_Applikationsleisten_in_Instrumententafel:
                not installed
            Cockpitbeleuchtung:
                installed
            Mittelkonsolenbeleuchtung:
                not installed
            Dachbeleuchtung:
                not installed
            Panoramaschiebedachbeleuchtung:
                not installed
            Fussraumbeleuchtung:
                installed
            Farbwahl ueber HMI:
                not installed
            Farbwahl ueber Fahrprofil:
                not installed
            LIN-Dachkonsole lokal aktivierbar:
                not active
            Ambientemenue mit globalem aus:
                not active
            Ambientemenue mit alle Zonen:
                active
        Characteristic curve:
            x0:
                0 lx
            x1:
                2000 lx
            x2:
                4000 lx
            x3:
                6000 lx
            x4:
                8000 lx
            x5:
                10200 lx
            y1_0:
            y1_1:
                40
            y1_2:
                90
            y1_3:
                140
            y1_4:
                190
            y1_5:
                245
            y2_0:
            y2_1:
                60
            y2_2:
                110
            y2_3:
                160
            y2_4:
                210
            y2_5:
                255
        LED bar setting values:
            Maximale Dauer fuer konstante Anzeige:
                0 s
            Sperrzeit:
                0 s
            Filterzeit Umgebungshelligkeit:
                1000 ms
            Filterzeit Anpassung:
                3000 ms
            Maximale Helligkeitsdifferenz:
                25
            Schwellwert Plausibilisierung RLS:
                393210 lx
            Schwellwert Plausibilisierung SLS:
                393210 lx
            Schwellwert Plausibilisierung Kombi-Fototransistor:
        Seat fan charac. curve:
            Level_1_Sitz:
                25 %
            Level_1_Lehne:
                30 %
            Level_2_Sitz:
                25 %
            Level_2_Lehne:
                30 %
            Level_3_Sitz:
                53 %
            Level_3_Lehne:
                58 %
            Level_4_Sitz:
                53 %
            Level_4_Lehne:
                58 %
            Level_5_Sitz:
                80 %
            Level_5_Lehne:
                85 %
            Level_6_Sitz:
                80 %
            Level_6_Lehne:
                85 %
        Window heater:
            Temperaturabhaengige Einschaltzeit HSH:
                active
            Temperaturabhaengige Einschaltzeit FSH:
                not active
            FSH Automatik:
                not active
            Heckscheibenheizung Zeitwert:
                600 s
            Running time of heated front window:
                600 s
            Abschalttemperatur fuer Heckscheibenheizung:
                35.00 °C
            Abschalttemperatur fuer Frontscheibenheizung:
                35.00 °C
        debug_light_function:
            Adresse:
            Bitmask:
            Offset:
            Divisor:
            Polaritaet:
            Aktivierung:
            WBT-Ausgabe:
        LIN-Mirrormode:
            Stufe:
            Bitmaske:
                63
        ambient_lighting_lin_slaves_groups:
            pa_verbauinfo_gruppe_1:
                not installed
            pa_lichtfunktion_gruppe_1:
                Door
            pa_korrekturfaktor_gruppe_1:
                1.00
            pa_verbauinfo_gruppe_2:
                not installed
            pa_lichtfunktion_gruppe_2:
                Door
            pa_korrekturfaktor_gruppe_2:
                1.00
            pa_verbauinfo_gruppe_3:
                not installed
            pa_lichtfunktion_gruppe_3:
                Door
            pa_korrekturfaktor_gruppe_3:
                1.00
            pa_verbauinfo_gruppe_4:
                not installed
            pa_lichtfunktion_gruppe_4:
                Door
            pa_korrekturfaktor_gruppe_4:
                1.00
            pa_verbauinfo_gruppe_5:
                not installed
            pa_lichtfunktion_gruppe_5:
                Door
            pa_korrekturfaktor_gruppe_5:
                1.00
            pa_verbauinfo_gruppe_6:
                not installed
            pa_lichtfunktion_gruppe_6:
                Door
            pa_korrekturfaktor_gruppe_6:
                1.00
            pa_verbauinfo_gruppe_7:
                not installed
            pa_lichtfunktion_gruppe_7:
                Door
            pa_korrekturfaktor_gruppe_7:
                1.00
            pa_verbauinfo_gruppe_8:
                not installed
            pa_lichtfunktion_gruppe_8:
                Door
            pa_korrekturfaktor_gruppe_8:
                1.00
            pa_verbauinfo_gruppe_9:
                not installed
            pa_lichtfunktion_gruppe_9:
                Door
            pa_korrekturfaktor_gruppe_9:
                1.00
            pa_verbauinfo_gruppe_10:
                not installed
            pa_lichtfunktion_gruppe_10:
                Door
            pa_korrekturfaktor_gruppe_10:
                1.00
            pa_verbauinfo_gruppe_11:
                not installed
            pa_lichtfunktion_gruppe_11:
                Door
            pa_korrekturfaktor_gruppe_11:
                1.00
            pa_verbauinfo_gruppe_12:
                not installed
            pa_lichtfunktion_gruppe_12:
                Door
            pa_korrekturfaktor_gruppe_12:
                1.00
            pa_verbauinfo_gruppe_13:
                not installed
            pa_lichtfunktion_gruppe_13:
                Door
            pa_korrekturfaktor_gruppe_13:
                1.00
            pa_verbauinfo_gruppe_14:
                not installed
            pa_lichtfunktion_gruppe_14:
                Door
            pa_korrekturfaktor_gruppe_14:
                1.00
            pa_verbauinfo_gruppe_15:
                not installed
            pa_lichtfunktion_gruppe_15:
                Door
            pa_korrekturfaktor_gruppe_15:
                1.00
        Personalisierung:
            Personalisierung_aktiv:
                not active
            Aktivierungsoption_im_HMI-Menue_sichtbar:
                not active
            Benutzerkontenverwaltung_in_HMI-Menue_sichtbar:
                not active
            Personalisierungsfunktionen_in_HMI-Menue_sichtbar:
                not active
        Daytime running lights:
            Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht:
                active
            Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge:
                active
            Standlicht aktiviert zusaetzlich Tagfahrlicht:
                active
            Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten:
                not active
            Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht:
                not active
            Tagfahrlichtkontrollleuchte:
                not active
            Fahrlicht bei Tag:
            Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich:
                active
            Tagfahrlicht nur in Schalterstellung AUTO:
                not active
        Remote_Start_Adaption:
            Anzahl zulaessiger Remotestarts:
            RemoteStart Betrieb Dauer:
                10 min
        Leuchte 0 BLK VL B36:
            Lasttyp 0:
            Lampendefektbit Position 0:
                34
                14
            Lichtfunktion A 0:
                Blinken links Hellphase
            Lichtfunktion B 0:
                nicht aktiv
            Dimmwert AB 0:
                127
                always
            Lichtfunktion C 0:
                Blinken links Dunkelphase
            Lichtfunktion D 0:
                nicht aktiv
            Dimmwert CD 0:
                maximize
            Lichtfunktion E 0:
                nicht aktiv
            Lichtfunktion F 0:
                nicht aktiv
            Dimmwert EF 0:
                maximize
            Lichtfunktion H 0:
                nicht aktiv
            Dimmwert GH 0:
                maximize
            Lichtfunktion G 0:
                nicht aktiv
        Leuchte1BLK VRB20:
            Lasttyp 1:
            Lampendefektbitposition 1:
                3e
                15
            Lichtfunktion A 1:
                Blinken rechts Hellphase
            Lichtfunktion B 1:
                nicht aktiv
            Dimmwert AB 1:
                127
                always
            Lichtfunktion C 1:
                Blinken rechts Dunkelphase
            Lichtfunktion D 1:
                nicht aktiv
            Dimmwert CD 1:
                maximize
            Lichtfunktion E 1:
                nicht aktiv
            Lichtfunktion F 1:
                nicht aktiv
            Dimmwert EF 1:
                maximize
            Lichtfunktion G 1:
                nicht aktiv
            Lichtfunktion H 1:
                nicht aktiv
            Dimmwert GH 1:
                maximize
        Leuchte2SL VLB10:
            Lasttyp 2:
            Lampendefektbitposition 2:
                48
                4a
            Lichtfunktion A 2:
                Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
            Lichtfunktion B 2:
                Parklicht links (beidseitiges Parklicht aktiviert li & re)
            Dimmwert AB 2:
                28
                always
            Lichtfunktion C 2:
                Coming Home oder Leaving Home aktiv
            Lichtfunktion D 2:
                nicht aktiv
            Dimmwert CD 2:
                28
                maximize
            Lichtfunktion E 2:
                Tagfahrlicht
            Lichtfunktion F 2:
                nicht aktiv
            Dimmwert EF 2:
                100
                maximize
            Lichtfunktion G 2:
                Blinken links aktiv (beide Phasen)
            Lichtfunktion H 2:
                nicht aktiv
            Dimmwert GH 2:
                minimize
        Leuchte3SL VRB21:
            Lasttyp 3:
            Lampendefektbitposition 3:
                4c
                4c
            Lichtfunktion A 3:
            Lichtfunktion B 3:
                Parklicht rechts
            Dimmwert AB 3:
                28
                always
            Lichtfunktion C 3:
            Lichtfunktion D 3:
                nicht aktiv
            Dimmwert CD 3:
                28
                maximize
            Lichtfunktion E 3:
                Tagfahrlicht
            Lichtfunktion F 3:
                nicht aktiv
            Dimmwert EF 3:
                100
                maximize
            Lichtfunktion G 3:
                Blinken rechts aktiv (beide Phasen)
            Lichtfunktion H 3:
                nicht aktiv
            Dimmwert GH 3:
                minimize
        Leuchte4TFL LB4:
            Lasttyp 4:
            Lampendefektbitposition 4:
                48
                49
            Lichtfunktion A 4:
                Tagfahrlicht
            Lichtfunktion B 4:
            Dimmwert AB 4:
                127
                always
            Lichtfunktion C 4:
            Lichtfunktion D 4:
            Dimmwert CD 4:
                127
                maximize
            Lichtfunktion E 4:
                nicht aktiv
            Lichtfunktion F 4:
                nicht aktiv
            Dimmwert EF 4:
                maximize
            Lichtfunktion G 4:
            Lichtfunktion H 4:
                nicht aktiv
            Dimmwert GH 4:
                minimize
        Leuchte5 TFL RB32:
            Lasttyp 5:
            Lampendefektbitposition 5:
                4c
                4b
            Lichtfunktion A 5:
                Tagfahrlicht
            Lichtfunktion B 5:
            Dimmwert AB 5:
                127
                always
            Lichtfunktion C 5:
            Lichtfunktion D 5:
                Parklicht rechts
            Dimmwert CD 5:
                127
                maximize
            Lichtfunktion E 5:
                nicht aktiv
            Lichtfunktion F 5:
                nicht aktiv
            Dimmwert EF 5:
                maximize
            Lichtfunktion G 5:
            Lichtfunktion H 5:
                nicht aktiv
            Dimmwert GH 5:
                minimize
        Leuchte6ABL LC5:
            Lasttyp 6:
            Lampendefektbitposition 6:
                36
                1a
            Lichtfunktion A 6:
                Abblendlicht links
            Lichtfunktion B 6:
                nicht aktiv
            Dimmwert AB 6:
                127
                always
            Lichtfunktion C 6:
            Lichtfunktion D 6:
                nicht aktiv
            Dimmwert CD 6:
                127
                maximize
            Lichtfunktion E 6:
                nicht aktiv
            Lichtfunktion F 6:
                nicht aktiv
            Dimmwert EF 6:
                maximize
            Lichtfunktion G 6:
                nicht aktiv
            Lichtfunktion H 6:
                nicht aktiv
            Dimmwert GH 6:
                maximize
        Leuchte7ABL RB1:
            Lasttyp 7:
            Lampendefektbitposition 7:
                40
                1b
            Lichtfunktion A 7:
                Abblendlicht rechts
            Lichtfunktion B 7:
                nicht aktiv
            Dimmwert AB 7:
                127
                always
            Lichtfunktion C 7:
            Lichtfunktion D 7:
                nicht aktiv
            Dimmwert CD 7:
                127
                maximize
            Lichtfunktion E 7:
                nicht aktiv
            Lichtfunktion F 7:
                nicht aktiv
            Dimmwert EF 7:
                maximize
            Lichtfunktion G 7:
                nicht aktiv
            Lichtfunktion H 7:
                nicht aktiv
            Dimmwert GH 7:
                maximize
        Leuchte8FL LB39:
            Lasttyp 8:
            Lampendefektbitposition 8:
                36
                5d
            Lichtfunktion A 8:
                Klemme 15 mit Nachlauf bis Fahrzeugstillstand
            Lichtfunktion B 8:
                nicht aktiv
            Dimmwert AB 8:
                127
                always
            Lichtfunktion C 8:
            Lichtfunktion D 8:
                nicht aktiv
            Dimmwert CD 8:
                127
                maximize
            Lichtfunktion E 8:
                nicht aktiv
            Lichtfunktion F 8:
                nicht aktiv
            Dimmwert EF 8:
                maximize
            Lichtfunktion G 8:
                nicht aktiv
            Lichtfunktion H 8:
                nicht aktiv
            Dimmwert GH 8:
                maximize
        Leuchte9FL RB2:
            Lasttyp 9:
            Lampendefektbitposition 9:
                40
                5e
            Lichtfunktion A 9:
            Lichtfunktion B 9:
                nicht aktiv
            Dimmwert AB 9:
                127
                always
            Lichtfunktion C 9:
            Lichtfunktion D 9:
                nicht aktiv
            Dimmwert CD 9:
                127
                maximize
            Lichtfunktion E 9:
                nicht aktiv
            Lichtfunktion F 9:
                nicht aktiv
            Dimmwert EF 9:
                maximize
            Lichtfunktion G 9:
                nicht aktiv
            Lichtfunktion H 9:
                nicht aktiv
            Dimmwert GH 9:
                maximize
        Leuchte10SHUTTER LB23:
            Lasttyp 10:
                not active
            Lampendefektbitposition 10:
            Lichtfunktion A 10:
                nicht aktiv
            Lichtfunktion B 10:
                nicht aktiv
            Dimmwert AB 10:
                always
            Lichtfunktion C 10:
                nicht aktiv
            Lichtfunktion D 10:
                nicht aktiv
            Dimmwert CD 10:
                maximize
            Lichtfunktion E 10:
                nicht aktiv
            Lichtfunktion F 10:
                nicht aktiv
            Dimmwert EF 10:
                maximize
            Lichtfunktion G 10:
                nicht aktiv
            Lichtfunktion H 10:
                nicht aktiv
            Dimmwert GH 10:
                maximize
        Leuchte11SHUTTER RB22:
            Lasttyp 11:
            Lampendefektbitposition 11:
                62
            Lichtfunktion A 11:
                Aktive Blinkfunktion hat ein auf 1 gesetztes zugeordnetes Bit in pa_dynamisch_blinken
            Lichtfunktion B 11:
                nicht aktiv
            Dimmwert AB 11:
                127
                always
            Lichtfunktion C 11:
                nicht aktiv
            Lichtfunktion D 11:
                nicht aktiv
            Dimmwert CD 11:
                maximize
            Lichtfunktion E 11:
                nicht aktiv
            Lichtfunktion F 11:
                nicht aktiv
            Dimmwert EF 11:
                maximize
            Lichtfunktion G 11:
                nicht aktiv
            Lichtfunktion H 11:
                nicht aktiv
            Dimmwert GH 11:
                maximize
        Leuchte12NL LB45:
            Lasttyp 12:
                not active
            Lampendefektbitposition 12:
            Lichtfunktion A 12:
                nicht aktiv
            Lichtfunktion B 12:
                nicht aktiv
            Dimmwert AB 12:
                always
            Lichtfunktion C 12:
                nicht aktiv
            Lichtfunktion D 12:
                nicht aktiv
            Dimmwert CD 12:
                maximize
            Lichtfunktion E 12:
                nicht aktiv
            Lichtfunktion F 12:
                nicht aktiv
            Dimmwert EF 12:
                maximize
            Lichtfunktion G 12:
                nicht aktiv
            Lichtfunktion H 12:
                nicht aktiv
            Dimmwert GH 12:
                maximize
        Leuchte13NL RB5:
            Lasttyp 13:
                not active
            Lampendefektbitposition 13:
            Lichtfunktion A 13:
                nicht aktiv
            Lichtfunktion B 13:
                nicht aktiv
            Dimmwert AB 13:
                always
            Lichtfunktion C 13:
                nicht aktiv
            Lichtfunktion D 13:
                nicht aktiv
            Dimmwert CD 13:
                maximize
            Lichtfunktion E 13:
                nicht aktiv
            Lichtfunktion F 13:
                nicht aktiv
            Dimmwert EF 13:
                maximize
            Lichtfunktion G 13:
                nicht aktiv
            Lichtfunktion H 13:
                nicht aktiv
            Dimmwert GH 13:
                maximize
        Leuchten14AL LB6:
            Lasttyp 14:
                not active
            Lampendefektbitposition 14:
            Lichtfunktion A 14:
                nicht aktiv
            Lichtfunktion B 14:
                nicht aktiv
            Dimmwert AB 14:
                always
            Lichtfunktion C 14:
                nicht aktiv
            Lichtfunktion D 14:
                nicht aktiv
            Dimmwert CD 14:
                maximize
            Lichtfunktion E 14:
                nicht aktiv
            Lichtfunktion F 14:
                nicht aktiv
            Dimmwert EF 14:
                maximize
            Lichtfunktion G 14:
                nicht aktiv
            Lichtfunktion H 14:
                nicht aktiv
            Dimmwert GH 14:
                maximize
        Leuchte15AL RB44:
            Lasttyp 15:
                not active
            Lampendefektbitposition 15:
            Lichtfunktion A 15:
                nicht aktiv
            Lichtfunktion B 15:
                nicht aktiv
            Dimmwert AB 15:
                always
            Lichtfunktion C 15:
                nicht aktiv
            Lichtfunktion D 15:
                nicht aktiv
            Dimmwert CD 15:
                maximize
            Lichtfunktion E 15:
                nicht aktiv
            Lichtfunktion F 15:
                nicht aktiv
            Dimmwert EF 15:
                maximize
            Lichtfunktion G 15:
                nicht aktiv
            Lichtfunktion H 15:
                nicht aktiv
            Dimmwert GH 15:
                maximize
        Leuchte16BLK SLB35BLK SL KC9:
            Lasttyp 16:
            Lampendefektbitposition 16:
                b
            Lichtfunktion A 16:
                Kofferraumlicht
            Lichtfunktion B 16:
                nicht aktiv
            Dimmwert AB 16:
                100
                always
            Lichtfunktion C 16:
                nicht aktiv
            Lichtfunktion D 16:
                nicht aktiv
            Dimmwert CD 16:
                maximize
            Lichtfunktion E 16:
                nicht aktiv
            Lichtfunktion F 16:
                nicht aktiv
            Dimmwert EF 16:
                maximize
            Lichtfunktion G 16:
                nicht aktiv
            Lichtfunktion H 16:
                nicht aktiv
            Dimmwert GH 16:
                maximize
        Leuchte17TFL R BLK SRB3TFL R BLK SR KC3:
            Lasttyp 17:
            Lampendefektbitposition 17:
                4
            Lichtfunktion A 17:
                Ambientelicht 2
            Lichtfunktion B 17:
                nicht aktiv
            Dimmwert AB 17:
                100
                always
            Lichtfunktion C 17:
                nicht aktiv
            Lichtfunktion D 17:
                nicht aktiv
            Dimmwert CD 17:
                maximize
            Lichtfunktion E 17:
                nicht aktiv
            Lichtfunktion F 17:
                nicht aktiv
            Dimmwert EF 17:
                maximize
            Lichtfunktion G 17:
                nicht aktiv
            Lichtfunktion H 17:
                nicht aktiv
            Dimmwert GH 17:
                maximize
        Leuchte18BLK HLA60:
            Lasttyp 18:
            Lampendefektbitposition 18:
                8
                16
            Lichtfunktion A 18:
            Lichtfunktion B 18:
                nicht aktiv
            Dimmwert AB 18:
                127
                always
            Lichtfunktion C 18:
            Lichtfunktion D 18:
                nicht aktiv
            Dimmwert CD 18:
                maximize
            Lichtfunktion E 18:
                nicht aktiv
            Lichtfunktion F 18:
                nicht aktiv
            Dimmwert EF 18:
                maximize
            Lichtfunktion G 18:
                nicht aktiv
            Lichtfunktion H 18:
                nicht aktiv
            Dimmwert GH 18:
                maximize
        Leuchte19BLK HRC31:
            Lasttyp 19:
            Lampendefektbitposition 19:
                18
                18
            Lichtfunktion A 19:
            Lichtfunktion B 19:
                nicht aktiv
            Dimmwert AB 19:
                127
                always
            Lichtfunktion C 19:
            Lichtfunktion D 19:
                nicht aktiv
            Dimmwert CD 19:
                maximize
            Lichtfunktion E 19:
                nicht aktiv
            Lichtfunktion F 19:
                nicht aktiv
            Dimmwert EF 19:
                maximize
            Lichtfunktion G 19:
                nicht aktiv
            Lichtfunktion H 19:
                nicht aktiv
            Dimmwert GH 19:
                maximize
        Leuchte20BR LA71:
            Lasttyp 20:
            Lampendefektbitposition 20:
                9
                2b
            Lichtfunktion A 20:
                Bremslicht
            Lichtfunktion B 20:
                nicht aktiv
            Dimmwert AB 20:
                127
                always
            Lichtfunktion C 20:
                nicht aktiv
            Lichtfunktion D 20:
                nicht aktiv
            Dimmwert CD 20:
                maximize
            Lichtfunktion E 20:
                nicht aktiv
            Lichtfunktion F 20:
                nicht aktiv
            Dimmwert EF 20:
                maximize
            Lichtfunktion G 20:
                nicht aktiv
            Lichtfunktion H 20:
                nicht aktiv
            Dimmwert GH 20:
                maximize
        Leuchte21BR RC8:
            Lasttyp 21:
            Lampendefektbitposition 21:
                19
                2d
            Lichtfunktion A 21:
                Bremslicht
            Lichtfunktion B 21:
                nicht aktiv
            Dimmwert AB 21:
                127
                always
            Lichtfunktion C 21:
                nicht aktiv
            Lichtfunktion D 21:
                nicht aktiv
            Dimmwert CD 21:
                maximize
            Lichtfunktion E 21:
                nicht aktiv
            Lichtfunktion F 21:
                nicht aktiv
            Dimmwert EF 21:
                maximize
            Lichtfunktion G 21:
                nicht aktiv
            Lichtfunktion H 21:
                nicht aktiv
            Dimmwert GH 21:
                maximize
        Leuchte22BR MA57:
            Lasttyp 22:
            Lampendefektbitposition 22:
                29
                2c
            Lichtfunktion A 22:
                Bremslicht
            Lichtfunktion B 22:
                nicht aktiv
            Dimmwert AB 22:
                100
                always
            Lichtfunktion C 22:
                nicht aktiv
            Lichtfunktion D 22:
                nicht aktiv
            Dimmwert CD 22:
                maximize
            Lichtfunktion E 22:
                nicht aktiv
            Lichtfunktion F 22:
                nicht aktiv
            Dimmwert EF 22:
                maximize
            Lichtfunktion G 22:
                nicht aktiv
            Lichtfunktion H 22:
                nicht aktiv
            Dimmwert GH 22:
                maximize
        Leuchte23SL HLC10:
            Lasttyp 23:
                40 - allgemeine LED
            Lampendefektbitposition 23:
                a
                29
            Lichtfunktion A 23:
            Lichtfunktion B 23:
            Dimmwert AB 23:
                100
                always
            Lichtfunktion C 23:
            Lichtfunktion D 23:
                nicht aktiv
            Dimmwert CD 23:
                100
                maximize
            Lichtfunktion E 23:
                Tagfahrlicht
            Lichtfunktion F 23:
                nicht aktiv
            Dimmwert EF 23:
                100
                maximize
            Lichtfunktion G 23:
                nicht aktiv
            Lichtfunktion H 23:
                nicht aktiv
            Dimmwert GH 23:
                maximize
        Leuchte24SL HRA65:
            Lasttyp 24:
                40 - allgemeine LED
            Lampendefektbitposition 24:
                1a
                2a
            Lichtfunktion A 24:
            Lichtfunktion B 24:
            Dimmwert AB 24:
                100
                always
            Lichtfunktion C 24:
                Parklicht rechts
            Lichtfunktion D 24:
                nicht aktiv
            Dimmwert CD 24:
                100
                maximize
            Lichtfunktion E 24:
                Tagfahrlicht
            Lichtfunktion F 24:
                nicht aktiv
            Dimmwert EF 24:
                100
                maximize
            Lichtfunktion G 24:
                nicht aktiv
            Lichtfunktion H 24:
                nicht aktiv
            Dimmwert GH 24:
                maximize
        Leuchte25KZL HA59:
            Lasttyp 25:
                43 - allgemeine LED
            Lampendefektbitposition 25:
                28
                30
            Lichtfunktion A 25:
            Lichtfunktion B 25:
            Dimmwert AB 25:
                100
                always
            Lichtfunktion C 25:
                Tagfahrlicht
            Lichtfunktion D 25:
                nicht aktiv
            Dimmwert CD 25:
                100
                maximize
            Lichtfunktion E 25:
                nicht aktiv
            Lichtfunktion F 25:
                nicht aktiv
            Dimmwert EF 25:
                maximize
            Lichtfunktion G 25:
                nicht aktiv
            Lichtfunktion H 25:
                nicht aktiv
            Dimmwert GH 25:
                maximize
        Leuchte26NSL LA72:
            Lasttyp 26:
                43 - allgemeine LED
            Lampendefektbitposition 26:
                c
                2e
            Lichtfunktion A 26:
                Bremslicht
            Lichtfunktion B 26:
                nicht aktiv
            Dimmwert AB 26:
                60
                always
            Lichtfunktion C 26:
                nicht aktiv
            Lichtfunktion D 26:
                nicht aktiv
            Dimmwert CD 26:
                maximize
            Lichtfunktion E 26:
                Nebelschlusslicht wenn kein Anhaenger gesteckt
            Lichtfunktion F 26:
                nicht aktiv
            Dimmwert EF 26:
                100
                maximize
            Lichtfunktion G 26:
                nicht aktiv
            Lichtfunktion H 26:
                nicht aktiv
            Dimmwert GH 26:
                maximize
        Leuchte27NSL RC6:
            Lasttyp 27:
                43 - allgemeine LED
            Lampendefektbitposition 27:
                1c
                2f
            Lichtfunktion A 27:
                Bremslicht
            Lichtfunktion B 27:
                nicht aktiv
            Dimmwert AB 27:
                60
                always
            Lichtfunktion C 27:
                nicht aktiv
            Lichtfunktion D 27:
                nicht aktiv
            Dimmwert CD 27:
                maximize
            Lichtfunktion E 27:
            Lichtfunktion F 27:
                nicht aktiv
            Dimmwert EF 27:
                100
                maximize
            Lichtfunktion G 27:
                nicht aktiv
            Lichtfunktion H 27:
                nicht aktiv
            Dimmwert GH 27:
                maximize
        Leuchte28RFL LC11:
            Lasttyp 28:
                40 - allgemeine LED
            Lampendefektbitposition 28:
                b
                31
            Lichtfunktion A 28:
                Rueckfahrlicht
            Lichtfunktion B 28:
                nicht aktiv
            Dimmwert AB 28:
                100
                always
            Lichtfunktion C 28:
                nicht aktiv
            Lichtfunktion D 28:
                nicht aktiv
            Dimmwert CD 28:
                maximize
            Lichtfunktion E 28:
                nicht aktiv
            Lichtfunktion F 28:
                nicht aktiv
            Dimmwert EF 28:
                maximize
            Lichtfunktion G 28:
                nicht aktiv
            Lichtfunktion H 28:
                nicht aktiv
            Dimmwert GH 28:
                maximize
        Leuchte29RFL RA64:
            Lasttyp 29:
                40 - allgemeine LED
            Lampendefektbitposition 29:
                1b
                32
            Lichtfunktion A 29:
                Rueckfahrlicht
            Lichtfunktion B 29:
                nicht aktiv
            Dimmwert AB 29:
                100
                always
            Lichtfunktion C 29:
                nicht aktiv
            Lichtfunktion D 29:
                nicht aktiv
            Dimmwert CD 29:
                maximize
            Lichtfunktion E 29:
                nicht aktiv
            Lichtfunktion F 29:
                nicht aktiv
            Dimmwert EF 29:
                maximize
            Lichtfunktion G 29:
                nicht aktiv
            Lichtfunktion H 29:
                nicht aktiv
            Dimmwert GH 29:
                maximize
        Leuchte30FR LC72:
            Lasttyp 30:
            Lampendefektbitposition 30:
            Lichtfunktion A 30:
                Fussraumlicht
            Lichtfunktion B 30:
                nicht aktiv
            Dimmwert AB 30:
                100
                always
            Lichtfunktion C 30:
                nicht aktiv
            Lichtfunktion D 30:
                nicht aktiv
            Dimmwert CD 30:
                maximize
            Lichtfunktion E 30:
                nicht aktiv
            Lichtfunktion F 30:
                nicht aktiv
            Dimmwert EF 30:
                maximize
            Lichtfunktion G 30:
                nicht aktiv
            Lichtfunktion H 30:
                nicht aktiv
            Dimmwert GH 30:
                maximize
        Leuchte31AMBL 1C61:
            Lasttyp 31:
                not active
            Lampendefektbitposition 31:
                3
            Lichtfunktion A 31:
                Ambientelicht 1
            Lichtfunktion B 31:
                nicht aktiv
            Dimmwert AB 31:
                100
                always
            Lichtfunktion C 31:
                nicht aktiv
            Lichtfunktion D 31:
                nicht aktiv
            Dimmwert CD 31:
                maximize
            Lichtfunktion E 31:
                nicht aktiv
            Lichtfunktion F 31:
                nicht aktiv
            Dimmwert EF 31:
                maximize
            Lichtfunktion G 31:
                nicht aktiv
            Lichtfunktion H 31:
                nicht aktiv
            Dimmwert GH 31:
                maximize
        Leuchte32AMBL 2C35:
            Lasttyp 32:
                not active
            Lampendefektbitposition 32:
                4
            Lichtfunktion A 32:
                Ambientelicht 2
            Lichtfunktion B 32:
                nicht aktiv
            Dimmwert AB 32:
                100
                always
            Lichtfunktion C 32:
                nicht aktiv
            Lichtfunktion D 32:
                nicht aktiv
            Dimmwert CD 32:
                maximize
            Lichtfunktion E 32:
                nicht aktiv
            Lichtfunktion F 32:
                nicht aktiv
            Dimmwert EF 32:
                maximize
            Lichtfunktion G 32:
                nicht aktiv
            Lichtfunktion H 32:
                nicht aktiv
            Dimmwert GH 32:
                maximize
        Leuchte33AMBL 3C36:
            Lasttyp 33:
                not active
            Lampendefektbitposition 33:
                5
            Lichtfunktion A 33:
                Ambientelicht 3
            Lichtfunktion B 33:
                nicht aktiv
            Dimmwert AB 33:
                100
                always
            Lichtfunktion C 33:
                nicht aktiv
            Lichtfunktion D 33:
                nicht aktiv
            Dimmwert CD 33:
                maximize
            Lichtfunktion E 33:
                nicht aktiv
            Lichtfunktion F 33:
                nicht aktiv
            Dimmwert EF 33:
                maximize
            Lichtfunktion G 33:
                nicht aktiv
            Lichtfunktion H 33:
                nicht aktiv
            Dimmwert GH 33:
                maximize
        Leuchte34AMBL 4C37:
            Lasttyp 34:
                not active
            Lampendefektbitposition 34:
                6
            Lichtfunktion A 34:
                Ambientelicht 4
            Lichtfunktion B 34:
                nicht aktiv
            Dimmwert AB 34:
                100
                always
            Lichtfunktion C 34:
                nicht aktiv
            Lichtfunktion D 34:
                nicht aktiv
            Dimmwert CD 34:
                maximize
            Lichtfunktion E 34:
                nicht aktiv
            Lichtfunktion F 34:
                nicht aktiv
            Dimmwert EF 34:
                maximize
            Lichtfunktion G 34:
                nicht aktiv
            Lichtfunktion H 34:
                nicht aktiv
            Dimmwert GH 34:
                maximize
        ambient_lighting_lin_slaves_modules:
            pa_einzeladresse_slave_1:
            pa_verbauinfo_slave_1:
                not installed
            pa_fehlerort_slave_1:
            pa_einzeladresse_slave_2:
            pa_verbauinfo_slave_2:
                not installed
            pa_fehlerort_slave_2:
            pa_einzeladresse_slave_3:
            pa_verbauinfo_slave_3:
                not installed
            pa_fehlerort_slave_3:
            pa_einzeladresse_slave_4:
            pa_verbauinfo_slave_4:
                not installed
            pa_fehlerort_slave_4:
            pa_einzeladresse_slave_5:
            pa_verbauinfo_slave_5:
                not installed
            pa_fehlerort_slave_5:
            pa_einzeladresse_slave_6:
            pa_verbauinfo_slave_6:
                not installed
            pa_fehlerort_slave_6:
            pa_einzeladresse_slave_7:
            pa_verbauinfo_slave_7:
                not installed
            pa_fehlerort_slave_7:
            pa_einzeladresse_slave_8:
            pa_verbauinfo_slave8:
                not installed
            pa_fehlerort_slave8:
            pa_einzeladresse_slave_9:
            pa_verbauinfo_slave_9:
                not installed
            pa_fehlerort_slave_9:
            pa_einzeladresse_slave_10:
            pa_verbauinfo_slave_10:
                not installed
            pa_fehlerort_slave_10:
            pa_einzeladresse_slave_11:
            pa_verbauinfo_slave_11:
                not installed
            pa_fehlerort_slave_11:
            pa_einzeladresse_slave_:12:
            pa_verbauinfo_slave_12:
                not installed
            pa_fehlerort_slave_12:
            pa_einzeladresse_slave_13:
            pa_verbauinfo_slave_13:
                not installed
            pa_fehlerort_slave_13:
            pa_einzeladresse_slave_14:
            pa_verbauinfo_slave_14:
                not installed
            pa_fehlerort_slave_14:
            pa_einzeladresse_slave_15:
            pa_verbauinfo_slave_15:
                not installed
            pa_fehlerort_slave_15:
            pa_einzeladresse_slave_16:
            pa_verbauinfo_slave_16:
                not installed
            pa_fehlerort_slave_16:
            pa_einzeladresse_slave_17:
            pa_verbauinfo_slave_17:
                not installed
            pa_fehlerort_slave_17:
            pa_einzeladresse_slave_18:
            pa_verbauinfo_slave_18:
                not installed
            pa_fehlerort_slave_18:
            pa_einzeladresse_slave_19:
            pa_verbauinfo_slave_19:
                not installed
            pa_fehlerort_slave_19:
            pa_einzeladresse_slave_20:
            pa_verbauinfo_slave_20:
                not installed
            pa_fehlerort_slave_20:
    Advanced identification:
        Number of programming attempts:
            Bootloader:
            Application:
            Data record:
        Maximum number of possible update programming:
            Bootloader:
                65535
            Application:
                65535
            Data record:
                65535
        Workshop code and date of last update programming of SW module:
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                28696
            Importer number:
                771
            Dealership number:
                2048
            Programming status:
                Correct result
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                28696
            Importer number:
                771
            Dealership number:
                2048
            Programming status:
                Correct result
        FAZIT-identification:
            Manufacture location index:
                SME-RBG
            Day of manufacture:
                17.07.14
            Manufacturer- test stand number:
                0011
            Running manufacturer number:
                2142
        Diagnostic mode:
                VW - diagnostic mode
        VW/Audi part number:
                5Q0937084BR
        Software version:
                0138
        Vehicle Identification Number (VIN):
        Hardware part number:
                5Q0937084AJ
        System description:
                BCM MQBAB H
        Adaptation workshop code:
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
        ASAM/ODX file identification:
                EV_BCMCONTI
        ASAM/ODX file version:
                013000
        Hardware version:
                H18
        Coding workshop code:
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
        System abbreviation:
                J519
        Versions of software module:
            Bootloader:
                0271
            Application:
                0138
            Data record:
                0138
        Programmability status:
            Programmability:
                programmable
            Program consistency:
                Program present
    Mileage: 22180 km
    Date: 2019-10-27 16:50
Backup
    Control unit: 15 Airbag
    System description: AirbagVW20
    Software number: 5Q0959655P
    Software version: 0870
    Hardware number: 5Q0959655P
    Hardware version: 009
    Serial number: 003M7R000NWS
    ODX name: EV_AirbaVW20SMEVW37X
    ODX version: 002138
    Backup name: Airbag
    Long coding:
        88CCF0C00C8000005C5000CFC04800000065
    Subsystems:
        Subsystem: SideSensor_Df
        Long coding: 2D2D2D
        Subsystem: SideSensor_Pf
        Long coding: 2D2D2D
        Subsystem: SideSensor_Dr
        Long coding: 2D2D2D
        Subsystem: FrontSensor_D
        Long coding: 2D2D2D
        Subsystem: FrontSensor_P
        Long coding: 2D2D2D
        Subsystem: PedP_Sensor_C
        Long coding: 2D2D2D
        Subsystem: PedPSensor_D2
        Long coding: 2D2D2D
        Subsystem: PedPSensor_P2
        Long coding: 2D2D2D
    Mileage: 22180 km
Backup
    Control unit: 16 Steering Column Electronics
    System description: Lenks. Modul
    Software number: 8S0907129AC
    Software version: 0140
    Hardware number: 8S0907129AC
    Hardware version: H06
    Serial number: 91335NHF00826
    ODX name: EV_SMLSKLOMQB
    ODX version: 019002
    Backup name: Steering Column
    Long coding:
        281C
    Adaptations:
        p_t_blinker_entprellen:
                40 ms
        p_t_blinker_gra_entprellen:
                40 ms
        p_t_fas_entprellen:
            p_t_fas_entprellen:
                40 ms
        p_t_wischer_entprellen:
                40 ms
        p_t_wischer_winterstellung:
                60 s
        p_t_wischer_intervall_entprellen:
                40 ms
        p_t_grahebel_entprellen:
                40 ms
        p_t_hupe_entprellen:
                40 ms
        p_s_NWDF_spg:
            p_s_NWDF_spg:
        p_t_hupe_indien_entprellen:
                500 ms
        p_t_blinker_sperrzeit:
                100 ms
        p_t_blinker_err_lichthupe_haengt_ein:
                300 s
        p_t_blinker_err_lichthupe_haengt_aus:
                5000 ms
        p_t_blinker_err_gra_haengt_ein:
                300 s
        p_t_blinker_err_gra_haengt_aus:
                5000 ms
        p_t_wischer_err_mfa_haengt_ein:
                300 s
        p_t_wischer_err_mfa_haengt_aus:
                5000 ms
        p_t_wischer_err_wischen_haengt_ein:
                300 s
        p_t_wischer_err_wischen_haengt_aus:
                5000 ms
        p_t_wischer_err_waschen_haengt_ein:
                300 s
        p_t_wischer_err_waschen_haengt_aus:
                5000 ms
        p_t_grahebel_err_gra_haengt_ein:
                300 s
        p_t_grahebel_err_gra_haengt_aus:
                5000 ms
        p_t_hupe_err_hupe_haengt_ein:
                60 s
        p_t_hupe_err_hupe_haengt_aus:
                5000 ms
        p_t_hupe_err_hinweis:
                2000 ms
        p_t_wischer_err_intervallpoti_haengt_ein:
                300 s
        p_t_wischer_err_intervallpoti_haengt_aus:
                5000 ms
        p_t_spannung_untere_schwelle:
                8.5 V
        p_t_spannung_obere_schwelle:
                16.5 V
        p_t_blinker_err_el_kurzschluss:
                200 ms
        p_t_blinker_err_el_unterbrechung:
                1000 ms
        p_t_blinker_err_unplausibel:
                200 ms
        p_t_wischer_err_el_kurzschluss:
                200 ms
        p_t_wischer_err_el_unterbrechung:
                1000 ms
        p_t_grahebel_err_el_kurzschluss:
                200 ms
        p_t_grahebel_err_el_unterbrechung:
                1000 ms
        p_t_grahebel_err_unplausibel:
                200 ms
        p_t_entprellzeit_unterspannung:
                90000 ms
        p_t_entprellzeit_ueberspannung:
                90000 ms
        p_t_blinker_err_fernlicht_haengt_ein:
                300 s
        p_t_blinker_err_fernlicht_haengt_aus:
                5000 ms
        p_t_gra_ea_error:
            p_t_gra_ea_error:
                200 ms
        p_k_p:
            p_k_p:
                10.0 %
        p_k_i:
            p_k_i:
                0.300 %/s
        p_t_soll_0:
            p_t_soll_0:
                33 °C
        p_t_soll_1:
            p_t_soll_1:
                37 °C
        p_t_soll_2:
            p_t_soll_2:
                41 °C
        p_k_i_offset:
            p_k_i_offset:
                5 K
        p_t_p_verriegelt_entprellen:
                40 ms
        p_t_entprellung_p_unplausibel:
                400 ms
        p_t_grenze_v:
            p_t_grenze_v:
                10 km/h
        p_n_fehler_p_verriegelt:
                250
        p_leistung_lrh:
            p_leistung_lrh:
                110 W
        p_zeit_temperatur_statisch_lrh:
                300 s
        p_t_lrh_kurzschluss_entprellen:
                200 ms
        p_t_lrh_unterbrechung_entprellen:
                1000 ms
        p_temp_lenkradheizung_aus:
                45 °C
        p_t_dimmung_nachlauf:
                720 s
        p_dimmung_default_pwm:
                80 %
            Bootloader:
            Application:
            Bootloader:
            Application:
                100
            Year:
                14
            Month:
                8
            Day:
                15
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                KO3-KLO
            Day of manufacture:
                15.08.14
                1335
                0826
        Manufacturer modification status:
            Control module family:
            Decoration variant:
            Construction version:
            Manufacture version:
        Diagnostic mode:
                8S0907129AC
        Software version:
                0140
                8S0907129AC
        System description:
                Lenks. Modul
            Device number:
            Importer number:
            Dealership number:
                EV_SMLSKLOMQB
                019002
        Hardware version:
                H06
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J527
            Bootloader:
                0007
            Application:
                0140
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 17 Dash Board
    System description: FBenRDW
    Software number: 8S0920790
    Software version: 0221
    Hardware number: 8S0920790
    Hardware version: H30
    ODX name: EV_DashBoardBOSCHAU33X
    ODX version: 001013
    Backup name: Dashboard
    Long coding:
        042F0050698400080422FF809000801000000000
    Adaptations:
        Speed warning:
            Unit:
                Kilometers per hour
                active
            Speed:
                240
        Oil temperature display:
                On
        dimming_characteristic_curve_adjustment_bargraph_main_colour:
            X1:
            Y1:
            X2:
                a
            Y2:
            X3:
                32
            Y3:
                6
            X4:
                64
            Y4:
                a
            X5:
                dc
            Y5:
                50
            X6:
                fd
            Y6:
                64
        dimming_characteristic_curve_adjustment_middle_display_main_field:
            X1:
            Y1:
            X2:
                a
            Y2:
            X3:
                32
            Y3:
                6
            X4:
                64
            Y4:
                a
            X5:
                dc
            Y5:
                50
            X6:
                fd
            Y6:
                64
        dimming_characteristic_curve_adjustment_indicator_lights:
            X1:
            Y1:
            X2:
                a
            Y2:
            X3:
                32
            Y3:
                6
            X4:
                64
            Y4:
                a
            X5:
                dc
            Y5:
                50
            X6:
                fd
            Y6:
                64
        dimming_characteristic_curve_adjustment_gauge:
            X1:
            Y1:
            X2:
                14
            Y2:
                14
            X3:
                1e
            Y3:
                1e
            X4:
                32
            Y4:
                32
            X5:
                46
            Y5:
                46
            X6:
                64
            Y6:
                64
        dimming_characteristic_curve_adjustment_clock_dial_day:
            X1:
            Y1:
            X2:
                a
            Y2:
            X3:
                32
            Y3:
                e
            X4:
                64
            Y4:
                1e
            X5:
                96
            Y5:
                32
            X6:
                fd
            Y6:
                64
        dimming_characteristic_curve_adjustment_clock_dial_night:
            X1:
            Y1:
            X2:
                a
            Y2:
            X3:
                32
            Y3:
                e
            X4:
                64
            Y4:
                1e
            X5:
                96
            Y5:
                32
            X6:
                fd
            Y6:
                64
        dimming_characteristic_curve_adjustment_internal_phototransistor:
            X1:
            Y1:
            X2:
                32
            Y2:
                32
            X3:
                64
            Y3:
                64
            X4:
                96
            Y4:
                c8
            X5:
                1f4
            Y5:
                fd
        Illumination_algorithm:
            Scale_switching_algorithm:
                lds
            Pointer_illumination_algorithim:
                terminal_58xs_bus
        outside_temperature:
            p_time_constant_pt1:
                40 s
            p_time_constant_slow_damping:
                2.00
            p_speed_threshold:
                20 km/h
            p_tendency_threshold:
                1.00 °C
            p_kmt_at_delta:
                25 °C
            p_blocking_time_after_v_bigger_0:
                15 s
            p_storage_time_engine_off:
                180 min
            p_mileage_after_v_bigger_0:
                5.00 km
            p_ice_warning_exit_temperature:
                6 °C
            p_ice_warning_entry_temperature:
                4 °C
            p_tendency_damping:
                15 s
        Source for synchronization of time:
                GPS
        Activating and deactivating all development messages:
            send_messages:
                not active
        Configuration of Development CAN-Messages:
            Block 1:
                off
            Block 2:
                off
            Block 3:
                off
            Block 4:
                off
            Block 5:
                off
            Block 6:
                off
            Block 7:
                off
            Block 8:
                off
            Block 9:
                off
            Block 10:
                off
            Block 11:
                off
            Block 12:
                off
            Block 13:
                off
            Block 14:
                off
            Block 15:
                off
            Block 16:
                off
            Block 17:
                off
            Block 18:
                off
            Block 19:
                off
            Block 20:
                off
            Block 21:
                off
            Block 22:
                off
            Block 23:
                off
            Block 24:
                off
            Block 25:
                off
            Block 26:
                off
            Block 27:
                off
            Block 28:
                off
            Block 29:
                off
            Block 30:
                off
            Block 31:
                off
            Block 32:
                off
            Block 33:
                off
            Block 34:
                off
            Block 35:
                off
            Block 36:
                off
            Block 37:
                50ms
            Block 38:
                50ms
            Block 39:
                50ms
            Block 40:
                50ms
        Offset for tank calibration values:
            Offset sensor 1:
                -12.80 L
            Offset sensor 2:
                -12.80 L
            Offset sensor 3:
                12.70 L
            Offset sensor 4:
                12.70 L
            Complete tank calibration:
                -12.80 L
        Units adjusted:
            Temperature:
                °C
            Distance:
                Kilometers
            Speed:
                Kilometers per hour
            Pressure:
                Bar
            Volume:
                Liter
            Time:
                24h
            Date:
                dd_mm_yy
            Consumption gasoline / diesel - LPG (liquefied petroleum gas):
                Liters per 100 km
            Operating range consumption, CNG (compressed natural gas):
                kg per 100 km
            Average consumption, electric drive:
                kWh per 100 km
        Language version:
                Italian
        Day counter:
                1890 d
        WIV: Resetting ESI:
                no warning
        SIE: time from inspection:
                71 d
        SIE: minimum value km-driving distance/inspection:
                15000 km
        SIE: maximum value of time between inspections:
                730 d
        SIE: maximum value km-driving distance/inspection:
                30000 km
        SIE: oil quality:
                Poor oil quality
        SIE: soot entry:
                0 km
        SIE: thermal load:
                2200 km
        SIE: distance driven from inspection:
                1200 km
        WIV: minimum value of time between inspections:
                365 d
        SIA: maximum value of distance to service:
                15000 km
        SIA: maximum value of time to service:
                365 d
        Fix: Max. distance until next mileage-related inspection:
                29722 km
        FIX: Maximum time until next time-dependent inspection:
                730 d
        FIX: Distance covered since last mileage-dependent inspection:
                9800 km
        FIX: Time since last time-dependent inspection:
                643 d
        Service notification in days:
                30 d
        FIX: Reset value for next mileage-dependent inspection:
                30000 km
        FIX: Reset value for next mileage-dependent inspections:
                1095 d
        Distance:
                22180 km
        Hour:
                16 h
        Minute:
                46 min
        Year:
                2019 a
        Month:
                10 mon
        Day:
                27 d
        Service-key settings:
            p_write_delay_time:
                40 s
            p_write_delay_speed:
                20 km/h
            p_write_distance:
                20 km
            p_forcewrite_qual_time:
                10 s
            p_deactivate_SK_Function:
                On
            p_main_switch_Basic:
                Off
            p_main_switch_Keyless:
                On
        SK2_Adjustment:
            max_number_of_writing_procedures:
                6
            timeout_request_normal:
                300 s
            timeout_request_immediate:
                150 s
        Vehicle positioning system interface control module:
                not installed
        Lap counter:
                Display
        Digital speedometer:
                Display
        Deactivate seat belt warning:
                No
        BAP_Debug_Mode_Release:
            Release:
                not_released
        Ignition active message, actuator:
                All doors
        Roller test bench mode, functional:
                Not activated
        Initialize sensor for fuel level:
            initialisation:
                No
        Cylinder shut-off:
                No display
        Driving profile for operating range consump.with electric drive:
                25
            Average consumption, low voltage auxiliary consumer:
                0.20
            Average consumption, high voltage auxiliary consumer:
                0.50
            Operating range average voltage:
                10.00 A
        Drive profile for road-specif. remain.oper.range for el. drive:
            s_erw_rwdv_antrieb_high_class_0:
                25.00
            s_erw_rwdv_antrieb_high_class_1:
                25.00
            s_erw_rwdv_antrieb_high_class_2:
                25.00
            s_erw_rwdv_antrieb_high_class_3:
                25.00
            s_erw_rwdv_antrieb_high_class_4:
                25.00
            s_erw_rwdv_antrieb_high_class_5:
                25.00
            s_erw_rwdv_antrieb_high_class_6:
                25.00
        Driving profile for road-related range remaining:
            s_vkmrw_rwdv_high_class_0:
                8.00 l/100 km
            s_vkmrw_rwdv_high_class_1:
                8.80 l/100 km
            s_vkmrw_rwdv_high_class_2:
                8.40 l/100 km
            s_vkmrw_rwdv_high_class_3:
                7.70 l/100 km
            s_vkmrw_rwdv_high_class_4:
                7.70 l/100 km
            s_vkmrw_rwdv_high_class_5:
                7.30 l/100 km
            s_vkmrw_rwdv_high_class_6:
                10.00 l/100 km
        Driving profiled for range remaining:
                7.90 l/100 km
        Driving profile for range remaining LPG:
                10.00 l/100 km
        Driving profiled for range remaining CNG:
                6.00
        total_range_gas:
            state:
                active
            selection_consumption_factor:
                consumption_factor_CAN
            consumption_profile:
                consumption_profile_calculation
            consumption_factor:
                1.40
        Display correction of consumptions and operating range:
                100 %
        Display correction of consumption and operating range, gas:
                100 %
        Control module switch-off, switch-off time:
            Control module:
                20 min
            Data bus:
                30 min
        designvariant_activation:
            Version 1:
                not active
            Version 2:
                not active
            Version 3:
                not active
            Version 4:
                not active
            Version 5:
                not active
            Version 6:
                not active
            Version 7:
                not active
            Version 8:
                not active
        Deactivate production mode:
                Deactivating
        Production mode:
                not active
        developers_menu:
                not active
        time_parameter_display:
            tDDWUP:
                0.00
            tDD15_on:
                0.50
            tDD15_off:
                0.25
            hmi_t_FTuerAUF:
                0 ms
        parameter_hmi:
                4143560205FF2303000100FA0200FF0000FFFF0000F30000FF002400FF43142800005A00E10019FFB4001E8CAA64AA00BF4B68A2916D6D97A2739B7500000000000000000000000000000000000000000000000000000000000000000000000000000000
        Picture_Upload_Download:
            Bootloader:
            Block 1:
                3
            Block 2:
            Block 3:
            Block 4:
                3
            Block 5:
                3
            Block 6:
                3
            Block 7:
                3
            Block 8:
                3
            Block 9:
                3
            Block 10:
            Block 11:
            Block 12:
            Block 13:
            Block 14:
            Block 15:
            Block 16:
            Block 17:
            Block 18:
                3
            Block 19:
            Block 20:
            Block 21:
            Block 22:
            Block 23:
            Block 24:
            Bootloader:
            Block 1:
                65535
            Block 2:
                65535
            Block 3:
                65535
            Block 4:
                65535
            Block 5:
                65535
            Block 6:
                65535
            Block 7:
                65535
            Block 8:
                65535
            Block 9:
                65535
            Block 10:
                65535
            Block 11:
                65535
            Block 12:
                65535
            Block 13:
                65535
            Block 14:
                65535
            Block 15:
                65535
            Block 16:
                65535
            Block 17:
                65535
            Block 18:
                65535
            Block 19:
                65535
            Block 20:
                65535
            Block 21:
                65535
            Block 22:
                65535
            Block 23:
                65535
            Block 24:
                65535
            Year:
                14
            Month:
                3
            Day:
                17
            Device number:
                394758
            Importer number:
            Dealership number:
                12288
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
                2088735
            Importer number:
                771
            Dealership number:
                65024
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                BVX-815
            Day of manufacture:
                07.07.14
                0401
                0030
        Diagnostic mode:
                8S0920790
        Software version:
                0221
                8S0920790
        System description:
                FBenRDW
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
                001013
        Hardware version:
                H30
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
                J285
            Bootloader:
                0013
            Block 1:
                0402
            Block 2:
                0126
            Block 3:
                0126
            Block 4:
                0343
            Block 5:
                0343
            Block 6:
                0343
            Block 7:
                0343
            Block 8:
                0343
            Block 9:
                0343
            Block 10:
            Block 11:
            Block 12:
            Block 13:
            Block 14:
            Block 15:
            Block 16:
            Block 17:
            Block 18:
                0400
            Block 19:
            Block 20:
            Block 21:
            Block 22:
            Block 23:
            Block 24:
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 19 Gateway
    System description: GW MQB TT3
    Software number: 8S0907468
    Software version: 0184
    Hardware number: 8S0907468
    Hardware version: 012
    Serial number: 08051410800376
    ODX name: EV_GatewContiAU33X
    ODX version: 011002
    Backup name: Gateway
    Long coding:
        030100042F025A004B0002683C0000000000000000000000000000000001
    Adaptations:
        Service-key, extended settings:
            Distance for activation:
                50
            Lower speed threshold:
                40
            Upper speed threshold:
                100
            Waiting time wake vehicle bus:
                15.00 s
            Timeout time wake vehicle bus:
                60 s
        Service_key_2_development:
            Service_key_2_retrys_at_timeout:
                3
            Service_key_2_retrys_at_negative_response:
                3
        Installation list, specified installations:
            Gateway:
                coded
            Node_0x01:
                Not coded
            Node_0x02:
                Not coded
            Node_0x03:
                Not coded
            Node_0x04:
                Not coded
            Node_0x05:
                Not coded
            Node_0x06:
                Not coded
            Node_0x07:
                Not coded
            Node_0x08:
                Not coded
            Multifunction Module:
                Not coded
            Parking Assistance:
                coded
            Tire Pressure Monitoring 1:
                Not coded
            Steering Column Electronics:
                coded
            Node_0x0D:
                Not coded
            Central Electrics:
                coded
            All Wheel Control:
                coded
            Node_0x11:
                Not coded
            Steering Assistance:
                coded
            Brakes 1:
                coded
            Dash Board:
                coded
            Airbag:
                coded
            Node_0x16:
                Not coded
            Node_0x17:
                Not coded
            Radio:
                Not coded
            Air Conditioning Compressor:
                Not coded
            Node_0x1A:
                Not coded
            Head Up Display:
                Not coded
            Actuator For Structure-Borne Sound:
                coded
            Node_0x1D:
                Not coded
            Lock Electronics:
                Not coded
            Node_0x1F:
                Not coded
            Node_0x20:
                Not coded
            Node_0x21:
                Not coded
            Node_0x22:
                Not coded
            Deck Lid Control Unit:
                Not coded
            Node_0x24:
                Not coded
            Node_0x25:
                Not coded
            Node_0x26:
                Not coded
            Node_0x27:
                Not coded
            Node_0x28:
                Not coded
            Node_0x29:
                Not coded
            Node_0x2A:
                Not coded
            Special Function 2:
                Not coded
            Special Function:
                Not coded
            Electronic Roof Control:
                Not coded
            Node_0x2E:
                Not coded
            Node_0x2F:
                Not coded
            High Beam Assistance:
                Not coded
            Steering Column Locking:
                coded
            Access Startsystem Interface:
                coded
            Sliding Door Rear Left:
                Not coded
            Sliding Door Rear Right:
                Not coded
            Node_0x35:
                Not coded
            Node_0x36:
                Not coded
            Node_0x37:
                Not coded
            Node_0x38:
                Not coded
            Node_0x39:
                Not coded
            Node_0x3A:
                Not coded
            Brake Boost:
                Not coded
            Node_0x3C:
                Not coded
            Node_0x3D:
                Not coded
            Door Electronics Rear Driver Side:
                Not coded
            Door Electronics Rear Passenger Side:
                Not coded
            Node_0x40:
                Not coded
            Node_0x41:
                Not coded
            Thermal Management:
                Not coded
            Node_0x43:
                Not coded
            Battery Charger Control Module:
                Not coded
            Node_0x45:
                Not coded
            Air Conditioning:
                coded
            Trailer Function:
                Not coded
            Node_0x48:
                Not coded
            Node_0x49:
                Not coded
            Door Electronics Driver Side:
                coded
            Door Electronics Passenger Side:
                coded
            Seat Adjustment Driver Side:
                Not coded
            Seat Adjustment Passenger Side:
                Not coded
            Lane Change Assistant:
                Not coded
            Front Sensors Driver Assistance System:
                coded
            Vehicle Position Detection:
                Not coded
            Node_0x51:
                Not coded
            Node_0x52:
                Not coded
            Node_0x53:
                Not coded
            Headlight Regulation:
                coded
            Node_0x55:
                Not coded
            Node_0x56:
                Not coded
            Adaptive Cruise Control:
                Not coded
            Node_0x58:
                Not coded
            Node_0x59:
                Not coded
            Node_0x5A:
                Not coded
            Node_0x5B:
                Not coded
            Node_0x5C:
                Not coded
            Node_0x5D:
                Not coded
            Node_0x5E:
                Not coded
            Node_0x5F:
                Not coded
            Node_0x60:
                Not coded
            Node_0x61:
                Not coded
            Node_0x62:
                Not coded
            Microphone Control Unit:
                Not coded
            Actuator For Exterior Noise:
                Not coded
            High Voltage Battery Charge Management:
                Not coded
            Node_0x66:
                Not coded
            Telematics Communication Unit:
                Not coded
            Node_0x68:
                Not coded
            Camera System Rear View:
                Not coded
            Auxiliary Parking Heater:
                Not coded
            Node_0x6B:
                Not coded
            Node_0x6C:
                Not coded
            TV Tuner:
                Not coded
            Node_0x6E:
                Not coded
            Sound System:
                Not coded
            Media Player Position 1:
                Not coded
            Tachograph:
                Not coded
            Wheel Dampening Electronics:
                Not coded
            Information Control Unit 1:
                coded
            Node_0x74:
                Not coded
            Node_0x75:
                Not coded
            Engine Control Module 1:
                coded
            Transmission Control Module:
                coded
            Node_0x78:
                Not coded
            Node_0x79:
                Not coded
            Node_0x7A:
                Not coded
            Battery Energy Control Module:
                Not coded
            Drive Motor Control Module:
                Not coded
            Node_0x7D:
                Not coded
            Node_0x7E:
                Not coded
            Node_0x7F:
                Not coded
            Node_0x80:
                Not coded
            Node_0x81:
                Not coded
            Node_0x82:
                Not coded
            Node_0x83:
                Not coded
            Control Module For Sunroof:
                Not coded
            Starter / Generator Control Module:
                Not coded
            Node_0x86:
                Not coded
            Node_0x87:
                Not coded
            Node_0x88:
                Not coded
            Node_0x89:
                Not coded
            Control Unit Lane Change Assistant 2:
                Not coded
            Node_0x8B:
                Not coded
            Node_0x8C:
                Not coded
            Node_0x8D:
                Not coded
            Node_0x8E:
                Not coded
            Node_0x8F:
                Not coded
            Node_0x90:
                Not coded
            Node_0x91:
                Not coded
            Node_0x92:
                Not coded
            Node_0x93:
                Not coded
            Node_0x94:
                Not coded
            Node_0x95:
                Not coded
            Node_0x96:
                Not coded
            Node_0x97:
                Not coded
            Node_0x98:
                Not coded
            Node_0x99:
                Not coded
            Node_0x9A:
                Not coded
            Node_0x9B:
                Not coded
            Battery Energy Control Module 2:
                Not coded
            Node_0x9D:
                Not coded
            Node_0x9E:
                Not coded
            Node_0x9F:
                Not coded
            Node_0xA0:
                Not coded
            Node_0xA1:
                Not coded
            Node_0xA2:
                Not coded
            Node_0xA3:
                Not coded
            Auxiliary Air Heater:
                Not coded
            Node_0xA5:
                Not coded
            Node_0xA6:
                Not coded
            Node_0xA7:
                Not coded
            Node_0xA8:
                Not coded
                Not coded
            Node_0xAA:
                Not coded
            Node_0xAB:
                Not coded
            Node_0xAC:
                Not coded
            Node_0xAD:
                Not coded
            Battery regulation:
                Not coded
            Node_0xAF:
                Not coded
            Node_0xB0:
                Not coded
            Node_0xB1:
                Not coded
            Node_0xB2:
                Not coded
            Node_0xB3:
                Not coded
            Node_0xB4:
                Not coded
            Node_0xB5:
                Not coded
            Node_0xB6:
                Not coded
            Node_0xB7:
                Not coded
            Node_0xB8:
                Not coded
            Node_0xB9:
                Not coded
            Node_0xBA:
                Not coded
            Node_0xBB:
                Not coded
            Node_0xBC:
                Not coded
            Node_0xBD:
                Not coded
            Node_0xBE:
                Not coded
            Node_0xBF:
                Not coded
            Node_0xC0:
                Not coded
            Node_0xC1:
                Not coded
            Node_0xC2:
                Not coded
            Node_0xC3:
                Not coded
            Node_0xC4:
                Not coded
            Node_0xC5:
                Not coded
            Node_0xC6:
                Not coded
            Node_0xC7:
                Not coded
            Node_0xC8:
                Not coded
            Node_0xC9:
                Not coded
            Node_0xCA:
                Not coded
            Node_0xCB:
                Not coded
            Node_0xCC:
                Not coded
            Node_0xCD:
                Not coded
            Node_0xCE:
                Not coded
            Node_0xCF:
                Not coded
            Node_0xD0:
                Not coded
            Node_0xD1:
                Not coded
            Node_0xD2:
                Not coded
            Node_0xD3:
                Not coded
            Node_0xD4:
                Not coded
            Node_0xD5:
                Not coded
            Node_0xD6:
                Not coded
            Node_0xD7:
                Not coded
            Node_0xD8:
                Not coded
            Node_0xD9:
                Not coded
            Node_0xDA:
                Not coded
            Node_0xDB:
                Not coded
            Node_0xDC:
                Not coded
            Node_0xDD:
                Not coded
            Node_0xDE:
                Not coded
            Node_0xDF:
                Not coded
            Node_0xE0:
                Not coded
            Node_0xE1:
                Not coded
            Node_0xE2:
                Not coded
            Node_0xE3:
                Not coded
            Node_0xE4:
                Not coded
            Node_0xE5:
                Not coded
            Node_0xE6:
                Not coded
            Node_0xE7:
                Not coded
            Node_0xE8:
                Not coded
            Node_0xE9:
                Not coded
            Node_0xEA:
                Not coded
            Node_0xEB:
                Not coded
            Node_0xEC:
                Not coded
            Node_0xED:
                Not coded
            Node_0xEE:
                Not coded
            Node_0xEF:
                Not coded
            Node_0xF0:
                Not coded
            Node_0xF1:
                Not coded
            Node_0xF2:
                Not coded
            Node_0xF3:
                Not coded
            Node_0xF4:
                Not coded
            Node_0xF5:
                Not coded
            Node_0xF6:
                Not coded
            Node_0xF7:
                Not coded
            Node_0xF8:
                Not coded
            Node_0xF9:
                Not coded
            Node_0xFA:
                Not coded
            Node_0xFB:
                Not coded
            Node_0xFC:
                Not coded
            Node_0xFD:
                Not coded
            Node_0xFE:
                Not coded
            Node_0xFF:
                Not coded
        Battery adaptation:
            Rated battery capacity:
                75 Ah
            Battery manufacturer:
                JCB
            Battery serial number:
                440811B0EI
            Battery technology:
                Fleece
        Static current measuring mode:
                Not activated
        Transport mode:
                not active
        Component protection showroom mode:
                not active
        GW_Enable_CAN_Timeout_DTC:
            Gateway:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x01:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x02:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x03:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x04:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x05:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x06:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x07:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x08:
                enabled
                enabled
            Parking Assistance:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x0D:
                enabled
            Central Electrics:
                enabled
            All Wheel Control:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x11:
                enabled
                enabled
            Brakes 1:
                not enabled
            Dash Board:
                enabled
            Airbag:
                not enabled
            Gateway_Component_List_Failure_Mask_Node_0x16:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x17:
                enabled
            Radio:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x1A:
                enabled
            Head Up Display:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x1D:
                enabled
            Lock Electronics:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x1F:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x20:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x21:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x22:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x24:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x25:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x26:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x27:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x28:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x29:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x2A:
                enabled
            Special Function 2:
                enabled
            Special Function:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x2E:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x2F:
                enabled
                enabled
                enabled
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x35:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x36:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x37:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x38:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x39:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x3A:
                enabled
            Brake Boost:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x3C:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x3D:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x40:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x41:
                enabled
            Thermal Management:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x43:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x45:
                enabled
            Air Conditioning:
                enabled
            Trailer Function:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x48:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x49:
                enabled
                enabled
                enabled
                enabled
                enabled
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x51:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x52:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x53:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x55:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x56:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x58:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x59:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x5A:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x5B:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x5C:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x5D:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x5E:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x5F:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x60:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x61:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x62:
                enabled
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x66:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x68:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x6B:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x6C:
                enabled
            TV Tuner:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x6E:
                enabled
            Sound System:
                enabled
                enabled
            Tachograph:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x74:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x75:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x78:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x79:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x7A:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x7D:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x7E:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x7F:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x80:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x81:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x82:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x83:
                enabled
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x86:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x87:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x88:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x89:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x8B:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x8C:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x8D:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x8E:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x8F:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x90:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x91:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x92:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x93:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x94:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x95:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x96:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x97:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x98:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x99:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x9A:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x9B:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x9D:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x9E:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x9F:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA0:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA1:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA2:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA3:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA5:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA6:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA7:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xA8:
                enabled
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xAA:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xAB:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xAC:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xAD:
                enabled
            Battery regulation:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xAF:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB0:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB1:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB2:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB3:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB4:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB5:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB6:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB7:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB8:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xB9:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xBA:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xBB:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xBC:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xBD:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xBE:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xBF:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC0:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC1:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC2:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC3:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC4:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC5:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC6:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC7:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC8:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xC9:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xCA:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xCB:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xCC:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xCD:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xCE:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xCF:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD0:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD1:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD2:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD3:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD4:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD5:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD6:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD7:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD8:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xD9:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xDA:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xDB:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xDC:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xDD:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xDE:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xDF:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE0:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE1:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE2:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE3:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE4:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE5:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE6:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE7:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE8:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xE9:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xEA:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xEB:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xEC:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xED:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xEE:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xEF:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF0:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF1:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF2:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF3:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF4:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF5:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF6:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF7:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF8:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xF9:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xFA:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xFB:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xFC:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xFD:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xFE:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0xFF:
                enabled
            Gateway_Component_List_Failure_Mask_Node_0x00:
                enabled
        GW_mirror_mode:
            mirror_mode_bus:
                Databus drivetrain
            mirror_mode_typ:
                not active
        MKE Check box:
                activated
        WakeUpMonitor_Configuration:
            Sample_Time_Keeping_Awake_Events:
                12 s
            Max_Num_Keeping_Awake_Events:
                100
            WakeUpMonitor_Start_Delay:
                0 s
        WakeUpMonitor_Activation:
            Activation:
                activated
            Open_Filter_Activate:
                Not activated
        Distance left for deactivation of static current measuring mode:
        Distance left for deactivation of transport mode:
                50
            Activation stages:
                Not activated
            Malfunction states:
                no error
        Deactivation of start-stop function:
                Mode not active
        Auxiliary heater activation restriction request:
            Switch_on_ban_activation:
                Mode not active
            Set_point_target_time:
        Energy management deactivation stage:
                Mode not active
        EM_energy_management_warning_displays:
            Generatormeldungen:
                Mode not active
            Batteriemeldungen:
                Mode not active
            MMI Vorwarnungen:
                Mode not active
            Ladezustand:
                Mode not active
        Energy management heat output control status:
                Mode not active
        Increase idle speed request:
                Mode not active
        Battery terminal recognition:
                connected
        Hysteresis voltage:
            Voltage_lowering:
                12.1 V
            Voltage_elevation:
                12.1 V
        EM_nominal_voltage_limitation_low_beams:
                12.1 V
        Generator specified voltage value variable:
            Set_point_voltage:
                10.6 V
        EM_start_stop_requirement_ambient_temperature:
            Minimum_temperature:
                -50.0 °C
            Maximum_temperature:
                -50.0 °C
        EM_requirement_reduction_air_blowers:
                Mode not active
        EM_requirement_cyclic_time_voltage_measurement:
                0 s
        Production mode:
            p_mode_deactivate_recuperation:
                Deactivating
            p_mode_deactivate_mfl_keys:
                Deactivating
            Development messages:
                not active
        GW_routing_0:
        GW_routing_1:
        GW_routing_2:
        GW_routing_3:
        GW_routing_4:
        GW_routing_5:
        GW_routing_6:
        GW_routing_7:
        GW_routing_8:
        GW_routing_9:
        Driving_Profile_Selection_Parameter:
            Driving_Profile_Selection_Toogle_Time_Adaptation:
                500 ms
            Driving_Profile_Selection_Touch_Contact_Time_Adaption:
                3000 ms
            Driving_Profile_Selection_Indication_Control_Adaption:
                3000 ms
            Driving_Profile_Selection_Kombi_Offset_Adaption:
                0 ms
            Driving_Profile_Selection_Sync_Time_Adaptation:
                500 ms
            Driving_Profile_Selection_Request_Repetition_Time_Adaptation:
                180000 ms
            Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation:
                10000 ms
            Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation:
                120
            Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation:
                60000 ms
            Driving_Profile_Selection_Counter_Master_Reset:
                active
        Efficiency program display:
            Live tip air resistance: close window/sunroof:
                activated
            Live tip engine brake: uncouple not until below 1300 RPM:
                activated
            Live tip do not operate gas pedal during engine start:
                activated
            Live tip adhere to switch display (only manual switch):
                activated
            Live tip use start-stop-system:
                activated
            Live tip switch on start-stop-system:
                activated
            Live tip air conditioning: close window/sunroof:
                activated
            Live tip use gearshift position D:
                activated
            Live tip Do not press accelerator pedal at standstill:
                activated
            Live tip sunroof open: switch of A/C (AC button):
                activated
            Live tip avoid engine warm-up at standstill:
                activated
            Comfort use A/C:
                activated
            Convenience_consumption_air_condition_ventilation_rear:
                activated
            Comfort use parking heater:
                activated
            Comfort use windshield heater:
                activated
            Comfort use rear window heater:
                activated
            Comfort use steering wheel heater:
                activated
            Comfort use rear heater:
                activated
            Comfort use mirror heater:
                activated
            Comfort use front seat heater:
                activated
            Comfort use rear seat heater:
                activated
            Comfort use front seat ventilation:
                activated
            Comfort use rear seat ventilation:
                activated
            Comfort use fog light:
                activated
            Comfort use rear fog light:
                activated
            Driver_warning_indications_Driving_Profile_dependency:
                Driver_warning_indications_Driving_Profile_independent
            Comfort use parking heater consumption emission:
                activated
            Convenience_consumption_mirror_heating_dependency:
                Until_temperature_threshold_with_after-run_with_switch
        Production process data 1:
                ffca
        Counter for inconsistent states:
        Start/stop start voltage limit:
                7.6 V
        Transfer of release code for a SWaP function:
                00
        Selection of release codes for a SWaP function:
                ffffffff
        AGW_Calibration:
            AGW_Time_Fade_In:
                0 ms
            AGW_Time_Fade_Out:
                0 ms
            AGW_Time_Fade_In_Start:
                0 ms
            AGW_Time_Fade_Out_Start:
                0 ms
            AGW_Time_Start_Sequence:
                0 ms
            AGW_Time_Start_Delay:
                0 ms
            AGW_Brightness_Start_Sequence:
                100 %
            AGW_fade_in_deactivation_threshold:
                100
        AGW_Function_Releases:
            AGW_Enabling_Brightness:
                active
            AGW_Enabling_Flash_Frequency:
                active
            AGW_Enabling_Supression_Symbol:
                active
        Number requests autonomous recharging:
                9
        Cyclization limitation request battery service:
        Range gain:
            PTC(low voltage) consumption:
                activated
            Convenience_consumption_means_plug:
                activated
            Consumption_mirror_heating_in_heated_rear_window:
                activated
            Windshield heater consumption in AC system:
                activated
            List at engine still stand:
                activated
            Listendarstellung Absolutwerte mit Gewichtung:
                activated
            Catalogue range display:
                activated
            Loading condition catalogue range display:
                activated
            Convenience_consumption_air_condition_ventilation_manually:
                activated
            Range gain AC system:
                activated
            Range gain auxiliary heater:
                activated
            Range gain window defogger:
                activated
            Range gain seat heater front:
                activated
            Range gain front set ventilation:
                activated
            Range gain rear heater:
                activated
            Range gain fog light:
                activated
            Range gain rear fog light:
                activated
            Range gain windshield heating:
                activated
            Range gain steering wheel heater:
                activated
            Range gain mirror heater:
                activated
            Range gain rear seat heater:
                activated
                activated
            Windshield heater range gain in AC system:
                activated
            PTC(low voltage) range gain:
                activated
            data block:
            data block:
            data block:
                65535
            data block:
                65535
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                SJ8-FST
            Day of manufacture:
                08.05.14
                1080
                0376
            Decoration variant:
        Diagnostic mode:
                8S0907468
        Software version:
                0184
                8S0907468
        System description:
                GW MQB TT3
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
                EV_GatewContiAU33X
                011002
        Hardware version:
                012
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J533
            data block:
                2006
            data block:
                0184
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 22 All Wheel Control
    System description: Haldex4Motion
    Software number: 0CQ907554C
    Software version: 7742
    Hardware number: 0CQ525130
    Hardware version: H52
    Serial number: HA1-00028.06.1400011971
    ODX name: EV_AllWheelContrHA1VW37X
    ODX version: 002001
    Backup name: All Wheel Drive
    Long coding:
        0101
    Adaptations:
                Not activated
        Acoustic measure, gasoline:
            Acoustic measure, anti droning:
                Keine Maßnahme
            Acoustic measure, anti impact wrench:
                Keine Maßnahme
        Acoustic measure, diesel:
                Keine Maßnahme
                Keine Maßnahme
        Acoustic measure, wiring logic:
                Standard
            Bootloader:
            Application:
            Data record:
            Data record 2:
            Bootloader:
            Application:
            Data record:
            Data record 2:
            Year:
                14
            Month:
                6
            Day:
                28
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
                HA1-000
            Day of manufacture:
                28.06.14
                0001
                1971
        Diagnostic mode:
                0CQ907554C
        Software version:
                7742
                0CQ525130
        System description:
                Haldex4Motion
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                002001
        Hardware version:
                H52
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J492
                0006001600080008R018
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 2B Steering Column Locking
    System description: ELV-MQBB
    Software number: 3Q0905861
    Software version: 0031
    Hardware number: 3Q0905861
    Hardware version: H05
    Serial number: 14000035318018
    ODX name: EV_ELVMarquMQBB
    ODX version: 001007
    Backup name: Steering Column Lock
    Long coding:
        0900000000000000
    Adaptations:
                not active
        Steering column lock unlocked:
                unlock
        functional_check_manufacturer:
                tested
        functional_check_steering_column_supplier:
                tested
            Bootloader:
            Application:
            CoCo:
            Bootloader:
                1000
            Application:
                1000
            CoCo:
                1000
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                MD9-MSR
            Day of manufacture:
                29.04.14
                0606
                0051
        Diagnostic mode:
                3Q0905861
        Software version:
                0031
                3Q0905861
        System description:
                ELV-MQBB
            Device number:
            Importer number:
            Dealership number:
                EV_ELVMarquMQBB
                001007
        Hardware version:
                H05
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J764
            Bootloader:
                0010
            Application:
                0031
            CoCo:
                0020
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 42 Door Electronics Driver Side
    System description: TSG FS
    Software number: 5Q0959593C
    Software version: 0026
    Hardware number: 5Q0959593B
    Hardware version: 020
    Serial number: 28071403110691
    ODX name: EV_DCUDriveSideEWMAXKLO
    ODX version: 006003
    Backup name: Driver door
    Long coding:
        001E47224000040100001402
    Adaptations:
        Production mode:
            Production mode:
        Reversing_Threshold_Driver_Side_Front:
                90 %
            Bootloader:
            Application:
            Data record:
            Bootloader:
            Application:
                1000
            Data record:
                65534
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
                KO1-MAL
            Day of manufacture:
                28.07.14
                0311
                0691
        Diagnostic mode:
                5Q0959593C
        Software version:
                0026
                5Q0959593B
        System description:
                TSG FS
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                006003
        Hardware version:
                020
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J386
            Bootloader:
                3385
            Application:
                0026
            Data record:
                0012
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 44 Steering Assistance
    System description: EPS_MQB_ZFLS
    Software number: 3Q0909144H
    Software version: 5061
    Hardware number: 3Q0909144F
    Hardware version: 503
    ODX name: EV_SteerAssisMQB
    ODX version: 012140
    Backup name: Steering Assistance
    Long coding:
        9103
    Adaptations:
                not active
        Characteristic curve of steering assistance:
                Driving profile selection button
        Activation of pwr steering asst without engine running:
                not active
        XCP calibration protocol:
                not active
        Software end stop:
                active
        Straight line running:
                active
        Support power:
                100%
        Driving profile switchover:
                Incremental, controlled over time
        Download without rest bus:
            Suspension data bus:
                not active
        RPM monitoring:
                active
            Bootloader:
            Application:
                3
            Data record:
                3
            Bootloader:
                1000
            Application:
                1000
            Data record:
                1000
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                12313
            Importer number:
                514
            Dealership number:
                19456
            Programming status:
                Correct result
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                12313
            Importer number:
                514
            Dealership number:
                19456
            Programming status:
                Correct result
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                12313
            Importer number:
                514
            Dealership number:
                19456
            Programming status:
                Correct result
                ZF0-000
            Day of manufacture:
                23.07.14
                0109
                0016
        Diagnostic mode:
                3Q0909144H
        Software version:
                5061
                00000000000001432
                3Q0909144F
        System description:
                EPS_MQB_ZFLS
            Device number:
                12313
            Importer number:
                514
            Dealership number:
                19456
                EV_SteerAssisMQB
                012140
        Hardware version:
                503
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J500
            Bootloader:
                0319
            Application:
                4345
            Data record:
                0937
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 52 Door Electronics Passenger Side
    System description: TSG BFS
    Software number: 5Q0959592C
    Hardware number: 5Q0959592B
    Serial number: 07071402090145
    ODX name: EV_DCUPasseSideEWMAXKLO
    ODX version: 006003
    Backup name: Passenger door
    Long coding:
        001E47224C00040100001402
    Adaptations:
        Production mode:
            Production mode:
        Reversing_Threshold_Passenger_Side_Front:
                90 %
            Bootloader:
            Application:
            Data record:
            Bootloader:
            Application:
                1000
            Data record:
                65534
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
                KO1-MAL
            Day of manufacture:
                07.07.14
                0209
                0145
        Diagnostic mode:
                5Q0959592C
        Software version:
                0026
                5Q0959592B
        System description:
                TSG BFS
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                006003
        Hardware version:
                020
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J387
            Bootloader:
                3385
            Application:
                0026
            Data record:
                0012
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: 55 Headlight Regulation
    System description: MxB-ECU
    Software number: 4H4907357D
    Software version: 0090
    Hardware number: 7P6907357B
    Hardware version: 001
    Serial number: --------------
    ODX name: EV_HeadlRegulAUDIMXBAU64X
    ODX version: 005008
    Backup name: Headlight Regulation
    Long coding:
        03EA001E2B200200
    Subsystems:
        Subsystem: LeiMo links
        Long coding: E01800
        Subsystem: LeiMo rechts
        Long coding: E01800
        Subsystem: LED LeiMo li.
        Long coding: E01800
        Subsystem: LED LeiMo re.
        Long coding: E01800
    Adaptations:
        Reference_Run_Start_Condition:
                Engine start
        PWM to Level Scaling Factor Front:
                3.30 mm/%
        PWM to Level Scaling Factor Rear:
                5.50 mm/%
        Presentation run dynamic AFS light:
                not active
        Presentation mode:
                not active
        Adaptive light functions:
                active
        Activate left/right hand drive switch-over:
                not active
        Matrix light, total dimming:
                100.8
        Matrix headlamp, function at standstill:
                not active
        Reference_Run_Activation_Effect:
                Activation effect enabled by motor start
                not active
        Order_Reference_Run_Activation_Effect:
                No dependency
        Bit pattern of individual segment activation, left headlight:
            LED 1:
                Off
            LED 2:
                Off
            LED 3:
                Off
            LED 4:
                Off
            LED 5:
                Off
            LED 6:
                Off
            LED 7:
                Off
            LED 8:
                Off
            LED 9:
                Off
            LED 10:
                Off
            LED 11:
                Off
            LED 12:
                Off
            LED 13:
                Off
            LED 14:
                Off
            LED 15:
                Off
            LED 16:
                Off
            LED 17:
                Off
            LED 18:
                Off
            LED 19:
                Off
            LED 20:
                Off
            LED 21:
                Off
            LED 22:
                Off
            LED 23:
                Off
            LED 24:
                Off
            LED 25:
                Off
            LED 26:
                Off
            LED 27:
                Off
            LED 28:
                Off
            LED 29:
                Off
            LED 30:
                Off
            LED 31:
                Off
            LED 32:
                Off
            LED 33:
                Off
            LED 34:
                Off
            LED 35:
                Off
            LED 36:
                Off
            LED 37:
                Off
            LED 38:
                Off
            LED 39:
                Off
            LED 40:
                Off
            LED 41:
                Off
            LED 42:
                Off
            LED 43:
                Off
            LED 44:
                Off
            LED 45:
                Off
        Bit pattern of individual segment activation, right headlight:
            LED 1:
                Off
            LED 2:
                Off
            LED 3:
                Off
            LED 4:
                Off
            LED 5:
                Off
            LED 6:
                Off
            LED 7:
                Off
            LED 8:
                Off
            LED 9:
                Off
            LED 10:
                Off
            LED 11:
                Off
            LED 12:
                Off
            LED 13:
                Off
            LED 14:
                Off
            LED 15:
                Off
            LED 16:
                Off
            LED 17:
                Off
            LED 18:
                Off
            LED 19:
                Off
            LED 20:
                Off
            LED 21:
                Off
            LED 22:
                Off
            LED 23:
                Off
            LED 24:
                Off
            LED 25:
                Off
            LED 26:
                Off
            LED 27:
                Off
            LED 28:
                Off
            LED 29:
                Off
            LED 30:
                Off
            LED 31:
                Off
            LED 32:
                Off
            LED 33:
                Off
            LED 34:
                Off
            LED 35:
                Off
            LED 36:
                Off
            LED 37:
                Off
            LED 38:
                Off
            LED 39:
                Off
            LED 40:
                Off
            LED 41:
                Off
            LED 42:
                Off
            LED 43:
                Off
            LED 44:
                Off
            LED 45:
                Off
        Unknown:
    Mileage: 22180 km
Backup
    Control unit: 5F Information Control Unit 1
    System description: MU-H-N-ER
    Software number: 8S0035028D
    Software version: 0364
    Hardware number: 8S0035028
    Hardware version: H33
    Serial number: A262G0EB003237
    ODX name: EV_MUHig6C3Gen2HBAS
    ODX version: 001115
    Backup name: Multimedia
    Long coding:
        01330401FF08000011110001000A00902F0000E100F00000FE
    Adaptations:
        Regional codes:
            Parameter_Set_DVD_Region_Code:
            Parameter_Set_BlueRay_System_Region_Code:
        Automatic ring break diagnostic:
                No automatic start
        Vehicle dimensions:
            Length:
                0 mm
            Width:
                0 mm
            Height:
                0 mm
        Summertime-automatic:
                Europe
        Production mode:
                000000
        Number 2 for Info call:
                000002C00000000000000000000000000000001AE4F0FF
        Number 2 for roadside assistance:
                005F34390000000000000000000000000000001A0CF1FF
        Number 1 for Info call:
        Number 1 for roadside assistance:
        Sporadic ring break detection:
                Visual
        Awakening ability on optical databus:
                Off
        Number 1 (roaming) for roadside assistance:
        Roadside assistance mode:
                Corresponding setting in MMI
        Number attempted dialing attempts for roadside assistance:
            Establishing a connection:
                3
        Electrical test of loudspeakers:
            Mode:
                automatic
            Parameter_AC-Diagnostics_Channel_1_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_1_Test_Volume:
                30
            Parameter_AC-Diagnostics_Channel_2_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_2_Test_Volume:
                20
            Parameter_AC-Diagnostics_Channel_3_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_3_Test_Volume:
                20
            Parameter_AC-Diagnostics_Channel_4_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_4_Test_Volume:
                30
            Parameter_AC-Diagnostics_Channel_5_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_5_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_6_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_6_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_7_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_7_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_8_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_8_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_9_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_9_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_10_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_10_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_11_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_11_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_12_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_12_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_13_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_13_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_14_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_14_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_15_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_15_Test_Volume:
                85
            Parameter_AC-Diagnostics_Channel_16_Test_Frequency:
                19000 Hz
            Parameter_AC-Diagnostics_Channel_16_Test_Volume:
                85
        Fee-based traffic information (TMC):
                15
        Infotainment recorder:
                activated
        Wheel pulse:
        Wheel circ.:
                0 mm
        Check tone frequency:
            High note frequency range:
                4000 Hz
            Medium note frequency range:
                1000 Hz
            Low note frequency range:
                100 Hz
        Confirmation of installation change:
            Key:
                1e4b
        Copy multimedia data:
                On
            Optical drive:
                On
        Bluetooth:
                On
        Bluetooth: Sniff mode:
                On
        Audio management mute function:
                Muting of audio sources
        Audio_Managment_Soundset_Menu:
                Off
        WLAN:
                On
        Dimming_Ambient_Illumination_Information_Control_Unit:
            X1:
            Y1:
            X2:
                50
            Y2:
                50
            X3:
                100
            Y3:
                100
            Release:
                not_released
        CD eject button:
            CD eject button:
                Enabled
        Developer mode:
                activated
                ffffffff
        Dimming_Ambient_Illumination_Operating_and_Display_Unit:
            X1:
            Y1:
            X2:
                50
            Y2:
                50
            X3:
                100
            Y3:
                100
        Country identification, country of sale:
                DE
            Infotainment_CAN_Messages:
                Off
            MIB_CAN_Messages:
                Off
        Dimming_Functional_Illumination_for_Operating_Unit:
            X1:
            Y1:
                1 %
            X2:
                10
            Y2:
                1 %
            X3:
                100
            Y3:
                6 %
            X4:
                150
            Y4:
                25 %
            X5:
                200
            Y5:
                55 %
            X6:
                253
            Y6:
                100 %
        Vehicle configuration:
            VZAPro:
                On
            online_POI:
                On
            online_POI_voice:
                On
            online_portal_browser_services:
                On
            online_navigation:
                On
            online_street_view:
                On
            WIFI_Hotspot:
                On
            my_audi:
                On
            picture_navi:
                Off
            online_dictation:
                On
            remote_HMI:
                Off
            advanced_range_display:
                Off
            gracenote_online_coverarts:
                Off
            gracenote_online_other:
                Off
            gracenote_local_coverarts:
                Off
            gracenote_local_other:
                Off
            UPnP:
                On
            OPS_display_in_dash_board_display_unit:
                Off
            Joker_button_1:
                Not present
            Joker_button_2:
                Not present
            LTE_modul:
                activated
            Support_second_phone:
                Off
            Support_of_threeway_calling:
                Off
            Dtmf_without_active_call:
                Off
            Support_for_response_and_hold:
                Off
            Sim_card_mode_switch:
                Not present
            Phone_module_operation_mode:
                only data service act.
            PSD_Protocol_Version:
                PSD_1.5
            RVC_video_input:
                FBAS
            Station_Logo_DB_Mode:
            TPEG_availability:
                Off
            VZO:
                On
            LGI:
                On
            ProbeCar_vzo:
                On
            online_media:
                On
            ProbeCar_lgi:
                Off
            Baidu_Car_Life:
                Off
            Google_GAL:
                Off
            Apple_DIO:
                Off
            SDS_Region_Flag:
                REGION_EU
            Privacy_WithPINRequest:
            Phone_HMI_Privacy:
                200
            Hybrid_Radio_additional_online_data:
                Not activated
            media_control:
                Not activated
            UOTA:
                On
            WiFi_Client_HMI:
                On
            RSE_software_component:
                Deactivated
            Mirror_link:
                Off
            Smartphone_interface_for_rhmi:
                activated
            sd_slot_deactivation:
                no restriction
            map_sms_support:
                Off
            map_email_support:
                Off
            map_instant_messaging_support:
                Off
            sim_data_only_sms_support:
                Off
            esim_data_only_sms_support:
                Off
            allow_message_editing:
                Off
            vehicle_readiness_sound:
                Not activated
            MirrorLink_Country_Code:
                MIB_EU
            vehicle_leaving_sound:
                Not activated
            MirrorLink_RGB_Preference:
                RGB565
            conditioning_variant:
            Map_Style:
            Hybrid_Radio_Range_Extender:
                deactivated
            scon_telephony:
                Not activated
            voice_over_lte:
                Not activated
            show_volte_hmi_switch:
                Not activated
            online_radio:
                deactivated
            wlan_5ghz_switch:
                activated
            unblock_functions_while_piloted_driving:
                blocked
            block_hmi_function_p_epb:
                blocked
            Popup_if_GPS_services_in_use:
                Not activated
            Baidu_Car_Life_ios:
                Off
            Tencent_myCar_canceling_share_location:
                Off
            UOTA_2:
                Off
            Pilot_Parking:
                Not activated
            perso_v_threshold:
            perso_v_threshold_hysteresis:
            FoD:
                SWaP
            Baidu_Car_Life_Wireless:
                Off
            Baidu_Car_Life_ios_Wireless:
                Off
            Google_GAL_Wireless:
                Off
            Apple_DIO_Wireless:
                Off
            rvc_low_black_screen_velocity_threshold:
                Not activated
            rvc_low_failsafe:
                Not activated
            rvc_low_black_screen_trunk_open:
                Not activated
            AliBox:
                Off
            internet_over_WLAN_default_setting:
                Off
            correction_e_mileage:
        Car_Function_Adaptations_Gen2:
            menu_display_ACC:
                Not activated
            menu_display_ACC_operation_clamp_15_off:
                Not activated
            menu_display_ACC_over_threshold_high:
                Not activated
            menu_display_ACC_standstill:
                Not activated
            menu_display_ACC_after_disclaimer:
                Not activated
            menu_display_ambient_illumination:
                activated
            menu_display_ambient_illumination_clamp_15_off:
                Not activated
            menu_display_ambient_illumination_over_threshold_high:
                activated
            menu_display_ambient_illumination_standstill:
                Not activated
            menu_display_ambient_illumination_after_disclaimer:
                Not activated
            menu_display_pdc:
                activated
            menu_display_pdc_clamp_15_off:
                Not activated
            menu_display_pdc_over_threshold_high:
                Not activated
            menu_display_pdc_standstill:
                Not activated
            menu_display_pdc_after_disclaimer:
                Not activated
            menu_display_awv:
                Not activated
            menu_display_awv_clamp_15_off:
                Not activated
            menu_display_awv_over_threshold_high:
                Not activated
            menu_display_awv_standstill:
                Not activated
            menu_display_awv_after_disclaimer:
                Not activated
            menu_display_Lane_Departure_Warning:
                activated
            menu_display_Lane_Departure_Warning_clamp_15_off:
                Not activated
            menu_display_Lane_Departure_Warning_over_threshold_high:
                activated
            menu_display_Lane_Departure_Warning_standstill:
                Not activated
            menu_display_Lane_Departure_Warning_after_disclaimer:
                Not activated
            menu_display_lane_assistant:
                Not activated
            menu_display_lane_assistant_clamp_15_off:
                Not activated
            menu_display_lane_assistant_over_threshold_high:
                Not activated
            menu_display_lane_assistant_standstill:
                Not activated
            menu_display_lane_assistant_after_disclaimer:
                Not activated
            menu_display_exterior_illumination:
                activated
            menu_display_exterior_illumination_clamp_15_off:
                Not activated
            menu_display_exterior_illumination_over_threshold_high:
                activated
            menu_display_exterior_illumination_standstill:
                Not activated
            menu_display_exterior_illumination_after_disclaimer:
                Not activated
            menu_display_windows:
                Not activated
            menu_display_windows_clamp_15_off:
                Not activated
            menu_display_windows_over_threshold_high:
                Not activated
            menu_display_windows_standstill:
                Not activated
            menu_display_windows_after_disclaimer:
                Not activated
            menu_display_clima_configuration:
                activated
            menu_display_clima_configuration_clamp_15_off:
                Not activated
            menu_display_clima_configuration_over_threshold_high:
                activated
            menu_display_clima_configuration_standstill:
                Not activated
            menu_display_clima_configuration_after_disclaimer:
                Not activated
            menu_display_auxiliary_heating:
                Not activated
            menu_display_auxiliary_heating_clamp_15_off:
                Not activated
            menu_display_auxiliary_heating_over_threshold_high:
                Not activated
            menu_display_auxiliary_heating_standstill:
                Not activated
            menu_display_auxiliary_heating_after_disclaimer:
                Not activated
            menu_display_board_computer:
                activated
            menu_display_board_computer_clamp_15_off:
                Not activated
            menu_display_board_computer_over_threshold_high:
                activated
            menu_display_board_computer_standstill:
                Not activated
            menu_display_board_computer_after_disclaimer:
                Not activated
            menu_display_rdk:
                activated
            menu_display_rdk_clamp_15_off:
                Not activated
            menu_display_rdk_over_threshold_high:
                Not activated
            menu_display_rdk_standstill:
                activated
            menu_display_rdk_after_disclaimer:
                Not activated
            menu_display_wiper:
                activated
            menu_display_wiper_clamp_15_off:
                Not activated
            menu_display_wiper_over_threshold_high:
                activated
            menu_display_wiper_standstill:
                Not activated
            menu_display_wiper_after_disclaimer:
                Not activated
            menu_display_sia:
                activated
            menu_display_sia_clamp_15_off:
                Not activated
            menu_display_sia_over_threshold_high:
                activated
            menu_display_sia_standstill:
                Not activated
            menu_display_sia_after_disclaimer:
                Not activated
            menu_display_seat_configuration:
                Not activated
            menu_display_seat_configuration_clamp_15_off:
                Not activated
            menu_display_seat_configuration_over_threshold_high:
                Not activated
            menu_display_seat_configuration_standstill:
                Not activated
            menu_display_seat_configuration_after_disclaimer:
                Not activated
            menu_display_central_locking:
                activated
            menu_display_central_locking_clamp_15_off:
                Not activated
            menu_display_central_locking_over_threshold_high:
                activated
            menu_display_central_locking_standstill:
                Not activated
            menu_display_central_locking_after_disclaimer:
                Not activated
            menu_display_compass:
                Not activated
            menu_display_compass_clamp_15_off:
                Not activated
            menu_display_compass_over_threshold_high:
                Not activated
            menu_display_compass_standstill:
                Not activated
            menu_display_compass_after_disclaimer:
                Not activated
            menu_display_charisma:
                activated
            menu_display_charisma_clamp_15_off:
                Not activated
            menu_display_charisma_over_threshold_high:
                activated
            menu_display_charisma_standstill:
                Not activated
            menu_display_charisma_after_disclaimer:
                Not activated
            menu_display_oil_level:
                Not activated
            menu_display_oil_level_clamp_15_off:
                Not activated
            menu_display_oil_level_over_threshold_high:
                Not activated
            menu_display_oil_level_standstill:
                Not activated
            menu_display_oil_level_after_disclaimer:
                Not activated
            menu_display_vin:
                activated
            menu_display_vin_clamp_15_off:
                Not activated
            menu_display_vin_over_threshold_high:
                activated
            menu_display_vin_standstill:
                Not activated
            menu_display_vin_after_disclaimer:
                Not activated
            menu_display_clock:
                activated
            menu_display_clock_clamp_15_off:
                Not activated
            menu_display_clock_over_threshold_high:
                activated
            menu_display_clock_standstill:
                Not activated
            menu_display_clock_after_disclaimer:
                Not activated
            menu_display_air_damper:
                Not activated
            menu_display_air_damper_clamp_15_off:
                Not activated
            menu_display_air_damper_over_threshold_high:
                Not activated
            menu_display_air_damper_standstill:
                Not activated
            menu_display_air_damper_after_disclaimer:
                Not activated
            menu_display_headup_display:
                Not activated
            menu_display_headup_display_clamp_15_off:
                Not activated
            menu_display_headup_display_over_threshold_high:
                Not activated
            menu_display_headup_display_standstill:
                Not activated
            menu_display_headup_display_after_disclaimer:
                Not activated
            menu_display_central_unit_master:
                activated
            menu_display_central_unit_master_clamp_15_off:
                Not activated
            menu_display_central_unit_master_over_threshold_high:
                activated
            menu_display_central_unit_master_standstill:
                Not activated
            menu_display_central_unit_master_after_disclaimer:
                Not activated
            menu_display_hybrid:
                Not activated
            menu_display_hybrid_clamp_15_off:
                Not activated
            menu_display_hybrid_over_threshold_high:
                Not activated
            menu_display_hybrid_standstill:
                Not activated
            menu_display_hybrid_after_disclaimer:
                Not activated
            menu_display_ugdo:
                Not activated
            menu_display_ugdo_clamp_15_off:
                Not activated
            menu_display_ugdo_over_threshold_high:
                Not activated
            menu_display_ugdo_standstill:
                Not activated
            menu_display_ugdo_after_disclaimer:
                Not activated
            menu_display_night_vision:
                Not activated
            menu_display_night_vision_clamp_15_off:
                Not activated
            menu_display_night_vision_over_threshold_high:
                Not activated
            menu_display_night_vision_standstill:
                Not activated
            menu_display_night_vision_after_disclaimer:
                Not activated
            menu_display_side_view:
                Not activated
            menu_display_side_view_clamp_15_off:
                Not activated
            menu_display_side_view_over_threshold_high:
                Not activated
            menu_display_side_view_standstill:
                Not activated
            menu_display_side_view_after_disclaimer:
                Not activated
            menu_display_reversible_belt_pre_load:
                Not activated
            menu_display_reversible_belt_pre_load_clamp_15_off:
                Not activated
            menu_display_reversible_belt_pre_load_over_threshold_high:
                Not activated
            menu_display_reversible_belt_pre_load_standstill:
                Not activated
            menu_display_reversible_belt_pre_load_after_disclaimer:
                Not activated
            menu_display_MFL_jocker:
                activated
            menu_display_MFL_jocker_clamp_15_off:
                Not activated
            menu_display_MFL_jocker_over_threshold_high:
                activated
            menu_display_MFL_jocker_standstill:
                Not activated
            menu_display_MFL_jocker_after_disclaimer:
                Not activated
            menu_display_road_sign_identification:
                activated
            menu_display_road_sign_identification_clamp_15_off:
                Not activated
            menu_display_road_sign_identification_over_threshold_high:
                activated
            menu_display_road_sign_identification_standstill:
                Not activated
            menu_display_road_sign_identification_after_disclaimer:
                Not activated
            menu_display_attention_identification:
                Not activated
            menu_display_attention_identification_clamp_15_off:
                Not activated
            menu_display_attention_identification_over_threshold_high:
                activated
            menu_display_attention_identification_standstill:
                Not activated
            menu_display_attention_identification_after_disclaimer:
                Not activated
            menu_display_adaptive_key:
                activated
            menu_display_adaptive_key_clamp_15_off:
                Not activated
            menu_display_adaptive_key_over_threshold_high:
                activated
            menu_display_adaptive_key_standstill:
                Not activated
            menu_display_adaptive_key_after_disclaimer:
                Not activated
            menu_display_car_mirror:
                Not activated
            menu_display_car_mirror_clamp_15_off:
                Not activated
            menu_display_car_mirror_over_threshold_high:
                Not activated
            menu_display_car_mirror_standstill:
                Not activated
            menu_display_car_mirror_after_disclaimer:
                Not activated
            menu_display_driving_school:
                Not activated
            menu_display_driving_school_clamp_15_off:
                Not activated
            menu_display_driving_school_over_threshold_high:
                Not activated
            menu_display_driving_school_standstill:
                Not activated
            menu_display_driving_school_after_disclaimer:
                Not activated
            menu_display_weariness_recognition:
                Not activated
            menu_display_weariness_recognition_clamp_15_off:
                Not activated
            menu_display_weariness_recognition_over_threshold_high:
                Not activated
            menu_display_weariness_recognition_standstill:
                Not activated
            menu_display_weariness_recognition_after_disclaimer:
                Not activated
            menu_display_BCmE:
                Not activated
            menu_display_BCmE_clamp_15_off:
                Not activated
            menu_display_BCmE_over_threshold_high:
                Not activated
            menu_display_BCmE_standstill:
                Not activated
            menu_display_BCmE_after_disclaimer:
                Not activated
            menu_display_user_eco_rating:
                Not activated
            menu_display_user_eco_rating_clamp_15_off:
                Not activated
            menu_display_user_eco_rating_over_threshold_high:
                Not activated
            menu_display_user_eco_rating_standstill:
                Not activated
            menu_display_user_eco_rating_after_disclaimer:
                Not activated
            menu_display_Brake_Function:
                Not activated
            menu_display_Brake_Function_clamp_15_off:
                Not activated
            menu_display_Brake_Function_over_threshold_high:
                Not activated
            menu_display_Brake_Function_standstill:
                Not activated
            menu_display_Brake_Function_after_disclaimer:
                Not activated
            menu_display_Start_Stop_reasons:
                Not activated
            menu_display_Start_Stop_reasons_clamp_15_off:
                Not activated
            menu_display_Start_Stop_reasons_over_threshold_high:
                Not activated
            menu_display_Start_Stop_reasons_standstill:
                Not activated
            menu_display_Start_Stop_reasons_after_disclaimer:
                Not activated
            menu_display_angle_of_slope:
                Not activated
            menu_display_angle_of_slope_clamp_15_off:
                Not activated
            menu_display_angle_of_slope_over_threshold_high:
                Not activated
            menu_display_angle_of_slope_standstill:
                Not activated
            menu_display_angle_of_slope_after_disclaimer:
                Not activated
            menu_display_battery_management:
                Not activated
            menu_display_battery_management_clamp_15_off:
                Not activated
            menu_display_battery_management_over_threshold_high:
                Not activated
            menu_display_battery_management_standstill:
                Not activated
            menu_display_battery_management_after_disclaimer:
                Not activated
            menu_display_RearSeatEntertainment:
                Not activated
            menu_display_RearSeatEntertainment_clamp_15_off:
                Not activated
            menu_display_RearSeatEntertainment_over_threshold_high:
                Not activated
            menu_display_RearSeatEntertainment_standstill:
                Not activated
            menu_display_RearSeatEntertainment_after_disclaimer:
                Not activated
            menu_display_special_functions:
                Not activated
            menu_display_special_functions_clamp_15_off:
                Not activated
            menu_display_special_functions_over_threshold_high:
                Not activated
            menu_display_special_functions_standstill:
                Not activated
            menu_display_special_functions_after_disclaimer:
                Not activated
            menu_display_trailer_assistant:
                Not activated
            menu_display_trailer_assistant_clamp_15_off:
                Not activated
            menu_display_trailer_assistant_over_threshold_high:
                Not activated
            menu_display_trailer_assistant_standstill:
                Not activated
            menu_display_trailer_assistant_after_disclaimer:
                Not activated
            menu_display_TV_Tuner:
                Not activated
            menu_display_TV_Tuner_clamp_15_off:
                Not activated
            menu_display_TV_Tuner_over_threshold_high:
                Not activated
            menu_display_TV_Tuner_standstill:
                Not activated
            menu_display_TV_Tuner_after_disclaimer:
                Not activated
            menu_auxiliary_climatization:
                Not activated
            menu_auxiliary_climatization_clamp_15_off:
                Not activated
            menu_auxiliary_climatization_over_threshold_high:
                Not activated
            menu_auxiliary_climatization_standstill:
                Not activated
            menu_auxiliary_climatization_after_disclaimer:
                Not activated
            menu_display_Pedestrian_Assist:
                Not activated
            menu_display_Pedestrian_Assist_clamp_15_off:
                Not activated
            menu_display_Pedestrian_Assist_over_threshold_high:
                Not activated
            menu_display_Pedestrian_Assist_standstill:
                Not activated
            menu_display_Pedestrian_Assist_after_disclaimer:
                Not activated
            menu_display_Seat_Pneumatic:
                Not activated
            menu_display_Seat_Pneumatic_clamp_15_off:
                Not activated
            menu_display_Seat_Pneumatic_over_threshold_high:
                Not activated
            menu_display_Seat_Pneumatic_standstill:
                Not activated
            menu_display_Seat_Pneumatic_after_disclaimer:
                Not activated
            menu_display_Curve_Assist:
                Not activated
            menu_display_Curve_Assist_clamp_15_off:
                Not activated
            menu_display_Curve_Assist_over_threshold_high:
                Not activated
            menu_display_Curve_Assist_standstill:
                Not activated
            menu_display_Curve_Assist_after_disclaimer:
                Not activated
            menu_display_eCall:
                Not activated
            menu_display_eCall_clamp_15_off:
                Not activated
            menu_display_eCall_over_threshold_high:
                Not activated
            menu_display_eCall_standstill:
                Not activated
            menu_display_eCall_after_disclaimer:
                Not activated
            menu_display_ENI:
                Not activated
            menu_display_ENI_clamp_15_off:
                Not activated
            menu_display_ENI_over_threshold_high:
                Not activated
            menu_display_ENI_standstill:
                Not activated
            menu_display_ENI_after_disclaimer:
                Not activated
            menu_display_SportHMI:
                Not activated
            menu_display_SportHMI_clamp_15_off:
                Not activated
            menu_display_SportHMI_over_threshold_high:
                Not activated
            menu_display_SportHMI_standstill:
                Not activated
            menu_display_SportHMI_after_disclaimer:
                Not activated
            menu_display_Adblue:
                Not activated
            menu_display_Adblue_clamp_15_off:
                Not activated
            menu_display_Adblue_over_threshold_high:
                Not activated
            menu_display_Adblue_standstill:
                Not activated
            menu_display_Adblue_after_disclaimer:
                Not activated
            menu_display_Spoiler:
                Not activated
            menu_display_Spoiler_clamp_15_off:
                Not activated
            menu_display_Spoiler_over_threshold_high:
                Not activated
            menu_display_Spoiler_standstill:
                Not activated
            menu_display_Spoiler_after_disclaimer:
                Not activated
            menu_display_Efficiency_Assist:
                Not activated
            menu_display_Efficiency_Assist_clamp_15_off:
                Not activated
            menu_display_Efficiency_Assist_over_threshold_high:
                Not activated
            menu_display_Efficiency_Assist_standstill:
                Not activated
            menu_display_Efficiency_Assist_after_disclaimer:
                Not activated
            menu_display_Display_Configuration:
                Not activated
            menu_display_Display_Configuration_clamp_15_off:
                Not activated
            menu_display_Display_Configuration_over_threshold_high:
                Not activated
            menu_display_Display_Configuration_standstill:
                Not activated
            menu_display_Display_Configuration_after_disclaimer:
                Not activated
            menu_soundcontrol:
                Not activated
            menu_soundcontrol_clamp_15_off:
                Not activated
            menu_soundcontrol_over_threshold_high:
                Not activated
            menu_soundcontrol_standstill:
                Not activated
            menu_soundcontrol_after_disclaimer:
                Not activated
            menu_auxiliary_ventilation:
                Not activated
            menu_auxiliary_ventilation_clamp_15_off:
                Not activated
            menu_auxiliary_ventilation_over_threshold_high:
                Not activated
            menu_auxiliary_ventilation_standstill:
                Not activated
            menu_auxiliary_ventilation_after_disclaimer:
                Not activated
            menu_crossroad_assistent:
                Not activated
            menu_crossroad_assistent_clamp_15_off:
                Not activated
            menu_crossroad_assistent_over_threshold_high:
                Not activated
            menu_crossroad_assistent_standstill:
                Not activated
            menu_crossroad_assistent_after_disclaimer:
                Not activated
        Testmode_Video_speed_cutoff:
            speed_limit:
                0 km/h
            pin:
        Base volume of speech output:
                50 %
        Dashboard_Display_Configuration:
            navigation_map_transmission_mode:
                LVDS_map_MMI_dashboard
            navigation_map_compression_mode:
                RLE
            navigation_map_resolution:
                resolution_1
            crossroad_detail_map_transmission_mode:
            crossroad_detail_map_compression_mode:
                RLE
            coverart:
                On
            stationart:
                On
            call_picture:
                On
            crossroad_detail_map_resolution:
                resolution_1
            fastlist_most:
                Off
            ability_switch_nav_maps:
                On
            dynamic_icon:
        Car_Function_List_CAN_Gen2:
            MFL:
                available
            MFL_msg_bus:
                Databus Infotainment
            reserved:
                Not available
            reserved_1:
                Not available
            Oil_level:
                Not available
            Oil_level_msg_bus:
                Not available
            PDC_audio_lowering:
                available
            PDC_audio_lowering_msg_bus:
                Terminal 15
            VIN:
                available
            VIN_msg_bus:
                Terminal 15
            Driving_school:
                Not available
            Driving_school_msg_bus:
                Not available
            Adaptive_key_msg_bus:
                Terminal 15
            Adaptive_key:
                available
            reserved_2:
                Not available
            reserved_3:
                Not available
        Bluetooth: Preferred connection profile for phone book data:
                PBAP
        Interface for external media, activation:
            Connection 1:
                activated
            Connection 2:
                activated
            Connection 3:
                Not activated
            Connection 4:
                Not activated
        Audio Management Input Gain Generation 2:
            TV tuner:
                -128
            Radio (FM):
                -128
            Radio (AM):
                -128
            Digital radio (DAB):
                -128
            Satellite radio:
                -128
            Tuner_TI:
                -128
            Media_AUXIN:
                -128
            Media_AUX_Adapter:
                -128
            Media_CDA:
                -128
            Media_DVD:
                -128
            Media_MFP:
                -128
            Media_BTDevice:
                -128
            TA_Tuner_FM:
                -128
            Media_Bluray:
                -128
            Media_HDMI:
                -128
            Tuner_Online:
                -128
            Media_Airplay:
                -128
            Media_UPNP:
                -128
            Media_Cloud:
                -128
            Tuner_Personal:
                -128
            Tone_Beep:
                -128
            Tone_Warning:
                -128
            Tone_Touchscreen:
                -128
            Tone_Messaging:
                -128
            Exbox_DMB:
                -128
            Mirrorlink:
                -128
            TTS_Nav:
                -128
            TTS_SDS:
                -128
            Phone_Voice:
                -128
            Phone_Ringer_MFP:
                -128
            Phone_Ringer_OB:
                -128
            HFP:
                -128
            TV_AV_IN:
                -128
        Radio_Level_Quality_Offsets:
            Set_AM_Quality_Level_Offset:
            Set_FM_Quality_Level_Offset:
        Audio_Management_Audio_Delay_Lines_Gen2:
            Main_Unit_Delay_On_Off:
                On
            Amplifier_Delay_On_Off:
                On
            Main_Unit_Delay_Time:
                150.00 ms
            Amplifier_Delay_Time:
                150.00 ms
            Headphone_Delay_On_Off:
                Off
            Headphone_Delay_Time:
                0.00 ms
            Headphone_wireless_Delay_On_Off:
                Off
            Headphone_wireless_Delay_Time:
                0.00 ms
        Car_Function_List_BAP_Gen2:
            climatic_master_0x01:
                activated
            climatic_master_0x01_msg_bus:
                Terminal 15
            climatic_slave_0x02:
                Not activated
            climatic_slave_0x02_msg_bus:
                Not activated
            auxilary_heating_0x03:
                Not activated
            auxilary_heating_0x03_msg_bus:
                Not activated
            headup_displ_0x04:
                Not activated
            headup_displ_0x04_msg_bus:
                Not activated
            ACC_0x05:
                Not activated
            ACC_0x05_msg_bus:
                Not activated
            air_suspension_0x06:
                Not activated
            air_suspension_0x06_msg_bus:
                Not activated
            tire_pressure_system_0x07:
                activated
            tire_pressure_system_0x07_msg_bus:
                Terminal 15
            interieur_light_0x08:
                activated
            interieur_light_0x08_msg_bus:
                Terminal 15
            exterieur_light_0x09:
                activated
            exterieur_light_0x09_msg_bus:
                Terminal 15
            parking_assist_0x0A:
                activated
            parking_assist_0x0A_msg_bus:
                Terminal 15
            VPS_0x0B:
                Not activated
            VPS_0x0B_msg_bus:
                Not activated
            wiper_comfort_0x0C:
                activated
            wiper_comfort_0x0C_msg_bus:
                Terminal 15
            central_locking_0x0D:
                activated
            central_locking_0x0D_msg_bus:
                Terminal 15
            mirror_0x0E:
                Not activated
            mirror_0x0E_msg_bus:
                Not activated
            MFA_0x0F:
                activated
            MFA_0x0F_msg_bus:
                Terminal 15
            driver_seat_0x10:
                Not activated
            driver_seat_0x10_msg_bus:
                Not activated
            clock_0x11:
                activated
            clock_0x11_msg_bus:
            service_interval_display_0x12:
                activated
            service_interval_display_0x12_msg_bus:
                Terminal 15
            unit_master_0x13:
                activated
            unit_master_0x13_msg_bus:
                Terminal 15
            UGDO_0x14:
                Not activated
            UGDO_0x14_msg_bus:
                Not activated
            compass_0x15:
                activated
            compass_0x15_msg_bus:
                Comfort data bus
            clima_slave_2_0x16:
                Not activated
            clima_slave_2_0x16_msg_bus:
                Not activated
            charisma_0x17:
                activated
            charisma_0x17_msg_bus:
                Terminal 15
            Night_Vision_0x18:
                Not activated
            Night_Vision_0x18_msg_bus:
                Not activated
            LDW_HCA_0x19:
                activated
            LDW_HCA_0x19_msg_bus:
                Terminal 15
            SWA_0x1A:
                Not activated
            SWA_0x1A_msg_bus:
                Not activated
            AWV_0x1B:
                Not activated
            AWV_0x1B_msg_bus:
                Not activated
            Hybrid_0x1D:
                Not activated
            Hybrid_0x1D_msg_bus:
                Not activated
            SideView_0x1E:
                Not activated
            SideView_0x1E_msg_bus:
                Not activated
            Reversible_Seat_Belt_Tightener_0x1F:
                Not activated
            Reversible_Seat_Belt_Tightener_0x1F_msg_bus:
                Not activated
            Passanger_Seat_0x20:
                Not activated
            Passanger_Seat_0x20_msg_bus:
                Not activated
            traffic_sign_recognition_0x21:
                Not activated
            traffic_sign_recognition_0x21_msg_bus:
                Comfort data bus
            weariness_rcognition_0x22:
                Not activated
            weariness_rcognition_0x22_msg_bus:
                Not activated
            BCmE_0x23:
                Not activated
            BCmE_0x23_msg_bus:
                Not activated
            Brake_0x26:
                Not activated
            Brake_0x26_msg_bus:
                Not activated
            Start_Stop_reasons_0x27:
                Not activated
            Start_Stop_reasons_0x27_msg_bus:
                Not activated
            Amplifier_0x2D:
                Not activated
            Amplifier_0x2D_msg_bus:
                Not activated
            TV_tuner_0x2C:
                Not activated
            TV_tuner_0x2C_msg_bus:
                Not activated
            RearSeatEntertainment_0x2E:
                Not activated
            RearSeatEntertainment_0x2E_msg_bus:
                Not activated
            MFL_Jocker_0x34:
                activated
            MFL_Jocker_msg_bus_0x34:
                CAN_MIB
            Special_Functions_0x35:
                Not activated
            Special_Functions_msg_bus_0x35:
                Not activated
            Trailer_Assistant_0x36:
                Not activated
            Trailer_Assistant_msg_bus_0x36:
                Not activated
            ExBoxM2_0x38:
                Not activated
            Range_Data_0x39:
                Not activated
            Range_Data_msg_bus_0x39:
                Not activated
            Angle_Of_Slope_0x24:
                Not activated
            Angle_Of_Slope_0x24_msg_bus:
                Not activated
            Battery_Management_0x25:
                Not activated
            Battery_Management_0x25_msg_bus:
                Not activated
            eCall_0x33:
                Not activated
            eCall_0x33_msg_bus:
                Not activated
            ENI_0x37:
                Not activated
            ENI_0x37_msg_bus:
                Not activated
            Pedestrian_Assist_0x3A:
                Not activated
            Pedestrian_Assist_msg_bus_0x3A:
                Not activated
            Seat_Pneumatic_0x3B:
                Not activated
            Seat_Pneumatic_msg_bus_0x3B:
                Not activated
            efficiency_assist_0x3C:
                Not activated
            efficiency_assis_msg_bus_0x3C:
                Not activated
            Seatmemory_driver_rear_0x3E:
                Not activated
            Seatmemory_driver_rear_msg_bus_0x3E:
                Not activated
            Seatmemory_codriver_rear_0x3F:
                Not activated
            Seatmemory_codriver_rear_msg_bus_0x3F:
                Not activated
            ExBoxM2_0x38_msg_bus:
                Not activated
        FM tuner, mono/stereo setting:
            l_hf_stereo_lower_threshold:
                20 dBµV
            l_nf_max_stereo_channel_separation:
                50 dB
            t_hysteresis_mono_to_stereo:
                0.1 s
        Brand-specific display of connect application:
                de.audi.mmiconnect
        Surroundings display, virtual camera positions:
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
            xpos:
                32767
            ypos:
                32767
            zpos:
                32767
            rollangle:
                65535
            yawangle:
                65535
            pitchangle:
                65535
            focallength:
                4294967295
        Installation list, specified installations:
            Instrument cluster control module:
                Yes
            Information electronics control module 2:
                No
            DVD changer:
                Yes
            TV tuner:
                No
            Digital Sound System Control Module:
                No
            Radio:
                No
            Information electronics control module 1:
                Yes
            Smart Display Carrier 1:
                No
            Control unit for head up display:
                No
            Multimedia Operating Unit:
                No
            Wireless Charger 2:
                No
            Wireless Charger 1:
                No
            Smart Control Carrier 2:
                No
            Smart Control Carrier 1:
                No
            Smart Display Carrier 2:
                No
            reserved_8:
                No
        Voice operation for telephone:
            apple_device:
                not installed
            other_devices:
                not installed
        Roller test bench mode, functional:
                Not activated
    Advanced identification:
        Number of programming attempts:
            Bootloader:
            Application:
                11
        Maximum number of possible update programming:
            Bootloader:
            Application:
        Workshop code and date of last update programming of SW module:
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                False result
        FAZIT-identification:
            Manufacture location index:
                JTB-074
            Day of manufacture:
                22.07.14
            Manufacturer- test stand number:
                1166
            Running manufacturer number:
                0BBB
        Diagnostic mode:
                VW - diagnostic mode
        VW/Audi part number:
                8S0035028D
        Software version:
                0364
        Vehicle Identification Number (VIN):
        Hardware part number:
                8S0035028
        System description:
                MU-H-N-ER
        Adaptation workshop code:
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
        ASAM/ODX file identification:
                EV_MUHig6C3Gen2HBAS
        ASAM/ODX file version:
                001115
        Hardware version:
                H33
        Coding workshop code:
            Device number:
                60933
            Importer number:
                3
            Dealership number:
                12289
        System abbreviation:
                J794
        Versions of software module:
            Bootloader:
            Application:
                0364
        Programmability status:
            Programmability:
                programmable
            Program consistency:
                no program present
    Mileage: 22180 km
    Date: 2019-10-27 16:50
Backup
    Control unit: 76 Parking Assistance
    System description: PARKHILFE 4K
    Software number: 5Q0919283E
    Software version: 0051
    Hardware number: 5Q0919283
    Hardware version: H10
    Serial number: 39231421001982
    ODX name: EV_EPHVA14AU3700000
    ODX version: 002022
    Backup name: Parking Assistant
    Long coding:
        0000050011
    Adaptations:
        Speaker volume for rear park assist:
                Stage 4
        Speaker frequency for rear park assist:
                Stage 6
        Audio reduction request:
                On
        Park assist activation tone:
                On
        Production mode:
                Deactivating
        Deactivate production mode:
                Deactivating
        Switch-off speed for parking assist:
                10 km/h
            Bootloader:
            Application:
            Data record:
            Application:
            Bootloader:
            Application:
                10000
            Data record:
                10000
            Application:
                10000
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                ATW-001
            Day of manufacture:
                03.08.14
                EA08
                0063
        Manufacturer modification status:
            Control module family:
            Decoration variant:
            Construction version:
            Manufacture version:
        Diagnostic mode:
                5Q0919283E
        Software version:
                0051
                5Q0919283
        System description:
                PARKHILFE 4K
            Device number:
            Importer number:
            Dealership number:
                EV_EPHVA14AU3700000
                002022
        Hardware version:
                H10
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J791
            Bootloader:
                0108
            Application:
                0051
            Data record:
                0051
            Application:
                0051
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: A5 Front Sensors Driver Assistance System
    System description: MQB_MFK
    Software number: 8S0980653
    Software version: 0002
    Hardware number: 5Q0980653
    Hardware version: H06
    Serial number: 10000097678
    ODX name: EV_MFKBoschAU370
    ODX version: 001001
    Backup name: Driver Assistance
    Long coding:
        0101010001010300000501000000000100
    Adaptations:
        Main_Beam_Assist_Urban_Area_Detection:
                On
        Function_Module_Road_Sign_Recognition:
                activated
        Function_Module_Main_Beam_Assist:
                activated
        VZMin_Attributierungs_Guete_Hauptverkehrszeichen:
                0 %
        VZMin_Klassifizierungs_Guete_Hauptverkehrszeichen:
                0 %
        VZMin_Attributierungs_Guete_Zusatzzeichen:
                0 %
        VZF_Country_Code:
        Country_Code_Signal_Consideration_Active:
                inputsignal_considered
        VZE_show_administrative_speed_limits:
                show_always
        VZE_Show_valid_additional_signs:
                activated
        VZE_Prioritize_moisture:
                Not activated
        VZE_Sorting_valid_signs:
                174
        CCP_interface:
                Not activated
        VZE_Sorting_alternative_signs:
                425
        Dev_Messages_VZE_deaktivation:
                Dev_Messages_not_activated
        Dev_Messages_VZF_deaktivation:
        Dev_Messages_EHR_deaktivation:
        Dev_Messages_HCA_deaktivation:
        Dev_Messages_MOD_deaktivation:
        Dev_Messages_FDD_FLA_deaktivation:
        Windscreen_heater_for_lane_departure_warning_settings:
            par_Min_heating_time:
                2 min
            par_Min_idle_time:
                3 min
            par_Max_camera_temp:
                85 °C
            par_Max_activation_temp:
                75 °C
            par_Qualification_time:
                0 s
            par_Init_heating_time:
                4 min
            par_Low_threshhold_temp:
                -20 °C
            par_High_threshhold_temp:
                2 °C
            par_Heater_Control_Power_Level:
                9.0 W
        Mask_error_reactions_for_development:
                Not activated
        Masked_fault_classes:
                255
                255
                255
                255
        HCA_On_State:
                Menu
        Operating mode:
                Menu
        HCA_Warning_Intensity:
                medium
        BAP_Personalisierung:
                activated
        Hands_Off_Gong:
                Gong Typ 2
        Hands_Off_Gong_Verzoegerung:
                0.0 s
        Urban_Leaving_Velocity:
                255 km/h
        Speed threshold for high beam recommendation off:
                27 km/h
        Activation speed for high beam assistant:
                57 km/h
        Direct. stab. assist speed threshold during towing mode:
                300 km/h
        Intervention moment:
                late (setting via menu)
        Road sign detection fusion mode:
                Road sign fusion
        Display end of speed limit symbol:
                activated
        Display no passing allowed:
                activated
        Predictive route data run time:
                0 ms
        Display valid additional signs:
                100111
        Directional stabilization assist driver inact deactiv threshold:
                Medium
        Directional stab. assist., intensity, steering wheel vibration:
                Medium
        Directional stab. assist., intensity, power steering support:
                Medium
        Distance to calibration field:
                1500 mm
        Personalization of lane dept. warning Cl. 15 on:
                Last setting
        Body height left front wheel house edge:
                704 mm
        Body height right front wheel house edge:
                706 mm
        Body height left rear wheel house edge:
                704 mm
        Body height right rear wheel house edge:
                704 mm
        Night vehicle detection activation brightness:
                3 lx
        Windshield heat. direct. stabilize. assist. activation duration:
                2 min
        Night vehicle detection deactivation brightness:
                20 lx
        Calibration result:
            Static calibration, pitch angle:
                -0.99 °
            Static calibration, yaw angle:
                0.27 °
            Static calibration, roll angle:
                -0.07 °
            Static calibration, camera height:
                1271 mm
        Static calibration (end of assembly line):
                7A0F960F850B000B060B000AFE257A4B6417E0257C319C17E0257A4B640D90257C319C0D90
        FDD, activation at standstill:
                Not activated
            Bootloader:
            Application:
            Data record:
            Bootloader:
            Application:
            Data record:
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
                JM5-195
            Day of manufacture:
                10.06.14
                13I3
                0391
        Diagnostic mode:
                8S0980653
        Software version:
                0002
                5Q0980653
        System description:
                MQB_MFK
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                EV_MFKBoschAU370
                001001
        Hardware version:
                H06
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                R242
            Bootloader:
                0008
            Application:
                0002
            Data record:
                0002
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: A9 Actuator For Structure-Borne Sound
    System description: SAS-GEN 2
    Software number: 8S0907159
    Software version: 0004
    Hardware number: 4H0907159A
    Hardware version: H07
    Serial number: 140116200909
    ODX name: EV_SoundActuaGen2AU64X
    ODX version: 003010
    Backup name: Structure Borne Sound
    Adaptations:
        Volume of structure-borne noise actuator:
                100.0 %
            Bootloader:
            Application:
                3
            Data record:
                3
            Bootloader:
            Application:
            Data record:
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                28696
            Importer number:
                771
            Dealership number:
                2048
            Programming status:
                Correct result
            Year:
                15
            Month:
                9
            Day:
                22
            Device number:
                28696
            Importer number:
                771
            Dealership number:
                2048
            Programming status:
                Correct result
                KKE-KKK
            Day of manufacture:
                16.01.14
                EOL1
                0909
        Diagnostic mode:
                8S0907159
        Software version:
                0004
                4H0907159A
        System description:
                SAS-GEN 2
            Device number:
            Importer number:
            Dealership number:
                003010
        Hardware version:
                H07
                J869
            Bootloader:
                0001
            Application:
                0213
            Data record:
                Z933
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Backup
    Control unit: B7 Access Startsystem Interface
    System description: VWKESSYMQB
    Software number: 3Q0959435
    Software version: 0522
    Hardware number: 3Q0959435
    Hardware version: 023
    Serial number: 0332397794
    ODX name: EV_KessyHellaMQBAB
    ODX version: 004027
    Backup name: Start system Interface
    Long coding:
        000F0F1720
    Adaptations:
        Control module switch-off, switch-off time:
            Control module:
                20 min
            Data bus:
                30 min
                Deactivating
        Production mode:
            Deactivation of automatic shutdowns of terminal 15:
                not active
            Deactivation of automatic rear lid opening:
                not active
            Deactivation of terminal 50 request:
                not active
        rpm_threshold_engine_runnning:
                100 1/min
        Number_of_ZAT_activations_to_DTC:
                10
        Number_of_Multiple_ZAT_activations_to_emergency_shutoff:
        Display_duration_please_engage_P:
                10 s
        time_to_drive_cycle_detection:
                1.00 s
        Display_duration_emergency_off:
                3000 ms
        Display_duration_error_mode_2_SPN:
                10 s
        min_time_for_Terminal_50_request:
                200 ms
        Terminal_S_Timeout:
                30 min
        time_to_ignore_ignition_trigger:
                35 s
        delay_time_Terminal_15_S_Shut_down_by_BEM:
                30.00 s
        delay_time_Terminal_15_S_Shut_down_after_leaving_vehicle:
                300 ms
        time_ZAT_actuation_detection:
                3000 ms
        duration_ZAT_debounce:
                50 ms
        time_to_ZAT_Short_circuit_fault_detection:
                60 s
        duration_to_ZAT_continuous_actuation_detection:
                1000 ms
        duration_to_ZAT_multi_actuation_detection:
                3000 ms
        time_ZAT_lock_after emergency_shutoff:
                1000 ms
        time_ZAT_lock_after_normal_shutoff:
                500 ms
        time_to_ZAT_Open_circuit_detection:
                1000 ms
        Speed_threshold_for_moving_vehicle_detection:
                1.0 km/h
        Speed_threshold_for_driving_cycle_detection:
                3.0 km/h
        Speed_threshold_for_terminal_15_emergency_shutoff:
                7.0 km/h
        CAN_signal_transmitting_duration_of_automatic_Terminal_15_shutoff:
                1.00 s
        Ignition_For_Immobilizer:
                Default
        Terminal_15_adaption_body_control_module:
                Default
        Debounce_time_driver_presence:
                200 ms
        Debounce_time_detection:
                500 ms
        Timeframe_request_immobilizer_terminal_approval:
                10000 ms
        CAN_signal_transmitting_duration_of_comfort_switch_off:
                1.00 s
        CAN_signal_transmitting_delay_of_car_roll _away_warning:
                1.00 s
        Byte13_vit_lf:
            vit_exit:
                Not activated
            vit_evaluate_inversbit:
                Not activated
            toggle_active:
                Not activated
            toggle_at _open_door:
                Not activated
            lock_via_toggle_by_closed_vehicle_skin:
                Not activated
        min_receptiontime_vit:
                0 ms
        Timeout_trigger_terminal_deactivation_central_locking:
                1.00 s
        Diagnostic: wait time after power on:
                500 ms
        CAN-timeout service-key message:
                260 ms
        LED dimming curve first point 20 percent dimming:
                40.0 %
        Delta value LED dimming curve first point 40 percent dimming:
                30.0 %
        Delta value LED dimming curve second point 60 percent dimming:
                15.0 %
        Delta value LED dimming curve third point 80 percent dimming:
                10.0 %
        Delta value LED dimming curve forth point 100 percent dimming:
                5.0 %
        Standard dimming value ZAT:
                80.0 %
        Correction value LED dimming:
                1.0
        ZAT post-carridge during clamp 15 off:
                10 min
        ZAT nominal voltage:
                13.0 V
        ZAT init value:
                0.0 %
        Stop release for start-stop function:
                According to function requirements
        Proximity Sensor: duration of proximity Signal:
                10 s
        Internal:
                0 B
        Passive Entry Exit: T_ACT_OP_2:
                5000 ms
        Passive Entry Exit: minimum activity time locking sensor:
                140 ms
        Passive Entry Exit: PARA_T_TIMOUT_PROXIMITY_ENTRY:
                210 ms
        Passive Entry Exit: control by pulling the door handle during active DSL_timeout:
                2.00 s
        Passive Entry Exit: entry request e-sliding door active time:
                500 ms
        Initialization_diagnostics_switching_terminal:
                Not activated
        Reduced current for transponder-ID request:
                0 Step
        MCTX settling phase:
                10 B
        MCTX pause:
                1 B
        MCTX pause for Go / Key Minder:
                20 ms
        MCTX pause for Go authentification:
                14 B
        Scan Procedure: Timeout Authentification Result:
                150 ms
        Scan Procedure: p_keyless_eventsuche_retries_pause:
                1000 ms
        Scan Procedure: Timeout LF Repetition:
                100 ms
        Scan Procedure: Number of Repeats:
        Scan Procedure: cycle convenience coverage limiting:
                65 ms
        Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Go:
                190 ms
        Scan Procedure: timeout ID-transmitter ready-to-receive after LF-error Kombi:
                700 ms
        Scan Procedure: current limiting on undervoltage at Go-protocol:
                5 Step
        ScanProcedure: Timeout Entry Response:
                260 ms
        ScanProcedure: Timeout Response:
                100 ms
        timeout_convenience_coverage_limiting:
                75 s
        internal_passive_entry_exit_byte1:
            lf_crc:
                Not activated
            Impairment Entry / Exit key on low battery:
                Not activated
            Passive Exit: access door not open:
                Not activated
            Passive Exit: all doors not open:
                Not activated
            passive_exit_door_slam_lock:
                Not activated
        internal_passive_entry_exit_byte2:
            Passive Entry Exit: control by pulling door handle during active DSL:
                activated
            Passive Entry Exit:
                Not activated
            Passive Entry: second control concept:
                Not activated
            Passive Entry Exit: retry with antennastep 1:
                Not activated
            Passive Entry bei Tuer verriegelt/gesafed ODER ZV ist gesafed:
                activated
            lf_shutdown:
                Not activated
            lf_shutdown_gotrigger:
                Not activated
        internal_keyminder_byte1:
            Seat Memory: scan after driver door opening:
                Not activated
            Seat Memory: scan after driver door opening no KESSY unlocking:
                Not activated
            Softtouch mounted:
                installed
            Cyclic interior scan during active warning message "Key not found":
                Not activated
            allowa_remotestart_to_disable_keys:
                Not activated
            aktivate_function_trigger_access_leaving_elv:
                Not activated
        internal_keyminder_byte2:
            No locking with ID-transmitter last used interior:
                Not activated
            Re-open after passive comfort closing:
                Not activated
            Re-open last handling:
                Not activated
            Re-open tailgate:
                activated
            Lock prevention tailgate:
                Not activated
            Inhibit ID-transmitter for passive go:
                activated
        DeveloperCoding: Search lights:
            ZAT active during clamp 58t on:
                activated
            Standardisation of ZAT:
                activated
            ZAT detecting open load:
                Not activated
            ZAT_illumination_modus_mybeat_clamp58xt:
                Not activated
            ZAT_illumination_concept_mybeat_clamp58xt:
                Not activated
        DeveloperCoding: vehicle environment:
            Steering wheel:
                Left-hand drive
            Convertible:
                Not activated
            Pre Catch for Trunk:
                Not activated
            reactivate_all_doorhandles:
                Not activated
        DeveloperCoding: Passiv Go:
            Passive Go:
                activated
            GO only via antenna IN1 if tailgate open:
                Not activated
            GO only via antenna IN1 if sliding door open:
                Not activated
            Passive Go: tailgate authorized to start:
                activated
            Impairment go on a low key battery:
                Not activated
        Sonstiges_byte1:
            Backdoor TSG:
                Not activated
            Response extension for scan procedure:
                Not activated
            Diagnostic: service 86 - response on event:
                Not activated
            Internal:
                Not activated
            Use default antenna data:
                Not activated
            Battery manager mounted:
                activated
            Scan Procedure: timeoutcontrol active:
                activated
        DeveloperCoding: Proximity Sensor:
            AUDI doorknobs mounted:
                Not activated
            Proximity Sensor: sensor stays active after fault detection:
                Not activated
            Detection of an repeated failed doorknob actuation:
                activated
            Suppress fault manager entry "Falschverbau aktiv":
                Not activated
            No turn off for driver doorknob while passive:
                activated
            energized_doorhandles_at_stateKL15on_when_opening_door:
                Not activated
        Byte9_VIP:
            active_vip:
                Not activated
            vip_activation_on_clamp15:
                Not activated
            vip_deactivation_on_running_engine:
                Not activated
            Hitch_trailer_installation:
                Not activated
            Coding_kick and_close_function:
                Not activated
            Coding_easyclose_locking:
                Not activated
            ECL_Start_ueber_ViP:
                Not activated
        sonstiges_byte2:
            interiorscan_clamp15_reach_trashhold:
                Not activated
            sad_existing:
                Not activated
            trunk_ecu_existing:
                Not activated
        Byte12_diverse:
            environment_scan_step1:
                Not activated
            environment_scan_step2:
                Not activated
            interior_scan_clamp_15_new_concept:
                Not activated
            exeption_drivers_doors_interior_scan:
                Not activated
            suppression_access_detection_for_remotestart:
                Not activated
            open_cabrio_canopy_interior_scan:
                Not activated
        proximity Sensor: max. length of Diagnosticimpuls:
                71 ms
        proximity Sensor: max. length of Entryimpuls:
                10400 µs
        Proximity Sensor: max. length of Exitimpuls:
                40400 µs
        Proximity Sensor: max. Impulslength of proximity-Impuls:
                20400 µs
        Proximity Sensor: max. Impulslength:
                75 ms
        Proximity Sensor: max. intermission-length Diagnostic:
                14 ms
        Proximity Sensor: upper limit intermission-length:
                10 ms
        Proximity Sensor: max. signal-length:
                120 s
        Proximity Sensor: min. length of Diagnosticimpuls:
                42 ms
        Proximity Sensor: min. length of Entryimpuls:
                6200 µs
        Proximity Sensor: min. length of Exitimpuls:
                24200 µs
        Proximity Sensor: lower limit proximity-Impuls:
                12200 µs
        Proximity Sensor: lower limit Impuls:
                2000 µs
        Proximity Sensor: max. length of signal hall sensor:
                100 s
        Doorknob contact sensor disconnecting time:
                5400 min
        Time Sensor Power Off Group 2:
                3600 min
        Proximity Sensor: Time Power On:
                1960 ms
        Key Minder: delay reunlocking tailgate:
                500 ms
        Proximity Sensor: SP_X2:
                10 min
        Proximity Sensor: SP_X3:
        Proximity Sensor: SP_X4:
                80
        Proximity Sensor: SP_X5:
        Proximity Sensor: SP_X6:
                30 min
        Proximity Sensor: SP_X7:
        Proximity Sensor: Timervalue for ExitReverseOption:
                0 ms
        Proximity Sensor: Comfort Exit-Enlargement:
                200 ms
        Proximity Sensor: turn-off limit from battery-manager:
        Proximity Sensor: min. enginespeed for a running engine:
                300 1/min
        Proximity Sensor: min Vehiclespeed for a driving vehicle:
                20.0 km/h
        Proximity Sensor: max Vehiclespeed for a standing vehicle:
                10.0 km/h
        Proximity Sensor: min. tolerance data bit length:
                120 µs
        Proximity Sensor: max. tolerance data bit length:
                200 µs
        deactivation_time_vip_slidingdoor:
                15 s
        Time_frame_VIP_kick_forecast:
                5
        Voltage monitoring: undervoltage for Keyless Go:
                6000 mV
        Voltage monitoring: undervoltage Delta:
                500 mV
        Voltage monitoring: undervoltage Jumpstart 1 Delta:
                0 mV
        Voltage monitoring: undervoltage for KESSY ECU:
                9000 mV
        Voltage monitoring: overvoltage for KESSY ECU:
                16000 mV
        Voltage monitoring: overvoltage for Keyless Go:
                27000 mV
        Voltage monitoring: overvoltage Delta:
                500 mV
        Voltage monitoring: overvoltage Jumpstart 2 Delta:
                0 mV
        Cycletime for voltage monitoring during sleepmode:
                100 ms
        settime_trigger_exit_vehicle:
                500 ms
        settime_trigger_entry_vehicle:
                500 ms
        Key Minder: p_keyless_eventsearch_holding_time:
                10 s
        Interior scan: opening threshold window lifter:
                5.0 %
        Interior scan: opening threshold sliding roof:
                1.0 %
        Interior scan: Speed - threshold:
                20 km/h
        Interior scan: max. engine speed for standing engine:
                10 km/h
        Key Minder: p_keyless_eventsearch_retries:
                4
        Interior scan: deceleration after comfort closing:
                3200 ms
        Cyclic interior scan during clamp 15 on:
                10 s
        environment_scan_duration_step1:
                300 min
        environment_scan_cyclic_step1:
                700 ms
        environment_scan_duration_step2:
                24 h
        environment_scan_cyclic_step2:
                2000 ms
        environment_scan_responselevel_reduction:
                500
        environment_scan_level_bem:
        environment_scan_startdelay_time:
                5 s
        Deactivation of start-stop function:
                not active
        Control module rear lid opening, duration status query:
                4960 ms
        Control module rear lid opening, vehicle type:
                fe
        Easy_close_detection_areas:
            Easy_close_antenna_current_step:
                96
            Easy_close_open_door_antenna_current_step:
                64
            Value_area_4:
                10 V/m
            Value_area_leaving_area:
                0 V/m
        Activating and deactivating all development messages:
            Development messages:
                not active
            Bootloader:
            Application:
            Data record:
            Bootloader:
            Application:
            Data record:
            Year:
                12
            Month:
            Day:
                27
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
            Month:
            Day:
            Device number:
            Importer number:
            Dealership number:
            Programming status:
                Correct result
            Year:
                14
            Month:
                8
            Day:
                22
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
            Programming status:
                Correct result
                HLH-W42
            Day of manufacture:
                16.06.14
                P002
                0141
            Decoration variant:
                023
                000
        Diagnostic mode:
                3Q0959435
        Software version:
                0522
                3Q0959435
        System description:
                VWKESSYMQB
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                EV_KessyHellaMQBAB
                004027
        Hardware version:
                023
            Device number:
                16
            Importer number:
                770
            Dealership number:
                6145
                J518
            Bootloader:
                0009
            Application:
                0522
            Data record:
                0020
            Programmability:
                programmable
                Program present
    Mileage: 22180 km
Jacopo79
New Member
Italy
Thank you for Who Will help me. Problem now Is that TMC Is not Always Active. Only One time every 5/6 reboot of the system in zones covered by radio! Fee information in 5F Is set with the value "15". I live in Italy and I don't have Audi connect. PS my NAVI Is retrofitted.
Thank you!!!
Viking
C?ID=151455
This forum exists for users of VCDS. Asking for assistance with OBDEleven won't get you the answers you need. I'd suggest asking your tools maker for support with their product.
Jacopo79
New Member
Italy
here is the last scan with vcds! Is ok or do you need other? Thank you very much guys!!
Tuesday,06,February,2018,18:11:40:11310
VCDS Version: 18.1.0.2 (x64)
VIN: TRUZZZFV3F1001432   License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 22 2B 42 44 52 55 5F A5 A9
VIN: TRUZZZFV3F1001432   Mileage: 12695km-7888miles
Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8S0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1D00324426050B3002
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259 001006
   ROD: EV_ECM20TFS0208S0906259.rod
   VCID: 7AF101E7FDF37795FB-802E
   Part No SW: 0D9 300 012 E    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4504
   Revision: 03253104    Serial number: TFK01407150047
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 18353B6FE3BF85856D-804C
   Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
   Component: ESC           H31 0504
   Revision: 00000000    Serial number: 61434000000141
   Coding: 32AA608D0A9915AA40950067C2939306444C0650A8020043C96022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_052.rod
   VCID: 4085B30FDBAFED45F5-8014
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0332397794
   Coding: 000F0F1720
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 77F718D3CEE16AFD84-8022
   Part No SW: 8S0 820 043     HW: 8S0 820 043
   Component: AC Automat    H05 0020
   Revision: 20007000    Serial number: 89300000000676
   Coding: 400040000011101100
   ASAM Dataset: EV_AirCondiVAPrehAU33x 003011
   ROD: EV_AirCondiVAPrehAU33x.rod
   VCID: 6CDD37BF87A7D92579-8038
   Serial number: CF99CF37000000000001
   Operating and display unit 1 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 373 A    HW: 8S0 820 373 A
   Component: E774 BuA_1  H06 0010
   Serial number: 00000000000000001449
   Operating and display unit 2 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H06 0010
   Operating and display unit 3 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H06 0010
   Operating and display unit 4 for air conditioning:
   Subsystem 5 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H06 0010
   Operating and display unit 5 for air conditioning:
   Subsystem 6 - Part No SW: 8S0 820 373 B    HW: 8S0 820 373 B
   Component: E778 BuA_5  H06 0010
   Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0138
   Serial number: 01011419703223
   Coding: 04055D46C20106FD43044004001807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 09136E2BA8156C0DE2-805C
   Subsystem 1 - Part No SW: 8S1 955 119 A    HW: 8K1 955 119 B  Labels: 5QX-955-119-V1.CLB
   Component: 43x LL 140625  032 0371
   Serial number: 00000001406250604733
   Coding: 1BC7F7
   Serial number: 22982889
   Coding: 00005D
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 06 06 2014  00000217
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39231421001982
   Coding: 0000050011
   ROD: EV_EPHVA14AU3700000_002_VW27.rod
   VCID: 3B7FC4E3B2498E9DA0-806E
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R000NWS
   Coding: 88CCF0C00C8000005C5000CFC04800000065
   VCID: 4D9B9A3B1CFD302D0E-8018
   Subsystem 1 - Part No SW: -----------    HW: 480 000 508 14
   Serial number: 3570000000024349A015
   Subsystem 2 - Part No SW: -----------    HW: 480 000 508 14
   Serial number: 3580000000093349A01C
   Subsystem 3 - Part No SW: -----------    HW: 480 011 006 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A01DDBD6832E2K
   Subsystem 4 - Part No SW: -----------    HW: 480 401 405 14
   Serial number: 3550002B5156E9F5B0FQ
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 405 14
   Serial number: 3560002B5156E9F0B13B
   Pedestrian Protection Center:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 207 14
   Serial number: 2300002AD1656901E0E0
   Subsystem 7 - Part No SW: -----------    HW: 480 003 005 14
   Serial number: I0M00000000C8319EF0G
   Subsystem 8 - Part No SW: -----------    HW: 480 003 005 14
   Serial number: I0N000000002AAFCEF0X
   Part No SW: 8S0 907 129 AC    HW: 8S0 907 129 AC
   Component: Lenks. Modul  H06 0140
   Revision: --------    Serial number: 91335NHF00826
   Coding: 281C
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_011_AU37.rod
   VCID: 7BFF04E3F2C94E9DE0-802E
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8S0 920 790     HW: 8S0 920 790
   Component: FBenRDW       H30 0221
   Coding: 042D0050698400080422EE809000801000000000
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 76E915D7C9EB13F59F-8022
   Part No SW: 8S0 907 468     HW: 8S0 907 468
   Component: GW MQB TT3    012 0184
   Revision: --------    Serial number: 08051410800376
   Coding: 030100042F025A004B0002683C0000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011002
   ROD: EV_GatewContiAU33X_011.rod
   VCID: 7DFB0AFBECDD40ADDE-8028
   Subsystem 2 - Part No SW: 8S0 951 523 C    HW: 8S0 951 523 C
   Component: J453 MFL  H06 0001
   Serial number: 20140710145330 RD002
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 2041663003
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7742
   Serial number: HA1-00028.06.14
   Coding: 0101
   VCID: 458BA21BC48DC86DC6-8010
   Serial number: 14000035318018
   Coding: 0900000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71E326CBA08534CD4A-8024
   Part No SW: 5Q0 959 593 C    HW: 5Q0 959 593 B
   Component: TSG FS        020 0026
   Serial number: 28071403110691
   Coding: 001E47224000040100001402
   VCID: 4183B60BD0A5E44DFA-8014
   Part No SW: 3Q0 909 144 H    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5061
   Coding: 9103
   VCID: 3777D8D38E61AAFD44-8062
   Part No SW: 5Q0 959 592 C    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0026
   Serial number: 07071402090145
   Coding: 001E47224C00040100001402
   Part No SW: 4H4 907 357 D    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0090
   Coding: 03EA001E2B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005008
   VCID: 336FECC39A1946DD78-8066
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
   Part No SW: 8S0 035 028 D    HW: 8S0 035 028
   Component: MU-H-N-ER     H33 0364
   Serial number: A262G0EB003237
   Coding: 01330401FF08000011110001000800102F0000E1007000003E
   VCID: 3163E6CB600574CD0A-8064
   Subsystem 1 - Part No SW: V03 959 801 ES    HW: -----------
   Component: ECE 2014/2015  --- 0086
   Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 A
   Component: ControlUnit_H  H21 0136
   Serial number: C1000016051400010062
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 5
                    Mileage: 12279 km
                    Date: 2018.01.23
                    Time: 11:07:25
                    Voltage terminal 30: 12.2 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
          B201A 00 [009] -  -
                    Reset counter: 5
                    Mileage: 12279 km
                    Date: 2018.01.23
                    Time: 11:07:30
                    Status_Software_Version_Management-module_name: MFPK/gss-inic
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 8S0 980 653     HW: 5Q0 980 653
   Component: MQB_MFK       H06 0002
   Coding: 0101010001010300000501000000000100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
End-------------------------(Elapsed Time: 04:37)--------------------------
The problem is that TMC doesn't work!!! Can't find the right code....maybe works for 1 time and then it disappears for few days and the come back...N.B. in zone covered by radio! (live in nrth of italy)
DV52
C?ID=194404
Jacopo: Hi.
I'm by no means an expert on the Audi TT (looks like a very nice car), but I understand that the mk3 has an MQB platform - which is the motivation for my novice reply!
I notice in your records for the "other manufacturer's" back-up file (which is kind-of the equivalent of VCDS's admap - but nowhere near as useful IMHO) that the hex 5F module in your car has the same adaptation channel for TMC as other MQB based vehicles- Fee-based traffic information (TMC):15
I'm not sure what Italy's actual code is for TMC, but here's the codes that I have in my database from past encounters with MQB platform vehicles (i.e. the setting for the TMC channel from hex5F admaps):
0 - dev options
1023 - Europe
1024 - Australia (SUNA Traffic: Intelematics)
1537 - USA
32768 - Germany
32771 - online traffic + VW TMCPro
65535 - TMC OFF
After changing the setting in the TMC channel and exiting VCDS/OBD11 software - have you tried resetting the MMI using the normal "3 x finger salute" (which I assume applies to the TT mk3)?
PS: and as a totally separate matter (I assume)- you might want to look at the records in the Codinglog.CSV file on your laptop (or the "History" option in the "other manufacturer's" SW) for what's causing the Control Module Incorrectly Coded DTC.
Jacopo79
New Member
Italy
thanks for the help Don, actually i tried all these codes and they all worked (except for australia). Unfortunately the TMC is active once every 4/5 times the machine is switched on (practically every 4/5 MMI reset). A strange thing that I noticed that I would like to tell you is that when TMC is active, the "map display" mode is also active (to select Google maps); when TMC is not active then there is no "map display" menu, and therefore there is no possibility to select the type of map and there are only the standard maps!
Viking
C?ID=151455
   Revision: --H13---
   Coding: 000F0F1720
   Coding: 1BC7F7
   Coding: 00005D
   Light switch:
   Coding: 0000050011
   Coding: 281C
   Coding: 0101
   Coding: 9103
   Coding: E01800
   Coding: E01800
   Coding: E01800
   Coding: E01800
          U1014 00 [009] - -
                    Reset counter: 5
                    Mileage: 12279 km
                    Date: 2018.01.23
                    Time: 11:07:25
          B201A 00 [009] -  -
                    Reset counter: 5
                    Mileage: 12279 km
                    Date: 2018.01.23
                    Time: 11:07:30
It'd be good if you could post a scan using a current version of VCDS. It's available to download for free here... https://www.ross-tech.com/vcds/download/
Jacopo79
New Member
Italy
Hi mate! This Is the only scansion I can give to you for now....I hope someone could help me with the details I have given to you...thank you for your precious help!!
PetrolDave
Westbury, UK
C?ID=1423
This Is the only scan I can give to you for now
What's the problem with installing the latest VCDS version from the Ross-Tech website and doing a new Auto-Scan?
It's free to all owners of a genuine Ross-Tech cable...
My guess is that it's not his VCDS; that he got someone else to scan it for him.
Jacopo79
New Member
Italy
Yes mate exactly! A friend of mine has vcds...and this scansion Is what I have... Impossibile to understand this strange thing of TMC correlated to map view?
PetrolDave
Westbury, UK
C?ID=1423
As a mate, I'd be suggesting that your mate keeps his copy of VCDS updated - to take advantage of all the fixes and updates, especially as the cost to him is zero :thanks:
