Results 1 to 9 of 9
Thread: VW Passat B8 Blind spot - Side assist
    Oct 2019
    Hi
    I have install blind spot in my Passat 2016.
    Is there anyone who can help with a guide on how to code it..?
    Quote Originally Posted by VAGParts View Post
    If there is, they would probably need to see an Auto-Scan from your car. So please post one.
  3. Likes downtime liked this post
    May 2017
    I might be able to help you as I did the same installation to my Tiguan. Passat and Tiguan both use the same radars.
    But I would also need to see the autoscan.
  5. Likes Uwe, myounus liked this post
    Oct 2019
    Fredag,18,Oktober,2019,12:30:28:52337
    VCDS -- Windows baseret VAG/VAS emulator - Kører på Windows 10 x64
    VCDS version: NEZ 19.6.1.0  HEX-NET CB: 0.4508.4
    Dataversion: 20190712 DS310.0
    www.vcds.dk
    Stelnummer: WVWZZZ3CZGE228682
    Modeltype: 3C-VW48 (5Q0)
    Søgt på: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 42 44 52 55 5F 69
              6D BB BC
    01-Motor -- Status: Fejlfunktion 0010
    02-Automatik -- Status: Ok 0000
    03-ABS bremser -- Status: Fejlfunktion 0010
    05-Adg./Startkodning -- Status: Ok 0000
    08-Klimaanlæg -- Status: Ok 0000
    09-Centralelektrik -- Status: Fejlfunktion 0010
    10-Park.assist. -- Status: Fejlfunktion 0010
    13-Afstandsreg. I -- Status: Fejlfunktion 0010
    15-Airbags -- Status: Fejlfunktion 0010
    16-Ratelektronik -- Status: Ok 0000
    17-Instrument -- Status: Ok 0000
    18-Parkeringsvarme -- Status: Ok 0000
    19-CAN Gateway -- Status: Ok 0000
    2B-Ratstammelås -- Status: Ok 0000
    42-Dørelektr. V for -- Status: Ok 0000
    44-Servostyring -- Status: Fejlfunktion 0010
    52-Dørelektr. H for -- Status: Ok 0000
    55-Lyslængdereg. -- Status: Ok 0000
    5F-Informationselek. -- Status: Fejlfunktion 0010
    69-Anhængertræk -- Status: Ok 0000
    6D-Bagklapelektronik -- Status: Ok 0000
    BB-Bagdør førerside -- Status: Ok 0000
    BC-Bagdør passagerside -- Status: Ok 0000
    Styreenhed  01: Motor (J623-DFCA)     Forklaringsfil:. NEZ\04L-907-309-V1.clb
       Styreenhedsnr: SW: 04L 906 026 FN    HW: 04L 907 309 M
       Komponent	: R4 2.0l TDI   H23 2011
       Revision	: B4H23---
       Kodning	: 011D001A047405083000
       Forhandler	: WSC 05311 115 00236
       ASAM datasæt	: EV_ECM20TDI01104L906026FN 004002
       ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
       VCID: 7BB621D8F2291197CC-802E
    1 fejl fundet:
    7150 - Ratvinkelvinkelføler
              U0428 00 [039] - Urealistisk signal
              Ikke bekræftet - Testet siden sletning af hukommelse
                 Fryserammedata:
                        Fejl status  : 00000001
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Kørestrækning: 108070 km
                        Dato: 2019.10.16
                        Tid: 00:02:20
                        Motoromdrejningstal: 0.00 /min
                        Normeret belastningsværdi: 0.0 %
                        Kørehastighed: 0 km/t
                        Kølevæsketemperatur: 13 °C
                        Inds.lufttemperatur: 13 °C
                        Barometerstand lufttryk: 1000 mbar
                        Kl. 30 spænding: 12.040 V
                        Nulstillingstæller: EOBD: 40
                        CAN-status – motorstyreenhed-Bits 0-7: 0
                        Fartpilotregulering status-Bits 0-7: 7
    Styreenhed  02: Automatik (J743)     Forklaringsfil: NEZ\0D9-927-770.clb
       Styreenhedsnr: SW: 0D9 300 041 J    HW: 02E 927 770 AQ
       Komponent	: DQ250-6F MQB  H53 4906
       Revision	: 06253104    Serienummer	: TFK01602241041
       Kodning	: 0014
       Forhandler	: WSC 05311 115 00061
       ASAM datasæt	: EV_TCMDQ250021 001001
       ROD: EV_TCMDQ250021.rod
       VCID: 1F0E35480671ADB780-804A
    Ingen fejlkoder fundet.
    Styreenhed  03: ABS bremser (J104)     Forklaringsfil:. NEZ\5Q0-907-379-IPB-V1.clb
       Styreenhedsnr: SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
       Komponent	: ESC           H42 0723
       Revision	: 00000000    Serienummer	: 61046000000938
       Kodning	: 0FEC6A8F34220B74077D060841C549F0562CD0E0608292F11862F078C209
       Forhandler	: WSC 00015 115 08193
       ASAM datasæt	: EV_Brake1UDSContiMK100IPB 034036
       VCID: 7AB824DCFD13289FD7-802E
    3 fejlkoder fundet:
    0297 - Ratvinkelsensor
              B1168 16 [137] - Spænding for lav
              Fejllampe aktiveret - Bekræftet - Testet siden sletning af hukommelse
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:20
    16412 - Dækkontrolvisning
              C1146 02 [137] - Signal fejl
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:32
    16413 - Dækkontrolvisning
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:32
    Styreenhed  05: Adg./Startkodning (J518)     Forklaringsfil:| NEZ\5Q0-959-435.clb
       Styreenhedsnr: SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
       Komponent	: VWKESSYMQB    026 0710
       Revision	: 00026000    Serienummer	: 0401603713
       Kodning	: 000F0F0F03
       ASAM datasæt	: EV_KessyHellaMQBAB 004032
       VCID: 393AFBD0B895E3879E-806C
       Styreenhed til åbning af bagklap/bagagerumsklap:
    Styreenhed  08: Klimaanlæg (J255)     Forklaringsfil:| NEZ\5G0-907-044.clb
       Styreenhedsnr: SW: 5G0 907 044 BH    HW: 5G0 907 044 BH
       Komponent	: Climatronic   H04 1202
       Revision	: 00001K10
       Kodning	: 12020104204101011015500000101802
       ASAM datasæt	: EV_ACClimaBHBVW37X 005137
       VCID: 6E90188CB15B743F7B-803A
       Styreenhed til friskluftblæser (foran):
       Luftkvalitetssensor:
       Føler for luftfugtighed udvendig:
    Styreenhed  09: Centralelektrik (J519)     Forklaringsfil:| NEZ\5Q0-937-08X-HV1.clb
       Styreenhedsnr: SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
       Komponent	: BCM PQ37BOSCH 028 0163
       Revision	: --------    Serienummer	: 8658160416012I
       Kodning	: 00031A46C2C102FF53C44004001457081C80000000000000000000000000
       ASAM datasæt	: EV_BodyContrModul1UDSBosc 015001
       ROD: EV_BCMBOSCH_015.rod
       VCID: 034659388AD9695784-8056
       Styreenhed til viskermotor:
       Undersystem 1 - Styreenhedsnr: SW: 3G1 955 119 A    HW: 3G1 955 119   Forklaringsfil: NEZ\5QX-955-119-V1.CLB
       Komponent	: WWS    160326  042 0607
       Serienummer	:         160408192827
       Kodning	: 0E4DDD
       Regn- og lyssensor:
       Undersystem 2 - Styreenhedsnr: SW: 8UD 955 559 B    HW: 8UD 955 559 B  Forklaringsfil: NEZ\8U0-955-559.CLB
       Komponent	: G397_RLFS  H06 0004
       Serienummer	: 90070925
       Kodning	: 00006E
       Lyskontakt:
       Undersystem 3 - Styreenhedsnr: SW: 3G0 941 633 H    HW: 3G0 941 633 H
       Komponent	: E1 - LDS MQB  H01 0032
       Serienummer	: 20 01 2016  10000219
       Føler for luftfugtighed indvendig:
    1 fejl fundet:
    558100 - Databus
              U1123 00 [009] - Modtaget fejlværdi
                 Fryserammedata:
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:18
    Styreenhed  10: Park.assist. (J446)     Forklaringsfil:| NEZ\5Q0-919-294.clb
       Styreenhedsnr: SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
       Komponent	: PARKHILFE 8K  H03 0056
       Revision	: --------    Serienummer	: 39331610302423
       Kodning	: 0071051911
       ASAM datasæt	: EV_EPHVA18AU3700000 002026
       VCID: 44C49A24CF57AE6FFD-8010
    1 fejl fundet:
    13637426 - Databus
                 Fryserammedata:
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:19
    Styreenhed  13: Afstandsreg. I (J428)     Forklaringsfil:| NEZ\3Q0-907-572.clb
       Styreenhedsnr: SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
       Komponent	: ACC BOSCH MQB H04 0194
       Kodning	: 3200670A51FFC428949C804D
       ASAM datasæt	: EV_ACCBOSCHVW48X 001009
       ROD: EV_ACCBOSCHVW48X.rod
       VCID: 3424CAE49FF71EEF4D-8060
    4 fejlkoder fundet:
    2055 - Databus
              U1122 00 [009] - Urealistisk besked
              [FAULT_ALP_STEERINGWHEEL_INIT]
                 Fryserammedata:
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:19
                        Styreenhedstemperatur: 16 °C
                        Spænding kl. 15: 12.0 V
                        Hastighed køretøjs reference: 0.00 m/s
                        Længdeakseacceleration for køretøj reference: 0.00 m/s²
                        Status for ACC system: ACC ikke reversibel fejl
    0795 - Databus
              [FAULT_APS_RELEVANT_ERROR]
                 Fryserammedata:
                        Fejlprioritet: 4
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:19
    2101 - Databus
              [FAULT_ESP_STATUS_SYSTEM]
                 Fryserammedata:
                        Fejlprioritet: 4
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:19
    2068 - Databus
              [FAULT_TSK_IRREV_FAIL]
                 Fryserammedata:
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:19
    Styreenhed  15: Airbags (J234)     Forklaringsfil:| NEZ\5Q0-959-655.clb
       Styreenhedsnr: SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
       Komponent	: Airbag VW20   013 0195
       Revision	: --------    Serienummer	: 003STP7HZFH4
       Kodning	: 88CCC000008000005C5400CC000800000065
       Forhandler	: WSC 05314 000 00001
       ASAM datasæt	: EV_AirbaVW20TS6VW48X 001116
       ROD: EV_AirbaVW20TS6VW48X.rod
       VCID: 7F4ED5C8E6310DB7E0-802A
       Crashsensor til sideairbag i førerside:
       Undersystem 1 - Styreenhedsnr: SW: -----------    HW: 454 000 204 16
       Komponent	: SideSensor_Df  008 0887
       Serienummer	: 3576U000000426303A1.
       Kodning	: 2D2D2D
       Crashsensor til sideairbag i passagerside:
       Undersystem 2 - Styreenhedsnr: SW: -----------    HW: 454 000 204 16
       Komponent	: SideSensor_Pf  008 0887
       Serienummer	: 3586U000000A5B5D4A1P
       Kodning	: 2D2D2D
       Crashsensor til sideairbag bagi i førersiden:
       Undersystem 3 - Styreenhedsnr: SW: -----------    HW: 454 802 503 16
       Komponent	: SideSensor_Dr  301 0148
       Serienummer	: 3516RE6FDFF090000000
       Kodning	: 2D2D2D
       Crashsensor til sideairbag bagi i passagerside:
       Undersystem 4 - Styreenhedsnr: SW: -----------    HW: 454 802 503 16
       Komponent	: SideSensor_Pr  301 0148
       Serienummer	: 3526RB1E4FF09000000Q
       Kodning	: 2D2D2D
       Crashsensor til frontairbag i førerside:
       Undersystem 5 - Styreenhedsnr: SW: -----------    HW: 454 802 803 16
       Komponent	: FrontSensor_D  304 0149
       Serienummer	: 3556VB451470A0000006
       Kodning	: 2D2D2D
    6 fejlkoder fundet:
    9439771 - Tændsats til sideairbag
              B100A 1B [137] - Passagerside
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Dato: 2019.10.16
                        Tid: 00:02:18
    9447187 - Sædebelastningssensor (G128)
              B1027 13 [137] - Passagerside
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Dato: 2019.10.16
                        Tid: 00:02:18
    9442836 - Kontrollampe til frakoblet airbag i passagerside
              B1016 14 [137] - Afbrydelse/Kortslutning til stel
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Dato: 2019.10.16
                        Tid: 00:02:18
    9629972 - Kontrollampe til tilkoblet airbag i passagerside
              B12F1 14 [137] - Afbrydelse/Kortslutning til stel
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Dato: 2019.10.16
                        Tid: 00:02:18
    9445395 - Nøglekontakt til frakobling af forsædepassagerens frontairbag
              B1020 13 [137] - Afbrydelse
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Dato: 2019.10.16
                        Tid: 00:02:18
    9446675 - Overflødig signalsti til deaktivering af airbag
              B1025 13 [137] - Passagerside
                 Fryserammedata:
                        Fejlprioritet: 2
                        Fejlhyppighed: 1
                        Dato: 2019.10.16
                        Tid: 00:02:18
    Styreenhed  16: Ratelektronik (J524)     Forklaringsfil:| NEZ\5Q0-953-549.clb
       Styreenhedsnr: SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
       Komponent	: Lenks.Modul   075 0195
       Revision	: FF033033    Serienummer	: 20160303501287
       Kodning	: 0410
       Forhandler	: WSC 00015 115 00001
       ASAM datasæt	: EV_SMLSVALEOMQB 001015
       ROD: EV_SMLSVALEOMQB.rod
    Styreenhed  17: Instrument (J285)     Forklaringsfil:| NEZ\5G0-920-XXX-17.clb-SRI3
       Styreenhedsnr: SW: 3G0 920 751 A    HW: 3G0 920 751 A
       Komponent	: KOMBI         301 6430
       Kodning	: 07A509182F80000C01887F011000000000000000
       Forhandler	: WSC 22339 970 00001
       ASAM datasæt	: EV_DashBoardVDDMQBAB 009046
       VCID: 230639B82A198957A4-8076
    Styreenhed  18: Parkeringsvarme (J364)     Forklaringsfil:| NEZ\5Q0-963-272.clb
       Styreenhedsnr: SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
       Komponent	: STH-MQB       007 0072
       Kodning	: 9309
       ASAM datasæt	: EV_AuxilParkiHeateWOS 002018
       VCID: 383CFED4839FFA8F61-806C
       Fjernbetjening: parkeringsvarme:
       Undersystem 1 - Styreenhedsnr: SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
       Komponent	: R149 T91-LIN  003 0301
       Serienummer	: 00000000000001374380
    Styreenhed  19: CAN Gateway (J533)     Forklaringsfil:| NEZ\5Q0-907-530-V1.clb
       Styreenhedsnr: SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
       Komponent	: GW MQB High   212 2246
       Revision	: --------    Serienummer	: 10041610801934
       Kodning	: 0B0300345F017300FB0002581C0F00010001070000000000000000000000
       ASAM datasæt	: EV_GatewConti 013020
       ROD: EV_GatewConti_013.rod
       VCID: 79BA3BD0F8152387DE-802C
       Generator:
       Styreenhed til multifunktionsrat:
       Undersystem 2 - Styreenhedsnr: SW: 5G0 959 442 N    HW: 5G0 959 442 N  Forklaringsfil: NEZ\3C8-959-537.CLB
       Komponent	: E221__MFL-DC1  H11 0040
       Serienummer	: 29160000731660016146
       Kodning	: 2DFFFF
       Omformer til netstik:
       Undersystem 3 - Styreenhedsnr: SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
       Komponent	: WECHSELRICHTE  H55 0033
       Serienummer	: 0226931
       Analogt ur:
       Undersystem 4 - Styreenhedsnr: SW: 3G0 919 204 C    HW: 3G0 919 204 C
       Komponent	: Analoguhr  209 2002
    Styreenhed  2B: Ratstammelås (J764)     Forklaringsfil:| NEZ\5Q0-905-861.clb
       Styreenhedsnr: SW: 3Q0 905 861     HW: 3Q0 905 861
       Komponent	: ELV-MQBB      H05 0032
       Serienummer	: 16000073540012
       Kodning	: 0800000000000000
       ASAM datasæt	: EV_ELVMarquMQBB 001007
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA03F0A0656BC766-8024
    Styreenhed  42: Dørelektr. V for (J386)     Forklaringsfil:| NEZ\5QX-959-X93-42.clb
       Styreenhedsnr: SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
       Komponent	: TSG FS        020 0041
       Serienummer	: 040416ED414997
       Kodning	: 003F0B208C00020000001000
       ASAM datasæt	: EV_DCUDriveSideEWMAXKLO 006003
       VCID: 43C69938CA59A957C4-8016
    Styreenhed  44: Servostyring (J500)     Forklaringsfil:| NEZ\5Q0-909-143.clb
       Styreenhedsnr: SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
       Komponent	: MQB_PP_APA    204 2041
       Revision	: 00000000    Serienummer	: 0000735503
       Kodning	: 01000010005000
       Forhandler	: WSC 00015 115 00236
       ASAM datasæt	: EV_SteerAssisVWBSMQBA 008028
       ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
       VCID: 3D32EFC0ACBDDFA7B2-8068
    1 fejl fundet:
    5262656 - Ratvinkelsensor
              B1168 F2 [137] - Ingen initialisering
                 Fryserammedata:
                        Fejlprioritet: 4
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:19
                        Write only channel
    Styreenhed  52: Dørelektr. H for (J387)     Forklaringsfil:| NEZ\5QX-959-X92-52.clb
       Styreenhedsnr: SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
       Komponent	: TSG BFS       020 0041
       Serienummer	: 060416ED60262A
       Kodning	: 003F01208C00020000001000
       ASAM datasæt	: EV_DCUPasseSideEWMAXKLO 006003
       VCID: 42C89C3CD543A05FCF-8016
    Styreenhed  55: Lyslængdereg. (J431)     Forklaringsfil:| NEZ\5Q0-907-357.clb
       Styreenhedsnr: SW: 5Q0 907 357     HW: 6R0 907 357 A
       Komponent	: LWR-ECU       005 0080
       Revision	: --------    Serienummer	: --------------
       Kodning	: 03DA000009010000
       Forhandler	: WSC 05311 000 08193
       ASAM datasæt	: EV_HeadlRegulVWLWRMQB 001110
       VCID: 75A237E0D40D47E7BA-8020
    Styreenhed  5F: Informationselek. (J794)     Forklaringsfil:* Ingen
       Styreenhedsnr: SW: 3G0 035 043 J    HW: 3G0 035 043
       Komponent	: MU-H-N-EU     H50 0343
       Serienummer	: A683D0GB030629
       Kodning	: 02840201FF00000051110001000808031F0106C401200100DF
       ASAM datasæt	: EV_MUHig4CGen2HBAS 001001
       Visnings- og betjeningsenhed 1 til informationselektronik:
       Undersystem 1 - Styreenhedsnr: SW: 5G0 919 606     HW: 5G0 919 606
       Komponent	: ABT_High  H63 0032
       Serienummer	: VWZ8Z9SKL00H4C
       Medie:
       Undersystem 2 - Styreenhedsnr: SW: V03 959 806 FM    HW: -----------
       Komponent	: ECE 2019/2020  --- 0177
       Serienummer	: --------------------
       Undersystem 3 - Styreenhedsnr: SW: V03 959 800 EG    HW: -----------
       Komponent	: Gracenote2  --- 1012
    3 fejlkoder fundet:
    0005 - Antenneforstærker 1 til radio
              B126D 13 [009] - Afbrydelse
                 Fryserammedata:
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:23
                        Kl. 30 spænding: 12.2 V
                        Status antenne 1 til radio-Antennestrøm: 0 mA
                        Status antenne 1 til radio-Forbindelse mellem radio og antenneforstærker: Afbrydelse
                        Status antenne 1 til radio-Forbindelse mellem antenneforstærker og antenne: Ikke tilgængelig
                        Status antenne 1 til radio-Modtagelsesniveau antenne 1: 255 dBµV
    0006 - Antenneforstærker 2 til radio
              B126E 13 [009] - Afbrydelse
                 Fryserammedata:
                        Fejlprioritet: 6
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:23
                        Status antenne 2 til radio-Antennestrøm: 0 mA
                        Status antenne 2 til radio-Forbindelse mellem radio og antenneforstærker: Afbrydelse
                        Status antenne 2 til radio-Forbindelse mellem antenneforstærker og antenne: Ikke tilgængelig
                        Status antenne 2 til radio-Modtagelsesniveau antenne 2: 255 dBµV
    2565 - GPS-Antenne
              B1054 13 [009] - Afbrydelse
              [GPS aerial - open circuit]
                 Fryserammedata:
                        Fejlprioritet: 4
                        Fejlhyppighed: 1
                        Nulstiltæller: 201
                        Dato: 2019.10.16
                        Tid: 00:02:23
                        Kl. 30 spænding: 12.3 V
    Styreenhed  69: Anhængertræk (J345)     Forklaringsfil:| NEZ\5Q0-907-383.clb
       Styreenhedsnr: SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
       Komponent	: Anhaenger     H21 0203
       Revision	: 8A001003    Serienummer	: 0400569602
       Kodning	: 0100000202000000
       ASAM datasæt	: EV_TrailFunctGener2Hella 001008
       VCID: 3B36E1D8B2A9D1978C-806E
    Styreenhed  6D: Bagklapelektronik (J605)     Forklaringsfil:| NEZ\5Q0-959-107.clb
       Styreenhedsnr: SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
       Komponent	: HDSG-Modul    H13 0253
       Revision	: --------    Serienummer	: 30613377500000
       Kodning	: 0280
       ASAM datasæt	: EV_DeckLidCONTIAU736 001012
       VCID: 3FCE95C8A6B1CDB7A0-806A
    Styreenhed  BB: Bagdør førerside (J388)     Forklaringsfil:| NEZ\5Q0-959-595.clb
       Styreenhedsnr: SW: 5Q0 959 595 E    HW: 5Q0 959 595 B
       Komponent	: TSG HFS       020 0041
       Serienummer	: 090316EC817976
       Kodning	: 000E01200100020000001000
       ASAM datasæt	: EV_DCURearDriveMAXKLO 006003
       VCID: 45C28720C46D9767EA-8010
    Styreenhed  BC: Bagdør passagerside (J389)     Forklaringsfil:| NEZ\5Q0-959-595.clb
       Komponent	: TSG HBFS      020 0041
       Serienummer	: 090316EC817797
       ASAM datasæt	: EV_DCURearPasseMAXKLO 006003
    Slutning-------(Forløbet tid: 02:11, VBat. start/slut: 12.2V/12.1V)--------
    Jan 2015
    Bosnia and Herzegovina
    official language on forum is english, install english vcds, scan car and post, it will work with your vcds version no problem
    also use code tags when posting scan
  8. Likes downtime, Uwe, PetrolDave, myounus, Dana liked this post
  9. #6
    May 2017
    While waiting for the english translation, at least 3C and CF modules are not communicating to gateway. So check the wiring. Do you have them on correct can bus and are the modules getting power and ground?
  10. #7
    Oct 2019
    This is old scan I have.
    I will post English later this week.
  11. #8
    May 2017
    Why? What use you think an old autoscan is? We need to see what modules are installed, what codings have you made etc.
    So we need fresh autoscan in english from the car in question with all the necessary hardware connected.
  12. Likes m87a, Uwe liked this post
  13. #9
