Results 1 to 10 of 13
Thread: 7E0-819-008 J737__Standheizung Coding
    Aug 2017
    Question 7E0-819-008 J737__Standheizung Coding
    For my T5 van there is no coding for aux heater behaviour. I knpow that German VCDS have a label file for it called: 7E0-819-008.clb
    Thatīs not included in English version (latest) I have HEX NET pro version.
    I am pretty much confused about language version difference ?!
    That label is pretty much needed in order to configure whether aux heater will warm up cabin, engine or both. It is getting cold up here in Finland.
    I tried to copy file to my version but obviously it will not work just like that.
    Nov 2017
    Latvia
    I think this is missing in your labels directory.
    https://www.ross-tech.com/vag-com/labelsredirect.html
    Post a scan from your aux heat control module.
    Aug 2017
    Address 18: Aux. Heat Labels: None
    Part No: 7E0 819 008 D
    Component: J737__Standheizung 0605
    Revision: 00084000 Serial number: 09019169F00000
    Coding: 0001322
    Shop #: WSC 02737 790 00000
    VCID: 2A50848E8530BE1FD9-807E
    Date: 2014.03.10
    Time: 00:00:01
    Temperature: 15.0°C
    Voltage: 12.92 V
    Temperature: 77.5°C
    (fault can be ignored, due to battery removal)
    Nov 2017
    Latvia
    Did you try renaming 7E0-819-008.clb to 7E0-819-008-D.clb ?
    Quote Originally Posted by _Val View Post
    That won't help in this case.
  6. #6
    Known coding for this module (hand-translated from German info):
    00?xxx2: Axuiliary Functions
    0 = Start-Stop not active/installed
    2 = Start-Stop is active/installed
    00x?xx2: Remote Control
    0 = Remote Control/Telestart not installed
    1 = Remote Control/Telestart is installed
    00xx?x2: 2/3-Wegeventil (I have no idea what this is)
    2 =
    3 =
    00xxx?2: HVAC Type:
    0 = Just Heating
    2 = A/C with Climatic type controls
    3 = A/C with Climatronic type controls
  7. #7
    Aug 2017
    Now it is getting hotter
    Those makes sense.
    This is exactly the thing I want to sort out. It is a magnet valve controlling water flow from heater.
    I have now "3" and it have to defined as cabin only. As it is 3 there might be atleast three other options left 0,1,2
    Possible choices I can imagine are engine, cabin, both. Maybe I will give a try and test 0 =>1022
    2 =
    3 =
    00xxx?2: HVAC Type:
    0 = Just Heating
    Quote Originally Posted by mrjj View Post
    Those makes sense.
    Well, '2' appears to be a value that has been seen, but unfortunately, neither '3' nor '2' have been documented as to their meaning.
    PS: I changed the thread topic to something more specific/informative.
  9. #9
    Aug 2017
    Confirmed. "0" will heat both cabin and engine. Works pretty good. Is there any known way to could get this coding included in VCDS English delivery ? Personally I donīt understand why these must be language dependent.
    Thinking about low level bits, using 0, 2 , 3 makes lot of sense.
  10. Likes Uwe liked this post
  11. #10
    Jan 2017
    2 =
    3 =
    00xxx?2: HVAC Type:
    0 = Just Heating
    Could use any additional bits of information also for
    Part No: 7E0 815 071 B
    Revision: 00085000 Serial number: 09019275F00000
    Coding: 0030031
    Shop #: WSC 02739 790 00000
    VCID: 2412E621B2D281C78DF-8070
    as in German version there seems to be a label file also for this one (7E0-815-071.clb dated Jan-06, 2013). Thanks.
