Results 1 to 5 of 5
Thread: MQB Blind spot monitor and VCDS
    Mar 2014
    Las Vegas, Nevada
    I have an MQB Tiguan (2018 SE) and my blind spot monitor system went nuts and then died, however VCDS shows no fault codes of any kind (autoscan below).
    First the little light in the rear view mirror started blinking on and off for no reason (nothing in blind spot) and then now it never comes on.
    My real question is there any way to look at this function with VCDS. I am just surprised that it is apparently quite dead but there are no DTCs stored. It is going into the dealership next week for a "calibration", but this apparently requires special equipment and VW's computer system. Can VCDS see anything about this system? I assume it is controlled in some way by the CECM (09).
    Saturday,24,August,2019,10:32:46:29381
    VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
    VIN: 3VV3B7AX0JM03xxxx  License Plate: xxxxx
    Mileage: 25484km-15835mi   Repair Order:
    Chassis Type: AX-VW37 (3Q0)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 2B 3C 42 44 52 5F 6C 75
    VIN: 3VV3B7AX0JM035049   Mileage: 25484km-15835miles
    Address 01: Engine (J623-DGUA)       Labels:. 06L-907-115-V1.clb
       Part No SW: 5NA 907 115 A    HW: 06L 907 309 B
       Component: R4 2.0l TFSI  H30 0004
       Revision: 1DH30000
       Coding: 012A00122424010F34000000000000000000000000000000
       Shop #: WSC 00066 790 00451
       ASAM Dataset: EV_ECM20TFS0115NA907115A 001005
       ROD: EV_ECM20TFS0115NA907115A.rod
       VCID: 3C34F33DB71962AF85-8068
       Part No SW: 09G 927 158 B    HW: 09G 927 158
       Component: AISIN AQ8     206 3380
       Coding: 0002000100000000000000000000000000000000
       Shop #: WSC 00066 790 00443
       ROD: EV_TCMAQ450031_VW37.rod
       VCID: 3228DD05655DA4DF5F-8066
       Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
       Component: ESC           H25 0413
       Revision: 00000000    Serial number: 52037000001741
       Coding: 0BFA6BA454231B71C5770204A2CC49D0D62AD8A34045927010415058C2824200002764121A1C230A35351919323200
       Shop #: WSC 01383 790 50316
       VCID: 76A02115C9B5F8FFB3-8022
       Component: VWKESSYMQB    037 0906
       Revision: 00037000    Serial number: 0447390592
       Coding: 132C0C0723
       VCID: 3E30F935A10570BFAB-806A
       Part No SW: 5NN 907 044 A    HW: 5NN 907 044 A
       Component: AC Automat    H35 4301
       Revision: 20K08000    Serial number: 00000D00033377
       Coding: 00020004200118001005000012111406
       ASAM Dataset: EV_ACClimaPrehVW37X 002023
       ROD: EV_ACClimaPrehVW37X.rod
       VCID: 4AD8A5E5EDCDCC1F07-801E
       Part No SW: 5Q0 937 087 AR    HW: 5Q0 937 087 AN
       Component: BCM PQ37BOSCH 034 0243
       Revision: --------    Serial number: C86427071701A4
       ROD: EV_BCMBOSCH_018.rod
       VCID: 0B5660E1A2379517FC-805E
       Subsystem 1 - Part No SW: 5NN 955 119     HW: 5NN 955 119   Labels: 1KX-955-119.CLB
       Component: 326 LL 170703  034 0373
       Serial number: 17063021013450
       Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
       Component: ACCCONTIMQB   H02 0233
       Coding: 3200000110FF8728749C8145004097
       Part No SW: 5Q0 959 655 AG    HW: 5Q0 959 655 AG
       Component: AirbagVW21    004 0336
       Serial number: 003NUM060HKZ
       Coding: 8CCCFC00000000005000001AC20800000065
       ROD: EV_AirbaVW20SMEVW37X.rod
       VCID: 054256D98453E367AA-8050
       Occupant Detection:
       Serial number: IBH000000000007J7GCL
       Coding: 303351
       Subsystem 2 - Part No SW: -----------    HW: 480 001 106 17
       Serial number: 3570000000097410C42B
       Subsystem 3 - Part No SW: -----------    HW: 480 001 806 17
       Serial number: 3580000000009B55252C
       Subsystem 4 - Part No SW: -----------    HW: 480 402 906 17
       Serial number: 3510001C725E6142B2B1
       Subsystem 5 - Part No SW: -----------    HW: 480 402 806 17
       Serial number: 3520001A7264428183D-
       Subsystem 6 - Part No SW: -----------    HW: 480 400 507 17
       Serial number: 3550001B32610AE6345-
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 507 17
       Component: FrontSensor_P  000 6149
       Serial number: 3560001B12610AE3B7E9
       Part No SW: 5Q0 953 507 HL    HW: 5Q0 953 549 E
       Revision: --------    Serial number: 03071708491275
       Coding: 0410
       VCID: 075E5CD1BE5FF177D8-8052
       Part No SW: 5NA 920 850 B    HW: 5NA 920 850 B
       Component: KOMBI         370 0310
       Coding: 0BA5091A2388CF0502882B0954000000A0000000
       Shop #: WSC 00066 790 00274
       Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
       Component: GW MQB High   518 5304
       Serial number: 10071700841250
       Coding: 030100347F085900FA0002481C0F00010001070000000000000000000000
       ROD: EV_GatewNF.rod
       VCID: 3326D8019A47ADD754-8066
       Subsystem 2 - Part No SW: 5NN 959 442     HW: 5NN 959 442
       Serial number: 1701703390500348BH2B
       Coding: 280000
       Serial number: 1114343504
       Serial number: 17000172077013
       Coding: 0800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 71AA1209A0DBDFC766-8024
       Component: HRE_Master    H12 0080
       Serial number: 0446829195
       Coding: 01011103
       ROD: EV_HREntryHella_VW37.rod
       VCID: 3D32FE39AC036BA7B2-8068
       Lane Change Assistant 2:
       Component: HRE_Slave  H12 0080
       Serial number: 0445410148
       Coding: 010111
       Part No SW: 5Q4 959 393 E    HW: 5Q4 959 393 B
       Serial number: 7038721402262
       Coding: 003013200000028000000000
       VCID: 45C296D9C4D32367EA-8010
       Serial number: 00000000000006981153
       Coding: 011000
       Revision: 00000000    Serial number: 0001810381
       Coding: 01000010004000
       ROD: EV_SteerAssisVWBSMQBA_009_VW37.rod
       VCID: 40CC87CDDBF1064FD9-8014
       Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
       Serial number: 8038722500295
       VCID: 44C48BDDCFE91A6FFD-8010
       Serial number: 00000000000006922623
       Coding: 091000
       Part No SW: 3Q0 035 844 B    HW: 3Q0 035 844 B
       Component: MU-S-S-US     721 0842
       Coding: 02730600BE00000051220001001808001F0500C40120050002
       ROD: EV_MUStd4CDELP_VW37.rod
       VCID: 2E10C9757165803F3B-807A
       Subsystem 1 - Part No SW: 5G6 919 605 C    HW: 5G6 919 605 C
       Component: ABT_Std-2  H50 8130
       Serial number: VWZ6ZJT2085716
       Coding: 0123060120002017300040
       VCID: 393AEA29B82B57879E-806C
       Component: OCULowMQBUS   007 0570
       Coding: 02230602C2821A017F1E06000000
       ROD: EV_OCULowMQB.rod
       VCID: 43C688C1CAE71D57C4-8016
    End----(Elapsed Time: 01:37, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
    Have Fun!
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Are you sure you haven't configured it off using the infotainment or instrument cluster menus? Find the checkbox and make sure it's turned on, likewise for Rear Cross Traffic Assist. I dimly recall it does a little flash dance when it's enabled or disabled. I believe it can also be enabled or disabled on a per-driver-profile basis. I'll also note, for others that might come across this thread, it will auto-disable if a trailer is detected, but I can see you're not equipped with a trailer detection module.
    Silence gives consent.
  3. Likes Jack@European_Parts, Uwe liked this post
    Mar 2014
    Las Vegas, Nevada
    Thanks guys. Now I have something to check and some reading to do. My car is still going to the dealer next week for a recall about the coolant bottle. We shall see what happens.
  6. Likes Uwe liked this post
    Mar 2014
    Las Vegas, Nevada
    Boy, do I feel stupid. Some idiot (me) accidentally turned off blind spot monitoring while looking for (or playing with) something else. However, thanks to you I don't feel nearly as stupid as I would have if I had asked the dealership service department to fix it and then they just turned it back on.
    Have Fun!
    P.S. I grew up in Cincinnati, but I like what they call winter here.
  8. Likes downtime, Uwe, jyoung8607, PetrolDave liked this post
